Hello
How can I stop fsck due to slow boot?
Is stopping fsck harmful for system?
Come on, what are you doing…?
Why’d you make this new thread?
Your other thread already covers this, and you’re not “stopping fsck”. You’re just re-directing the console messages to another TTY. It’s harmless.
EDIT: Alright. It’s fine. You don’t need to “stop fsck”. In fact, the message you see only confirms your filesystem is clean. It’s not actually doing a full scan.
Well, you could always remove the fsck
hook from /etc/mkinitcpio.conf
— see below — and rebuild your initramfs
That said however, I don’t think the fsck
would be taking up too much time. If the filesystem was cleanly shut down, then it should only take a few milliseconds per filesystem. So that’s not going to make much of a difference.
Still, if you want to go ahead with it, open up the file /etc/mkinitcpio.conf
in an editor of your choice and look for the line near the bottom of the file that starts with…
HOOKS=( udev autodetect ...
One of the keywords on that line is the fsck
hook. Delete that keyword, save the file — it’ll ask you for the root password or the sudo
password — and then in a terminal window, run the command…
sudo mkinitcpio -P
Well, let’s just say that it’s there for a reason. If your system suffers an unclean shutdown, then chances are that your filesystem(s) have ended up in disarray, and having the system perform an fsck
at boot can then automatically repair the damage.
Note: The fsck
hook is either way unneeded — and even advised against — on btrfs
, because btrfs
has its own filesystem integrity checks built in.
This is 100% spot on.
I feel that the “message” during bootup keeps giving users concern over nothing important. It’s quite literally like passing by a store on the road and you read a sign that says “We’re open!”
That’s all it is. It’s just a message. “Your filesystem is fine, nothing to do! Anyways, enjoy your computer!”
You can test this yourself by manually invoking fsck
(on an unmounted filesystem or in a live USB session) without any parameters. It will most likely immediately exit and skip any such scan because your filesystem is “clean”. That’s why you need to invoke the -f
flag to FORCE it to scan your filesystem. (The bootup process does not do that. Nothing is forced.)
EDIT: Made it more clear.
At this point I’m tempted to file a Manjaro feature request in which console message are redirected to TTY3 by default. If the user doesn’t see any messages, then it means their system is healthy.
This worry / issue about “fsck message” keeps coming up repeatedly in this forum.
Don’t ever do that!
fsck
may only be run against an unmounted filesystem. Running it against a mounted filesystem is going to cause damage to said filesystem, unless the filesystem is mounted read-only, but even then I still wouldn’t recommend it.
tty3
won’t have been initialized yet at that point of the boot process. The tty
s — i.e. the virtual consoles — are initialized by systemd
, which isn’t running yet at that point of the boot process. So the output is sent to /dev/console
instead, which is the default Linux console — or boot console, if you will — as built into the kernel.
You know what? Correcting me in front of others in public? Fsck yo-, nevermind.
Anyways, I found a solution. Just remove the dust cover when you think the login screen or desktop is ready. No need to change any settings or defaults. It is highly effective at resolving most bootup concerns.
Also works with laptops too!
But wouldn’t changing the default Grub parameter to be console=tty3
take care of this for most Manjaro users? (As seen how it usually works when others want to hide such fsck messages during bootup.)
Hello my friend let see my systemd-analyze blame output
5.286s dev-sda5.device
3.673s udisks2.service
2.943s ModemManager.service
2.926s dev-loop4.device
2.770s dev-loop3.device
2.647s systemd-fsck@dev-disk-by\x2duuid-0084\x2d9283.service
2.534s upower.service
2.520s dev-loop2.device
2.511s dev-loop0.device
1.979s cups.service
1.920s dev-loop1.device
1.816s NetworkManager.service
1.521s systemd-tmpfiles-clean.service
1.435s systemd-rfkill.service
1.278s systemd-fsck@dev-disk-by\x2duuid-004B\x2d54D2.service
1.248s polkit.service
1.032s systemd-tmpfiles-setup-dev.service
936ms lvm2-monitor.service
899ms bluetooth.service
891ms systemd-logind.service
887ms dbus.service
884ms dev-disk-by\x2duuid-f93c95ee\x2d0acb\x2d4d06\x2da79a\x2d7be3e5f7bc70.swap
742ms systemd-random-seed.service
508ms systemd-fsck@dev-disk-by\x2duuid-4e65a8f9\x2db8f2\x2d48cb\x2d97ec\x2dfade6f35e638.service
501ms systemd-timesyncd.service
455ms user@1000.service
377ms systemd-modules-load.service
help me find things that is useless and tell me how to stop them TNX I`m a noob
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
winnie I redirect them to TTY can you tell me Is there a way to see messages ?
Well, it would attempt to send the boot-up messages to tty3
, but that’s no guarantee that they will arrive there, given that the fsck
is being run before tty3
is initialized. And in that case, my might then just as easily point them at /dev/null
… where no one hears you scream…
is that harmful ?
To cycle between TTYs: CTRL + ALT + F1 (or F2, F3, F4, etc)
when to use these shortcuts? I`m really noob
It could be, because those messages are there for a reason. If you redirect all output of the boot process to /dev/null
and something goes wrong, you’d never know about it.
I have no way of knowing what you need and what you don’t need, because it all depends on your hardware and how you’ve installed the system. For instance, I myself don’t have Bluetooth, so I’ve disabled that, and I’m also not using lvm2
, so I’ve disabled that too. But you in turn may need those things. We don’t know that.
What I will say is that 5.286 seconds is definitely not a bad score, so I don’t see what could possibly still make a difference.
TNX really help me bro
You can use them at any point when the system is running. UNIX is a multiuser operating system and every tty
(except for tty12
) is a separate login console.
ok and how can I see the result of fsck that are redirected?
Ctrl+Alt+F3. The shortcut for returning to your GUI environment differs per GUI. In the event of KDE Plasma, it would be Alt+F1, but if you’re running XFCE, then it’ll be Alt+F7. I’m not sure anymore what it is for GNOME these days — Alt+F4 maybe?
Either way, if you want to see those messages, then why redirect them in the first place?
- you can disable this if you are not using any modem…
1.979s cups.service
- this is used for printing, so if you are not using printing you can disable it
if you are not using logical volumes (probably not) you can disable it
this loop devices are probably related to snap, so if you have any snap packages installed, remove them and replace them if you want to improve boot time
