i don’t found any option to add my RDP server to remmina
here is my screenshot have a look. and please tell me how to connect to my RDP server?
Looks like you use a GTK version without CSD (client side decorations). The Button to add a connection is only available if you use a standard GTK package with CSD.
A shortcut to solve this can be mouse right click on the remmina minimized icon in the lower right corner, a “new connection” option appears.
Another option is to call freerdp directly using a script
How to execute this script, i am new to manjaro can you please help me with simple guide?
I have updated the linked topic to include this
Ensure you have the folder ~/.local/bin
mkdir -p ~/.local/bin
Create a new file in the folder and paste the content from template into the new file.
Save it using a meaningfull name e.g. a nickname for the device you are connecting to.
Then adjust the properties at the top of the script - just below the header - to match your connection and save the file.
Make the file executable
chmod +x ~/.local/bin/nickname
Then you can execute from commandline
nickname
If you want an icon to click create a desktop file in ~/.local/share/applications/nickname.desktop with content
[Desktop Entry]
Name=nickname RDP
Icon=network-server
Comment=Connect to nickname RDP
Exec="~/.local/bin/nickname"
Version=1.0
Type=Application
Terminal=false
StartupNotify=true
