I have a Legion 5 laptop with a 144Hz 1080 display, but I want to run it capped at 60.
Using the GUI in Gnome Display Settings does nothing. I choose 60 and when I hit apply it switches back to 144Hz.
I tried xrandr --output eDP-1 --mode 1920x1080 --rate 60 and the display goes blank for a couple of seconds then I get xrandr: Configure crtc 0 failed.
This is where my knowledge ends and googling leads to weird stuff with dumping an EDID.bin file from NVIDIA X-Settings and editing it on a Windows machine, which I’d rather not bother with.
Any ideas?
Kernel: 6.0.8-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/vmlinuz-linux
root=UUID=59a43d3f-5cbf-466d-bc76-dd27fab6c161 rw rootfstype=ext4
loglevel=3 quiet nowatchdog ibt=off
Desktop: GNOME v: 43.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 43.0
Distro: Arch Linux
Type: Laptop System: LENOVO product: 82JM v: Legion 5 17ITH6H
serial: <superuser required> Chassis: type: 10 v: Legion 5 17ITH6H
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: H1CN49WW date: 08/16/2022
ID-1: BAT0 charge: 48.4 Wh (58.0%) condition: 83.4/80.0 Wh (104.3%)
volts: 15.8 min: 15.4 model: Celxpert L20C4PC2 type: Li-poly serial: <filter>
status: not charging cycles: 4
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x42
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1996 high: 2300 min/max: 800/4600 scaling:
driver: intel_pstate governor: performance cores: 1: 1521 2: 2300 3: 2300
4: 800 5: 2300 6: 2300 7: 2300 8: 1230 9: 2300 10: 2300 11: 2300 12: 2300
13: 2300 14: 2300 15: 2300 16: 800 bogomips: 73744
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0
chip-ID: 10de:2560 class-ID: 0300
Device-3: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 3-6:3
chip-ID: 174f:2459 class-ID: fe01 serial: <filter>
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :1
screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: AU Optronics 0x449d built: 2018 res: 1920x1080
hz: 144 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8
class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Sound API: ALSA v: k6.0.8-arch1-1 running: yes
Sound Server-3: PipeWire v: 0.3.60 running: no
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 58:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp88s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-14:6
chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.16 TiB used: 605.2 GiB (51.0%)
model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: SK Hynix model: HFS001TDE9X084N
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 41010C22 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 232.38 GiB size: 227.68 GiB (97.97%)
used: 134.59 GiB (59.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot raw-size: 511 MiB size: 510 MiB (99.80%) used: 89.4 MiB (17.5%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 4 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/zram0
System Temperatures: cpu: 37.0 C mobo: N/A
Processes: 347 Uptime: 1m wakeups: 1 Memory: 31.14 GiB used: 2.79 GiB (9.0%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: pm: pacman pkgs: 1201 libs: 326
tools: pamac,yay pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.23
[ 4.130] (--) Log file renamed from "/var/log/Xorg.pid-831.log" to "/var/log/Xorg.0.log"
[ 4.131]
X.Org X Server 1.21.1.4
[ 4.131] Current Operating System: Linux archlinux 6.0.8-arch1-1 #1 SMP PREEMPT_DYNAMIC Thu, 10 Nov 2022 21:14:24 +0000 x86_64
[ 4.131] Kernel command line: BOOT_IMAGE=/vmlinuz-linux root=UUID=59a43d3f-5cbf-466d-bc76-dd27fab6c161 rw rootfstype=ext4 loglevel=3 nowatchdog ibt=off
[ 4.131]
[ 4.131] Current version of pixman: 0.42.2
[ 4.131] Before reporting problems, check http://wiki.x.org
[ 4.131] Markers: (--) probed, (**) from config file, (==) default setting,
[ 4.131] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Nov 17 14:57:20 2022
[ 4.132] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 4.132] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 4.132] (==) No Layout section. Using the first Screen section.
[ 4.132] (==) No screen section available. Using defaults.
[ 4.132] (**) |-->Screen "Default Screen Section" (0)
[ 4.132] (**) | |-->Monitor "<default monitor>"
[ 4.133] (==) No monitor specified for screen "Default Screen Section".
[ 4.133] (==) Automatically adding devices
[ 4.133] (==) Automatically enabling devices
[ 4.133] (==) Automatically adding GPU devices
[ 4.133] (==) Automatically binding GPU devices
[ 4.133] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 4.133] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 4.133] Entry deleted from font path.
[ 4.133] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 4.133] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 4.133] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/OTF".
[ 4.133] (Run 'mkfontdir' on "/usr/share/fonts/OTF").
[ 4.133] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 4.133] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 4.133] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 4.133] (==) FontPath set to:
[ 4.133] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 4.133] (II) The server relies on udev to provide the list of input devices.
[ 4.133] (II) Module ABI versions:
[ 4.133] X.Org ANSI C Emulation: 0.4
[ 4.133] X.Org Video Driver: 25.2
[ 4.133] X.Org XInput driver : 24.4
[ 4.133] X.Org Server Extension : 10.0
[ 4.134] (++) using VT number 1
[ 4.134] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 4.135] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 4.135] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
[ 4.135] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 14 paused 0
[ 4.135] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 4.135] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 4.135] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 15 paused 0
[ 4.136] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 4.137] (--) PCI:*(0@0:2:0) 8086:9a60:17aa:3f82 rev 1, Mem @ 0x622c000000/16777216, 0x4000000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 4.137] (--) PCI: (1@0:0:0) 10de:2560:17aa:3f82 rev 161, Mem @ 0x6d000000/16777216, 0x6000000000/8589934592, 0x6200000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[ 4.137] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 4.137] (II) LoadModule: "glx"
[ 4.137] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 4.141] (II) Module glx: vendor="X.Org Foundation"
[ 4.141] compiled for 1.21.1.4, module version = 1.0.0
[ 4.141] ABI class: X.Org Server Extension, version 10.0
[ 4.141] (II) Applying OutputClass "nvidia" to /dev/dri/card1
[ 4.141] loading driver: nvidia
[ 4.141] (==) Matched intel as autoconfigured driver 0
[ 4.141] (==) Matched nvidia as autoconfigured driver 1
[ 4.141] (==) Matched nouveau as autoconfigured driver 2
[ 4.141] (==) Matched nv as autoconfigured driver 3
[ 4.141] (==) Matched modesetting as autoconfigured driver 4
[ 4.141] (==) Matched fbdev as autoconfigured driver 5
[ 4.141] (==) Matched vesa as autoconfigured driver 6
[ 4.141] (==) Assigned the driver to the xf86ConfigLayout
[ 4.141] (II) LoadModule: "intel"
[ 4.141] (WW) Warning, couldn't open module intel
[ 4.141] (EE) Failed to load module "intel" (module does not exist, 0)
[ 4.141] (II) LoadModule: "nvidia"
[ 4.141] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 4.143] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 4.143] compiled for 1.6.99.901, module version = 1.0.0
[ 4.143] Module class: X.Org Video Driver
[ 4.143] (II) LoadModule: "nouveau"
[ 4.143] (WW) Warning, couldn't open module nouveau
[ 4.143] (EE) Failed to load module "nouveau" (module does not exist, 0)
[ 4.143] (II) LoadModule: "nv"
[ 4.143] (WW) Warning, couldn't open module nv
[ 4.143] (EE) Failed to load module "nv" (module does not exist, 0)
[ 4.143] (II) LoadModule: "modesetting"
[ 4.143] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 4.145] (II) Module modesetting: vendor="X.Org Foundation"
[ 4.145] compiled for 1.21.1.4, module version = 1.21.1
[ 4.145] Module class: X.Org Video Driver
[ 4.145] ABI class: X.Org Video Driver, version 25.2
[ 4.145] (II) LoadModule: "fbdev"
[ 4.145] (WW) Warning, couldn't open module fbdev
[ 4.145] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 4.145] (II) LoadModule: "vesa"
[ 4.145] (WW) Warning, couldn't open module vesa
[ 4.145] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 4.145] (II) NVIDIA dlloader X Driver 520.56.06 Thu Oct 6 21:29:26 UTC 2022
[ 4.145] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 4.145] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 4.145] (II) modeset(0): using drv /dev/dri/card0
[ 4.145] (II) systemd-logind: releasing fd for 226:1
[ 4.146] (II) Loading sub module "fb"
[ 4.146] (II) LoadModule: "fb"
[ 4.146] (II) Module "fb" already built-in
[ 4.146] (II) Loading sub module "wfb"
[ 4.146] (II) LoadModule: "wfb"
[ 4.146] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 4.146] (II) Module wfb: vendor="X.Org Foundation"
[ 4.146] compiled for 1.21.1.4, module version = 1.0.0
[ 4.146] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4.146] (II) Loading sub module "ramdac"
[ 4.146] (II) LoadModule: "ramdac"
[ 4.146] (II) Module "ramdac" already built-in
[ 4.147] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 4.147] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 4.147] (==) modeset(0): RGB weight 888
[ 4.147] (==) modeset(0): Default visual is TrueColor
[ 4.147] (II) Loading sub module "glamoregl"
[ 4.147] (II) LoadModule: "glamoregl"
[ 4.147] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 4.150] (II) Module glamoregl: vendor="X.Org Foundation"
[ 4.150] compiled for 1.21.1.4, module version = 1.0.1
[ 4.150] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4.262] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics (TGL GT1)
[ 4.262] (II) modeset(0): glamor initialized
[ 4.262] (==) modeset(0): VariableRefresh: disabled
[ 4.262] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 4.264] (II) modeset(0): Output eDP-1 has no monitor section
[ 4.264] (II) modeset(0): Output DP-1 has no monitor section
[ 4.264] (II) modeset(0): Output HDMI-1 has no monitor section
[ 4.264] (II) modeset(0): Output DP-2 has no monitor section
[ 4.264] (II) modeset(0): Output DP-3 has no monitor section
[ 4.264] (II) modeset(0): Output DP-4 has no monitor section
[ 4.264] (II) modeset(0): Output DP-5 has no monitor section
[ 4.266] (II) modeset(0): EDID for output eDP-1
[ 4.266] (II) modeset(0): Manufacturer: AUO Model: 449d Serial#: 0
[ 4.266] (II) modeset(0): Year: 2018 Week: 0
[ 4.266] (II) modeset(0): EDID Version: 1.4
[ 4.266] (II) modeset(0): Digital Display Input
[ 4.266] (II) modeset(0): 8 bits per channel
[ 4.266] (II) modeset(0): Digital interface is DisplayPort
[ 4.266] (II) modeset(0): Max Image Size [cm]: horiz.: 38 vert.: 22
[ 4.266] (II) modeset(0): Gamma: 2.20
[ 4.266] (II) modeset(0): No DPMS capabilities specified
[ 4.266] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 4.266] (II) modeset(0): First detailed timing is preferred mode
[ 4.266] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 4.266] (II) modeset(0): Display is continuous-frequency
[ 4.266] (II) modeset(0): redX: 0.643 redY: 0.332 greenX: 0.307 greenY: 0.626
[ 4.266] (II) modeset(0): blueX: 0.156 blueY: 0.052 whiteX: 0.313 whiteY: 0.329
[ 4.266] (II) modeset(0): Manufacturer's mask: 0
[ 4.266] (II) modeset(0): Supported detailed timing:
[ 4.266] (II) modeset(0): clock: 368.1 MHz Image Size: 382 x 215 mm
[ 4.266] (II) modeset(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2102 h_border: 0
[ 4.266] (II) modeset(0): v_active: 1080 v_sync: 1090 v_sync_end 1095 v_blanking: 1216 v_border: 0
[ 4.266] (II) modeset(0): Unknown vendor-specific block f
[ 4.266] (II) modeset(0): AUO
