This not working now ((
buildiso -p my-kde -t /mybuild
==> ERROR: my-kde is not a valid profile or build list!
==> ERROR: Profile [/usr/share/manjaro-tools/iso-profiles//my-kde] sanity check failed!
I changed the parameters of the partitions in the /desktop-overlay/etc/calamares/modules/ directory, but after building the ISO image nothing was saved. How to modify Calamares?
I want to add packages locally to an ISO image that I build via isobuild, how can I do this?
I have collected several AUR packages and now I want to add the manjaro image to the ISO using buildiso, but the manjaro website says that for this you need to upload packages to the server, but how can I add packages locally, what should I write in pacman.conf?
Pacman Overview - Manjaro
Pacman can also directly install packages from the local system or a location on the internet. The format of that command ispacman -U packagelocation. For example, to install a copy of your package cache you could do something like:sudo pacman -U /var/cache/pacman/pkg/smplayer-19.5.0-1-x86_64.pkg.tar.xz
Or
pamac install /var/cache/pacman/pkg/smplayer-19.5.0-1-x86_64.pkg.tar.xz
And how will this help me to add a package when building Manjaro ISO ??
I’m building a Manjaro ISO using buildiso, I need to add packages to the ISO.
Perhaps this will help:
Read my first message again carefully.
Mne ne podkhodit to chto tam napisano v wiki , mne nuzhen sposob lokal’no dobavit’ paket v ISO obraz
What’s written in the wiki doesn’t suit me, I need a way to locally add the package to the ISO image
I think the point was that you can build a package from the AUR source. Once you have those packages, you can do what you like with them; place them on your ISO, if you like, and perhaps script some commands to install them.
That is all. Good luck.
You can have a local repo in pacman.conf, but buildpkg uses a different file, it may (or may not) be able to handle a local repo.
https://wiki.archlinux.org/title/Pacman/Tips_and_tricks#Custom_local_repository
EDIT:
I used to be able to read better. ![]()
I have this manjaro ISO builder code:
chroot_create(){
msg “Creating chroot for [%s] (%s)…” “${target_branch}” “${target_arch}”
mkdir -p “${work_dir}”
df -h “${work_dir}”
mkchroot_args+=(-L)
setarch “${target_arch}”
mkchroot ${mkchroot_args[]}
“${work_dir}/root”
${base_packages[]} || abort
Where can I add my own command so that it can be executed in Chroot?
I have already collected the packages.
How do I put them in an ISO?
Please keep your questions in one thread. Thanks.
Scroll up.
full code
chroot_create(){
msg "Creating chroot for [%s] (%s)..." "${target_branch}" "${target_arch}"
mkdir -p "${work_dir}"
df -h "${work_dir}"
mkchroot_args+=(-L)
setarch "${target_arch}" \
mkchroot ${mkchroot_args[*]} \
"${work_dir}/root" \
${base_packages[*]} || abort
chroot_clean(){
msg "Cleaning chroot for [%s] (%s)..." "${target_branch}" "${target_arch}"
for copy in "${work_dir}"/*; do
[[ -d ${copy} ]] || continue
msg2 "Deleting chroot copy %s ..." "$(basename "${copy}")"
lock 9 "${copy}.lock" "Locking chroot copy '${copy}'"
subvolume_delete_recursive "${copy}"
rm -rf --one-file-system "${copy}"
done
exec 9>&-
rm -rf --one-file-system "${work_dir}"
chroot_update(){
msg "Updating chroot for [%s] (%s)..." "${target_branch}" "${target_arch}"
chroot-run ${mkchroot_args[*]} \
"${work_dir}/${OWNER}" \
pacman -Syu --noconfirm || abort
How to add your own command so that it runs in a chroot ?
