Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=463e8966-3361-469d-8993-4e40e654e335 rw quiet apparmor=1
security=apparmor resume=UUID=99927f33-25e8-444c-9cc2-52152bfaad8c
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: Acer product: Aspire 5755G v: V1.21 serial: <filter>
Chassis: type: 10 v: 1.21 serial: <filter>
Mobo: Acer model: JV51_HR serial: <filter> BIOS: Acer v: 1.21
date: 08/09/2012
RAM: total: 3.69 GiB used: 1.36 GiB (36.9%)
Info: Dual Core model: Intel Core i5-2450M bits: 64 type: MT MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
cache: L2: 3 MiB bogomips: 19963
Speed: 798 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 798 2: 798 3: 797
4: 798
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear
mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse sse2
sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer
vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0126 class-ID: 0300
Device-2: NVIDIA GF108M [GeForce GT 620M/630M/635M/640M LE] driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus-ID: 01:00.0 chip-ID: 10de:0de9
class-ID: 0300
Device-3: Chicony 1.3M HD WebCam type: USB driver: uvcvideo bus-ID: 1-1.3:3
chip-ID: 04f2:b21b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: intel display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
v: 3.3 Mesa 21.1.6 compat-v: 3.0 direct render: Yes
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.33 running: no
Device-1: Broadcom NetLink BCM57785 Gigabit Ethernet PCIe
vendor: Acer Incorporated ALI driver: tg3 v: kernel port: 3040
bus-ID: 02:00.0 chip-ID: 14e4:16b5 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Broadcom BCM43227 802.11b/g/n vendor: Foxconn driver: wl v: kernel
modules: bcma port: 3040 bus-ID: 03:00.0 chip-ID: 14e4:4358 class-ID: 0280
Device-1: Foxconn / Hon Hai Acer Module type: USB driver: btusb v: 0.8
bus-ID: 1-1.6:5 chip-ID: 0489:e033 class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 298.09 GiB used: 10.76 GiB (3.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK3276GSX
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 1A scheme: MBR
Optical-1: /dev/sr0 vendor: PIONEER model: DVD-RW DVRTD11RS rev: 1.01
dev-links: cdrom
ID-1: / raw-size: 289.96 GiB size: 284.35 GiB (98.06%)
used: 10.76 GiB (3.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 463e8966-3361-469d-8993-4e40e654e335
ID-1: swap-1 type: partition size: 8.12 GiB used: 2 MiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 99927f33-25e8-444c-9cc2-52152bfaad8c
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.3:3 info: Chicony 1.3M HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b21b
Device-2: 1-1.6:5 info: Foxconn / Hon Hai Acer Module type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0489:e033
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 2-1.4:6 info: SteelSeries ApS SteelSeries Rival 100 Gaming Mouse
type: HID,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 130mA chip-ID: 1038:1702 class-ID: 0301
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 68.0 C mobo: N/A
Processes: 205 Uptime: 5h 19m wakeups: 2 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1111 lib: 306
flatpak: 0 Shell: Zsh v: 5.8 running-in: xfce4-terminal inxi: 3.3.06
Output of aplay --list-devices
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC269VB Analog [ALC269VB Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 0 [HDMI 0]
Subdevices: 1/1
First of all i thought this was some hardware issue but Youtube works fine but websites like spotify web player, netflix, prime videos have hissing or some static noise.
i tested firefox, chrome, chromium, opera. Same results
