Is it possible to build nvidia-340xx with the 5.11 kernel?
I donât know, but probably yes. Try it:
It doesnât build for 511. Many fatal errors. Probably needs new patches.
Iâve marked this answer as the solution to your question as it is by far the best answer youâll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldnât have done this or
or
if you agree)
P.S. In the future, please donât forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
so that the next person that has the exact same problem you just had will benefit from your post as well as your question will now be in the âsolvedâ status.
I see the AUR package was just updated: https://aur.archlinux.org/packages/nvidia 340xx/
This github repo hosts patches: https://github.com/warpme/minimyth2/tree/master/script/nvidia/nvidia-340.108/files
Yes, version 14 arrived and works on 5.10 and 5.4LTS but canât say for 5.11. In pamac do
- âedit build fileâ
- replace existing file with this one
- edit line 9 to the correct version
pkgrel=14 - save
Read this:
I know about the policy, just saying
Click the link⌠There is a workaround too!
