How to Boot Repair my Lenovo IdeaPad L340-15IRH Gaming?
Issue started with playing around video settings with envycontrol -S hybrid
See Android tablet or phone display on Linux Manjaro Laptop with SCRCPY
See also my Manjaro Cinnamon boots into black screen.
Then I changed my laptop with envycontrol -S nvidia, and it worked fine. Thanks to the forum hero’s.
Now I experienced with the “envycontrol -S nvidia” setting, the laptop refuses to operate my wished scrcpy. I do want to show Android apps by use of my laptop on a big screen for an audience
Switching from “envycontrol -S nvidia”, to another setting I first did try envycontrol -s integrated
On the Lenovo laptop I did # envycontrol -s integrated. Result : Black screen. With CTRL ALT F3, login in as hans, and startx, Manjaro showed up !
So I was able to change the setting once more : Same trick but now with “envycontrol -S hybrid”. Result : Manjaro booting goes bad. I managed to come into grub>, played a bit around. Commands to investigate ,found on online manuals, do work.
Managed to mount an external harddisk to backup.
I did a grub recovery a long time before on Linux Mint, with /dev/sdxn devices
Now I have a GPT system with (see below) with /dev/nvme0n1pn devices
The proposed manual
feels to difficult. It keeps too many questions open for me.
Please help me out.
These topics showed up while saving this post thef first time. They dont help :innocent: :
Thanks in advance.
Hans
Using fdisk -l and grub> ls (hd0,7) :
theharddisk = /dev/nvme0n1
the harddisk partition x = /dev/nvme0n1p1
the harddisk partition x = /dev/nvme0n1p2
the harddisk partition x = /dev/nvme0n1p3
the harddisk partition x = /dev/nvme0n1p4
the harddisk partition x = /dev/nvme0n1p5
the harddisk partition x = /dev/nvme0n1p6 = datalinux
the harddisk partition x = /dev/nvme0n1p7 = manjaroroot
the harddisk partition x = /dev/nvme0n1p8
inxi -zv8
  Kernel: 6.18.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=112cd725-a20f-43d0-b548-13024d82080a rw quiet apparmor=1
  Console: pty pts/0 DM: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 81LK v: IdeaPad L340-15IRH Gaming
    serial: <superuser required> Chassis: type: 10 v: IdeaPad L340-15IRH Gaming
  Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
    serial: <superuser required> part-nu: LENOVO_MT_81LK_BU_idea_FM_IdeaPad
    L340-15IRH Gaming uuid: <superuser required> Firmware: UEFI vendor: LENOVO
    v: BGCN36WW date: 05/24/2022
  ID-1: BAT0 charge: 33.4 Wh (100%) condition: 33.4/45 Wh (74.2%) volts: 12.69
    min: 11.52 model: Celxpert L18C3PF1 type: Li-poly serial: <filter> charging:
    status: full type: standard avail: long_life,standard cycles: 950
  System RAM: total: 16 GiB available: 15.48 GiB used: 2.18 GiB (14.1%)
  Array-1: capacity: 16 GiB slots: 1 modules: 1 EC: None
  Device-1: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
    speed: 2400 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M471A2K43DB1-CTD serial: <filter>
  Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/2600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
    class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
    driver: nvidia v: 590.48.01 alternate: nouveau,nova_core,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: none off: HDMI-A-1 empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:1f91
    class-ID: 0300
  Device-3: Lite-On Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 04ca:7070
    class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9 driver:
    X: loaded: modesetting,nvidia dri: iris gpu: i915,nvidia,nvidia-nvswitch
    tty: 80x24
  Monitor-1: HDMI-A-1 model: Dell P2219H serial: <filter> built: 2020
    res: 1920x1080 dpi: 102 gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green:
    x: 0.325 y: 0.612 blue: x: 0.153 y: 0.063 white: x: 0.314 y: 0.329
    size: 476x267mm (18.74x10.51") diag: 546mm (21.5") ratio: 16:9
    modes: 1920x1080, 1600x900, 1280x1024, 1152x864, 1280x720, 1024x768,
    800x600, 720x576, 720x480, 640x480
  Monitor-2: eDP-1 model: ChiMei InnoLux 0x15e7 built: 2016 res: 1920x1080
    dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329 y: 0.557
    blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080
  API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
  API: OpenGL v: 4.6.0 vendor: nvidia v: 590.48.01
