How can I improve boot speed?
I have been reviewing the page ‘Boot_process’ and I am not sure what I should do to improve the boot speed.
My current speed is
systemd-analyze:
Startup finished in 7.435s (firmware) + 6.234s (loader) + 4.721s (kernel) + 3.122s (userspace) = 21.512s
graphical.target reached after 3.108s in userspace.
systemd-analyze critical-chain:
graphical.target @3.108s
└─multi-user.target @3.108s
  └─cups.service @3.022s +86ms
    └─network.target @3.021s
      └─NetworkManager.service @2.713s +306ms
        └─basic.target @2.713s
          └─dbus-broker.service @2.692s +19ms
            └─dbus.socket @2.690s
              └─sysinit.target @2.689s
                └─systemd-timesyncd.service @2.609s +79ms
                  └─systemd-tmpfiles-setup.service @2.371s +234ms
                    └─run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount @2.406s
systemd-analyze blame:
1.065s dev-nvme0n1p2.device
 531ms boot-efi.mount
 359ms systemd-udev-trigger.service
 330ms systemd-udev-load-credentials.service
 306ms NetworkManager.service
 300ms systemd-remount-fs.service
 299ms systemd-tmpfiles-setup-dev-early.service
 278ms user@1000.service
 271ms systemd-modules-load.service
 234ms systemd-tmpfiles-setup.service
 192ms modprobe@fuse.service
 155ms lvm2-monitor.service
 152ms modprobe@drm.service
 151ms systemd-sysctl.service
 139ms systemd-fsck@dev-disk-by\x2duuid-9E29\x2dD933.service
 125ms systemd-journal-flush.service
 110ms NetworkManager-wait-online.service
 101ms systemd-tmpfiles-setup-dev.service
  90ms upower.service
  88ms systemd-vconsole-setup.service
  86ms systemd-tmpfiles-clean.service
  86ms cups.service
  84ms systemd-udevd.service
  79ms systemd-timesyncd.service
  78ms systemd-user-sessions.service
  77ms systemd-update-utmp.service
  76ms user-runtime-dir@1000.service
  71ms systemd-userdbd.service
  66ms kmod-static-nodes.service
  63ms modprobe@configfs.service
  63ms systemd-random-seed.service
  59ms systemd-journald.service
  55ms power-profiles-daemon.service
  55ms ModemManager.service
  53ms sys-fs-fuse-connections.mount
  53ms sys-kernel-config.mount
  52ms systemd-backlight@backlight:intel_backlight.service
  52ms modprobe@loop.service
  47ms dev-disk-by\x2duuid-22dd78cc\x2dbef7\x2d4c7e\x2daa88\x2d541ac97a7585.swap
  46ms udisks2.service
  43ms systemd-rfkill.service
  37ms polkit.service
  36ms alsa-restore.service
  33ms tmp.mount
  27ms systemd-logind.service
lsblk -fs:
NAME      FSTYPE FSVER LABEL UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
nvme0n1p1 vfat   FAT32       9E29-D933                             299.1M     0% /boot/efi
└─nvme0n1
nvme0n1p2 ext4   1.0         8eeb8888-4cc1-4e3c-92c2-682098fcdb5f  716.5G    18% /
└─nvme0n1
nvme0n1p3 swap   1     swap  22dd78cc-bef7-4c7e-aa88-541ac97a7585                [SWAP]
└─nvme0n1
There seems nothing wrong with your boot speed.
Why do you feel it should be faster?
Do you need cups started at boot?
Is there a reason you have the service enabled rather than the socket?
Do you use logical volumes ?