[ 4.266] (II) modeset(0): B173HAN04.4
[ 4.266] (II) modeset(0): EDID (in hex):
[ 4.266] (II) modeset(0): 00ffffffffffff0006af9d4400000000
[ 4.266] (II) modeset(0): 001c0104a5261678038915a4554ea028
[ 4.266] (II) modeset(0): 0d505400000001010101010101010101
[ 4.266] (II) modeset(0): 010101010101ce8f80b6703888403020
[ 4.266] (II) modeset(0): a5007ed7100000180000000f00000000
[ 4.266] (II) modeset(0): 00000000000000000020000000fe0041
[ 4.266] (II) modeset(0): 554f0a202020202020202020000000fe
[ 4.266] (II) modeset(0): 004231373348414e30342e34200a0032
[ 4.266] (II) modeset(0): Printing probed modes for output eDP-1
[ 4.266] (II) modeset(0): Modeline "1920x1080"x144.0 368.14 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (175.1 kHz eP)
[ 4.266] (II) modeset(0): Modeline "1920x1080"x120.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 4.266] (II) modeset(0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 4.266] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 4.266] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 4.266] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 4.266] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 4.266] (II) modeset(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[ 4.266] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 4.266] (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 4.266] (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 4.266] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 4.266] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 4.266] (II) modeset(0): Modeline "1280x1024"x85.0 157.50 1280 1344 1504 1728 1024 1025 1028 1072 +hsync +vsync (91.1 kHz d)
[ 4.266] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz d)
[ 4.266] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 4.266] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 4.266] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 4.266] (II) modeset(0): Modeline "1280x960"x85.0 148.50 1280 1344 1504 1728 960 961 964 1011 +hsync +vsync (85.9 kHz d)
[ 4.266] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 4.266] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 4.266] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 4.266] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 4.266] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 4.266] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 4.266] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 4.266] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 4.266] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 4.267] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 4.267] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 4.267] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 4.267] (II) modeset(0): Modeline "1024x768"x170.0 194.02 1024 1108 1220 1416 768 768 770 806 doublescan -hsync +vsync (137.0 kHz d)
[ 4.267] (II) modeset(0): Modeline "1024x768"x150.1 170.24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[ 4.267] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 4.267] (II) modeset(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz d)
[ 4.267] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz d)
[ 4.267] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 4.267] (II) modeset(0): Modeline "1024x768i"x43.5 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync (35.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "960x720"x170.0 170.68 960 1036 1144 1328 720 720 722 756 doublescan -hsync +vsync (128.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "960x720"x150.0 148.50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 4.267] (II) modeset(0): Modeline "928x696"x150.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 4.267] (II) modeset(0): Modeline "896x672"x150.1 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[ 4.267] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 4.267] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 4.267] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 4.267] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 4.267] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 4.267] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz d)
[ 4.267] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 4.267] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 4.267] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 4.267] (II) modeset(0): Modeline "800x600"x170.0 114.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (106.2 kHz d)
[ 4.267] (II) modeset(0): Modeline "800x600"x150.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[ 4.267] (II) modeset(0): Modeline "800x600"x140.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "800x600"x130.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[ 4.267] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 4.267] (II) modeset(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz d)
[ 4.267] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz d)
[ 4.267] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 4.267] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 4.267] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 4.267] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 4.267] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 4.267] (II) modeset(0): Modeline "700x525"x149.5 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 4.267] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x512"x170.0 78.75 640 672 752 864 512 512 514 536 doublescan +hsync +vsync (91.1 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x512"x150.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 4.267] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 4.267] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x480"x170.2 74.25 640 672 752 864 480 480 482 505 doublescan +hsync +vsync (85.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 4.267] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 4.267] (II) modeset(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 4.267] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "576x432"x150.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 4.267] (II) modeset(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "512x384"x170.0 47.25 512 536 584 688 384 384 386 404 doublescan +hsync +vsync (68.7 kHz d)
[ 4.267] (II) modeset(0): Modeline "512x384"x150.1 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[ 4.267] (II) modeset(0): Modeline "512x384"x140.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 4.267] (II) modeset(0): Modeline "512x384i"x87.1 22.45 512 516 604 632 384 384 388 408 interlace doublescan +hsync +vsync (35.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "416x312"x149.3 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[ 4.267] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 4.267] (II) modeset(0): Modeline "400x300"x170.5 28.15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync (53.7 kHz d)
[ 4.267] (II) modeset(0): Modeline "400x300"x144.4 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[ 4.267] (II) modeset(0): Modeline "400x300"x150.2 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 4.267] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 4.267] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 4.267] (II) modeset(0): Modeline "320x240"x170.4 18.00 320 348 376 416 240 240 242 254 doublescan -hsync -vsync (43.3 kHz d)
[ 4.267] (II) modeset(0): Modeline "320x240"x145.6 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "320x240"x150.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 4.267] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 4.267] (II) modeset(0): Modeline "360x200"x170.1 17.75 360 378 414 468 200 200 202 223 doublescan -hsync +vsync (37.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "320x200"x170.5 15.75 320 336 368 416 200 200 202 222 doublescan -hsync +vsync (37.9 kHz d)
[ 4.267] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 4.267] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 4.267] (II) modeset(0): Modeline "320x175"x170.5 15.75 320 336 368 416 175 191 192 222 doublescan +hsync -vsync (37.9 kHz d)
[ 4.267] (II) modeset(0): EDID for output DP-1
[ 4.267] (II) modeset(0): EDID for output HDMI-1
[ 4.267] (II) modeset(0): EDID for output DP-2
[ 4.267] (II) modeset(0): EDID for output DP-3
[ 4.267] (II) modeset(0): EDID for output DP-4
[ 4.267] (II) modeset(0): EDID for output DP-5
[ 4.267] (II) modeset(0): Output eDP-1 connected
[ 4.267] (II) modeset(0): Output DP-1 disconnected
[ 4.267] (II) modeset(0): Output HDMI-1 disconnected
[ 4.267] (II) modeset(0): Output DP-2 disconnected
[ 4.267] (II) modeset(0): Output DP-3 disconnected
[ 4.267] (II) modeset(0): Output DP-4 disconnected
[ 4.267] (II) modeset(0): Output DP-5 disconnected
[ 4.267] (II) modeset(0): Using exact sizes for initial modes
[ 4.267] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[ 4.267] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 4.267] (==) modeset(0): DPI set to (96, 96)
[ 4.267] (II) Loading sub module "fb"
[ 4.267] (II) LoadModule: "fb"
[ 4.267] (II) Module "fb" already built-in
[ 4.267] (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
[ 4.267] (==) NVIDIA(G0): RGB weight 888
[ 4.267] (==) NVIDIA(G0): Default visual is TrueColor
[ 4.267] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 4.267] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 4.267] (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
[ 4.268] (**) NVIDIA(G0): Enabling 2D acceleration
[ 4.268] (II) Loading sub module "glxserver_nvidia"
[ 4.268] (II) LoadModule: "glxserver_nvidia"
[ 4.268] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 4.285] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 4.285] compiled for 1.6.99.901, module version = 1.0.0
[ 4.285] Module class: X.Org Server Extension
[ 4.285] (II) NVIDIA GLX Module 520.56.06 Thu Oct 6 21:26:26 UTC 2022
[ 4.285] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 4.321] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 4.321] (--) NVIDIA(0): DFP-0
[ 4.321] (--) NVIDIA(0): DFP-1
[ 4.321] (--) NVIDIA(0): DFP-2
[ 4.321] (--) NVIDIA(0): DFP-3
[ 4.321] (--) NVIDIA(0): DFP-4
[ 4.321] (--) NVIDIA(0): DFP-5
[ 4.321] (II) NVIDIA(G0): NVIDIA GPU NVIDIA GeForce RTX 3060 Laptop GPU (GA106-B) at
[ 4.321] (II) NVIDIA(G0): PCI:1:0:0 (GPU-0)
[ 4.321] (--) NVIDIA(G0): Memory: 6291456 kBytes
[ 4.321] (--) NVIDIA(G0): VideoBIOS: 94.06.1f.00.1f
[ 4.321] (II) NVIDIA(G0): Detected PCI Express Link width: 16X
[ 4.321] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 4.321] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 4.321] (--) NVIDIA(GPU-0): DFP-0: 2670.0 MHz maximum pixel clock
[ 4.322] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 4.322] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 4.322] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 4.322] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 4.322] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 4.322] (--) NVIDIA(GPU-0): DFP-2: 2670.0 MHz maximum pixel clock
[ 4.322] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 4.322] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 4.322] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 4.322] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 4.322] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 4.322] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 4.322] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 4.322] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 4.322] (--) NVIDIA(GPU-0): DFP-5: 2670.0 MHz maximum pixel clock
[ 4.322] (II) NVIDIA(G0): Validated MetaModes:
[ 4.322] (II) NVIDIA(G0): "NULL"
[ 4.322] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
[ 4.322] (WW) NVIDIA(G0): Unable to get display device for DPI computation.