    note: console (EGL sourced) renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-smi
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
  Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
    class-ID: 0403
  API: ALSA v: k6.18.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: off tools: pw-cli
  Server-3: PulseAudio v: 17.0-98-gb096 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 07:00.0 chip-ID: 168c:0042 class-ID: 0280
  IF: wlp7s0 state: up mac: <filter>
  IP v6: <filter> type: dynamic mngtmpaddr proto kernel_ra scope: global
  IP v6: <filter> virtual: proto kernel_ll scope: link
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp8s0 state: down mac: <filter>
  Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 0cf3:e500
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Local Storage: total: 953.87 GiB used: 250.83 GiB (26.3%)
    model: MZVLB1T0HALR-000L2 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 5L1QEXA7 temp: 22.9 C scheme: GPT
  ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 27.78 GiB (29.1%)
    fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: rootmanjaro
    uuid: 112cd725-a20f-43d0-b548-13024d82080a
  ID-2: /boot/efi raw-size: 371 MiB size: 370.3 MiB (99.80%)
    used: 44.3 MiB (12.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 0B3C-369A
  ID-3: /mnt/datalinux raw-size: 494.67 GiB size: 485.83 GiB (98.21%)
    used: 75.34 GiB (15.5%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
    label: N/A uuid: N/A
  ID-4: /mnt/winc raw-size: 282.24 GiB size: 282.24 GiB (100.00%)
    used: 141.63 GiB (50.2%) fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: 6E7CD3E67CD3A6DD
  ID-5: /mnt/windata raw-size: 77.1 GiB size: 77.1 GiB (100.00%)
    used: 6.03 GiB (7.8%) fs: ntfs dev: /dev/nvme0n1p5 maj-min: 259:5
    label: windata uuid: 206A5A4F6A5A21B8
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: ext4 label: N/A
    uuid: ad5af1dc-27c2-4b6f-9b43-6bf51b2e7c35
  ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 878 MiB fs: ntfs label: N/A
    uuid: 1CCEB437CEB40B52
  ID-3: /dev/nvme0n1p8 maj-min: 259:8 size: 1000 MiB fs: ntfs label: N/A
    uuid: 769C5D369C5CF1DB
  Hub-2: 1-1:2 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
    chip-ID: 214b:7250 class-ID: 0900
  Device-1: 1-1.1:4 info: Trust Deskset type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 145f:02cc class-ID: 0301
  Device-2: 1-1.4:6 info: Genesys Logic microSD Card Reader
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 98mA
    chip-ID: 05e3:0751 class-ID: 0806
  Device-3: 1-8:3 info: Lite-On Integrated Camera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04ca:7070 class-ID: 0e02
  Device-4: 1-14:5 info: Qualcomm Atheros type: bluetooth driver: btusb
    power: 100mA chip-ID: 0cf3:e500 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  System Temperatures: cpu: 42.0 C pch: 38.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1369 libs: 379 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    2: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    3: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    5: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    7: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
    8: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 323
  1: cpu: 16.8% command: firefox pid: 3779 mem: 484.3 MiB (3.0%)
  2: cpu: 12.6% command: firefox pid: 4293 mem: 349.3 MiB (2.2%)
  3: cpu: 7.2% command: cinnamon pid: 2252 mem: 268.0 MiB (1.6%)
  4: cpu: 3.6% command: firefox pid: 4224 mem: 230.6 MiB (1.4%)
  5: cpu: 3.5% command: Xorg pid: 1593 mem: 157.4 MiB (0.9%)
  Memory top: 5 of 323
  1: mem: 484.3 MiB (3.0%) command: firefox pid: 3779 cpu: 16.8%
  2: mem: 349.3 MiB (2.2%) command: firefox pid: 4293 cpu: 12.6%
  3: mem: 268.0 MiB (1.6%) command: cinnamon pid: 2252 cpu: 7.2%
  4: mem: 230.6 MiB (1.4%) command: firefox pid: 4224 cpu: 3.6%
  5: mem: 201.9 MiB (1.2%) command: firefox pid: 4286 cpu: 0.8%
  Processes: 323 Power: uptime: 6m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.14 GiB services: csd-power,upowerd
    Init: systemd v: 258 default: graphical tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash (su) v: 5.3.9
    running-in: pty pts/0 inxi: 3.3.40
I did try to fix booting with this procedure : GRUB/Restore the GRUB Bootloader - Manjaro.