Firmware and loader take some time. Please provide output of
inxi -Fza
Just for fun haha. Besides, I feel like it’s slow compared to what I remember from the Windows 11 startup.
inxi -Fza:
  Kernel: 6.6.52-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=8eeb8888-4cc1-4e3c-92c2-682098fcdb5f rw quiet acpi=force
    apm=power_off resume=UUID=22dd78cc-bef7-4c7e-aa88-541ac97a7585
    udev.log_priority=3 nouveau.modeset=0 intel_idle.max_cstate=4
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
    wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: HP product: Victus by HP Gaming Laptop 15-fa1xxx v: N/A
  Mobo: HP model: 8C2D v: 63.33 serial: <superuser required>
    part-nu: A14LKLA#ABM uuid: <superuser required> UEFI: AMI v: F.16
    date: 03/19/2024
  ID-1: BAT0 charge: 70.1 Wh (100.0%) condition: 70.1/70.1 Wh (100.0%)
    volts: 17.3 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
    status: full cycles: 15
  Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
    microcode: 0x434
  Topology: cpus: 1x dies: 1 clusters: 5 cores: 8 threads: 12 mt: 4 tpc: 2
    st: 4 smt: enabled cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32
    KiB, 4x64 KiB L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 484 min/max: 400/4400:3300 scaling: driver: intel_pstate
    governor: powersave cores: 1: 484 2: 484 3: 484 4: 484 5: 484 6: 484 7: 484
    8: 484 9: 484 10: 484 11: 484 12: 484 bogomips: 59916
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:46a3
    class-ID: 0300
  Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile]
    vendor: Hewlett-Packard driver: nvidia v: 550.120
    alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-09) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:28a1
    class-ID: 0300
  Device-3: Luxvisions Innotech HP Wide Vision HD Camera driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3
    chip-ID: 30c9:0069 class-ID: fe01 serial: <filter>
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: BOE Display 0x094d built: 2020 res: 1920x1080
    hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
    surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
    device-ID: 8086:46a3 memory: 7.45 GiB unified: yes
  API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4050 Laptop GPU driver: nvidia v: 550.120 device-ID: 10de:28a1
    surfaces: xcb,xlib
  Device-1: Intel Alder Lake PCH-P High Definition Audio
    vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51c8 class-ID: 0401
  Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be
    class-ID: 0403
  API: ALSA v: k6.6.52-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 1.84 TiB used: 366.21 GiB (19.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: HP02AN00 temp: 32.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 970 EVO Plus 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
    fw-rev: 1.00 scheme: GPT
  ID-1: / raw-size: 944.77 GiB size: 928.86 GiB (98.32%)
    used: 190.96 GiB (20.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: partition size: 8.8 GiB used: 699.1 MiB (7.8%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 38.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2198 fan-2: 1998
  Memory: total: 16 GiB note: est. available: 15.26 GiB used: 6.52 GiB (42.7%)
  Processes: 293 Power: uptime: 1h 12m states: freeze,mem,disk
    suspend: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.06 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1294 libs: 335 tools: yay Compilers:
    clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: wezterm-gui
    inxi: 3.3.36
I didn’t know what ‘cups.service’ was. I researched and found out I don’t need it. How do I disable it correctly?
I don’t know if I use it. What are ‘logical volumes’ used for? Are they important?
Windows 11 likely had Fast Startup enabled; a hibernation variant that Microsoft uses to give the illusion of a faster startup.
In fact, when using Fast Startup, the machine never actually shuts down. Instead, it just hibernates and subsequently wakes from hibernation. So, it’s not necessarily a good comparison.
Disabling a few services starting during boot might show minor improvements; as already indicated by posts above.
Switching to Wayland instead of X11 should improve performance, generally, but that probably won’t have much effect on boot speed.
High performance NVMe or SSD drives might enhance read/write, and therefore boot speed to some extent. So, if you have a few thousand dollars to spare, you might shave off a fraction of a second here and there.
Are we having fun yet? :wink:
7-8 seconds seems fine to me.
Cheers.
systemctl disable cups.service --now
If you want the socket enabled (will start the service when needed) then
systemctl enable cups.socket --now
Its a way of organizing disks.
Then you probably dont use them. You may wish to retain the ability to work with them … such as an external logical volume.
https://wiki.archlinux.org/title/LVM
Do you remember if Windows 11 was using Fast Startup (hybrid hibernation) rather than a full restart?