[ 4.322] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
[ 4.376] (==) modeset(0): Backing store enabled
[ 4.376] (==) modeset(0): Silken mouse enabled
[ 4.406] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 4.406] (==) modeset(0): DPMS enabled
[ 4.406] (II) modeset(0): [DRI2] Setup complete
[ 4.406] (II) modeset(0): [DRI2] DRI driver: iris
[ 4.406] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 4.406] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 4.406] (II) NVIDIA: access.
[ 4.489] (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 4.489] (II) NVIDIA(G0): may not be running or the "AcpidSocketPath" X
[ 4.489] (II) NVIDIA(G0): configuration option may not be set correctly. When the
[ 4.489] (II) NVIDIA(G0): ACPI event daemon is available, the NVIDIA X driver will
[ 4.489] (II) NVIDIA(G0): try to use it to receive ACPI event notifications. For
[ 4.489] (II) NVIDIA(G0): details, please see the "ConnectToAcpid" and
[ 4.489] (II) NVIDIA(G0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 4.489] (II) NVIDIA(G0): Config Options in the README.
[ 4.502] (II) NVIDIA(G0): Setting mode "NULL"
[ 4.508] (==) NVIDIA(G0): Disabling shared memory pixmaps
[ 4.509] (==) NVIDIA(G0): Backing store enabled
[ 4.509] (==) NVIDIA(G0): Silken mouse enabled
[ 4.509] (==) NVIDIA(G0): DPMS enabled
[ 4.509] (II) Loading sub module "dri2"
[ 4.509] (II) LoadModule: "dri2"
[ 4.509] (II) Module "dri2" already built-in
[ 4.509] (II) NVIDIA(G0): [DRI2] Setup complete
[ 4.509] (II) NVIDIA(G0): [DRI2] VDPAU driver: nvidia
[ 4.509] (II) Initializing extension Generic Event Extension
[ 4.509] (II) Initializing extension SHAPE
[ 4.509] (II) Initializing extension MIT-SHM
[ 4.509] (II) Initializing extension XInputExtension
[ 4.509] (II) Initializing extension XTEST
[ 4.509] (II) Initializing extension BIG-REQUESTS
[ 4.509] (II) Initializing extension SYNC
[ 4.509] (II) Initializing extension XKEYBOARD
[ 4.509] (II) Initializing extension XC-MISC
[ 4.509] (II) Initializing extension SECURITY
[ 4.509] (II) Initializing extension XFIXES
[ 4.509] (II) Initializing extension RENDER
[ 4.509] (II) Initializing extension RANDR
[ 4.509] (II) Initializing extension COMPOSITE
[ 4.510] (II) Initializing extension DAMAGE
[ 4.510] (II) Initializing extension MIT-SCREEN-SAVER
[ 4.510] (II) Initializing extension DOUBLE-BUFFER
[ 4.510] (II) Initializing extension RECORD
[ 4.510] (II) Initializing extension DPMS
[ 4.510] (II) Initializing extension Present
[ 4.510] (II) Initializing extension DRI3
[ 4.510] (II) Initializing extension X-Resource
[ 4.510] (II) Initializing extension XVideo
[ 4.510] (II) Initializing extension XVideo-MotionCompensation
[ 4.510] (II) Initializing extension GLX
[ 4.510] (II) Indirect GLX disabled.
[ 4.514] (II) AIGLX: Loaded and initialized iris
[ 4.514] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 4.514] (II) Initializing extension XFree86-VidModeExtension
[ 4.514] (II) Initializing extension XFree86-DGA
[ 4.514] (II) Initializing extension XFree86-DRI
[ 4.514] (II) Initializing extension DRI2
[ 4.514] (II) Initializing extension NV-GLX
[ 4.514] (II) Initializing extension NV-CONTROL
[ 4.514] (II) modeset(0): Damage tracking initialized
[ 4.514] (II) modeset(0): Setting screen physical size to 508 x 285
[ 4.542] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 4.542] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 4.542] (**) Power Button: Applying InputClass "system-keyboard"
[ 4.542] (II) LoadModule: "libinput"
[ 4.542] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 4.543] (II) Module libinput: vendor="X.Org Foundation"
[ 4.543] compiled for 1.21.1.3, module version = 1.2.1
[ 4.543] Module class: X.Org XInput Driver
[ 4.543] ABI class: X.Org XInput driver, version 24.4
[ 4.544] (II) Using input driver 'libinput' for 'Power Button'
[ 4.544] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 48 paused 0
[ 4.544] (**) Power Button: always reports core events
[ 4.544] (**) Option "Device" "/dev/input/event3"
[ 4.546] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 4.546] (II) event3 - Power Button: device is a keyboard
[ 4.546] (II) event3 - Power Button: device removed
[ 4.546] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 4.546] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 4.546] (**) Option "xkb_model" "pc105"
[ 4.546] (**) Option "xkb_layout" "ro"
[ 4.546] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.556] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 4.556] (II) event3 - Power Button: device is a keyboard
[ 4.556] (II) config/udev: Adding input device Video Bus (/dev/input/event22)
[ 4.556] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 4.556] (**) Video Bus: Applying InputClass "system-keyboard"
[ 4.556] (II) Using input driver 'libinput' for 'Video Bus'
[ 4.556] (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 51 paused 0
[ 4.556] (**) Video Bus: always reports core events
[ 4.556] (**) Option "Device" "/dev/input/event22"
[ 4.556] (II) event22 - Video Bus: is tagged by udev as: Keyboard
[ 4.557] (II) event22 - Video Bus: device is a keyboard
[ 4.557] (II) event22 - Video Bus: device removed
[ 4.557] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input34/event22"
[ 4.557] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 4.557] (**) Option "xkb_model" "pc105"
[ 4.557] (**) Option "xkb_layout" "ro"
[ 4.557] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.557] (II) event22 - Video Bus: is tagged by udev as: Keyboard
[ 4.557] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 4.557] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 4.557] (**) Power Button: Applying InputClass "system-keyboard"
[ 4.557] (II) Using input driver 'libinput' for 'Power Button'
[ 4.558] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 52 paused 0
[ 4.558] (**) Power Button: always reports core events
[ 4.558] (**) Option "Device" "/dev/input/event1"
[ 4.558] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 4.558] (II) event1 - Power Button: device is a keyboard
[ 4.558] (II) event1 - Power Button: device removed
[ 4.558] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 4.558] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 4.558] (**) Option "xkb_model" "pc105"
[ 4.558] (**) Option "xkb_layout" "ro"
[ 4.558] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.558] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 4.558] (II) No input driver specified, ignoring this device.
[ 4.558] (II) This device may have been added with another device file.
[ 4.559] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 4.559] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 4.559] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 4.559] (II) Using input driver 'libinput' for 'Sleep Button'
[ 4.559] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 53 paused 0
[ 4.559] (**) Sleep Button: always reports core events
[ 4.559] (**) Option "Device" "/dev/input/event2"
[ 4.559] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 4.559] (II) event2 - Sleep Button: device is a keyboard
[ 4.559] (II) event2 - Sleep Button: device removed
[ 4.559] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[ 4.559] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 4.559] (**) Option "xkb_model" "pc105"
[ 4.559] (**) Option "xkb_layout" "ro"
[ 4.559] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.560] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 4.560] (II) event2 - Sleep Button: device is a keyboard
[ 4.560] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event9)
[ 4.560] (II) No input driver specified, ignoring this device.
[ 4.560] (II) This device may have been added with another device file.
[ 4.560] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event10)
[ 4.560] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event11)
[ 4.560] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event12)
[ 4.560] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event13)
[ 4.561] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event14)
[ 4.561] (II) No input driver specified, ignoring this device.
[ 4.561] (II) This device may have been added with another device file.
[ 4.561] (II) config/udev: Adding input device Razer Razer Mouse Dock (/dev/input/event17)
[ 4.561] (**) Razer Razer Mouse Dock: Applying InputClass "libinput pointer catchall"
[ 4.561] (**) Razer Razer Mouse Dock: Applying InputClass "libinput keyboard catchall"
[ 4.561] (**) Razer Razer Mouse Dock: Applying InputClass "system-keyboard"
[ 4.561] (II) Using input driver 'libinput' for 'Razer Razer Mouse Dock'
[ 4.561] (II) systemd-logind: got fd for /dev/input/event17 13:81 fd 54 paused 0
[ 4.561] (**) Razer Razer Mouse Dock: always reports core events
[ 4.561] (**) Option "Device" "/dev/input/event17"
[ 4.562] (II) event17 - Razer Razer Mouse Dock: is tagged by udev as: Keyboard Mouse
[ 4.562] (II) event17 - Razer Razer Mouse Dock: device is a pointer
[ 4.562] (II) event17 - Razer Razer Mouse Dock: device is a keyboard
[ 4.562] (II) event17 - Razer Razer Mouse Dock: device removed
[ 4.562] (II) libinput: Razer Razer Mouse Dock: needs a virtual subdevice
[ 4.562] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.1/3-1.1:1.0/0003:1532:007E.0004/input/input30/event17"
[ 4.562] (II) XINPUT: Adding extended input device "Razer Razer Mouse Dock" (type: MOUSE, id 10)
[ 4.562] (**) Option "AccelerationScheme" "none"
[ 4.562] (**) Razer Razer Mouse Dock: (accel) selected scheme none/0
[ 4.562] (**) Razer Razer Mouse Dock: (accel) acceleration factor: 2.000
[ 4.562] (**) Razer Razer Mouse Dock: (accel) acceleration threshold: 4
[ 4.563] (II) event17 - Razer Razer Mouse Dock: is tagged by udev as: Keyboard Mouse
[ 4.563] (II) event17 - Razer Razer Mouse Dock: device is a pointer
[ 4.563] (II) event17 - Razer Razer Mouse Dock: device is a keyboard
[ 4.563] (II) config/udev: Adding input device Razer Razer Mouse Dock (/dev/input/mouse2)
[ 4.563] (**) Razer Razer Mouse Dock: Applying InputClass "system-keyboard"
[ 4.563] (II) No input driver specified, ignoring this device.