The code you posted is not complete, it’s just 3 function definitions. However if you read it you might notice something that looks like a command being run in a chroot. ![]()
But when I added my commands there, they were simply skipped and not executed
This is the code from buildiso manjaro itself
[[ -r ${LIBDIR}/util-msg.sh ]] && source ${LIBDIR}/util-msg.sh
import ${LIBDIR}/util.sh
show_profile(){
prepare_profile "$1"
msg2 "iso_file: %s" "${iso_file}"
msg2 "iso_label: %s" "${iso_label}"
if ${verbose}; then
msg2 "autologin: %s" "${autologin}"
msg2 "nonfree_mhwd: %s" "${nonfree_mhwd}"
[[ ${target_arch} == 'x86_64' ]] && msg2 "multilib: %s" "${multilib}"
msg2 "extra: %s" "${extra}"
msg2 "office_installer: %s" "${office_installer}"
msg2 "permalink: %s" "${permalink}"
msg2 "netinstall: %s" "${netinstall}"
msg2 "chrootcfg: %s" "${chrootcfg}"
${netinstall} && msg2 "netgroups: %s" "$(get_yaml)"
msg2 "geoip: %s" "${geoip}"
msg2 "oem_used: %s" "${oem_used}"
msg2 "efi_boot_loader: %s" "${efi_boot_loader}"
msg2 "custom_boot_args: %s" "${custom_boot_args}"
msg2 "hostname: %s" "${hostname}"
msg2 "username: %s" "${username}"
msg2 "password: %s" "${password}"
msg2 "user_shell: %s" "${user_shell}"
msg2 "login_shell: %s" "${login_shell}"
msg2 "addgroups: %s" "${addgroups}"
[[ -n ${smb_workgroup} ]] && msg2 "smb_workgroup: %s" "${smb_workgroup}"
msg2 "enable_systemd: %s" "${enable_systemd[*]}"
msg2 "enable_systemd_timers: %s" "${enable_systemd_timers[*]}"
msg2 "enable_systemd_live: %s" "${enable_systemd_live[*]}"
[[ -n ${disable_systemd[*]} ]] && msg2 "disable_systemd: %s" "${disable_systemd[*]}"
msg2 "strict_snaps: %s" "${strict_snaps}"
msg2 "classic_snaps: %s" "${classic_snaps}"
msg2 "snap_channel: %s" "${snap_channel}"
fi
reset_profile
display_settings(){
show_version
show_config
msg "PROFILE:"
msg2 "gitlab branch: %s" "${branch}"
msg2 "build_lists: %s" "$(show_build_lists ${list_dir_iso})"
msg2 "build_list_iso: %s" "${build_list_iso}"
msg2 "is_build_list: %s" "${is_build_list}"
msg "OPTIONS:"
msg2 "arch: %s" "${target_arch}"
msg2 "branch: %s" "${target_branch}"
msg2 "kernel: %s" "${kernel}"
[[ -n ${gpgkey} ]] && msg2 "gpgkey: %s" "${gpgkey}"
msg "ARGS:"
msg2 "clean_first: %s" "${clean_first}"
msg2 "images_only: %s" "${images_only}"
msg2 "iso_only: %s" "${iso_only}"
msg2 "persist: %s" "${persist}"
msg2 "extra: %s" "${full_iso}"
# msg2 "office_installer: %s" "pacman-key --recv-key 3056513887B78AEB --keyserver keyserver.ubuntu.com"
# msg2 "office_installer: %s" "pacman-key --lsign-key 3056513887B78AEB"
msg "DIST SETTINGS:"
msg2 "dist_name: %s" "${dist_name}"
msg2 "dist_release: %s" "${dist_release}"
msg2 "dist_codename: %s" "${dist_codename}"
msg "ISO INFO:"
msg2 "iso_compression: %s" "${iso_compression}"
msg "BUILD QUEUE:"
run show_profile "${build_list_iso}"
# $1: section
parse_section() {
local is_section=0
while read line; do
[[ $line =~ ^\ {0,}# ]] && continue
[[ -z "$line" ]] && continue
if [ $is_section == 0 ]; then
if [[ $line =~ ^\[.*?\] ]]; then
line=${line:1:$((${#line}-2))}
section=${line// /}
if [[ $section == $1 ]]; then
is_section=1
continue
fi
continue
fi
elif [[ $line =~ ^\[.*?\] && $is_section == 1 ]]; then
break
else
pc_key=${line%%=*}
pc_key=${pc_key// /}
pc_value=${line##*=}
pc_value=${pc_value## }
eval "$pc_key='$pc_value'"
fi
done < "$2"
get_repos() {
local section repos=() filter='^\ {0,}#'
while read line; do
[[ $line =~ "${filter}" ]] && continue
section=${line// /}
case ${section} in
"options") continue ;;
*) repos+=("${section}") ;;
esac
fi
done < "$1"
echo ${repos[@]}
check_user_repos_conf(){
local repositories=$(get_repos "$1") uri='file://'
for repo in ${repositories[@]}; do
msg2 "parsing repo [%s] ..." "${repo}"
parse_section "${repo}" "$1"
[[ ${pc_value} == $uri* ]] && die "Using local repositories is not supported!"
