Hi,
I’m trying to build my own customized .iso from the GNOME base as guided in a wiki titled " Build Manjaro ISOs with buildiso" and I have almost everything set up the way I want, however when I add packages from AURs in my configuration the build throws errors and only packages from official repositories are fetched.
This is an example from Packages-Desktop:
gnome-tweak-tool
>extra gnome-backgrounds
These packages are from official repositories but when I add numix-gtk-theme I get the following errors:
error: target not found: numix-gtk-theme
==> ERROR: Failed to install packages to new root
==> ERROR: Failed to install all packages
==> ERROR: A failure occurred in make_image_desktop().
Aborting...
I’ve also came across the wiki guide titled “Buildiso with AUR packages: Using buildpkg” but this only refers to AURs created by myself and uploaded to a custom server not the ones on Arch Linux AURs.
Ups I missed that one. That is partially correct because you can create your own repository on a web service you control.
You just have to add that repo to pacman.conf.
It is also documented in the README of manjaro-tools repoiso-profiles repo.
You can even use github as an online repo and with that in mind - this would be applicable to a local webserver on your network even on the same machine.
One example is to amend all the steps in the article on creating a custom repo - then starting a local webservice - like caddy and point the config to that local caddy service
[online-repo]
SigLevel = Never
Server = http://machinename/$repo/$arch
