How do I force reinstall broken packages?
I’ve found out through keepassxc that my libqt5-svg is corrupt (no doubt due to the forced reboot that I had to do during an update about 30min ago by now). I suspect it’s not the only package broken and this one in particular is a dep of manjaro utils forcing me to keep it in it’s state despite my best efforts to reinstall it through the gui package manager. At this point I expect I will need the terminal to fix things so how do I force reinstall the package and, if possible, trigger the same for all packages detected as broken (reinstalling at point of detection, not just list then reinstall)
Edit: The solution here is just for this sub problem. The initial problem has it’s own thread here: KeePassXC won't boot
:warning: :warning: :warning:
XY problem detected.
The XY problem is asking about your attempted solution rather than your actual problem. This leads to enormous amounts of wasted time and energy, both on the part of people asking for help, and on the part of those providing help.
Please tell us about the problem, rather than asking about the assumed solution.
No reason to act that way. I’m trying to help, and this is a real thing.
I don’t pretend to know everything, but I do have a working KeepassXC here, and I do not even have thee package installed:
$ pacman -Qs libqt5-svg
Nor can I even find it in the repositories:
$ pacman -Ss libqt5-svg
Or even a package that it beolongs to:
$ pamac search --files libqt5-svg
No package owns libqt5-svg
I was even unable to find anything to do with it in the AUR:
$ pamac search--aur libqt5-svg
So it’s not a package that can be reinstalled, which indicates that it might be something else that’s the matter.
keepassxc: error while loading shared libraries: /usr/lib/libQt5Svg.so.5: file too short
don’t tell me it doesn’t need it if it needs it
edit: also the package you’re looking for is not libqt5-svg but just qt5-svg, libqt5-svg is likely inside that
edit 2: sorry for the name calling btw, just tired of people trying to redirect the topic of threads I make just because they see it as an xy problem. like is it their problem if the poster is chasing the wrong problem? a problem is still a problem and should be addressed, only then can the mind focus on whatever else is a problem
I was simply going of the information you gave, which is:
…and nothing else.
But from your last post I found out that libqt5-svg isn’t the package name, as your post suggested. Which could have been avoided if I had all the inforatrion from the beginning.
Mine doesn’t complain about that:
$ keepassxc
qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
libQt5Svg.so.5 is owned by qt5-svg:
$ pamac search --files libQt5Svg.so.5
/usr/lib/libQt5Svg.so.5 is owned by qt5-svg
And qt5-svg ownes several files:
$ pamac list --files qt5-svg
/usr/include/qt/QtSvg/5.15.19/QtSvg/private/qsvgfont_p.h
/usr/include/qt/QtSvg/5.15.19/QtSvg/private/qsvggraphics_p.h
/usr/include/qt/QtSvg/5.15.19/QtSvg/private/qsvghandler_p.h
/usr/include/qt/QtSvg/5.15.19/QtSvg/private/qsvgnode_p.h
/usr/include/qt/QtSvg/5.15.19/QtSvg/private/qsvgstructure_p.h
/usr/include/qt/QtSvg/5.15.19/QtSvg/private/qsvgstyle_p.h
/usr/include/qt/QtSvg/5.15.19/QtSvg/private/qsvgtinydocument_p.h
/usr/include/qt/QtSvg/5.15.19/QtSvg/private/qtsvgglobal_p.h
/usr/include/qt/QtSvg/QGraphicsSvgItem
/usr/include/qt/QtSvg/QSvgGenerator
/usr/include/qt/QtSvg/QSvgRenderer
/usr/include/qt/QtSvg/QSvgWidget
/usr/include/qt/QtSvg/QtSvg
/usr/include/qt/QtSvg/QtSvgDepends
/usr/include/qt/QtSvg/QtSvgVersion
/usr/include/qt/QtSvg/qgraphicssvgitem.h
/usr/include/qt/QtSvg/qsvggenerator.h
/usr/include/qt/QtSvg/qsvgrenderer.h
/usr/include/qt/QtSvg/qsvgwidget.h
/usr/include/qt/QtSvg/qtsvgglobal.h
/usr/include/qt/QtSvg/qtsvgversion.h
/usr/lib/cmake/Qt5Gui/Qt5Gui_QSvgIconPlugin.cmake
/usr/lib/cmake/Qt5Gui/Qt5Gui_QSvgPlugin.cmake
/usr/lib/cmake/Qt5Svg/Qt5SvgConfig.cmake
/usr/lib/cmake/Qt5Svg/Qt5SvgConfigVersion.cmake
/usr/lib/libQt5Svg.prl
/usr/lib/libQt5Svg.so.5.15
/usr/lib/libQt5Svg.so.5.15.19
/usr/lib/pkgconfig/Qt5Svg.pc
/usr/lib/qt/mkspecs/modules/qt_lib_svg.pri
/usr/lib/qt/mkspecs/modules/qt_lib_svg_private.pri
/usr/lib/qt/plugins/iconengines/libqsvgicon.so
/usr/lib/qt/plugins/imageformats/libqsvg.so
/usr/share/licenses/qt5-svg
…none of which seems to be something critically important. So let’s try:
pamac install --overwrite="/usr/*" qt5-svg
hmm, seems pamac refuses to understand it should replace the installation:
❯ pamac install --overwrite="/usr/*" qt5-svg
Preparing...
