How to change /home partition after installation?
Hi!
I’ve been a long time Kubuntu user, and I’m switching to Manjaro. I’ve just installed the latest version of KDE Manjaro, replacing my Kubuntu partition.
I had my /home on a different partition and I checked the “keep the same /home partition” (can’t remember the exact name :slight_smile: ) during installation.
But it didn’t seem to work, and my /home is just on the manjaro system partition.
How could I tell Manjora to use my old /home partition? And would it screw up the whole kde config?
I’ve looked around but I can’t seem to find the relevant information about this…
Thanks !
You can use manual partitioning in the installer to explicitly set what partition to use as your root, and which one as your home – and which one is your EFI when applicable.
Just be careful not to format your home partition in order to keep its content!
Regarding KDE, Manjaro using (presumably) a later version, the configuration should update itself on the first run. You can make a backup of the configuration folder beforehand, just in case.
So you’re saying I should just reinstall Manjaro? I was hoping I could do it without reinstalling…
Without reinstallation, you can simply add your partition to be automatically mounted to /home.
Beware that mounting a partition to /home will not delete the files currently in that folder. You will need to boot from a LiveUSB afterwards in order to do that.
Change the mount point of the partition to /home in your fstab. Make sure to clear out the “fake” home directory first that was populated with files by the installer.
EDIT: Need to get my eyes checked. Didn’t even notice @maycne.sonahoz 's post. :upside_down_face:
