I tried:
nmcli device wifi connect SSID password YOUR_PASSWORD
And the error says “Errore: nessun dispositivo Wi-Fi trovato.” and it means that nmcli couldn’t find any device.
Edit: my wifi device info:
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard
driver: bcma-pci-bridge v: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s
Welcome to Manjaro!
Please read the information behind this link. It will help you to post necessary information.
[HowTo] Provide System Information
Please press the three dots … below your post and then press the
If you give us information about your system, we can see what we’re talking about and make better suggestions.
You can do this by using inxi in a terminal or in console.
Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
Copy the output from inxi (including the command) and paste it into your post.
To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
(Wisdom lies in reading )
there is also nmtui - a terminal based graphical UI
may be easier to use/navigate
but yes, as @andreas85 said - system info is needed
Thank you, just edited the post
prepend your command with:
LANG=C
the output will be in english then
It looks like that there is no valid driver for your wifi card present
inxi -Fazy
is a command that I remember that will get you (and us) that info
along with a lot more …
Thank you, in “Activate a connection” i see only Ethernet: USB and PCI, what I should do?
Output of inxi -Fazy
Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=583ac903-6214-4258-8809-00ef4e8d9b56 rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP Notebook
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 80C2 v: 96.02 serial: <superuser required>
UEFI: Insyde v: F.02 date: 03/24/2015
ID-1: BAT1 charge: 22.6 Wh (100.0%) condition: 22.6/41.4 Wh (54.6%)
volts: 16.7 min: 14.8 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse
status: discharging
Info: model: Intel Core i7-5500U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1112 high: 2353 min/max: 500/3000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 500 3: 800 4: 2353
bogomips: 19161
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile] vendor: Hewlett-Packard driver: radeon v: kernel
alternate: amdgpu arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 03:00.0 chip-ID: 1002:6660 class-ID: 0380
temp: 43.0 C
Device-3: Chicony HP Truevision HD type: USB driver: uvcvideo bus-ID: 1-5:4
chip-ID: 04f2:b509 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.7 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting,radeon alternate: fbdev,vesa dri: iris,radeonsi gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: Samsung 0x4e51 built: 2014 res: 1366x768 hz: 60
dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:9ca0 class-ID: 0403
Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
lanes: 1 bus-ID: 04:00.0 chip-ID: 14e4:4365 class-ID: 0280
IF-ID-1: enp0s20u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Samsung Galaxy series misc. (tethering mode) type: USB
driver: rndis_host v: kernel bus-ID: 1-2:12 chip-ID: 04e8:6863 class-ID: 0a00
serial: <filter>
Device-2: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
Report: ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: N/A
Local Storage: total: 931.51 GiB used: 9.17 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 244.14 GiB size: 239.25 GiB (98.00%) used: 9.15 GiB (3.8%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 56.0 C pch: 44.0 C mobo: N/A gpu: radeon
temp: 43.0 C
Processes: 183 Uptime: 1h 22m wakeups: 7 Memory: 15.54 GiB
used: 2.09 GiB (13.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1042 libs: 315 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.25
show us what you see - show us the output of a command that provides system info
don’t tell us what you see - show us
edit:
I see - you just added that info above
no wifi device present - however
a possible candidate (with no driver) is there
no idea at the moment how to make it work …
Thank you, I’m new on this forum, should I mark this as solution and make another topic asking for driver of my wifi device or not?
it’s not a solution - it’s the start of how to find a driver for that device
you could now, with that information, try on your own …
But maybe it would be better to start a new thread, with all that info from the start,
and ask how to make that device work - if it can be made to work.
or adjust the title of the thread and continue here - I don’t know what might be better
Please do not create duplicate topics for the same issue. You marked this post as solved. If it’s not, unmark it and follow up.
not the way to go, it seems
new thread was closed
and I said it was not a solution
stay here - perhaps adjust the title …
Just solved!
FIrst I opened settings, then Manjaro Settings Manager, then Hardware configuration, I installed the driver, rebooted and then with nmtui i connected Manjaro to wifi.
ok - so there was a driver to use and install
which was not installed by default - obviously
Could you tell us what it was?
so “we” can learn from it
inxi -Fazy
again -
with the now functioning driver
would help see what was done, what was missing for you
Thanks!
anon33601770:
inxi -Fazy
ystem:
status: discharging
Speed (MHz): avg: 1274 high: 3000 min/max: 500/3000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 798 3: 3000 4: 500
bogomips: 19167
vulnerable
temp: 44.0 C
Device-3: Chicony HP Truevision HD type: USB driver: uvcvideo bus-ID: 1-5:5
loaded: modesetting unloaded: radeon alternate: fbdev,vesa dri: iris,radeonsi
gpu: i915 display-ID: :0.0 screens: 1
class-ID: 0403
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-4:4 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 10.38 GiB (1.1%)
ID-1: / raw-size: 244.14 GiB size: 239.25 GiB (98.00%) used: 10.36 GiB (4.3%)
System Temperatures: cpu: 56.0 C pch: 45.5 C mobo: N/A gpu: radeon
temp: 44.0 C
Processes: 187 Uptime: 42m wakeups: 5 Memory: 15.54 GiB used: 1.9 GiB (12.2%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman pkgs: 1082 libs: 341