Warning: qt5-svg-5.15.19+kde+r5-1 is up to date -- skipping
Nothing to do.
❯ sudo pamac install --overwrite="/usr/*" qt5-svg
[sudo] password for zxuiji:
Preparing...
Nothing to do.
❯ keepassxc
Technically what happens in the process is
  • the library first removes the package
  • then install the package
so the generic answer would be
sudo pacman -Syu <pkgname>
Preparing...
Nothing to do.
Preparing...
Nothing to do.
❯ keepassxc
Doesn’t look like it forcibly replaced the package which is what I need for eliminating this issue from the causes of keepassxc (and any other software that happens to need it) not booting
Never use sudo with pamac. You’ll end up with incorrect permissions. It uses Polkit instead and will prompt for a password if it needs any.
Try without the quotes:
pamac install --overwrite=/usr/* qt5-svg
The sudo thing is noted, though I’ll likely forget by the time it next matters, taht aside see this post above:
That is why I suggested:
it’s the same command though? The 1 which I tried 1st (as shown in the post) before the sudo variant (also shown in the post)
It doesn’t have quotes around the --overwrite= argument value.
Didn’t notice that, tried it and got this instead:
zsh: no matches found: --overwrite=/usr/*
OK, last effort from me, I’ve got an appointment:
sudo pacman -S --overwrite="/usr/*" qt5-svg
Try this instead:
It worked on my system:
❯ sudo pacman -S --overwrite="/usr/*" qt5-svg
[sudo] password for scotty:
warning: qt5-svg-5.15.19+kde+r5-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) qt5-svg-5.15.19+kde+r5-1
Total Installed Size:  0.49 MiB
Net Upgrade Size:      0.00 MiB
(1/1) checking keys in keyring                                           [########################################] 100%
(1/1) checking package integrity                                         [########################################] 100%
(1/1) loading package files                                              [########################################] 100%
(1/1) checking for file conflicts                                        [########################################] 100%
(1/1) checking available disk space                                      [########################################] 100%
(1/2) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/2) Scanning packages for security issues...
(1/1) reinstalling qt5-svg                                               [########################################] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Checking which packages need to be rebuilt
Got progress:
keepassxc: error while loading shared libraries: /usr/lib/libQt5Concurrent.so.5: file too short, I’ll start a diff thread for that after rebooting though since the log said something about needing an update:
:: Proceed with installation? [Y/n] Y
(1/1) checking keys in keyring                                       [######################################] 100%
(1/1) checking package integrity                                     [######################################] 100%
(1/1) loading package files                                          [######################################] 100%
(1/1) checking for file conflicts                                    [######################################] 100%
(1/1) checking available disk space                                  [######################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
(1/1) reinstalling qt5-svg                                           [######################################] 100%
ldconfig: File /usr/lib/libQt6LabsSettings.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5EglFsKmsSupport.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickVectorImageGenerator.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5Core.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt5EglFsKmsSupport.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickWidgets.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt5PrintSupport.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libhandle.so is empty, not checked.
ldconfig: File /usr/lib/libQt5OpenGL.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2BasicStyleImpl.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsSynchronizer.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandClient.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Fusion.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2BasicStyleImpl.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickTest.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt5Concurrent.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsSharedImage.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandClient.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2ImagineStyleImpl.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickParticles.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Network.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickParticles.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5OpenGL.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Universal.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlNetwork.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5Concurrent.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt5XcbQpa.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlLocalStorage.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlCompiler.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickWidgets.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsSharedImage.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickTemplates2.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Widgets.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickDialogs2QuickImpl.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickParticles.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlWorkerScript.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt5PrintSupport.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsFolderListModel.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsPlatform.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsAnimation.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsFolderListModel.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5Sql.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6Qml.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5X11Extras.so is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsStyleKitImpl.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickTest.so is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsStyleKit.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlModels.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlWorkerScript.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5Quick.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Universal.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsSynchronizer.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5Network.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickShapes.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Fusion.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Impl.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlModels.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt5Widgets.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlWorkerScript.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2UniversalStyleImpl.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5Qml.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2MaterialStyleImpl.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickParticles.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickDialogs2QuickImpl.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6Qml.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Fusion.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Basic.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libvapoursynth.so.4 is empty, not checked.
