How create iso from current manjaro without a terminal?
Are there any analogs of programs for manjaro (Remastersys, System back, qt5-fsarchiver)
To create an iso of your system with the interface, no buildiso…
I don’t think there is any program that creates a working “snapshot” of your current system as an ISO.
There is however some How-To(s) on the subject of creating a Manjaro ISO from scratch IIRC…
Plus more see: Search results for 'Manjaro iso #contributions:tutorials' - Manjaro Linux Forum
There is no GUI to create an ISO from current state.
Technically you can use buildiso - I have outlined the commands necessary - you may want to script them - though I recommend to test them as they are written from memory - flash memory - the kind of memory which is gone in a flash :slight_smile:
Steps
1. Create a folder in the root filesystem to hold your system
sudo mkdir /mybuild
2. Set permissions on the folder
Setting your user as owner which automagically gives rw access
sudo chown $USER:$USER /mybuild
3. Clone the iso-profiles repo into /mybuild
git clone https://gitlab.manjaro.org/profiles-and-settings/iso-profiles /mybuild/iso-profiles
4. Create a folder to hold your build
mkdir /mybuild/iso-profiles/$USER
5. Copy the relevant profile-folder into mybuild
In this case it is Plasma - it would work for any edition
cp -R /mybuild/iso-profiles/manjaro/kde /mybuild/iso-profiles/$USER/my-kde
6. Clean up your system for orphans
pamac remove --orphans
7. Create a package list of your current system
Excluding custom packages
pacman -Qqen > ~/my-packages.txt
8. Create new filtered list
Use the comm utility comparing the two files ~/my-packages.txt and /rootfs-pkgs.txt and pipe the result to replace the my-kde profile’s Packages-Desktop file
comm -23 <(sort ~/my-packages.txt) <(sort /rootfs-pkgs.txt) > /mybuild/iso-profiles/$USER/my-kde/Packages-Desktop
9. Create the folder to hold your personal settings
mkdir -p /mybuild/iso-profiles/$USER/my-kde/desktop-overlay/etc/skel
10. Copy the content of your home
Place the content in the desktop-overlay/etc/skel folder - make sure to be selective and remove unwanted files like Documents and Pictures and whatnot
cp -R $HOME/. /mybuild/iso-profiles/$USER/my-kde/desktop-overlay/etc/skel
11. Run buildiso
Use the -t target directory argument to place your build inside the /mybuild folder.
If you have used buildiso previously with another profile-root you need to edit the file ~/.config/manjaro-tools/iso-profiles.conf to point to the folder /mybuild/iso-profiles
buildiso -p my-kde -t /mybuild
The size of the final ISO will be reflected by the packagelist and the size of your $HOME folder