No succes, despite well preparing the commands in a text file, before starting Manjaro live from usb drive.
Too much to explain what went good (a lot) and what went wrong … :confused:
I can still booting into windows, which makes me this time more happy than ever :grin:
Next trial : find another manual with the proper procudere … :thinking:
Searching for “Hoe herstel ik het opstarten van manjaro linux op een laptop met een ssd disk ?” = “How to repair booting of manjaro linux on a laptop with an ssd drive ?”
So nice to ask it to “DuckDuckGo AI Chat at DuckDuckGo”. You guys dont like AI ? I will take care :slight_smile: The answer provides a lot of knowledge to use for finding a real manual. Which I do need. Gambling around is forbidden in this quest !
Will check out again : https://forum.manjaro.org/t/root-tip-recovery-basic-manjaro-linux-rescue-and-recovery/175302
And this one ? Small but good ? https://jrehkemper.de/content/linux/grub/manually-boot-from-grub-shell/
Recovering a system with bad Nvidia GPU configuration.
Depending on your system it can be - somewhat - complicated to reach that point.
Using encryption and btrfs is all factors that add steps to reach the goal of recovering from a bad configuration.
The primary steps is to get into the system - this is described in the basic recovery guide - where you will end in what is called a chroot environment - I won’t go into those details - the recovery guide outlines those details.
The following assume you have mounted the system and entered the chroot environment.
When the bad configuration has been caused by envycontrol - you can run envycontrol to remove the changes made.
envycontrol --reset
Then exit the chroot
exit
And restart
reboot
According to the OP’s linked earlier post where you also provided help I think the issue is that this step:
sudo mhwd -i pci video-hybrid-intel-nvidia-prime
fails with
linux616-nvidia breaks dependency 'linux616-nvidia' required by linux-nvidia-meta
The OP seemed to leave it at that instead of fixing the issue by removing the meta package and running the command again.
To check if I’m guessing right the OP should again post the output of
mhwd -li
If the hybrid config is not listed there I doubt envycontrol will ever work.
manjaro-bobs.rescue-26.019-unstable-260119-linux618.iso used to boot
Done uptill envycontrol --reset.
response pc :
Rebuilding the initramfs
Succesfully rebuilt the initramfs
Operation completely succesfully
exit
reboot
grub>
Not good. Will reuse bootable usb to repair grub
manual to follow : https://wiki.manjaro.org/index.php/GRUB/Restore_the_GRUB_Bootloader
grub-mkconfig -o /boot/grub/grub.cfg
one error :
grub-probe error: cannot find a GRUB drive for /dev/sda1. Check your device map
To be continued. No final fix yet.
I am busy with configuring another laptop. Because I cannot use my mail in my Thunderbird. On this other laptop, I did choose for Linux Mint Cinnamon. To have not similar issues as on both of my Manjaro running computers. In Mint, I do fase other challenges, so I do prefer to get my Lenovo with Manjaro up and running again. Please again : I takes me so much time. Any advise is very welcome …
Can it help to try to te repair first te bootloader with windows ? And try to repair it duur grub ?
I have never used custom ISOs. But tracking down where it’s from. I think it’s this one?
And there hasn’t been a real commit in over 2 years. And it’s from the unstable branch to boot?
Did you try an up to date official image at all?
Ha Molski,
Somewhere on my recent topics, this rescue iso was advised to me. It runs into a root prompt only.
An official Linux Manjaro Cinnamon live usb drive delivers more functionality, as the possibility to connect / mount another usb flash drive, for making text notes and keeping screencopy’s.
I still do need the knowlegde to make it bootable in linux now. At the moment, the laptop starts in windows. Which I only use for some specific applications
Thanks so far.