[ 4.563] (II) This device may have been added with another device file.
[ 4.563] (II) config/udev: Adding input device Razer Razer Mouse Dock (/dev/input/event21)
[ 4.563] (**) Razer Razer Mouse Dock: Applying InputClass "libinput keyboard catchall"
[ 4.563] (II) Using input driver 'libinput' for 'Razer Razer Mouse Dock'
[ 4.564] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 55 paused 0
[ 4.564] (**) Razer Razer Mouse Dock: always reports core events
[ 4.564] (**) Option "Device" "/dev/input/event21"
[ 4.564] (II) event21 - Razer Razer Mouse Dock: is tagged by udev as: Keyboard
[ 4.564] (II) event21 - Razer Razer Mouse Dock: device is a keyboard
[ 4.564] (II) event21 - Razer Razer Mouse Dock: device removed
[ 4.564] (II) libinput: Razer Razer Mouse Dock: needs a virtual subdevice
[ 4.564] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:1532:007E.0006/input/input33/event21"
[ 4.564] (II) XINPUT: Adding extended input device "Razer Razer Mouse Dock" (type: MOUSE, id 11)
[ 4.564] (**) Option "AccelerationScheme" "none"
[ 4.564] (**) Razer Razer Mouse Dock: (accel) selected scheme none/0
[ 4.564] (**) Razer Razer Mouse Dock: (accel) acceleration factor: 2.000
[ 4.564] (**) Razer Razer Mouse Dock: (accel) acceleration threshold: 4
[ 4.565] (II) event21 - Razer Razer Mouse Dock: is tagged by udev as: Keyboard
[ 4.565] (II) event21 - Razer Razer Mouse Dock: device is a keyboard
[ 4.565] (II) config/udev: Adding input device Razer Razer Mouse Dock (/dev/input/event23)
[ 4.565] (**) Razer Razer Mouse Dock: Applying InputClass "libinput keyboard catchall"
[ 4.565] (**) Razer Razer Mouse Dock: Applying InputClass "system-keyboard"
[ 4.565] (II) Using input driver 'libinput' for 'Razer Razer Mouse Dock'
[ 4.566] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 56 paused 0
[ 4.566] (**) Razer Razer Mouse Dock: always reports core events
[ 4.566] (**) Option "Device" "/dev/input/event23"
[ 4.566] (II) event23 - Razer Razer Mouse Dock: is tagged by udev as: Keyboard
[ 4.566] (II) event23 - Razer Razer Mouse Dock: device is a keyboard
[ 4.566] (II) event23 - Razer Razer Mouse Dock: device removed
[ 4.566] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.1/3-1.1:1.2/0003:1532:007E.0007/input/input35/event23"
[ 4.566] (II) XINPUT: Adding extended input device "Razer Razer Mouse Dock" (type: KEYBOARD, id 12)
[ 4.566] (**) Option "xkb_model" "pc105"
[ 4.566] (**) Option "xkb_layout" "ro"
[ 4.566] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.567] (II) event23 - Razer Razer Mouse Dock: is tagged by udev as: Keyboard
[ 4.567] (II) event23 - Razer Razer Mouse Dock: device is a keyboard
[ 4.567] (II) config/udev: Adding input device Razer Razer Basilisk Ultimate Dongle (/dev/input/event19)
[ 4.567] (**) Razer Razer Basilisk Ultimate Dongle: Applying InputClass "libinput pointer catchall"
[ 4.567] (II) Using input driver 'libinput' for 'Razer Razer Basilisk Ultimate Dongle'
[ 4.624] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 57 paused 0
[ 4.624] (**) Razer Razer Basilisk Ultimate Dongle: always reports core events
[ 4.624] (**) Option "Device" "/dev/input/event19"
[ 4.624] (II) event19 - Razer Razer Basilisk Ultimate Dongle: is tagged by udev as: Mouse
[ 4.625] (II) event19 - Razer Razer Basilisk Ultimate Dongle: device is a pointer
[ 4.625] (II) event19 - Razer Razer Basilisk Ultimate Dongle: device removed
[ 4.625] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.2/3-1.2:1.0/0003:1532:0088.0003/input/input31/event19"
[ 4.625] (II) XINPUT: Adding extended input device "Razer Razer Basilisk Ultimate Dongle" (type: MOUSE, id 13)
[ 4.625] (**) Option "AccelerationScheme" "none"
[ 4.625] (**) Razer Razer Basilisk Ultimate Dongle: (accel) selected scheme none/0
[ 4.625] (**) Razer Razer Basilisk Ultimate Dongle: (accel) acceleration factor: 2.000
[ 4.625] (**) Razer Razer Basilisk Ultimate Dongle: (accel) acceleration threshold: 4
[ 4.625] (II) event19 - Razer Razer Basilisk Ultimate Dongle: is tagged by udev as: Mouse
[ 4.626] (II) config/udev: Adding input device Razer Razer Basilisk Ultimate Dongle (/dev/input/mouse3)
[ 4.626] (II) No input driver specified, ignoring this device.
[ 4.626] (II) This device may have been added with another device file.
[ 4.626] (II) config/udev: Adding input device Razer Razer Basilisk Ultimate Dongle (/dev/input/event20)
[ 4.626] (**) Razer Razer Basilisk Ultimate Dongle: Applying InputClass "libinput keyboard catchall"
[ 4.626] (**) Razer Razer Basilisk Ultimate Dongle: Applying InputClass "system-keyboard"
[ 4.626] (II) Using input driver 'libinput' for 'Razer Razer Basilisk Ultimate Dongle'
[ 4.626] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 58 paused 0
[ 4.626] (**) Razer Razer Basilisk Ultimate Dongle: always reports core events
[ 4.626] (**) Option "Device" "/dev/input/event20"
[ 4.627] (II) event20 - Razer Razer Basilisk Ultimate Dongle: is tagged by udev as: Keyboard
[ 4.627] (II) event20 - Razer Razer Basilisk Ultimate Dongle: device is a keyboard
[ 4.627] (II) event20 - Razer Razer Basilisk Ultimate Dongle: device removed
[ 4.627] (II) libinput: Razer Razer Basilisk Ultimate Dongle: needs a virtual subdevice
[ 4.627] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.2/3-1.2:1.1/0003:1532:0088.0005/input/input32/event20"
[ 4.627] (II) XINPUT: Adding extended input device "Razer Razer Basilisk Ultimate Dongle" (type: MOUSE, id 14)
[ 4.627] (**) Option "AccelerationScheme" "none"
[ 4.627] (**) Razer Razer Basilisk Ultimate Dongle: (accel) selected scheme none/0
[ 4.627] (**) Razer Razer Basilisk Ultimate Dongle: (accel) acceleration factor: 2.000
[ 4.627] (**) Razer Razer Basilisk Ultimate Dongle: (accel) acceleration threshold: 4
[ 4.628] (II) event20 - Razer Razer Basilisk Ultimate Dongle: is tagged by udev as: Keyboard
[ 4.628] (II) event20 - Razer Razer Basilisk Ultimate Dongle: device is a keyboard
[ 4.628] (II) config/udev: Adding input device Razer Razer Basilisk Ultimate Dongle (/dev/input/event24)
[ 4.628] (**) Razer Razer Basilisk Ultimate Dongle: Applying InputClass "libinput keyboard catchall"
[ 4.628] (**) Razer Razer Basilisk Ultimate Dongle: Applying InputClass "system-keyboard"
[ 4.628] (II) Using input driver 'libinput' for 'Razer Razer Basilisk Ultimate Dongle'
[ 4.628] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 59 paused 0
[ 4.628] (**) Razer Razer Basilisk Ultimate Dongle: always reports core events
[ 4.628] (**) Option "Device" "/dev/input/event24"
[ 4.629] (II) event24 - Razer Razer Basilisk Ultimate Dongle: is tagged by udev as: Keyboard
[ 4.629] (II) event24 - Razer Razer Basilisk Ultimate Dongle: device is a keyboard
[ 4.629] (II) event24 - Razer Razer Basilisk Ultimate Dongle: device removed
[ 4.629] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.2/3-1.2:1.2/0003:1532:0088.0008/input/input36/event24"
[ 4.629] (II) XINPUT: Adding extended input device "Razer Razer Basilisk Ultimate Dongle" (type: KEYBOARD, id 15)
[ 4.629] (**) Option "xkb_model" "pc105"
[ 4.629] (**) Option "xkb_layout" "ro"
[ 4.629] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.630] (II) event24 - Razer Razer Basilisk Ultimate Dongle: is tagged by udev as: Keyboard
[ 4.630] (II) event24 - Razer Razer Basilisk Ultimate Dongle: device is a keyboard
[ 4.630] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event18)
[ 4.630] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[ 4.630] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[ 4.630] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[ 4.631] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 60 paused 0
[ 4.631] (**) Integrated Camera: Integrated C: always reports core events
[ 4.631] (**) Option "Device" "/dev/input/event18"
[ 4.631] (II) event18 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 4.631] (II) event18 - Integrated Camera: Integrated C: device is a keyboard
[ 4.631] (II) event18 - Integrated Camera: Integrated C: device removed
[ 4.631] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-6/3-6:1.0/input/input22/event18"
[ 4.631] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 16)
[ 4.631] (**) Option "xkb_model" "pc105"
[ 4.631] (**) Option "xkb_layout" "ro"
[ 4.631] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.632] (II) event18 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 4.632] (II) event18 - Integrated Camera: Integrated C: device is a keyboard
[ 4.632] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Keyboard (/dev/input/event15)
[ 4.632] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "libinput keyboard catchall"
[ 4.632] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "system-keyboard"
[ 4.632] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Keyboard'
[ 4.632] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 61 paused 0
[ 4.632] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: always reports core events
[ 4.632] (**) Option "Device" "/dev/input/event15"
