Hello, I KNOW someone here has the expertise to solve this problem. How do I completely UNINSTALL Bluetooth from Manjaro without affecting other apps? I tried to uninstall it, then it told me “Uninstalling Bluetooth will uninstall dependencies that other apps rely on” or something like that. I uninstalled anyway, then after I uninstalled it I couldn’t turn on my wifi. lol I had to re-install Manjaro just to get it working again.
Microsoft bundles Bluetooth into Windows 10 so you can never remove it. Now it seems like it’s “bundled” with Linux Manjaro also.
What I DO believe is that somebody here is smart enough to DEFEAT Bluetooth. Who shall it be?
There is several dependency trees for example GNOME has some I think. You would need to create dummy packages that “provides” satisfies bluetooth dependencies.
There is also your kernel that has some bluetooth drivers inside, does it count?? You can’t uninstall it because the kernel is one piece bundle, you would need compile yourself your custom kernel without said drivers.
Anyway, most people are fine with disabling bluetooth. Completely remove it?
I would like to completely uninstall it, no drivers, no Bluetooth, no nothing. I’m new to Linux so compiling a custom kernel is not possible at this time. Is there a place that I can find one?
There are pleny of custom kernels floating around. If security is your concern, then trusting a random guy from the internet providing you a kernel instead of having one that is used by several order of magnitude more technically minded people with disabled bluetooth drivers is way worse.
This is true and in Linux is often bundled with the operating system
SO? just turn it off and disable, it’s not gonna randomly enable and start pairing like a promiscuous …
Thanks TriMoon for your help. I’ll have to come here later and read all you guy’s responses again and try to figure this all out when I have the time. I must get my day started. Thanks for responding to my question FAST!
Hey freed, thank you for helping me. I will look at this information, watch some YouTube videos about what you guys are talking about then solve this problem. I need time to digest what you guys have said and firgure out what you guys are saying. I’m new to Linux. I guarantee you one thing though, I WILL eradicate Bluetooth!
Thats a bit too much
You dont need sudo, the entry with/out ‘.service’ is the same, and you can disable and stop at once…
I think you might be looking for:
systemctl disable --now bluetooth
and if they want to mask:
systemctl mask bluetooth
(PS - ‘disable’ means it wont start at boot, ‘mask’ means it wont start even if something calls for it)
