Ok my question is simple but I have found it is quite difficult to get a handle because of my environment. Currently I am running linux on a ps4 pro. It works really well. But I have a specific desire. I want to make a version of what I run now that is stripped down. I know how to do that in Windows but learning how in Linux has not been fun. I hear tell that I can do it but well. It’s hard to say if I can on a ps4. I am using to my knowledge:
Catjaro (Manjaro 21.0.7 Ornara)
Kernel “Kernel 5.3.7 Gentoo gc41cdf12d-dirty” to my knowledge this has been edited for the PS4.
I would like to boot a very old application called “linmugen”. This program has limited specs.
I can run the program but many users will not have my know how so I want the system to go straight to linmugen. Ideally with as few files as possible. If it is helpful I have a modded xbox that does just this that works fine.
Any help is greatly appreciated. I can provide any files you wish. I would describe my skills as capable but I cannot seem to determine the best path forward after hours of reading. I continue to read. Thanks.
What is Catjaro?
If it is based on Manjaro why the Gentoo kernel?
linmugen doesn’t exist as a package for Arch based distributions - I think you are asking the wrong place.
Closed as off-topic for Manjaro.
Fabby
23 September 2021 17:57
4
Catjaro is a Manjaro spin for running on PS4 hardware.
If the kernel is indeed a gentoo kernel, it’s not Manjaro any more and thus off-topic but we never got an inxi
so I’'ve reopened this question to be able to ask @seantorres
Please read this:
How to provide good information
and reply to this message to give us more information so we can see what’s really going on.
Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width
would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text .
P.S. If you want to notify me that you did provide this information, please this message and I’ll come back and have another look.
P.P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which exact CPU/GPU or Kernel, … you have without typing it every time
'''itmania@ITmania-PS4 Linux 5.3.7-gentoo-gc41cdf12d-dirty x86_64 21.0.7 Ornara
~ >>> sudo inxi --admin --verbosity=7 --filter --no-host --width
[sudo] password for itmania:
Kernel: 5.3.7-gentoo-gc41cdf12d-dirty x86_64 bits: 64 compiler: gcc v: 8.3.0
parameters: panic=0 clocksource=tsc radeon.dpm=0 console=tty0
console=ttyS0,115200n8 console=uart8250,mmio32,0xd0340000
video=HDMI-A-1:1920x1080-24@60 consoleblank=0 net.ifnames=0 drm.debug=0
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: LXDM
Type: N/A Mobo: N/A model: N/A serial: N/A
BIOS: Sony Interactive Entertainment v: unde date: Wed 08/05/2020 5:2
RAM: total: 4.87 GiB used: 991.5 MiB (19.9%)
RAM Report: unknown-error: Unknown dmidecode error. Unable to generate data.
Info: 8-Core model: DG1310SML87IB bits: 64 type: MCP arch: Jaguar
family: 16 (22) model-id: 41 (65) stepping: 2 microcode: 7041001 cache:
L2: 2 MiB bogomips: 25504
Speed: 2092 MHz min/max: N/A Core speeds (MHz): 1: 2092 2: 2092 3: 2091
4: 2092 5: 2092 6: 2092 7: 2091 8: 2092
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 bpext clflush
cmov cmp_legacy constant_tsc cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht hw_pstate ibs
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni
popcnt proc_feedback pse pse36 rdtscp rep_good sep skinit ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme
vmmcall wdt xsave xsaveopt
Vulnerabilities: Type: l1tf status: Not affected
Type: spectre_v2 status: Vulnerable, STIBP: disabled
Device-1: AMD Gladius driver: amdgpu v: kernel bus-ID: 00:01.0
chip-ID: 1002:9924 class-ID: 0300
Display: server: X.Org 1.20.11 compositor: gnome-shell driver:
loaded: amdgpu,modesetting alternate: ati,fbdev,vesa display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60
OpenGL: renderer: AMD LIVERPOOL (DRM 3.33.0 5.3.7-gentoo-gc41cdf12d-dirty
LLVM 12.0.0)
v: 4.5 Mesa 20.3.0-devel (git-a575bb1369) direct render: Yes
Device-1: AMD Liverpool HDMI/DP Audio vendor: nCipher Security
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9921
class-ID: 0403
Sound Server-1: ALSA v: k5.3.7-gentoo-gc41cdf12d-dirty running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Message: No device data found.