Hans
I think getting into manjaro-chroot from a live image is practically a requirement to run Manjaro.
I can’t count the amount of times where I’ve needed it to save an unbootable system.
The wiki page is still down, was last week too. I can’t even remember what’s on it.
Where do you get hung up?
Both the Manjaro Wiki and the Arch Wiki are up and running. Which page exactly do you have a problem with? :thinking:
The topic [root tip] [recovery] Basic Manjaro Linux Rescue and Recovery was recommended.
The ISO
The ISO referred is my personal ISO - and yes it boot to a root prompt.
It is capable of running plasma session as well. Instructions is written on screen at boot time.
Three instructions are written
  • How to set console keymap (example dk-keymap)
  • How to set graphic keymap (example dk-keymap)
  • How to launch plasma
How you fix your boot issue on the laptop at hand depends on how the system is laid out.
Is it UEFI/GPT or is it BIOS/MBR. Some systems has been configured to use a compatibility mode - that is they are capable of booting using either BIOS or UEFI.
It is recommended to disable CSM (compatibility mode) to ensure the system is booted in UEFI mode. The two modes are incompatible and this is often causing confusion when it comes to bootloader.
When boot to a live ISO - please verify if the following folder exist
ls /sys/firmware/efi/efivars
If it does not exist - the system is booted as BIOS system - and you are advised to disable CSM.
Unless of course you have a strong aversion to using UEFI and GPT.
I’m sorry, I should of at least tried to figure out where this came from. I did not read the other threads.
(And I know nothing about custom ISOs.)
My laptop is using UEFI and GPT.
When and how to disable CSM (compatibility mode) ?
It is usually found in the boot options of the UEFI settings.
I will have a try to find it. Thanks
I did start the laptop. F2 to reach the Lenovo Setup Utility. Menu with tabs Information, Configuration, Security, Boot, Exit.
Here I dont see the CMS option.
Do you mean I should boot into live Linux ?
Booting. Didnt see a CMS option
I did check the “ls /sys/firmware/efi/efivars” …
yes it does exist and contains 119 lines
It’s not always called “CMS”. It could just as easily be called “BIOS emulation” or “legacy boot”, or something like that.
Do you mean that secure boot should be off ? It is off !
If it does exist, your system booted correctly as UEFI.
So:
all good
It would not exist at all if your system would have booted as a BIOS system.
Yes!
Good!
Boot loader has been fixed. Here is my explanation :flexed_biceps: :grin: :smiling_face_with_sunglasses: :laptop: :penguin: :waving_hand: :+1:
Based on https://dev.to/patfinder/repair-grub-linuxwindows-dual-boot-23ki
# Investigate computer partitions
# Vraag de partities in de computer op :
# Met fdisk
fdisk -l
# Met blkid
blkid
# Met lsblk
lsblk
# Mount your partitions
mount /dev/nvme0n1p7 /mnt
for i in /sys /proc /run /dev; do mount --rbind "$i" "/mnt$i"; done
mount /dev/nvme0n1p7 /mnt/boot/efi
# Change root
# Stap over naar de harddisk, waarop Linux is geinstalleerd. Hij die gerepareerd wil worden.
chroot /mnt
# Video settings quest
# investigate with envycontrol
# opvragen met envycontrol
envycontrol --query
# envycontrol --reset
envycontrol --reset
envycontrol --query
# I decided to change back to nvidia. Which worked well before
Als er niets veranderd, dan terug naar nvidia
# envycontrol -s nvidia
# Check if efi is present
blkid | grep -i efi
# Check if efi is present in /etc/fstab
grep -i efi /etc/fstab
# Update GRUB met : update-grub
update-grub
# Change root to Linux Live on USB
# Exit chroot
exit
# Exit root terminal
exit
# Reboot computer, by shutting down the computer, using the mouse in the Linux menu
I did try the result. Succes ! No need to do a grub-install /dev/nvme0n1
Solution above is also available on my own Dutch website : https://www.linuxzob.nl/wiki/doku.php?id=linux_beheer:bootrepair#linux_boot_repair_-_2026_reparatie_manjaro_cinnamon