done
get_pac_mirrors_conf(){
local conf="$tmp_dir/pacman-mirrors-$1.conf"
cp "${DATADIR}/pacman-mirrors.conf" "$conf"
sed -i "$conf" \
-e "s|Branch = stable|Branch = $1|"
echo "$conf"
read_build_list(){
local _space="s| ||g" \
_clean=':a;N;$!ba;s/\n/ /g' \
_com_rm="s|#.*||g"
build_list=$(sed "$_com_rm" "$1.list" \
| sed "$_space" \
| sed "$_clean")
# $1: list_dir
show_build_lists(){
local list temp
for item in $(ls $1/*.list); do
temp=${item##*/}
list=${list:-}${list:+|}${temp%.list}
done
echo $list
# $1: make_conf_dir
show_build_profiles(){
local cpuarch temp
for item in $(ls $1/*.conf); do
temp=${item##*/}
cpuarch=${cpuarch:-}${cpuarch:+|}${temp%.conf}
done
echo $cpuarch
# $1: list_dir
# $2: build list
eval_build_list(){
eval "case $2 in
$(show_build_lists $1)) is_build_list=true; read_build_list $1/$2 ;;
*) is_build_list=false ;;
esac"
in_array() {
local needle=$1; shift
local item
for item in "$@"; do
[[ $item = $needle ]] && return 0 # Found
done
return 1 # Not Found
get_timer(){
echo $(date +%s)
# $1: start timer
elapsed_time(){
echo $(echo $1 $(get_timer) | awk '{ printf "%0.2f",($2-$1)/60 }')
show_elapsed_time(){
info "Time %s: %s minutes" "$1" "$(elapsed_time $2)"
lock() {
eval "exec $1>"'"$2"'
if ! flock -n $1; then
stat_busy "$3"
flock $1
stat_done
fi
slock() {
if ! flock -sn $1; then
stat_busy "$3"
flock -s $1
stat_done
fi
check_root() {
(( EUID == 0 )) && return
if type -P sudo >/dev/null; then
exec sudo -- "$@"
else
exec su root -c "$(printf ' %q' "$@")"
fi
copy_mirrorlist(){
cp -a /etc/pacman.d/mirrorlist "$1/etc/pacman.d/"
copy_keyring(){
if [[ -d /etc/pacman.d/gnupg ]] && [[ ! -d $1/etc/pacman.d/gnupg ]]; then
cp -a /etc/pacman.d/gnupg "$1/etc/pacman.d/"
fi
load_vars() {
local var
[[ -f $1 ]] || return 1
for var in {SRC,SRCPKG,PKG,LOG}DEST MAKEFLAGS PACKAGER CARCH GPGKEY; do
[[ -z ${!var} ]] && eval $(grep -a "^${var}=" "$1")
done
return 0
prepare_dir(){
if [[ ! -d $1 ]]; then
mkdir -p $1
fi
# $1: chroot
get_branch(){
echo $(cat "$1/etc/pacman-mirrors.conf" | grep '^Branch = ' | sed 's/Branch = \s*//g')
# $1: chroot
# $2: branch
set_branch(){
if [[ $1 =~ "rootfs" ]]; then
info "Setting mirrorlist branch: %s" "$2"
sed -e "s|/stable|/$2|g" -i "$1/etc/pacman.d/mirrorlist"
fi
init_common(){
[[ -z ${target_branch} ]] && target_branch='stable'
[[ -z ${target_arch} ]] && target_arch=$(uname -m)
[[ -z ${cache_dir} ]] && cache_dir='/var/cache/manjaro-tools'
[[ -z ${chroots_dir} ]] && chroots_dir='/var/lib/manjaro-tools'
[[ -z ${log_dir} ]] && log_dir='/var/log/manjaro-tools'
[[ -z ${build_mirror} ]] && build_mirror='https://mirror.easyname.at/manjaro'
[[ -z ${tmp_dir} ]] && tmp_dir='/tmp/manjaro-tools'
init_buildtree(){
tree_dir=${cache_dir}/pkgtree
tree_dir_abs=${tree_dir}/packages-archlinux
[[ -z ${repo_tree[@]} ]] && repo_tree=('core' 'extra' 'community' 'multilib')
[[ -z ${host_tree} ]] && host_tree='https://github.com/manjaro'
[[ -z ${host_tree_abs} ]] && host_tree_abs='https://projects.archlinux.org/git/svntogit'
init_buildpkg(){
chroots_pkg="${chroots_dir}/buildpkg"
list_dir_pkg="${SYSCONFDIR}/pkg.list.d"
make_conf_dir="${SYSCONFDIR}/make.conf.d"
