I use Manjaro from architect, used an unconfigured KDE with only the plasma-shell, however, I did notice this problem as well on my previous XFCE install.
There is horizontal flickering, most prominent whenever I have a steam game open. I don’t think this is unique to steam or steam games. I have a demo, but not allowed to post links.
I have an intel i5 4590 and an AMD RX570 4GB, with 8GB RAM.
dmesg doesn’t seem to have anything related to mesa or amdgpu
I have tested the following kernels:
5.8 and 5.4 the problem is very prominent, and 4.14 the problem is greatly reduced, but more apparent once I open a steam game.
It is most noticeable on dark colours and gradients.
I noticed this started happening when I moved from preconfigured desktop environments in Architect to unconfigured, though it’s possible there is some other change that coincidentally occurred at the same time.
I also noticed that if I open a terminal window, for example, and move the mouse from the flickering window to the terminal, the flickering reduces or even stops completely, and returns when the mouse hovers back over the flickering window.
When I have something like a steam game open, the flickering is intense, and visible on a static image desktop.
https://streamable.com/o20r16
Inxi output:
Kernel: 5.4.67-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: initrd=\amd-ucode.img initrd=\intel-ucode.img
initrd=\initramfs-5.4-x86_64.img
root=UUID=353a3615-3b50-44ec-ad68-f65b2dedf259 rw
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: H81M-S2PV serial: <filter>
UEFI: American Megatrends v: F9 date: 08/11/2015
RAM: total: 7.74 GiB used: 4.26 GiB (55.1%)
RAM Report: missing: Required program dmidecode not available
Topology: Quad Core model: Intel Core i5-4590 bits: 64 type: MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28
L2 cache: 6144 KiB bogomips: 26348
Speed: 1587 MHz min/max: 800/3700 MHz Core speeds (MHz): 1: 1014 2: 1081
3: 1158 4: 1101
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep
smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Type: l1tf
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 01:00.0
chip ID: 1002:67df
Display: x11 server: X.org 1.20.9 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting alternate: fbdev,vesa
resolution: <xdpyinfo missing>
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aaf0
Device-3: Solid Year AWC113 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 2-4:4 chip ID: 060b:8059
Sound Server: ALSA v: k5.4.67-1-MANJARO
vendor: Gigabyte driver: r8168 v: 8.048.03-NAPI modules: r8169 port: d000
bus ID: 03:00.0 chip ID: 10ec:8168
Local Storage: total: 1.13 TiB used: 349.51 GiB (30.3%)
ID-1: /dev/sda vendor: PNY model: CS900 240GB SSD size: 223.57 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 0P13 scheme: GPT
ID-2: /dev/sdb vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC49 scheme: MBR
ID-1: / raw size: 223.07 GiB size: 218.57 GiB (97.98%)
used: 25.19 GiB (11.5%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: 353a3615-3b50-44ec-ad68-f65b2dedf259
ID-2: /boot raw size: 512.0 MiB size: 511.0 MiB (99.80%)
used: 94.0 MiB (18.4%) fs: vfat dev: /dev/sda1 label: N/A uuid: B7A9-3188
ID-3: /mnt/hamza/HDD raw size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 324.23 GiB (35.4%) fs: ext4 dev: /dev/sdb1 label: N/A
uuid: 0e320d10-7528-4e71-850a-291e613b8489
ID-1: swap-1 type: file size: 7.74 GiB used: 3.2 MiB (0.0%) priority: -2
file: /swapfile
Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8008
Hub: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 2-1:2 info: Logitech Keyboard K120 type: Keyboard,HID
chip ID: 046d:c31c
Device-2: 2-2:3 info: Logitech Bluetooth mini-receiver type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 046d:c054
Device-3: 2-4:4 info: Solid Year AWC113 type: Video,Audio
chip ID: 060b:8059
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8000
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 29 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1238
Processes: 171 Uptime: 1h 36m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 972 lib: 366 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.05
Any ideas?