[ 4.633] (II) event15 - ITE Tech. Inc. ITE Device(8910) Keyboard: is tagged by udev as: Keyboard
[ 4.633] (II) event15 - ITE Tech. Inc. ITE Device(8910) Keyboard: device is a keyboard
[ 4.633] (II) event15 - ITE Tech. Inc. ITE Device(8910) Keyboard: device removed
[ 4.633] (II) libinput: ITE Tech. Inc. ITE Device(8910) Keyboard: needs a virtual subdevice
[ 4.633] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0/0003:048D:C101.0002/input/input19/event15"
[ 4.633] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Keyboard" (type: MOUSE, id 17)
[ 4.634] (**) Option "AccelerationScheme" "none"
[ 4.634] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: (accel) selected scheme none/0
[ 4.634] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: (accel) acceleration factor: 2.000
[ 4.634] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: (accel) acceleration threshold: 4
[ 4.634] (II) event15 - ITE Tech. Inc. ITE Device(8910) Keyboard: is tagged by udev as: Keyboard
[ 4.634] (II) event15 - ITE Tech. Inc. ITE Device(8910) Keyboard: device is a keyboard
[ 4.635] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Wireless Radio Control (/dev/input/event16)
[ 4.635] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[ 4.635] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "system-keyboard"
[ 4.635] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Wireless Radio Control'
[ 4.635] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 62 paused 0
[ 4.635] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: always reports core events
[ 4.635] (**) Option "Device" "/dev/input/event16"
[ 4.636] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: is tagged by udev as: Keyboard
[ 4.636] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device is a keyboard
[ 4.636] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device removed
[ 4.636] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0/0003:048D:C101.0002/input/input20/event16"
[ 4.636] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Wireless Radio Control" (type: KEYBOARD, id 18)
[ 4.636] (**) Option "xkb_model" "pc105"
[ 4.636] (**) Option "xkb_layout" "ro"
[ 4.636] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.637] (II) config/udev: Adding input device MSFT0001:01 04F3:31DD Mouse (/dev/input/event7)
[ 4.637] (**) MSFT0001:01 04F3:31DD Mouse: Applying InputClass "libinput pointer catchall"
[ 4.637] (II) Using input driver 'libinput' for 'MSFT0001:01 04F3:31DD Mouse'
[ 4.637] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 63 paused 0
[ 4.637] (**) MSFT0001:01 04F3:31DD Mouse: always reports core events
[ 4.637] (**) Option "Device" "/dev/input/event7"
[ 4.638] (II) event7 - MSFT0001:01 04F3:31DD Mouse: is tagged by udev as: Mouse Pointingstick
[ 4.638] (II) event7 - MSFT0001:01 04F3:31DD Mouse: device is a pointer
[ 4.638] (II) event7 - MSFT0001:01 04F3:31DD Mouse: device removed
[ 4.638] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-MSFT0001:01/0018:04F3:31DD.0001/input/input16/event7"
[ 4.638] (II) XINPUT: Adding extended input device "MSFT0001:01 04F3:31DD Mouse" (type: MOUSE, id 19)
[ 4.639] (**) Option "AccelerationScheme" "none"
[ 4.639] (**) MSFT0001:01 04F3:31DD Mouse: (accel) selected scheme none/0
[ 4.639] (**) MSFT0001:01 04F3:31DD Mouse: (accel) acceleration factor: 2.000
[ 4.639] (**) MSFT0001:01 04F3:31DD Mouse: (accel) acceleration threshold: 4
[ 4.639] (II) event7 - MSFT0001:01 04F3:31DD Mouse: is tagged by udev as: Mouse Pointingstick
[ 4.639] (II) event7 - MSFT0001:01 04F3:31DD Mouse: device is a pointer
[ 4.640] (II) config/udev: Adding input device MSFT0001:01 04F3:31DD Mouse (/dev/input/mouse0)
[ 4.640] (II) No input driver specified, ignoring this device.
[ 4.640] (II) This device may have been added with another device file.
[ 4.640] (II) config/udev: Adding input device MSFT0001:01 04F3:31DD Touchpad (/dev/input/event8)
[ 4.640] (**) MSFT0001:01 04F3:31DD Touchpad: Applying InputClass "libinput touchpad catchall"
[ 4.640] (II) Using input driver 'libinput' for 'MSFT0001:01 04F3:31DD Touchpad'
[ 4.641] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 64 paused 0
[ 4.641] (**) MSFT0001:01 04F3:31DD Touchpad: always reports core events
[ 4.641] (**) Option "Device" "/dev/input/event8"
[ 4.641] (II) event8 - MSFT0001:01 04F3:31DD Touchpad: is tagged by udev as: Touchpad
[ 4.642] (II) event8 - MSFT0001:01 04F3:31DD Touchpad: device is a touchpad
[ 4.642] (II) event8 - MSFT0001:01 04F3:31DD Touchpad: device removed
[ 4.642] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-MSFT0001:01/0018:04F3:31DD.0001/input/input18/event8"
[ 4.642] (II) XINPUT: Adding extended input device "MSFT0001:01 04F3:31DD Touchpad" (type: TOUCHPAD, id 20)
[ 4.642] (**) Option "AccelerationScheme" "none"
[ 4.642] (**) MSFT0001:01 04F3:31DD Touchpad: (accel) selected scheme none/0
[ 4.642] (**) MSFT0001:01 04F3:31DD Touchpad: (accel) acceleration factor: 2.000
[ 4.642] (**) MSFT0001:01 04F3:31DD Touchpad: (accel) acceleration threshold: 4
[ 4.643] (II) event8 - MSFT0001:01 04F3:31DD Touchpad: is tagged by udev as: Touchpad
[ 4.643] (II) event8 - MSFT0001:01 04F3:31DD Touchpad: device is a touchpad
[ 4.644] (II) config/udev: Adding input device MSFT0001:01 04F3:31DD Touchpad (/dev/input/mouse1)
[ 4.644] (II) No input driver specified, ignoring this device.
[ 4.644] (II) This device may have been added with another device file.
[ 4.644] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event5)
[ 4.644] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[ 4.644] (**) Ideapad extra buttons: Applying InputClass "system-keyboard"
[ 4.644] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[ 4.644] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 65 paused 0
[ 4.644] (**) Ideapad extra buttons: always reports core events
[ 4.644] (**) Option "Device" "/dev/input/event5"
[ 4.645] (II) event5 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 4.645] (II) event5 - Ideapad extra buttons: device is a keyboard
[ 4.645] (II) event5 - Ideapad extra buttons: device removed
[ 4.645] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input5/event5"
[ 4.645] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 21)
[ 4.645] (**) Option "xkb_model" "pc105"
[ 4.645] (**) Option "xkb_layout" "ro"
[ 4.645] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.646] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event25)
[ 4.646] (II) No input driver specified, ignoring this device.
[ 4.646] (II) This device may have been added with another device file.
[ 4.646] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event26)
[ 4.646] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event27)
[ 4.646] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event28)
[ 4.646] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event29)
[ 4.646] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event30)
[ 4.646] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event31)
[ 4.646] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=11 (/dev/input/event256)
[ 4.647] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=12 (/dev/input/event257)
[ 4.647] (II) No input driver specified, ignoring this device.
[ 4.647] (II) This device may have been added with another device file.
[ 4.647] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=13 (/dev/input/event258)
[ 4.647] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=14 (/dev/input/event259)
[ 4.647] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=15 (/dev/input/event260)
[ 4.647] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=16 (/dev/input/event261)
[ 4.647] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=17 (/dev/input/event262)
[ 4.647] (II) config/udev: Adding input device AT Raw Set 2 keyboard (/dev/input/event4)
[ 4.647] (**) AT Raw Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 4.647] (**) AT Raw Set 2 keyboard: Applying InputClass "system-keyboard"
[ 4.647] (II) Using input driver 'libinput' for 'AT Raw Set 2 keyboard'
[ 4.648] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 66 paused 0
[ 4.648] (**) AT Raw Set 2 keyboard: always reports core events
[ 4.648] (**) Option "Device" "/dev/input/event4"
[ 4.648] (II) event4 - AT Raw Set 2 keyboard: is tagged by udev as: Keyboard
[ 4.648] (II) event4 - AT Raw Set 2 keyboard: device is a keyboard
[ 4.649] (II) event4 - AT Raw Set 2 keyboard: device removed
[ 4.649] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 4.649] (II) XINPUT: Adding extended input device "AT Raw Set 2 keyboard" (type: KEYBOARD, id 22)
[ 4.649] (**) Option "xkb_model" "pc105"
[ 4.649] (**) Option "xkb_layout" "ro"
[ 4.649] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.649] (II) event4 - AT Raw Set 2 keyboard: is tagged by udev as: Keyboard
[ 4.649] (II) event4 - AT Raw Set 2 keyboard: device is a keyboard
[ 4.650] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 4.650] (II) No input driver specified, ignoring this device.