[[ -d ${USERCONFDIR}/pkg.list.d ]] && list_dir_pkg=${USERCONFDIR}/pkg.list.d
[[ -z ${build_list_pkg} ]] && build_list_pkg='default'
cache_dir_pkg=${cache_dir}/pkg
get_iso_label(){
local label="$1"
#label="${label//_}" # relace all _
label="${label//-}" # relace all -
label="${label^^}" # all uppercase
label="${label::32}" # limit to 32 characters
echo ${label}
get_codename(){
source /home/jeegrobot/ISO-Build/lsb-release
echo "${DISTRIB_CODENAME}"
get_release(){
echo "${DISTRIB_RELEASE}"
get_distname(){
echo "${DISTRIB_ID%Linux}"
get_distid(){
echo "${DISTRIB_ID}"
get_disturl(){
source /home/jeegrobot/ISO-Build/os-release
echo "${HOME_URL}"
get_osname(){
echo "${NAME}"
get_osid(){
echo "${ID}"
init_buildiso(){
chroots_iso="${chroots_dir}/buildiso"
list_dir_iso="${SYSCONFDIR}/iso.list.d"
[[ -d ${USERCONFDIR}/iso.list.d ]] && list_dir_iso=${USERCONFDIR}/iso.list.d
[[ -z ${build_list_iso} ]] && build_list_iso='default'
cache_dir_iso="${cache_dir}/iso"
profile_repo='iso-profiles'
##### iso settings #####
[[ -z ${dist_release} ]] && dist_release=$(get_release)
[[ -z ${dist_codename} ]] && dist_codename=$(get_codename)
dist_name=$(get_distname)
iso_name=$(get_osid)
[[ -z ${dist_branding} ]] && dist_branding="SHEFOS"
[[ -z ${iso_compression} ]] && iso_compression='zstd'
[[ -z ${kernel} ]] && kernel="linux66"
load_run_dir "${profile_repo}"
if [[ -d ${run_dir}/.git ]]; then
current_path=$(pwd)
cd ${run_dir}
branch=$(git rev-parse --abbrev-ref HEAD)
cd ${current_path}
else
[[ -z ${branch} ]] && branch="v18.0" #current branch release
fi
[[ -z ${gpgkey} ]] && gpgkey=''
mhwd_repo="/opt/mhwd/pkg"
init_calamares(){
[[ -z ${welcomestyle} ]] && welcomestyle=false
[[ -z ${welcomelogo} ]] && welcomelogo=true
[[ -z ${windowexp} ]] && windowexp=noexpand
[[ -z ${windowsize} ]] && windowsize="800px,560px"
[[ -z ${windowplacement} ]] && windowplacement="center"
[[ -z ${sidebarbackground} ]] && sidebarbackground=#454948
[[ -z ${sidebartext} ]] && sidebartext=#efefef
[[ -z ${sidebartextselect} ]] && sidebartextselect=#4d915e
[[ -z ${sidebartexthighlight} ]] && sidebartexthighlight=#1a1c1b
init_deployiso(){
host="osdn.net"
[[ -z ${account} ]] && account="[SetUser]"
[[ -z ${alt_storage} ]] && alt_storage=false
[[ -z ${tracker_url} ]] && tracker_url='udp://tracker.opentrackr.org:1337'
[[ -z ${piece_size} ]] && piece_size=21
torrent_meta="$(get_distid)"
load_config(){
manjaro_tools_conf="$1"
[[ -r ${manjaro_tools_conf} ]] && source ${manjaro_tools_conf}
init_common
init_buildtree
init_buildpkg
init_buildiso
init_calamares
init_deployiso
return 0
load_profile_config(){
profile_conf="$1"
[[ -r ${profile_conf} ]] && source ${profile_conf}
[[ -z ${displaymanager} ]] && displaymanager="none"
[[ -z ${autologin} ]] && autologin="true"
[[ ${displaymanager} == 'none' ]] && autologin="false"
[[ -z ${snap_channel} ]] && snap_channel="stable"
[[ -z ${multilib} ]] && multilib="true"
[[ ${no_multilib} == 'true' ]] && multilib="false"
[[ -z ${nonfree_mhwd} ]] && nonfree_mhwd="true"
[[ -z ${efi_boot_loader} ]] && efi_boot_loader="grub"
[[ -z ${hostname} ]] && hostname="ShefOS"
[[ -z ${username} ]] && username="shefos"
[[ -z ${password} ]] && password="shefos"