ldconfig: File /usr/lib/libQt5Sql.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsStyleKitImpl.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2ImagineStyleImpl.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsPlatform.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5Sql.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickVectorImage.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlXmlListModel.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Material.so is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandCompositor.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Basic.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Concurrent.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt5OpenGL.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickTest.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libvapoursynth.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickWidgets.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickDialogs2Utils.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5DBus.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickWidgets.so.6 is empty, not checked.
ldconfig: File /usr/lib/libvapoursynth-script.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Qml.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Impl.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2FusionStyleImpl.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5Gui.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlCompiler.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsSharedImage.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickLayouts.so is empty, not checked.
ldconfig: File /usr/lib/libvsscript.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickShapes.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Material.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5Test.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickEffects.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5XcbQpa.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt5Xml.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt5Widgets.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickTemplates2.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5Widgets.so is empty, not checked.
ldconfig: File /usr/lib/libQt5XcbQpa.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Material.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5Core.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickShapes.so is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsWavefrontMesh.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5Gui.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Network.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickTest.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libqt6ct-common.so.0.11 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlCore.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2FusionStyleImpl.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickDialogs2Utils.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5Quick.so is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandCompositor.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsStyleKit.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5DBus.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt5X11Extras.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlWorkerScript.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlModels.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Quick.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickShapes.so.6 is empty, not checked.
ldconfig: File /usr/lib/libhandle.so.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsSettings.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickWidgets.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2FluentWinUI3StyleImpl.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickDialogs2.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlNetwork.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5Xml.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2FusionStyleImpl.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickTemplates2.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickVectorImage.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsStyleKit.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickShapes.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickShapesDesignHelpers.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libhandle.so.1.0.3 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Sql.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Core.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickEffects.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5Qml.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2FluentWinUI3StyleImpl.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickEffects.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Qml.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsQmlModels.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickLayouts.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlModels.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickVectorImageHelpers.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libvapoursynth-script.so.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5Quick.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlModels.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlWorkerScript.so is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandClient.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2MaterialStyleImpl.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlXmlListModel.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2UniversalStyleImpl.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Imagine.so is empty, not checked.
ldconfig: File /usr/lib/libQt5EglFSDeviceIntegration.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt5Test.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Test.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt5SerialPort.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickTest.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlCore.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Imagine.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5SerialPort.so is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsAnimation.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickDialogs2QuickImpl.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5PrintSupport.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlMeta.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickDialogs2.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5PrintSupport.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2UniversalStyleImpl.so is empty, not checked.
ldconfig: File /usr/lib/libQt5SerialPort.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt5Qml.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlMeta.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickDialogs2.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Core.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlLocalStorage.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlNetwork.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Gui.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlMeta.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5EglFSDeviceIntegration.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2ImagineStyleImpl.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5OpenGL.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickShapes.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5Gui.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsPlatform.so is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandCompositor.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt5EglFsKmsSupport.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt5X11Extras.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsWavefrontMesh.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickShapes.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Imagine.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlModels.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlCore.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickLayouts.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2FluentWinUI3StyleImpl.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickWidgets.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsStyleKitImpl.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlWorkerScript.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlModels.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsSettings.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickShapesDesignHelpers.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlCompiler.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickParticles.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickParticles.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsQmlModels.so is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsAnimation.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5Xml.so.5 is empty, not checked.
ldconfig: File /usr/lib/libqt6ct-common.so is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandCompositor.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt5X11Extras.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt5XcbQpa.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandClient.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsSynchronizer.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Test.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Basic.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5Concurrent.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickDialogs2Utils.so is empty, not checked.
ldconfig: File /usr/lib/libQt5EglFSDeviceIntegration.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt6Quick.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsFolderListModel.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Impl.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickTest.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2Universal.so is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsQmlModels.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickWidgets.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlXmlListModel.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickShapesDesignHelpers.so is empty, not checked.
ldconfig: File /usr/lib/libQt5SerialPort.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2BasicStyleImpl.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickParticles.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickTest.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6LabsWavefrontMesh.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickVectorImageGenerator.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickVectorImageGenerator.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickVectorImageHelpers.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5EglFsKmsSupport.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt5Network.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickVectorImageHelpers.so is empty, not checked.
ldconfig: File /usr/lib/libQt5DBus.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlWorkerScript.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt5EglFSDeviceIntegration.so.5.15.19 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickVectorImage.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5DBus.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt5Xml.so is empty, not checked.
ldconfig: File /usr/lib/libQt6QmlLocalStorage.so.6.11.1 is empty, not checked.
ldconfig: File /usr/lib/libQt6QuickControls2MaterialStyleImpl.so.6.11.1 is empty, not checked.
(1/1) Arming ConditionNeedsUpdate...
