Relative Noob here. Running latest Manjaro 24 KDE. I have a recently cleaned SSD (no data, no partitions) installed as an additional drive for my PC. Apologies in advance for my ignorance, but I need to partition this drive so I can direct my Timeshift to it as a backup. I presume I can do this via KDE Partition Manager, but need a little help as to the particulars (i.e. what format, etc.). Seems like a pretty simple process, but I don’t want to screw it up. Thanks in advance for your help
first post your system infos:
inxi --admin --verbosity=5 --filter --no-host --width
Second: Choose Rsync Option in Timeshift.
Third: A external disk for a Timeshift snapshot gives you more security (think about overvoltage/lightning strike, randsomware attack a.s.o).
There are pretty fast external SSD’s available today.
Downside is: To be fair, always connect/disconnect a external drive from USB takes a little time, so for some lazy people, a second Internal drive for timeshift is understandable.
It really depends, how important is safety for you… so its a individual decision.
I’d recommend ext4 for simplicity. Yes KDE Partition Manager should be fine. I use it when I want a GUI editor.
So I can learn, why ext4 vs. Fat32 for example? What would be the pros and cons?Glad to hear KDE Partition Manager is a good GUI option.
Good Point.
Timeshift required ext4 because its a Linux Filesystem and respect and can store the required userrights.
Thats not possible with fat32
Excellent. Thanks for the info. Always something to learn here.
And cheap USB3 to SATA cables, which in my experience work well. Didn’t take long to transfer my system to a new SSD using one.
Microsoft-style filesystems do not support POSIX permissions and file ownership, and if you want to make backups of your system, then you need to have a filesystem that supports this POSIX information.
Please read the following two tutorials — they are long, but informative… ![]()
Im even still use my external samsung T5 SSD for my Manjaro install.
I bought it 5 year’s ago only to gave Linux a chance, but its running so fast and stable… there was no need to switch for me for a internal drive for a new Manjaro install.
I only use a 2TB Corsair NVMe 4.0 drive for gaming under Linux.
Good read. I knew the two systems were different (thus the switch to Linux in the first place), now I have a baseline as to why and how. Thank you
I was genuinely surprised myself at how fast this was. Transferring ~800G of data from the internal spinning rust (inc. cloning all the partitions except / which I had to transfer manually), mostly done at a Pub sitting (and finished, GRUB and UUIDs fixed etc.) … with the first run before last bell!
I had already put the SSD in the machine for its final bits-and-bobs though.
If your question is solved, mark the best answer for a solution that the Topic can be closed.