[[ -z ${user_shell} ]] && user_shell='/bin/bash'
[[ -z ${login_shell} ]] && login_shell='/bin/bash'
if [[ -z ${addgroups} ]]; then
addgroups="lp,network,power,sys,wheel"
fi
if [[ -z ${enable_systemd[@]} ]]; then
enable_systemd=('avahi-daemon' 'bluetooth' 'cronie' 'ModemManager' 'NetworkManager' 'org.cups.cupsd' 'tlp' 'tlp-sleep' 'ufw')
fi
[[ -z ${disable_systemd[@]} ]] && disable_systemd=('pacman-init')
if [[ -z ${enable_systemd_live[@]} ]]; then
enable_systemd_live=('manjaro-live' 'mhwd-live' 'pacman-init' 'mirrors-live')
fi
if [[ ${displaymanager} != "none" ]]; then
enable_systemd+=("${displaymanager}")
fi
[[ -z ${needs_internet} ]] && needs_internet='false'
[[ -z ${netinstall} ]] && netinstall='false'
[[ -z ${netinstall_label} ]] && netinstall_label='Package selection'
[[ -z ${mhwd_used} ]] && mhwd_used='true'
[[ -z ${oem_used} ]] && oem_used='false'
[[ -z ${set_oem_user} ]] && set_oem_user='true'
[[ -z ${chrootcfg} ]] && chrootcfg='false'
netgroups="https://gitlab.manjaro.org/applications/calamares-netgroups/-/raw/master/"
[[ -z ${geoip} ]] && geoip='true'
[[ -z ${smb_workgroup} ]] && smb_workgroup=''
[[ -z ${extra} ]] && extra='false'
[[ ${full_iso} ]] && extra='true'
basic='true'
[[ ${extra} == 'true' ]] && basic='false'
[[ -z ${office_installer} ]] && office_installer="false"
return 0
get_edition(){
local result=$(find ${run_dir} -maxdepth 2 -name "$1") path
[[ -z $result ]] && die "%s is not a valid profile or build list!" "$1"
path=${result%/*}
echo ${path##*/}
get_project(){
case "${edition}" in
'manjaro')
project="manjaro"
'community')
project="manjaro-community"
esac
echo "${project}"
reset_profile(){
unset displaymanager
unset strict_snaps
unset classic_snaps
unset snap_channel
unset autologin
unset multilib
unset nonfree_mhwd
unset efi_boot_loader
unset hostname
unset username
unset password
unset addgroups
unset enable_systemd
unset disable_systemd
unset enable_systemd_live
unset disable_systemd_live
unset packages_desktop
unset packages_mhwd
unset user_shell
unset login_shell
unset netinstall
unset chrootcfg
unset geoip
unset extra
unset full_iso
unset office_installer
unset no_multilib
check_profile(){
local keyfiles=("$1/Packages-Root"
"$1/Packages-Live")
local keydirs=("$1/root-overlay"
"$1/live-overlay")
local has_keyfiles=false has_keydirs=false
for f in ${keyfiles[@]}; do
if [[ -f $f ]]; then
has_keyfiles=true
else
has_keyfiles=false
break
fi
done
for d in ${keydirs[@]}; do
if [[ -d $d ]]; then
has_keydirs=true
else
has_keydirs=false
break
fi
done
if ! ${has_keyfiles} && ! ${has_keydirs}; then
die "Profile [%s] sanity check failed!" "$1"
fi
[[ -f "$1/Packages-Desktop" ]] && packages_desktop=$1/Packages-Desktop
[[ -f "$1/Packages-Mhwd" ]] && packages_mhwd=$1/Packages-Mhwd
if ! ${netinstall}; then
chrootcfg="false"
fi
# $1: file name
load_pkgs(){
info "Loading Packages: [%s] ..." "${1##*/}"
local _multi _nonfree_default _nonfree_multi _arch _arch_rm _nonfree_i686 _nonfree_x86_64 _basic _basic_rm _extra _extra_rm
if ${basic}; then
_basic="s|>basic||g"
else
_basic_rm="s|>basic.*||g"
fi
if ${extra}; then
_extra="s|>extra||g"
else
_extra_rm="s|>extra.*||g"