[ 4.650] (II) This device may have been added with another device file.
[ 4.700] (**) Razer Razer Mouse Dock: Applying InputClass "libinput pointer catchall"
[ 4.700] (**) Razer Razer Mouse Dock: Applying InputClass "libinput keyboard catchall"
[ 4.700] (**) Razer Razer Mouse Dock: Applying InputClass "system-keyboard"
[ 4.700] (II) Using input driver 'libinput' for 'Razer Razer Mouse Dock'
[ 4.700] (II) systemd-logind: returning pre-existing fd for /dev/input/event17 13:81
[ 4.700] (**) Razer Razer Mouse Dock: always reports core events
[ 4.700] (**) Option "Device" "/dev/input/event17"
[ 4.700] (II) libinput: Razer Razer Mouse Dock: is a virtual subdevice
[ 4.700] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.1/3-1.1:1.0/0003:1532:007E.0004/input/input30/event17"
[ 4.700] (II) XINPUT: Adding extended input device "Razer Razer Mouse Dock" (type: KEYBOARD, id 23)
[ 4.700] (**) Option "xkb_model" "pc105"
[ 4.700] (**) Option "xkb_layout" "ro"
[ 4.700] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.700] (II) systemd-logind: returning pre-existing fd for /dev/input/event21 13:85
[ 4.700] (**) Option "Device" "/dev/input/event21"
[ 4.700] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:1532:007E.0006/input/input33/event21"
[ 4.700] (II) XINPUT: Adding extended input device "Razer Razer Mouse Dock" (type: KEYBOARD, id 24)
[ 4.700] (**) Razer Razer Basilisk Ultimate Dongle: Applying InputClass "libinput keyboard catchall"
[ 4.700] (**) Razer Razer Basilisk Ultimate Dongle: Applying InputClass "system-keyboard"
[ 4.700] (II) Using input driver 'libinput' for 'Razer Razer Basilisk Ultimate Dongle'
[ 4.700] (II) systemd-logind: returning pre-existing fd for /dev/input/event20 13:84
[ 4.700] (**) Razer Razer Basilisk Ultimate Dongle: always reports core events
[ 4.700] (**) Option "Device" "/dev/input/event20"
[ 4.700] (II) libinput: Razer Razer Basilisk Ultimate Dongle: is a virtual subdevice
[ 4.700] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.2/3-1.2:1.1/0003:1532:0088.0005/input/input32/event20"
[ 4.700] (II) XINPUT: Adding extended input device "Razer Razer Basilisk Ultimate Dongle" (type: KEYBOARD, id 25)
[ 4.700] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "libinput keyboard catchall"
[ 4.700] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "system-keyboard"
[ 4.700] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Keyboard'
[ 4.700] (II) systemd-logind: returning pre-existing fd for /dev/input/event15 13:79
[ 4.700] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: always reports core events
[ 4.700] (**) Option "Device" "/dev/input/event15"
[ 4.700] (II) libinput: ITE Tech. Inc. ITE Device(8910) Keyboard: is a virtual subdevice
[ 4.700] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0/0003:048D:C101.0002/input/input19/event15"
[ 4.700] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Keyboard" (type: KEYBOARD, id 26)
[ 4.732] (II) config/udev: removing device Video Bus
[ 4.732] (**) Option "fd" "51"
[ 4.732] (II) event22 - Video Bus: device removed
[ 4.733] (II) UnloadModule: "libinput"
[ 4.733] (II) systemd-logind: releasing fd for 13:86
[ 4.807] (II) config/udev: Adding input device Video Bus (/dev/input/event22)
[ 4.807] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 4.807] (**) Video Bus: Applying InputClass "system-keyboard"
[ 4.807] (II) Using input driver 'libinput' for 'Video Bus'
[ 4.807] (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 68 paused 0
[ 4.807] (**) Video Bus: always reports core events
[ 4.808] (**) Option "Device" "/dev/input/event22"
[ 4.808] (II) event22 - Video Bus: is tagged by udev as: Keyboard
[ 4.808] (II) event22 - Video Bus: device is a keyboard
[ 4.808] (II) event22 - Video Bus: device removed
[ 4.808] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input34/event22"
[ 4.808] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 4.808] (**) Option "xkb_model" "pc105"
[ 4.808] (**) Option "xkb_layout" "ro"
[ 4.808] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.809] (II) event22 - Video Bus: device is a keyboard
[ 4.809] (II) config/udev: removing device Razer Razer Mouse Dock
[ 4.809] (**) Option "fd" "55"
[ 4.809] (II) UnloadModule: "libinput"
[ 4.809] (II) systemd-logind: not releasing fd for 13:85, still in use
[ 4.809] (II) event21 - Razer Razer Mouse Dock: device removed
[ 4.809] (II) systemd-logind: releasing fd for 13:85
[ 4.847] (II) config/udev: Adding input device Razer Razer Mouse Dock (/dev/input/event21)
[ 4.847] (**) Razer Razer Mouse Dock: Applying InputClass "libinput keyboard catchall"
[ 4.847] (**) Razer Razer Mouse Dock: Applying InputClass "system-keyboard"
[ 4.847] (II) Using input driver 'libinput' for 'Razer Razer Mouse Dock'
[ 4.848] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 70 paused 0
[ 4.848] (**) Razer Razer Mouse Dock: always reports core events
[ 4.848] (**) Option "Device" "/dev/input/event21"
[ 4.848] (II) event21 - Razer Razer Mouse Dock: is tagged by udev as: Keyboard
[ 4.848] (II) event21 - Razer Razer Mouse Dock: device is a keyboard
[ 4.848] (II) event21 - Razer Razer Mouse Dock: device removed
[ 4.848] (II) libinput: Razer Razer Mouse Dock: needs a virtual subdevice
[ 4.848] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:1532:007E.0006/input/input33/event21"
[ 4.848] (II) XINPUT: Adding extended input device "Razer Razer Mouse Dock" (type: MOUSE, id 11)
[ 4.848] (**) Option "AccelerationScheme" "none"
[ 4.848] (**) Razer Razer Mouse Dock: (accel) selected scheme none/0
[ 4.848] (**) Razer Razer Mouse Dock: (accel) acceleration factor: 2.000
[ 4.848] (**) Razer Razer Mouse Dock: (accel) acceleration threshold: 4
[ 4.849] (II) event21 - Razer Razer Mouse Dock: is tagged by udev as: Keyboard
[ 4.849] (II) event21 - Razer Razer Mouse Dock: device is a keyboard
[ 4.849] (**) Razer Razer Mouse Dock: Applying InputClass "libinput keyboard catchall"
[ 4.849] (**) Razer Razer Mouse Dock: Applying InputClass "system-keyboard"
[ 4.849] (II) Using input driver 'libinput' for 'Razer Razer Mouse Dock'
[ 4.849] (II) systemd-logind: returning pre-existing fd for /dev/input/event21 13:85
[ 4.849] (**) Razer Razer Mouse Dock: always reports core events
[ 4.849] (**) Option "Device" "/dev/input/event21"
[ 4.849] (II) libinput: Razer Razer Mouse Dock: is a virtual subdevice
[ 4.849] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:1532:007E.0006/input/input33/event21"
[ 4.849] (II) XINPUT: Adding extended input device "Razer Razer Mouse Dock" (type: KEYBOARD, id 24)
[ 4.849] (**) Option "xkb_model" "pc105"
[ 4.849] (**) Option "xkb_layout" "ro"
[ 4.849] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.850] (II) config/udev: Adding input device Razer Razer Mouse Dock (/dev/input/mouse2)
[ 4.850] (**) Razer Razer Mouse Dock: Applying InputClass "system-keyboard"
[ 4.850] (II) No input driver specified, ignoring this device.
[ 4.850] (II) This device may have been added with another device file.
[ 4.850] (II) config/udev: Adding input device Razer Razer Basilisk Ultimate Dongle (/dev/input/mouse3)
[ 4.851] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=15 (/dev/input/event260)
[ 4.851] (II) No input driver specified, ignoring this device.
[ 4.851] (II) This device may have been added with another device file.