IF-ID-1: eth0 state: down mac: <filter>
IF-ID-2: mlan0 state: up speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 11.13 TiB used: 6.56 TiB (58.9%)
ID-1: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WD easystore 240GB size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s rotation: SSD serial: <filter> scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate
model: ST8000DM004-2CX188 size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B rotation: 5425 rpm serial: <filter> rev: 9401 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD Game Drive size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B serial: <filter> rev: 5002 scheme: GPT
Optical-1: /dev/sr0 vendor: SONY model: PS-SYSTEM 410R rev: 4100
dev-links: cdrom
Features: speed: N/A multisession: yes audio: yes dvd: yes rw: none
state: running
ID-1: / raw-size: 223.51 GiB size: 220.01 GiB (98.43%)
used: 43.39 GiB (19.7%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: psxitarch uuid: 54dec853-cccf-4e55-aa06-bcdb6140eb76
ID-2: /run/media/itmania/0000-004C raw-size: 54.9 MiB size: 54 MiB (98.46%)
used: 11 MiB (20.4%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: 0000-004C
ID-3: /run/media/itmania/PS4 raw-size: 7.28 TiB size: 7.28 TiB (100.00%)
used: 2.97 TiB (40.8%) fs: fuseblk block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: PS4 uuid: 06F1-53A7
ID-4: /run/media/itmania/WD_BLACK raw-size: 3.64 TiB
size: 3.64 TiB (100.00%) used: 3.55 TiB (97.5%) fs: fuseblk
block-size: 4096 B dev: /dev/sdc1 maj-min: 8:33 label: WD_BLACK
uuid: EA5B-A14F
ID-1: swap-1 type: file size: 4 GiB used: 1.43 GiB (35.9%) priority: -2
file: /swapfile
ID-1: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: N/A label: N/A uuid: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-2:2 info: Sony ports: 2 rev: 2.1 speed: 480 Mb/s chip-ID: 054c:0ba5
Hub-3: 1-2.2:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
Device-1: 1-2.2.1:4 info: Nintendo Wii U GameCube Controller Adapter
type: HID driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 057e:0337 class-ID: 0300 serial: <filter>
Device-2: 1-2.2.2:12 info: Shenzhen Riitek Wireless Receiver
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 50mA chip-ID: 1997:2466 class-ID: 0301
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-5: 2-2:2 info: Sony ports: 2 rev: 3.0 speed: 5 Gb/s chip-ID: 054c:0ba6
Device-1: 2-2.1:3 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E SATA
6Gb/s bridge ASM1153 SATA 3Gb/s bridge ASM1153E SATA 6Gb/s bridge
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
chip-ID: 174c:55aa class-ID: 0806 serial: <filter>
Hub-6: 2-2.2:4 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
Device-1: 2-2.2.3:9 info: Seagate RSS LLC SRD0NF2 [Expansion Desktop Drive]
chip-ID: 0bc2:3322 class-ID: 0806 serial: <filter>
Device-2: 2-2.2.4:10 info: Western Digital Game Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
chip-ID: 1058:262f class-ID: 0806 serial: <filter>
Hub-7: 3-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 49.4 C mobo: N/A
Processes: 241 Uptime: 1d 3h 07m Init: systemd v: 248 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1121 lib: 363 Shell: Zsh (sudo) v: 5.8
default: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.04```
Fabby
11 October 2021 18:20
7
That’s a really old EOL kernel and indeed a gentoo one, so you’ve basically created a monster made out of dead body parts (the Gentoo kernel) and blew life in it using electricity (Manjaro).
Unfortunately, I have to agree with @linux-aarhus and close this thread.
If I were you I would:
try making it work on a new Manjaro install with a recent kernel
Try to back-port those changes into this monster
You’re basically on your own on this one