fi
case "${target_arch}" in
"i686")
_arch="s|>i686||g"
_arch_rm="s|>x86_64.*||g"
_multi="s|>multilib.*||g"
_nonfree_multi="s|>nonfree_multilib.*||g"
_nonfree_x86_64="s|>nonfree_x86_64.*||g"
if ${nonfree_mhwd}; then
_nonfree_default="s|>nonfree_default||g"
_nonfree_i686="s|>nonfree_i686||g"
else
_nonfree_default="s|>nonfree_default.*||g"
_nonfree_i686="s|>nonfree_i686.*||g"
fi
_arch="s|>x86_64||g"
_arch_rm="s|>i686.*||g"
if ${multilib}; then
_multi="s|>multilib||g"
_nonfree_x86_64="s|>nonfree_x86_64||g"
_nonfree_multi="s|>nonfree_multilib||g"
else
fi
else
else
fi
fi
esac
# We can reuse this code
local _edition _edition_rm
'sonar')
_edition="s|>sonar||g"
_edition_rm="s|>manjaro.*||g"
_edition="s|>manjaro||g"
_edition_rm="s|>sonar.*||g"
esac
local _office _office_rm
if ${office_installer}; then
_office="s|>office||g"
else
_office_rm="s|>office.*||g"
fi
local _blacklist="s|>blacklist.*||g" \
_kernel="s|KERNEL|$kernel|g" \
_used_kernel=${kernel:5:2} \
_space="s| ||g" \
_com_rm="s|#.*||g" \
_purge="s|>cleanup.*||g" \
_purge_rm="s|>cleanup||g"
packages=$(sed "$_com_rm" "$1" \
| sed "$_space" \
| sed "$_blacklist" \
| sed "$_purge" \
| sed "$_arch" \
| sed "$_arch_rm" \
| sed "$_nonfree_default" \
| sed "$_multi" \
| sed "$_nonfree_i686" \
| sed "$_nonfree_x86_64" \
| sed "$_nonfree_multi" \
| sed "$_kernel" \
| sed "$_edition" \
| sed "$_edition_rm" \
| sed "$_basic" \
| sed "$_basic_rm" \
| sed "$_extra" \
| sed "$_extra_rm" \
| sed "$_office" \
| sed "$_office_rm" \
| sed "$_clean")
if [[ $1 == "${packages_mhwd}" ]]; then
[[ ${_used_kernel} < "42" ]] && local _amd="s|xf86-video-amdgpu||g"
packages_cleanup=$(sed "$_com_rm" "$1" \
| grep cleanup \
| sed "$_purge_rm" \
| sed "$_kernel" \
| sed "$_clean" \
| sed "$_amd")
fi
user_own(){
local flag=$2
chown ${flag} "${OWNER}:$(id --group ${OWNER})" "$1"
clean_dir(){
if [[ -d $1 ]]; then
msg "Cleaning [%s] ..." "$1"
rm -r $1/*
fi
write_repo_conf(){
local repos=$(find $USER_HOME -type f -name "repo_info")
local path name
[[ -z ${repos[@]} ]] && run_dir=${DATADIR}/iso-profiles && return 1
for r in ${repos[@]}; do
path=${r%/repo_info}
name=${path##*/}
echo "run_dir=$path" > ${USERCONFDIR}/$name.conf
done
load_user_info(){
OWNER=${SUDO_USER:-$USER}
if [[ -n $SUDO_USER ]]; then
eval "USER_HOME=~$SUDO_USER"
else
USER_HOME=$HOME
fi
USERCONFDIR="$USER_HOME/.config/manjaro-tools"
prepare_dir "${USERCONFDIR}"
load_run_dir(){
[[ -f ${USERCONFDIR}/$1.conf ]] || write_repo_conf
[[ -r ${USERCONFDIR}/$1.conf ]] && source ${USERCONFDIR}/$1.conf
return 0
show_version(){
msg "manjaro-tools"
msg2 "version: %s" "${version}"
show_config(){
if [[ -f ${USERCONFDIR}/manjaro-tools.conf ]]; then
msg2 "config: %s" "~/.config/manjaro-tools/manjaro-tools.conf"
else
msg2 "config: %s" "${manjaro_tools_conf}"
fi
# $1: chroot
kill_chroot_process(){
# enable to have more debug info
#msg "machine-id (etc): $(cat $1/etc/machine-id)"
#[[ -e $1/var/lib/dbus/machine-id ]] && msg "machine-id (lib): $(cat $1/var/lib/dbus/machine-id)"
#msg "running processes: "
#lsof | grep $1
local prefix="$1" flink pid name
for root_dir in /proc/*/root; do
flink=$(readlink $root_dir)