Boot time depends on a lot of things and will vary from system to system.
Take this system - what is the boot time?
08:05:48 ○ [fh@tiger] ~
 $ inxi -SCMm
  Host: tiger Kernel: 6.11.2-1-MANJARO arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.1.5 Distro: Manjaro Linux
  Type: Desktop System: LENOVO product: 30E000GMMT v: ThinkStation P620
  Mobo: LENOVO model: 1046 v: SBB1C50523 WIN 3556073303264
    serial: <superuser required> UEFI: LENOVO v: S07KT5DA date: 04/19/2024
  Info: 12-core model: AMD Ryzen Threadripper PRO 5945WX s bits: 64
    type: MT MCP cache: L2: 6 MiB
  Speed (MHz): avg: 1429 min/max: 400/4565 cores: 1: 1429 2: 1429 3: 1429
    4: 1429 5: 1429 6: 1429 7: 1429 8: 1429 9: 1429 10: 1429 11: 1429 12: 1429
    13: 1429 14: 1429 15: 1429 16: 1429 17: 1429 18: 1429 19: 1429 20: 1429
    21: 1429 22: 1429 23: 1429 24: 1429
  System RAM: total: 64 GiB available: 62.65 GiB used: 3.32 GiB (5.3%)
  Array-1: capacity: 1024 GiB note: check slots: 8 modules: 4
    EC: Multi-bit ECC
  Device-1: DIMM5 type: no module installed
  Device-2: DIMM6 type: no module installed
  Device-3: DIMM7 type: DDR4 size: 16 GiB speed: 3200 MT/s
  Device-4: DIMM8 type: DDR4 size: 16 GiB speed: 3200 MT/s
  Device-5: DIMM4 type: no module installed
  Device-6: DIMM3 type: no module installed
  Device-7: DIMM2 type: DDR4 size: 16 GiB speed: 3200 MT/s
  Device-8: DIMM1 type: DDR4 size: 16 GiB speed: 3200 MT/s
The boot time ...
08:03:07 ○ [fh@tiger] ~
 $ systemd-analyze
Startup finished in 48.785s (firmware) + 6.645s (loader) + 1.316s (kernel) + 3.016s (initrd) + 9.294s (userspace) = 1min 9.057s
graphical.target reached after 9.292s in userspace.
08:03:27 ○ [fh@tiger] ~
 $ systemd-analyze blame --no-pager
5.399s NetworkManager-wait-online.service
3.426s dev-sdb.device
3.426s dev-disk-by\x2did-ata\x2dSamsung_SSD_840_PRO_Series_S1AXNEAD509881Y.device
3.426s sys-devices-pci0000:00-0000:00:03.1-0000:02:00.0-0000:03:0a.0-0000:06:00.0-ata14-host13-target13:0:0-1…
3.426s dev-disk-by\x2dpath-pci\x2d0000:06:00.0\x2data\x2d6.0.device
3.426s dev-disk-by\x2ddiskseq-2.device
3.426s dev-disk-by\x2did-wwn\x2d0x50025385503607df.device
3.426s dev-disk-by\x2dpath-pci\x2d0000:06:00.0\x2data\x2d6.device
3.423s dev-disk-by\x2ddiskseq-2\x2dpart1.device
3.423s dev-disk-by\x2dlabel-private.device
3.423s dev-disk-by\x2dpath-pci\x2d0000:06:00.0\x2data\x2d6\x2dpart1.device
3.423s dev-disk-by\x2dpath-pci\x2d0000:06:00.0\x2data\x2d6.0\x2dpart-by\x2dpartuuid-0f28e6e1\x2deff8\x2d4fb0\…
3.423s dev-disk-by\x2dpartuuid-0f28e6e1\x2deff8\x2d4fb0\x2d9821\x2d234dd7add7f8.device
3.423s dev-disk-by\x2dpath-pci\x2d0000:06:00.0\x2data\x2d6.0\x2dpart-by\x2dlabel-private.device
3.423s dev-disk-by\x2did-ata\x2dSamsung_SSD_840_PRO_Series_S1AXNEAD509881Y\x2dpart1.device
3.423s dev-sdb1.device
3.423s dev-disk-by\x2dpath-pci\x2d0000:06:00.0\x2data\x2d6.0\x2dpart-by\x2duuid-1f3d1a6e\x2db4b5\x2d46da\x2d9…