[ 4.851] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event29)
[ 4.851] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=16 (/dev/input/event261)
[ 4.851] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event30)
[ 4.851] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=12 (/dev/input/event257)
[ 4.851] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event27)
[ 4.851] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=11 (/dev/input/event256)
[ 4.851] (II) config/udev: removing device Razer Razer Mouse Dock
[ 4.851] (**) Option "fd" "54"
[ 4.851] (II) UnloadModule: "libinput"
[ 4.851] (II) systemd-logind: not releasing fd for 13:81, still in use
[ 4.851] (II) event17 - Razer Razer Mouse Dock: device removed
[ 4.851] (II) systemd-logind: releasing fd for 13:81
[ 4.900] (II) config/udev: Adding input device Razer Razer Mouse Dock (/dev/input/event17)
[ 4.900] (**) Razer Razer Mouse Dock: Applying InputClass "libinput pointer catchall"
[ 4.900] (**) Razer Razer Mouse Dock: Applying InputClass "libinput keyboard catchall"
[ 4.900] (**) Razer Razer Mouse Dock: Applying InputClass "system-keyboard"
[ 4.900] (II) Using input driver 'libinput' for 'Razer Razer Mouse Dock'
[ 4.901] (II) systemd-logind: got fd for /dev/input/event17 13:81 fd 55 paused 0
[ 4.901] (**) Razer Razer Mouse Dock: always reports core events
[ 4.901] (**) Option "Device" "/dev/input/event17"
[ 4.901] (II) event17 - Razer Razer Mouse Dock: is tagged by udev as: Keyboard Mouse
[ 4.901] (II) event17 - Razer Razer Mouse Dock: device is a pointer
[ 4.901] (II) event17 - Razer Razer Mouse Dock: device is a keyboard
[ 4.902] (II) event17 - Razer Razer Mouse Dock: device removed
[ 4.902] (II) libinput: Razer Razer Mouse Dock: needs a virtual subdevice
[ 4.902] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.1/3-1.1:1.0/0003:1532:007E.0004/input/input30/event17"
[ 4.902] (II) XINPUT: Adding extended input device "Razer Razer Mouse Dock" (type: MOUSE, id 10)
[ 4.902] (**) Option "AccelerationScheme" "none"
[ 4.902] (**) Razer Razer Mouse Dock: (accel) selected scheme none/0
[ 4.902] (**) Razer Razer Mouse Dock: (accel) acceleration factor: 2.000
[ 4.902] (**) Razer Razer Mouse Dock: (accel) acceleration threshold: 4
[ 4.902] (II) event17 - Razer Razer Mouse Dock: is tagged by udev as: Keyboard Mouse
[ 4.902] (II) event17 - Razer Razer Mouse Dock: device is a pointer
[ 4.902] (II) event17 - Razer Razer Mouse Dock: device is a keyboard
[ 4.902] (**) Razer Razer Mouse Dock: Applying InputClass "libinput pointer catchall"
[ 4.902] (**) Razer Razer Mouse Dock: Applying InputClass "libinput keyboard catchall"
[ 4.902] (**) Razer Razer Mouse Dock: Applying InputClass "system-keyboard"
[ 4.902] (II) Using input driver 'libinput' for 'Razer Razer Mouse Dock'
[ 4.902] (II) systemd-logind: returning pre-existing fd for /dev/input/event17 13:81
[ 4.902] (**) Razer Razer Mouse Dock: always reports core events
[ 4.902] (**) Option "Device" "/dev/input/event17"
[ 4.902] (II) libinput: Razer Razer Mouse Dock: is a virtual subdevice
[ 4.903] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.1/3-1.1:1.0/0003:1532:007E.0004/input/input30/event17"
[ 4.903] (II) XINPUT: Adding extended input device "Razer Razer Mouse Dock" (type: KEYBOARD, id 23)
[ 4.903] (**) Option "xkb_model" "pc105"
[ 4.903] (**) Option "xkb_layout" "ro"
[ 4.903] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.903] (II) config/udev: removing device Razer Razer Basilisk Ultimate Dongle
[ 4.903] (**) Option "fd" "59"
[ 4.903] (II) event24 - Razer Razer Basilisk Ultimate Dongle: device removed
[ 4.903] (II) UnloadModule: "libinput"
[ 4.903] (II) systemd-logind: releasing fd for 13:88
[ 4.924] (II) config/udev: Adding input device Razer Razer Basilisk Ultimate Dongle (/dev/input/event24)
[ 4.924] (**) Razer Razer Basilisk Ultimate Dongle: Applying InputClass "libinput keyboard catchall"
[ 4.924] (**) Razer Razer Basilisk Ultimate Dongle: Applying InputClass "system-keyboard"
[ 4.924] (II) Using input driver 'libinput' for 'Razer Razer Basilisk Ultimate Dongle'
[ 4.924] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 59 paused 0
[ 4.924] (**) Razer Razer Basilisk Ultimate Dongle: always reports core events
[ 4.924] (**) Option "Device" "/dev/input/event24"
[ 4.925] (II) event24 - Razer Razer Basilisk Ultimate Dongle: is tagged by udev as: Keyboard
[ 4.925] (II) event24 - Razer Razer Basilisk Ultimate Dongle: device is a keyboard
[ 4.925] (II) event24 - Razer Razer Basilisk Ultimate Dongle: device removed
[ 4.925] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.2/3-1.2:1.2/0003:1532:0088.0008/input/input36/event24"
[ 4.925] (II) XINPUT: Adding extended input device "Razer Razer Basilisk Ultimate Dongle" (type: KEYBOARD, id 15)
[ 4.925] (**) Option "xkb_model" "pc105"
[ 4.925] (**) Option "xkb_layout" "ro"
[ 4.925] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.926] (II) event24 - Razer Razer Basilisk Ultimate Dongle: is tagged by udev as: Keyboard
[ 4.926] (II) event24 - Razer Razer Basilisk Ultimate Dongle: device is a keyboard
[ 4.926] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event31)
[ 4.926] (II) No input driver specified, ignoring this device.
[ 4.926] (II) This device may have been added with another device file.
[ 4.926] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event26)
[ 4.926] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event28)
[ 4.926] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=13 (/dev/input/event258)
[ 4.926] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=14 (/dev/input/event259)
[ 4.926] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event25)
[ 4.927] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=17 (/dev/input/event262)
[ 4.927] (II) No input driver specified, ignoring this device.
[ 4.927] (II) This device may have been added with another device file.
[ 4.927] (II) config/udev: removing device Razer Razer Mouse Dock
[ 4.927] (**) Option "fd" "56"
[ 4.927] (II) event23 - Razer Razer Mouse Dock: device removed
[ 4.927] (II) UnloadModule: "libinput"
[ 4.927] (II) systemd-logind: releasing fd for 13:87
[ 4.957] (II) config/udev: Adding input device Razer Razer Mouse Dock (/dev/input/event23)
[ 4.957] (**) Razer Razer Mouse Dock: Applying InputClass "libinput keyboard catchall"
[ 4.957] (**) Razer Razer Mouse Dock: Applying InputClass "system-keyboard"
[ 4.957] (II) Using input driver 'libinput' for 'Razer Razer Mouse Dock'
[ 4.958] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 56 paused 0
[ 4.958] (**) Razer Razer Mouse Dock: always reports core events
[ 4.958] (**) Option "Device" "/dev/input/event23"
[ 4.958] (II) event23 - Razer Razer Mouse Dock: is tagged by udev as: Keyboard
[ 4.958] (II) event23 - Razer Razer Mouse Dock: device is a keyboard
[ 4.958] (II) event23 - Razer Razer Mouse Dock: device removed
[ 4.958] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.1/3-1.1:1.2/0003:1532:007E.0007/input/input35/event23"
[ 4.958] (II) XINPUT: Adding extended input device "Razer Razer Mouse Dock" (type: KEYBOARD, id 12)
[ 4.958] (**) Option "xkb_model" "pc105"
[ 4.958] (**) Option "xkb_layout" "ro"
[ 4.958] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.959] (II) event23 - Razer Razer Mouse Dock: is tagged by udev as: Keyboard
[ 4.959] (II) event23 - Razer Razer Mouse Dock: device is a keyboard
[ 4.959] (II) config/udev: removing device Razer Razer Basilisk Ultimate Dongle
[ 4.959] (**) Option "fd" "58"
[ 4.959] (II) UnloadModule: "libinput"
[ 4.959] (II) systemd-logind: not releasing fd for 13:84, still in use
[ 4.959] (II) event20 - Razer Razer Basilisk Ultimate Dongle: device removed
[ 4.959] (II) systemd-logind: releasing fd for 13:84
[ 4.987] (II) config/udev: Adding input device Razer Razer Basilisk Ultimate Dongle (/dev/input/event20)
[ 4.987] (**) Razer Razer Basilisk Ultimate Dongle: Applying InputClass "libinput keyboard catchall"
[ 4.987] (**) Razer Razer Basilisk Ultimate Dongle: Applying InputClass "system-keyboard"
[ 4.987] (II) Using input driver 'libinput' for 'Razer Razer Basilisk Ultimate Dongle'
[ 4.988] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 58 paused 0
[ 4.988] (**) Razer Razer Basilisk Ultimate Dongle: always reports core events
[ 4.988] (**) Option "Device" "/dev/input/event20"
[ 4.988] (II) event20 - Razer Razer Basilisk Ultimate Dongle: is tagged by udev as: Keyboard
[ 4.988] (II) event20 - Razer Razer Basilisk Ultimate Dongle: device is a keyboard
[ 4.988] (II) event20 - Razer Razer Basilisk Ultimate Dongle: device removed
[ 4.988] (II) libinput: Razer Razer Basilisk Ultimate Dongle: needs a virtual subdevice
[ 4.988] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.2/3-1.2:1.1/0003:1532:0088.0005/input/input32/event20"
[ 4.988] (II) XINPUT: Adding extended input device "Razer Razer Basilisk Ultimate Dongle" (type: MOUSE, id 14)
[ 4.988] (**) Option "AccelerationScheme" "none"
[ 4.988] (**) Razer Razer Basilisk Ultimate Dongle: (accel) selected scheme none/0
[ 4.988] (**) Razer Razer Basilisk Ultimate Dongle: (accel) acceleration factor: 2.000
[ 4.988] (**) Razer Razer Basilisk Ultimate Dongle: (accel) acceleration threshold: 4
[ 4.989] (II) event20 - Razer Razer Basilisk Ultimate Dongle: is tagged by udev as: Keyboard
[ 4.989] (II) event20 - Razer Razer Basilisk Ultimate Dongle: device is a keyboard