if [ "x$flink" != "x" ]; then
if [ "x${flink:0:${#prefix}}" = "x$prefix" ]; then
# this process is in the chroot...
pid=$(basename $(dirname "$root_dir"))
name=$(ps -p $pid -o comm=)
info "Killing chroot process: %s (%s)" "$name" "$pid"
kill -9 "$pid"
fi
fi
done
create_min_fs(){
msg "Creating install root at %s" "$1"
mkdir -m 0755 -p $1/var/{cache/pacman/pkg,lib/pacman,log} $1/{dev,run,etc}
mkdir -m 1777 -p $1/tmp
mkdir -m 0555 -p $1/{sys,proc}
is_valid_arch_pkg(){
eval "case $1 in
$(show_build_profiles "${make_conf_dir}")) return 0 ;;
*) return 1 ;;
esac"
is_valid_arch_iso(){
case $1 in
'i686'|'x86_64') return 0 ;;
*) return 1 ;;
esac
is_valid_branch(){
case $1 in
'stable'|'stable-staging'|'testing'|'unstable') return 0 ;;
*) return 1 ;;
esac
is_valid_comp(){
case $1 in
'gzip'|'lzma'|'lz4'|'lzo'|'xz'|'zstd') return 0 ;;
*) return 1 ;;
esac
run(){
if ${is_build_list}; then
for item in ${build_list[@]}; do
$1 $item
done
else
$1 $2
fi
is_btrfs() {
[[ -e "$1" && "$(stat -f -c %T "$1")" == btrfs ]]
subvolume_delete_recursive() {
local subvol
is_btrfs "$1" || return 0
while IFS= read -d $'\0' -r subvol; do
if ! btrfs subvolume delete "$subvol" &>/dev/null; then
error "Unable to delete subvolume %s" "$subvol"
return 1
fi
done < <(find "$1" -xdev -depth -inum 256 -print0)
return 0
create_chksums() {
msg2 "creating checksums for [$1]"
sha1sum $1 > $1.sha1
sha256sum $1 > $1.sha256
init_profiles() {
_workdir='/usr/share/manjaro-tools'
if [[ -d ${_workdir}/iso-profiles ]]; then
rm -Rf ${_workdir}/iso-profiles
fi
git clone -q --depth 1 -b ${branch} https://gitlab.manjaro.org/profiles-and-settings/iso-profiles.git ${_workdir}/iso-profiles/
#Check if git clone is done
if [[ -d ${_workdir}/iso-profiles/manjaro ]] && [[ -d ${_workdir}/iso-profiles/community ]]; then
for i in ${_workdir}/iso-profiles/.gitignore ${_workdir}/iso-profiles/README.md; do
rm -f $i
done
for i in ${_workdir}/iso-profiles/.git ${_workdir}/iso-profiles/sonar; do
rm -Rf $i
done
else msg2 "Impossible to initialize iso-profiles, please check internet connection or browse at 'https://gitlab.manjaro.org/profiles-and-settings/iso-profiles'"
exit 1
fi
Well without seeing it, I couldn’t say why.
There’s a reason I said “looks like”. I haven’t seen chroot-run before, perhaps it’s not what it seems.
EDIT:
Sorry, I didn’t mean we needed it all (was just being pedantic really), if it’s available online we can find it.
I haven’t used buildiso in years, but last time I edited it so I could supply more than one local package. I can’t remember enough to help with that and can’t find any docs about that functionality atm, it may have changed.