3.423s dev-disk-by\x2duuid-1f3d1a6e\x2db4b5\x2d46da\x2d909a\x2d8a87a45dd18b.device
3.423s sys-devices-pci0000:00-0000:00:03.1-0000:02:00.0-0000:03:0a.0-0000:06:00.0-ata14-host13-target13:0:0-1…
3.423s dev-disk-by\x2dpath-pci\x2d0000:06:00.0\x2data\x2d6.0\x2dpart-by\x2dpartlabel-private.device
3.423s dev-disk-by\x2did-wwn\x2d0x50025385503607df\x2dpart1.device
3.423s dev-disk-by\x2dpartlabel-private.device
3.423s dev-disk-by\x2dpath-pci\x2d0000:06:00.0\x2data\x2d6.0\x2dpart-by\x2dpartnum-1.device
3.423s dev-disk-by\x2dpath-pci\x2d0000:06:00.0\x2data\x2d6.0\x2dpart1.device
3.406s dev-disk-by\x2dpath-pci\x2d0000:05:00.0\x2data\x2d4.device
3.406s dev-disk-by\x2did-ata\x2dSamsung_SSD_840_EVO_500GB_mSATA_S1KMNSAFB02237V.device
3.406s dev-sda.device
3.406s dev-disk-by\x2dpath-pci\x2d0000:05:00.0\x2data\x2d4.0.device
3.406s sys-devices-pci0000:00-0000:00:03.1-0000:02:00.0-0000:03:09.0-0000:05:00.0-ata4-host3-target3:0:0-3:0:…
3.406s dev-disk-by\x2ddiskseq-1.device
3.406s dev-disk-by\x2did-wwn\x2d0x5002538844584d30.device
3.397s dev-ttyS3.device
3.397s sys-devices-platform-serial8250-serial8250:0-serial8250:0.3-tty-ttyS3.device
3.396s dev-ttyS2.device
3.396s sys-devices-platform-serial8250-serial8250:0-serial8250:0.2-tty-ttyS2.device
3.396s dev-ttyS1.device
3.396s sys-devices-platform-serial8250-serial8250:0-serial8250:0.1-tty-ttyS1.device
3.395s dev-ttyS0.device
3.395s sys-devices-platform-serial8250-serial8250:0-serial8250:0.0-tty-ttyS0.device
3.392s sys-devices-platform-MSFT0101:00-tpmrm-tpmrm0.device
3.392s dev-tpmrm0.device
3.389s sys-module-fuse.device
3.389s sys-module-configfs.device
3.382s sys-devices-pci0000:00-0000:00:03.1-0000:02:00.0-0000:03:09.0-0000:05:00.0-ata4-host3-target3:0:0-3:0:…
3.382s dev-disk-by\x2dpath-pci\x2d0000:05:00.0\x2data\x2d4.0\x2dpart1.device
3.382s dev-disk-by\x2did-ata\x2dSamsung_SSD_840_EVO_500GB_mSATA_S1KMNSAFB02237V\x2dpart1.device
3.382s dev-sda1.device
3.382s dev-disk-by\x2dpartuuid-83088f4c\x2d115f\x2d463a\x2d8e84\x2dc25b9fa0a772.device
3.382s dev-disk-by\x2dpath-pci\x2d0000:05:00.0\x2data\x2d4.0\x2dpart-by\x2dpartuuid-83088f4c\x2d115f\x2d463a\…
3.382s dev-disk-by\x2dpath-pci\x2d0000:05:00.0\x2data\x2d4\x2dpart1.device
3.382s dev-disk-by\x2did-wwn\x2d0x5002538844584d30\x2dpart1.device
3.382s dev-disk-by\x2dpath-pci\x2d0000:05:00.0\x2data\x2d4.0\x2dpart-by\x2dpartnum-1.device
3.382s dev-disk-by\x2ddiskseq-1\x2dpart1.device
3.382s dev-disk-by\x2dpath-pci\x2d0000:05:00.0\x2data\x2d4.0\x2dpart-by\x2duuid-a0a54066\x2d5053\x2d4aaf\x2db…
3.382s dev-disk-by\x2dpath-pci\x2d0000:05:00.0\x2data\x2d4.0\x2dpart-by\x2dpartlabel-virtualbox.device
3.382s dev-disk-by\x2dpartlabel-virtualbox.device
3.382s dev-disk-by\x2duuid-a0a54066\x2d5053\x2d4aaf\x2db0de\x2d0cf5fefeb260.device
3.373s dev-disk-by\x2dpath-pci\x2d0000:21:00.0\x2dnvme\x2d1\x2dpart-by\x2dlabel-projects.device
3.373s dev-disk-by\x2did-nvme\x2dSamsung_SSD_990_PRO_2TB_S6Z2NJ0W505466B\x2dpart1.device