[ 4.989] (**) Razer Razer Basilisk Ultimate Dongle: Applying InputClass "libinput keyboard catchall"
[ 4.989] (**) Razer Razer Basilisk Ultimate Dongle: Applying InputClass "system-keyboard"
[ 4.989] (II) Using input driver 'libinput' for 'Razer Razer Basilisk Ultimate Dongle'
[ 4.989] (II) systemd-logind: returning pre-existing fd for /dev/input/event20 13:84
[ 4.989] (**) Razer Razer Basilisk Ultimate Dongle: always reports core events
[ 4.989] (**) Option "Device" "/dev/input/event20"
[ 4.989] (II) libinput: Razer Razer Basilisk Ultimate Dongle: is a virtual subdevice
[ 4.989] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.2/3-1.2:1.1/0003:1532:0088.0005/input/input32/event20"
[ 4.989] (II) XINPUT: Adding extended input device "Razer Razer Basilisk Ultimate Dongle" (type: KEYBOARD, id 25)
[ 4.989] (**) Option "xkb_model" "pc105"
[ 4.989] (**) Option "xkb_layout" "ro"
[ 4.989] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 4.989] (II) config/udev: removing device Razer Razer Basilisk Ultimate Dongle
[ 4.989] (**) Option "fd" "57"
[ 4.989] (II) event19 - Razer Razer Basilisk Ultimate Dongle: device removed
[ 4.989] (II) UnloadModule: "libinput"
[ 4.989] (II) systemd-logind: releasing fd for 13:83
[ 5.044] (II) config/udev: Adding input device Razer Razer Basilisk Ultimate Dongle (/dev/input/event19)
[ 5.044] (**) Razer Razer Basilisk Ultimate Dongle: Applying InputClass "libinput pointer catchall"
[ 5.044] (II) Using input driver 'libinput' for 'Razer Razer Basilisk Ultimate Dongle'
[ 5.100] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 57 paused 0
[ 5.100] (**) Razer Razer Basilisk Ultimate Dongle: always reports core events
[ 5.100] (**) Option "Device" "/dev/input/event19"
[ 5.101] (II) event19 - Razer Razer Basilisk Ultimate Dongle: is tagged by udev as: Mouse
[ 5.101] (II) event19 - Razer Razer Basilisk Ultimate Dongle: device is a pointer
[ 5.101] (II) event19 - Razer Razer Basilisk Ultimate Dongle: device removed
[ 5.101] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.2/3-1.2:1.0/0003:1532:0088.0003/input/input31/event19"
[ 5.101] (II) XINPUT: Adding extended input device "Razer Razer Basilisk Ultimate Dongle" (type: MOUSE, id 13)
[ 5.101] (**) Option "AccelerationScheme" "none"
[ 5.101] (**) Razer Razer Basilisk Ultimate Dongle: (accel) selected scheme none/0
[ 5.101] (**) Razer Razer Basilisk Ultimate Dongle: (accel) acceleration factor: 2.000
[ 5.101] (**) Razer Razer Basilisk Ultimate Dongle: (accel) acceleration threshold: 4
[ 5.102] (II) event19 - Razer Razer Basilisk Ultimate Dongle: is tagged by udev as: Mouse
[ 5.102] (II) event19 - Razer Razer Basilisk Ultimate Dongle: device is a pointer
[ 5.293] (II) modeset(0): EDID vendor "AUO", prod id 17565
[ 5.293] (II) modeset(0): Printing DDC gathered Modelines:
[ 5.293] (II) modeset(0): Modeline "1920x1080"x0.0 368.14 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (175.1 kHz eP)
[ 5.295] (II) modeset(0): EDID vendor "AUO", prod id 17565
[ 5.295] (II) modeset(0): Printing DDC gathered Modelines:
[ 5.295] (II) modeset(0): Modeline "1920x1080"x0.0 368.14 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (175.1 kHz eP)
[ 5.295] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 5.295] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 5.295] (--) NVIDIA(GPU-0): DFP-0: 2670.0 MHz maximum pixel clock
[ 5.295] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 5.295] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 5.295] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 5.295] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 5.295] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 5.295] (--) NVIDIA(GPU-0): DFP-2: 2670.0 MHz maximum pixel clock
[ 5.295] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 5.295] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 5.295] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 5.295] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 5.295] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 5.295] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 5.295] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 5.295] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 5.295] (--) NVIDIA(GPU-0): DFP-5: 2670.0 MHz maximum pixel clock
[ 11.537] (**) Option "fd" "48"
[ 11.537] (II) event3 - Power Button: device removed
[ 11.537] (**) Option "fd" "52"
[ 11.537] (II) event1 - Power Button: device removed
[ 11.537] (**) Option "fd" "53"
[ 11.537] (II) event2 - Sleep Button: device removed
[ 11.537] (**) Option "fd" "60"
[ 11.537] (II) event18 - Integrated Camera: Integrated C: device removed
[ 11.537] (**) Option "fd" "61"
[ 11.537] (**) Option "fd" "62"
[ 11.537] (II) event16 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device removed
[ 11.537] (**) Option "fd" "63"
[ 11.537] (II) event7 - MSFT0001:01 04F3:31DD Mouse: device removed
[ 11.537] (**) Option "fd" "64"
[ 11.537] (II) event8 - MSFT0001:01 04F3:31DD Touchpad: device removed
[ 11.537] (**) Option "fd" "65"
[ 11.537] (II) event5 - Ideapad extra buttons: device removed
[ 11.537] (**) Option "fd" "66"
[ 11.537] (II) event4 - AT Raw Set 2 keyboard: device removed
[ 11.537] (II) event15 - ITE Tech. Inc. ITE Device(8910) Keyboard: device removed
[ 11.537] (**) Option "fd" "68"
[ 11.537] (II) event22 - Video Bus: device removed
[ 11.538] (**) Option "fd" "70"
[ 11.538] (II) event21 - Razer Razer Mouse Dock: device removed
[ 11.538] (**) Option "fd" "55"
[ 11.538] (II) event17 - Razer Razer Mouse Dock: device removed
[ 11.538] (**) Option "fd" "59"
[ 11.538] (II) event24 - Razer Razer Basilisk Ultimate Dongle: device removed
[ 11.538] (**) Option "fd" "56"
[ 11.538] (II) event23 - Razer Razer Mouse Dock: device removed
[ 11.538] (**) Option "fd" "58"
[ 11.538] (II) event20 - Razer Razer Basilisk Ultimate Dongle: device removed
[ 11.538] (**) Option "fd" "57"
[ 11.538] (II) event19 - Razer Razer Basilisk Ultimate Dongle: device removed
[ 11.538] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 11.571] (EE) modeset(0): Failed to set CTM property: -13
[ 11.571] (EE) modeset(0): failed to set mode: No such file or directory
[ 11.571] (II) systemd-logind: got pause for 13:88
[ 11.571] (II) systemd-logind: got pause for 13:84
[ 11.571] (II) systemd-logind: got pause for 13:71
[ 11.571] (II) systemd-logind: got pause for 13:79
[ 11.571] (II) systemd-logind: got pause for 13:86
[ 11.571] (II) systemd-logind: got pause for 13:87
[ 11.571] (II) systemd-logind: got pause for 13:66
[ 11.571] (II) systemd-logind: got pause for 13:82
[ 11.571] (II) systemd-logind: got pause for 13:69
[ 11.571] (II) systemd-logind: got pause for 13:67
[ 11.571] (II) systemd-logind: got pause for 13:68
[ 11.571] (II) systemd-logind: got pause for 13:65
[ 11.571] (II) systemd-logind: got pause for 13:72
[ 11.571] (II) systemd-logind: got pause for 13:81
[ 11.571] (II) systemd-logind: got pause for 13:83
[ 11.571] (II) systemd-logind: got pause for 13:85
[ 11.571] (II) systemd-logind: got pause for 13:80
[ 15.815] (II) UnloadModule: "libinput"
[ 15.815] (II) systemd-logind: releasing fd for 13:83
[ 15.837] (II) UnloadModule: "libinput"
[ 15.837] (II) systemd-logind: not releasing fd for 13:84, still in use
[ 15.837] (II) systemd-logind: releasing fd for 13:84
[ 15.873] (II) UnloadModule: "libinput"
[ 15.873] (II) systemd-logind: releasing fd for 13:87
[ 15.913] (II) UnloadModule: "libinput"
[ 15.913] (II) systemd-logind: releasing fd for 13:88
[ 15.943] (II) UnloadModule: "libinput"
[ 15.943] (II) systemd-logind: not releasing fd for 13:81, still in use
[ 15.943] (II) systemd-logind: releasing fd for 13:81
[ 15.980] (II) UnloadModule: "libinput"
[ 15.980] (II) systemd-logind: not releasing fd for 13:85, still in use
[ 15.980] (II) systemd-logind: releasing fd for 13:85
[ 16.007] (II) UnloadModule: "libinput"
[ 16.007] (II) systemd-logind: releasing fd for 13:86
[ 16.037] (II) UnloadModule: "libinput"
[ 16.037] (II) systemd-logind: not releasing fd for 13:79, still in use
[ 16.037] (II) systemd-logind: releasing fd for 13:68
[ 16.057] (II) UnloadModule: "libinput"
[ 16.057] (II) systemd-logind: releasing fd for 13:69
[ 16.077] (II) UnloadModule: "libinput"
[ 16.077] (II) systemd-logind: releasing fd for 13:72
[ 16.103] (II) UnloadModule: "libinput"
[ 16.103] (II) systemd-logind: releasing fd for 13:71
[ 16.127] (II) UnloadModule: "libinput"
[ 16.127] (II) systemd-logind: releasing fd for 13:80
[ 16.153] (II) UnloadModule: "libinput"
[ 16.153] (II) systemd-logind: releasing fd for 13:79
[ 16.187] (II) UnloadModule: "libinput"
[ 16.187] (II) systemd-logind: releasing fd for 13:82
[ 16.207] (II) UnloadModule: "libinput"
[ 16.207] (II) systemd-logind: releasing fd for 13:66
[ 16.233] (II) UnloadModule: "libinput"
[ 16.233] (II) systemd-logind: releasing fd for 13:65
[ 16.267] (II) UnloadModule: "libinput"
[ 16.267] (II) systemd-logind: releasing fd for 13:67
[ 16.294] (WW) NVIDIA(G0): Failed to set the display configuration
[ 16.294] (WW) NVIDIA(G0): - Setting a mode on head 0 failed: Insufficient permissions
[ 16.294] (WW) NVIDIA(G0): - Setting a mode on head 1 failed: Insufficient permissions
[ 16.294] (WW) NVIDIA(G0): - Setting a mode on head 2 failed: Insufficient permissions
[ 16.294] (WW) NVIDIA(G0): - Setting a mode on head 3 failed: Insufficient permissions
[ 16.297] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 16.298] (II) Server terminated successfully (0). Closing log file.