There are several more files there that are managed by buildiso, but these are the main ones, tell me where I can insert my code for execution in the chroot
This is the complete code of the file where we are talking about chroot
load_compiler_settings(){
local tarch="$1" conf
conf=${make_conf_dir}/$tarch.conf
[[ -f $conf ]] || return 1
info "Loading compiler settings: %s" "$tarch"
source $conf
return 0
get_makepkg_conf(){
local conf="${tmp_dir}/makepkg-$1.conf"
cp "${DATADIR}/makepkg.conf" "$conf"
load_compiler_settings "$1"
sed -i "$conf" \
-e "s|@CARCH[@]|$carch|g" \
-e "s|@CHOST[@]|$chost|g" \
-e "s|@CFLAGS[@]|$cflags|g"
echo "$conf"
# $1: target_arch
prepare_conf(){
if ! is_valid_arch_pkg "$1"; then
die "%s is not a valid arch!" "$1"
fi
local pac_arch='default'
if [[ "$1" == 'multilib' ]]; then
pac_arch='multilib'
is_multilib=true
fi
pacman_conf="${DATADIR}/pacman-$pac_arch.conf"
work_dir="${chroots_pkg}/${target_branch}/$1"
pkg_dir="${cache_dir_pkg}/${target_branch}/$1"
makepkg_conf=$(get_makepkg_conf "$1")
[[ "$pac_arch" == 'multilib' ]] && target_arch='x86_64'
check_build(){
find_pkg $1
[[ ! -f $1/PKGBUILD ]] && die "Directory must contain a PKGBUILD!"
find_pkg(){
local result=$(find . -type d -name "$1")
[[ -z $result ]] && die "%s is not a valid package or build list!" "$1"
init_base_devel(){
if ${is_multilib}; then
base_packages=('base-devel' 'multilib-devel')
else
base_packages=('base-devel')
fi
chroot_create(){
df -h "${work_dir}"
mkchroot_args+=(-L)
mkchroot ${mkchroot_args[*]} pacman-key --init \
chroot_clean(){
done
exec 9>&-
chroot_update(){
clean_up(){
msg "Cleaning up ..."
msg2 "Cleaning [%s]" "${pkg_dir}"
find ${pkg_dir} -maxdepth 1 -name "*.*" -delete #&> /dev/null
if [[ -z $SRCDEST ]]; then
msg2 "Cleaning [source files]"
find $PWD -maxdepth 1 -name '*.?z?' -delete #&> /dev/null
fi
sign_pkg(){
su ${OWNER} -c "signfile ${pkg_dir}/$1"
move_to_cache(){
local src="$1"
[[ -n $PKGDEST ]] && src="$PKGDEST/$1"
[[ ! -f $src ]] && die
if [[ ${pkg_dir} != $PKGDEST ]]; then
msg2 "Moving [%s] -> [%s]" "${src##*/}" "${pkg_dir}"
mv $src ${pkg_dir}/
fi
${sign} && sign_pkg "${src##*/}"
user_own "${pkg_dir}" "-R"
archive_logs(){
local archive name="$1" ext=log.tar.xz ver src=${tmp_dir}/archives.list target='.'
ver=$(get_full_version "$name")
archive="${name}-${ver}-${target_arch}"
if [[ -n $LOGDEST ]]; then
target=$LOGDEST
find $target -maxdepth 1 -name "$archive*.log" -printf "%f\n" > $src
else
find $target -maxdepth 1 -name "$archive*.log" > $src
fi
msg2 "Archiving log files [%s] ..." "$archive.$ext"
tar -cJf ${log_dir}/$archive.$ext -C "$target" -T $src
msg2 "Cleaning log files ..."
find $target -maxdepth 1 -name "$archive*.log" -delete
post_build(){
source PKGBUILD
local ext='pkg.tar.zst' tarch ver src
for pkg in ${pkgname[@]}; do
case $arch in
any) tarch='any' ;;
*) tarch=${target_arch}
esac
local ver=$(get_full_version "$pkg") src
src=$pkg-$ver-$tarch.$ext
move_to_cache "$src"
done
local name=${pkgbase:-$pkgname}
archive_logs "$name"
chroot_init(){
local timer=$(get_timer)
if ${clean_first} || [[ ! -d "${work_dir}" ]]; then
chroot_clean
chroot_create
else
chroot_update
fi
show_elapsed_time "${FUNCNAME}" "${timer}"
build_pkg(){
mkchrootpkg ${mkchrootpkg_args[*]}
post_build
make_pkg(){
check_build "$1"
msg "Start building [%s]" "$1"
cd $1
build_pkg
cd ..
msg "Finished building [%s]" "$1"
show_elapsed_time "${FUNCNAME}" "${timer_start}"
Have you considered using a local webserver, like in the link I posted.