3.373s dev-disk-by\x2dpath-pci\x2d0000:21:00.0\x2dnvme\x2d1\x2dpart-by\x2duuid-04f0ac14\x2d1556\x2d4666\x2d9f…
3.373s dev-nvme0n1p1.device
3.373s dev-disk-by\x2dpartlabel-pro\x2dsrc\x2dtools.device
3.373s dev-disk-by\x2ddiskseq-3\x2dpart1.device
3.373s dev-disk-by\x2did-nvme\x2deui.0025384531408347\x2dpart1.device
3.373s sys-devices-pci0000:20-0000:20:01.1-0000:21:00.0-nvme-nvme0-nvme0n1-nvme0n1p1.device
3.373s dev-disk-by\x2dpath-pci\x2d0000:21:00.0\x2dnvme\x2d1\x2dpart1.device
3.373s dev-disk-by\x2duuid-04f0ac14\x2d1556\x2d4666\x2d9f12\x2d617ba471502c.device
3.373s dev-disk-by\x2dpath-pci\x2d0000:21:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartnum-1.device
3.373s dev-disk-by\x2dpartuuid-14acf004\x2d5615\x2d6646\x2d9f12\x2d617ba471502c.device
3.373s dev-disk-by\x2dpath-pci\x2d0000:21:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartuuid-14acf004\x2d5615\x2d6646\x…
3.373s dev-disk-by\x2did-nvme\x2dSamsung_SSD_990_PRO_2TB_S6Z2NJ0W505466B_1\x2dpart1.device
3.373s dev-disk-by\x2dlabel-projects.device
3.373s dev-disk-by\x2dpath-pci\x2d0000:21:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartlabel-pro\x2dsrc\x2dtools.device
3.370s dev-disk-by\x2did-nvme\x2dSamsung_SSD_990_PRO_2TB_S6Z2NJ0W505466B.device
3.370s dev-disk-by\x2ddiskseq-3.device
3.370s dev-disk-by\x2did-nvme\x2deui.0025384531408347.device
3.370s sys-devices-pci0000:20-0000:20:01.1-0000:21:00.0-nvme-nvme0-nvme0n1.device
3.370s dev-disk-by\x2dpath-pci\x2d0000:21:00.0\x2dnvme\x2d1.device
3.370s dev-disk-by\x2did-nvme\x2dSamsung_SSD_990_PRO_2TB_S6Z2NJ0W505466B_1.device
3.370s dev-nvme0n1.device
3.367s dev-disk-by\x2did-nvme\x2dSamsung_SSD_990_PRO_2TB_S6Z2NJ0W505466B\x2dpart2.device
3.367s dev-disk-by\x2ddiskseq-3\x2dpart2.device
3.367s dev-disk-by\x2duuid-db9d1c46\x2d1b32\x2d4942\x2d9bfa\x2d69d76ee44be2.device
3.367s dev-disk-by\x2dpath-pci\x2d0000:21:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartnum-2.device
3.367s dev-disk-by\x2dpath-pci\x2d0000:21:00.0\x2dnvme\x2d1\x2dpart-by\x2duuid-db9d1c46\x2d1b32\x2d4942\x2d9b…
3.367s dev-disk-by\x2dlabel-swap\x2don\x2dproject.device
3.367s dev-disk-by\x2dpath-pci\x2d0000:21:00.0\x2dnvme\x2d1\x2dpart2.device
3.367s dev-disk-by\x2dpartuuid-82c0829b\x2d2085\x2d482f\x2d9f3d\x2d9c7ef75325ac.device
3.367s dev-disk-by\x2dpath-pci\x2d0000:21:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartuuid-82c0829b\x2d2085\x2d482f\x…
3.367s dev-disk-by\x2dpath-pci\x2d0000:21:00.0\x2dnvme\x2d1\x2dpart-by\x2dlabel-swap\x2don\x2dproject.device
3.367s dev-disk-by\x2did-nvme\x2deui.0025384531408347\x2dpart2.device
3.367s dev-disk-by\x2did-nvme\x2dSamsung_SSD_990_PRO_2TB_S6Z2NJ0W505466B_1\x2dpart2.device
3.367s dev-nvme0n1p2.device
3.367s sys-devices-pci0000:20-0000:20:01.1-0000:21:00.0-nvme-nvme0-nvme0n1-nvme0n1p2.device
3.357s dev-nvme1n1.device
3.357s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1.device
3.357s sys-devices-pci0000:20-0000:20:01.2-0000:22:00.0-nvme-nvme1-nvme1n1.device
