How do I check the battery percentage of connected bluetooth devices in KDE?
When my bluetooth keyboard is getting low on battery, I’ll get a notification from Power Management that shows me it’s low. How can I check this otherwise? If I check the Power Management settings, I don’t see any indicator for battery percentage of any peripherals.
Is it not visible under the Energy section of the Info Center?
Aha! That’s where it is. Thank you. :slight_smile:
Alternatively it’s also available from “Battery and Brightness” widget:
