I’m obviously not doing something correctly. I tried adding the UUID and mount points found when doing running blkid in terminal but once I save fstab the drives disappear. However, I’m curious if maybe I’m getting the mount points wrong as the disks are located in my /run/media/user folder.
This is also on a fresh install of Manjaro and I switched to XFCE from GNOME. Not sure if that would cause any issues.
Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=a3cde39f-540a-457b-b2ee-44fd0a0413ce rw quiet splash apparmor=1
security=apparmor resume=UUID=5a38419e-ab7f-434a-b717-dc89aec9799f
udev.log_priority=3
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Gigabyte product: AB350-Gaming v: N/A
serial: <superuser required>
Mobo: Gigabyte model: AB350-Gaming-CF v: x.x serial: <superuser required>
uuid: <superuser required> UEFI-[Legacy]: American Megatrends v: F21
date: 02/08/2018
System RAM: total: 16 GiB available: 15.57 GiB used: 3.47 GiB (22.3%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
part-no: UD4-3000 serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001129
smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1550 min/max: 1550/3200 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1550 2: 1550 3: 1550
4: 1550 5: 1550 6: 1550 7: 1550 8: 1550 9: 1550 10: 1550 11: 1550 12: 1550
bogomips: 76669
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm
lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit
smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm
svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif
vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
driver: nouveau v: kernel non-free: 550/565.xx+ status: current (as of
2025-01; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: DVI-D-1,HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 08:00.0 chip-ID: 10de:1c02 class-ID: 0300 temp: 53.0 C
Display: x11 server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
compositor: xfwm4 v: 4.20.0 driver: X: loaded: modesetting
alternate: fbdev,vesa dri: nouveau gpu: nouveau display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: DVI-D-1 pos: primary,left model: Acer G277HL serial: <filter>
built: 2018 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
chroma: red: x: 0.639 y: 0.337 green: x: 0.314 y: 0.624 blue: x: 0.149
y: 0.063 white: x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 640x480,
720x400
Monitor-2: HDMI-A-1 mapped: HDMI-1 pos: right model: Acer SA241Y
serial: <filter> built: 2023 res: mode: 1920x1080 hz: 75 scale: 100% (1)
dpi: 93 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green: x: 0.329 y: 0.612
blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
modes: 1920x1080, 1920x1080i, 1680x1050, 1280x1024, 1440x900, 1280x800,
1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.3.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: NV136 device-ID: 10de:1c02 memory: 2.91 GiB
unified: no
Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
x11: xprop,xrandr
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 08:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
API: ALSA v: k6.12.17-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter
driver: bcma-pci-bridge v: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 07:00.0 chip-ID: 14e4:43a0 class-ID: 0280
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0b05:190e
Local Storage: total: 3.47 TiB used: 2.7 TiB (77.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD20EZAZ-00L9GB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3500312CS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5900 serial: <filter> fw-rev: CA12 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 EVO 1TB
ID-5: /dev/sde maj-min: 8:64 vendor: SanDisk model: Cruzer Glide
size: 58.46 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
fw-rev: 1.27 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH30N rev: A201
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 215.76 GiB size: 211.31 GiB (97.94%)
used: 20.38 GiB (9.6%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: a3cde39f-540a-457b-b2ee-44fd0a0413ce
ID-2: /run/media/nicholas/fourth-disk raw-size: 931.51 GiB
size: 915.82 GiB (98.31%) used: 853.32 GiB (93.2%) fs: ext4 dev: /dev/sdd
maj-min: 8:48 label: fourth-disk
uuid: 1be4d25b-4ff6-40b0-a5c7-dfe6cc409b83
ID-3: /run/media/nicholas/second disk raw-size: 434.51 GiB
size: 426.62 GiB (98.18%) used: 257.67 GiB (60.4%) fs: ext4 dev: /dev/sdc2
maj-min: 8:34 label: second disk
uuid: 1ec047b4-ec64-4d28-8893-f16ad7899256
ID-4: /run/media/nicholas/third-disk raw-size: 1.82 TiB
size: 1.79 TiB (98.37%) used: 1.59 TiB (89.1%) fs: ext4 dev: /dev/sda
maj-min: 8:0 label: third-disk uuid: 31f2d06a-293c-46c3-9216-27dc993cfb4e
ID-1: swap-1 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18 label: swap
uuid: 5a38419e-ab7f-434a-b717-dc89aec9799f
ID-1: /dev/sdc1 maj-min: 8:33 size: 31.25 GiB fs: swap label: N/A
uuid: 14863704-322a-453c-b7a5-87bba34bb094
ID-2: /dev/sde1 maj-min: 8:65 size: 3.63 GiB fs: iso9660
ID-3: /dev/sde2 maj-min: 8:66 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 9D59-BEAA
Device-1: 1-1:2 info: ASUSTek ASUS USB-BT500 type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
Device-2: 1-3:3 info: SanDisk Cruzer Glide type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 0781:5575 class-ID: 0806
serial: <filter>
Device-1: 3-3:6 info: Logitech G502 Proteus Spectrum Optical Mouse
type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
chip-ID: 046d:c332 class-ID: 0300 serial: <filter>
Device-2: 3-4:7 info: Ducky One 3̠ type: HID,keyboard,mouse
driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:1011 class-ID: 0300
serial: <filter>
Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 39.2 C mobo: N/A gpu: nouveau temp: 53.0 C
Fan Speeds (rpm): N/A gpu: nouveau fan: 0
Packages: pm: pacman pkgs: 1163 libs: 389 tools: pamac pm: flatpak pkgs: 0
1: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
2: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 371
1: cpu: 14.0% command: firefox pid: 2272 mem: 511.7 MiB (3.2%)
2: cpu: 6.7% command: Xorg pid: 948 mem: 132.7 MiB (0.8%)
3: cpu: 6.4% command: Thunar pid: 1187 mem: 68.1 MiB (0.4%)
4: cpu: 3.4% command: [kworker/u49:0-events_unbound] pid: 91
mem: 0.00 MiB (0.0%)
5: cpu: 3.4% command: [kworker/u50:1-events_unbound] pid: 3991
Memory top: 5 of 371
1: mem: 511.7 MiB (3.2%) command: firefox pid: 2272 cpu: 14.0%
2: mem: 428.9 MiB (2.6%) command: steamwebhelper pid: 1970 cpu: 1.4%
3: mem: 352.2 MiB (2.2%) command: ./steamwebhelper pid: 1898 cpu: 1.2%
4: mem: 265.8 MiB (1.6%) command: firefox pid: 3625 cpu: 2.1%
5: mem: 257.7 MiB (1.6%) command: firefox pid: 3056 cpu: 3.2%
Processes: 371 Power: uptime: 21m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: upowerd,xfce4-power-manager
Compilers: N/A Shell: Bash v: 5.2.37 running-in: xfce4-terminal
inxi: 3.3.37