3.357s dev-disk-by\x2did-nvme\x2dSAMSUNG_MZVL21T0HCLR\x2d00BL7_S64PNX0T519991.device
3.357s dev-disk-by\x2did-nvme\x2dSAMSUNG_MZVL21T0HCLR\x2d00BL7_S64PNX0T519991_1.device
3.357s dev-disk-by\x2ddiskseq-4.device
3.357s dev-disk-by\x2did-nvme\x2deui.002538b521b93bcc.device
3.352s dev-disk-by\x2did-nvme\x2deui.002538b521b93bcc\x2dpart1.device
3.352s sys-devices-pci0000:20-0000:20:01.2-0000:22:00.0-nvme-nvme1-nvme1n1-nvme1n1p1.device
3.352s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart1.device
3.352s dev-disk-by\x2did-nvme\x2dSAMSUNG_MZVL21T0HCLR\x2d00BL7_S64PNX0T519991_1\x2dpart1.device
3.352s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart-by\x2duuid-AD24\x2dB748.device
3.352s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartnum-1.device
3.352s dev-nvme1n1p1.device
3.352s dev-disk-by\x2did-nvme\x2dSAMSUNG_MZVL21T0HCLR\x2d00BL7_S64PNX0T519991\x2dpart1.device
3.352s dev-disk-by\x2duuid-AD24\x2dB748.device
3.352s dev-disk-by\x2dpartuuid-519fa53d\x2dc862\x2d4efb\x2d948b\x2deee1a5d9c584.device
3.352s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartuuid-519fa53d\x2dc862\x2d4efb\x…
3.352s dev-disk-by\x2ddiskseq-4\x2dpart1.device
3.351s dev-disk-by\x2duuid-3cd93eae\x2d1d0d\x2d4ce6\x2da7e6\x2d7df665e8cede.device
3.351s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart3.device
3.351s dev-disk-by\x2did-nvme\x2dSAMSUNG_MZVL21T0HCLR\x2d00BL7_S64PNX0T519991\x2dpart3.device
3.351s dev-disk-by\x2dpartuuid-392cd4b5\x2d074a\x2d4b93\x2dba74\x2d42eb0bb5048c.device
3.351s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart-by\x2duuid-3cd93eae\x2d1d0d\x2d4ce6\x2da7…
3.351s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartnum-3.device
3.351s dev-disk-by\x2dlabel-swap.device
3.351s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartuuid-392cd4b5\x2d074a\x2d4b93\x…
3.351s dev-nvme1n1p3.device
3.351s dev-disk-by\x2did-nvme\x2deui.002538b521b93bcc\x2dpart3.device
3.351s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart-by\x2dlabel-swap.device
3.351s sys-devices-pci0000:20-0000:20:01.2-0000:22:00.0-nvme-nvme1-nvme1n1-nvme1n1p3.device
3.351s dev-disk-by\x2ddiskseq-4\x2dpart3.device
3.351s dev-disk-by\x2did-nvme\x2dSAMSUNG_MZVL21T0HCLR\x2d00BL7_S64PNX0T519991_1\x2dpart3.device
3.345s dev-disk-by\x2duuid-cafce1fc\x2da404\x2d48b9\x2db7e8\x2d00ec59a4e2c0.device
3.345s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart2.device
3.345s sys-devices-pci0000:20-0000:20:01.2-0000:22:00.0-nvme-nvme1-nvme1n1-nvme1n1p2.device
3.345s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartuuid-de0c9749\x2dc372\x2d43f4\x…
3.345s dev-nvme1n1p2.device
3.345s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart-by\x2duuid-cafce1fc\x2da404\x2d48b9\x2db7…
3.345s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartlabel-root.device
3.345s dev-disk-by\x2did-nvme\x2dSAMSUNG_MZVL21T0HCLR\x2d00BL7_S64PNX0T519991\x2dpart2.device
