Yes but I want to see them if there is something important ?
or it will show the important messages there ?
TNX brahma
It does not matter whether the messages are important or not. The redirection will apply to all messages.
Like @Aragorn said earlier, and Iāll reiterate again: just leave it all alone, as it was before you were concerned about seeing āfsck messagesā.
Your computer will boot normally, like always.
Just ignore the āfsck messageā if it really bothers you. (Or look away.)
Trying to dive into the nitty-gritty to shave off a few seconds from the bootup time may not even be worth the stress involved, let alone the back-and-forth comparisons of ābeforeā and āafterā.
ok so is there a way to see them or I go and cancel redirecting?
Iāve already told you that.
As @winnie saidā¦
TNX all of you
