How can I switch /home partition?
Hi! I’ve been using Manjaro KDE since July. Recently I decided to try out Manjaro Xfce so I only reinstalled the system on its partition what means I didn’t lose my personal data. Also, without any tricks during the installation new system used my old /home directory which I have on separate partition. However, I decided I want to get back to KDE but here is the problem. It didn’t work the same way. I still have my data on that partition but it’s not my /home now. The system created new /home directory on the system partition what is highly inconvenient.
Is there an easy way to mount /home directory to that old partition?
Hi @cptkidd62, and welcome!
Have a look at [root tip] Use systemd to mount ANY device and [root tip] systemd mount unit samples. I believe those can help you.
Thank you! I must say it was easier than I thought :smiley:
:wink:
Things usually are. Glad you managed.