3.345s dev-disk-by\x2dpartuuid-de0c9749\x2dc372\x2d43f4\x2da952\x2df4d3e0d6eaf4.device
3.345s dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartnum-2.device
3.345s dev-disk-by\x2dpartlabel-root.device
3.345s dev-disk-by\x2did-nvme\x2deui.002538b521b93bcc\x2dpart2.device
3.345s dev-disk-by\x2ddiskseq-4\x2dpart2.device
3.345s dev-disk-by\x2did-nvme\x2dSAMSUNG_MZVL21T0HCLR\x2d00BL7_S64PNX0T519991_1\x2dpart2.device
2.358s plymouth-quit-wait.service
2.358s plymouth-quit.service
 796ms vmware-networks.service
 754ms NetworkManager.service
 688ms systemd-binfmt.service
 646ms systemd-resolved.service
 636ms systemd-timesyncd.service
 615ms docker.service
 555ms initrd-switch-root.service
 359ms a-private.mount
 331ms lvm2-monitor.service
 263ms plymouth-switch-root.service
 245ms user@1000.service
 125ms systemd-udev-trigger.service
 113ms containerd.service
  96ms udisks2.service
  79ms a-virtualbox.mount
  76ms upower.service
  69ms libvirtd.service
  68ms power-profiles-daemon.service
  67ms plymouth-start.service
  65ms systemd-journal-flush.service
  57ms cups.service
  57ms systemd-tmpfiles-setup-dev-early.service
  56ms modprobe@dm_mod.service
  56ms modprobe@loop.service
  54ms systemd-tmpfiles-setup.service
  49ms a-projects.mount
  48ms initrd-cleanup.service
  48ms proc-sys-fs-binfmt_misc.mount
  48ms sshd.service
  44ms initrd-parse-etc.service
  43ms systemd-remount-fs.service
  42ms user-runtime-dir@1000.service
  41ms systemd-vconsole-setup.service
  39ms plymouth-read-write.service
  37ms docker.socket
  36ms systemd-userdbd.service
  34ms boot-efi.mount
  34ms systemd-udevd.service
  30ms ModemManager.service
  30ms polkit.service
  24ms systemd-journald.service
  24ms systemd-hostnamed.service
  22ms systemd-random-seed.service
  20ms systemd-logind.service
  19ms dbus-broker.service
  17ms systemd-modules-load.service
  17ms nordvpnd.socket
  14ms systemd-fsck-root.service
  14ms dev-disk-by\x2ddiskseq-4\x2dpart3.swap
   9ms systemd-tmpfiles-setup-dev.service
   9ms systemd-fsck@dev-disk-by\x2duuid-AD24\x2dB748.service
   9ms dev-hugepages.mount
   8ms dev-mqueue.mount
   8ms sys-kernel-debug.mount
   8ms sys-kernel-tracing.mount
   7ms systemd-machined.service
   7ms kmod-static-nodes.service
   6ms rtkit-daemon.service
   6ms modprobe@drm.service
   6ms avahi-daemon.service
   6ms systemd-sysctl.service
   5ms systemd-udev-load-credentials.service
   5ms systemd-update-utmp.service
   5ms initrd-udevadm-cleanup-db.service
   4ms alsa-restore.service
   3ms systemd-user-sessions.service
   3ms modprobe@fuse.service
   3ms systemd-hibernate-resume.service
   3ms tmp.mount
   2ms sys-fs-fuse-connections.mount
   2ms sys-kernel-config.mount
If you’re a fan of boot speed, in my experience, booster starts about twice as fast as mkinitcpio or dracut in my specific use case without Nvidia.
