I’ve formatted my hard drive through KDE Partition manager into btrfs
and wanted to set it’s mounting point as ~/western-digital
, but after reboot I’ve seen, that it’s actually mounted into /run/media/username/western-digital
and I’m also permitted to write anything into disk without using sudo
privileges.
For this operations I use gnome-disk-utility
(I’m not on KDE so don’t if there is an equivalent for Qt desktops) which format drives as your user and can let you configure the mount point as you wish, by the way write the full path; like /home/$your-username/western-digital
replacing $your-username
with your actual username
Thanks for answer, that’s my mistake, I’ve managed to mount it in correct point, but I’m still unable to create any files/directories on drive. Should there be any specific arguments in /etc/fstab
No, you need to chown
(change owner) the partition to your user
Ah, I see now, it’s sudo chown -R user:user /run/media/user/yourDisk
command. Thanks for your help again
If there is a lost+found
directory (I’m not using btrfs so can’t say sure) you may want to chown that back to root
Please beware that any directory ─ and thus mountpoint ─ under /run
lives in virtual memory, and therefore, any manually applied change in the permissions on such mountpoint will not persist across reboots. It is therefore more advisable to use a static mountpoint as defined in /etc/fstab
This tutorial below will explain best practice…
