Installed Manjaro on a laptop with a battery that does not charge. That is not the issue as I am fine using it as a portable.
The issue is Manjaro constantly pops a GUI at the top right letting me know my battery is charging, it goes away after a few seconds and returns. It does this constantly. There must be a way to make it go away!
Please post additional information.
Hi,
I have the same issue in one of my laptop that has the same issue as per Kazoo descritpion.
it is really annoying this pop up. I didnt find anything on how to bloc that pop up.
is there a way like a flag to disable this ?
thanks,
Canāt you click the āsettings iconā in the notification popup to configure this type of notification?
Yup. That what I ended up doing.
Applications -> Settings -> Power Manager
ā¦and in the General tab I turned off Status Notifications.
I have the same problem added to that it makes a soundā¦ how the hell do you turn it off? manjaro kde doesnt seem to have the option i cant find any option other than turning all sound off to maintain my sanity.