Because booster does not add many kernel modules. However, it requires some tech knowledge to manage what I need to add some necessary modules manually.
Unlike mkinitcpio and dracut, which may automatically add a lot of unnecessary, bloated modules that I do not need. booster gives me more control and has some limitations.
If you’re a beginner, it’s better to stick with the default mkinitcpio and accept your unexpected boot time.
First, your boot time seems pretty normal and fine.
Second, as said, there is no universe in which windows BOOTED faster than that. Fast startup is enabled there by default, so it RESTORED maybe a second or two faster.
Third, you are in experienced user territory. And you do not sound that way, sorry. The possibility to break the system if you start messing with it without knowing what you’re doing is big.
Fourth, now ontopic: the ways to reduce boot time are disabling some services (ideas above, but yours are fine), blacklisting some modules (but i doubt how much will that bring), and modifying the hooks in the init. That can save several seconds.
https://wiki.archlinux.org/title/Mkinitcpio
I think I was using Hybrid Hibernation
I understand that this:
You can’t do anything really about the firmware boot time, it is your motherboard initializing (you could enable FastBoot but that would break things like keyboard before you reach the system so don’t do that), the loader time you can simply modify it, in the GRUB config file.
Open /etc/default/grub and edit the line for GRUB_TIMEOUT like this GRUB_TIMEOUT=1, save the file, then rebuild GRUB config with command sudo update-grub and then reboot.
Can I put 0? Does it work?
Yes, you can.
However, this may limit your ability to quickly change boot options, if needed; for example, selecting a different kernel to boot.
The reason the timeout exists is to give you that opportunity, before the computer continues to boot.
Usually, touching the Space bar before the timeout expires would allow this.
Three seconds seems a fair compromise; it’s a tradeoff, really.
You might also consider changing the timeout that allows you to boot to the BIOS; it’s typically set at around 5 seconds (by default) but it varies according to hardware used. The timeout would be found in your BIOS (somewhere).
I wouldn’t recommend setting this too short, though.
You can hide the menu completely if you will. In 99% of the topics however newbies scream they cannot access the menu then, obviously incapable of pumping shift or esc fast enough.
My general advice is, as a newbie, keep the customizations to a minimum. There is a reason for the default settings to be as they are. But i somehow have the feeling you want “learning by (un)doing”.
It will not work if you have other OS detected by GRUB it will fallback to 10 seconds. anyway with 0 it is very hard/impossible then to get the grub menu if needed, 1 second lets you some time (1 second) to push the key to show the GRUB menu.
