The Output of inxi -zv8:
Kernel: 6.18.24-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
root=UUID=858f7022-23f6-49c3-8cbf-9956643da584 rw rootflags=subvol=@
resume=UUID=858f7022-23f6-49c3-8cbf-9956643da584 resume_offset=21688691
Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
Type: Convertible System: Dell product: Inspiron 16 7620 2-in-1 v: N/A
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: Dell model: 0FD3D2 v: A00 serial: <superuser required> part-nu: 0B37
uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.30.1
date: 09/09/2025
ID-1: BAT0 charge: 6.2 Wh (8.9%) condition: 69.5/87 Wh (79.9%) health: good
temp: 28.3 C volts: 11.79 min: 11.4 model: SMP DELL 817GN98 made: 2022-04-21
type: Li-poly serial: <filter> charging: status: charging control:
start: 60% end: 80% type: custom
avail: adaptive,custom,fast,standard,trickle cycles: N/A
System RAM: total: 16 GiB available: 15.3 GiB used: 4.3 GiB (28.1%)
Device-1: DIMM 1 type: DDR4 detail: synchronous size: 8 GiB
speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: 80AD000080AD part-no: HMAA1GS6CJR6N-XN serial: <filter>
Device-2: DIMM 2 type: DDR4 detail: synchronous size: 8 GiB
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x43B
Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2
st: 8 smt: enabled cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32
KiB, 8x64 KiB L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 400 min/max: 400/4700:3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
bogomips: 79872
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Xe process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce MX550] vendor: Dell driver: nvidia
v: 595.58.03 non-free: 550-580.xx+ status: current (as of 2025-11;
EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 bus-ID: 0000:01:00.0 chip-ID: 10de:1f9f class-ID: 0302
Device-3: Microdia Integrated_Webcam_FHD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3 chip-ID: 0c45:673f
class-ID: 0e02
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: Samsung 0x4164 built: 2021 res: mode: 3840x2400
hz: 60 scale: 190% (1.9) to: 2021x1263 dpi: 284 gamma: 1.2 chroma: red:
x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue: x: 0.137 y: 0.047 white:
x: 0.314 y: 0.329 size: 344x215mm (13.54x8.46") diag: 406mm (16")
ratio: 16:10 modes: 3840x2400
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 26.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (ADL
GT2) device-ID: 8086:46a6 memory: 14.94 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.341 layers: 2 device: 0 type: discrete-gpu
name: NVIDIA GeForce MX550 driver: nvidia v: 595.58.03 device-ID: 10de:1f9f
surfaces: N/A
wl: wayland-info x11: xdpyinfo,xprop
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: sof-audio-pci-intel-tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8
class-ID: 0401
API: ALSA v: k6.18.24-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 251.74 GiB (26.4%)
model: PM991a NVMe 1024GB size: 953.87 GiB block-size: physical: 512 B
fw-rev: 26304039 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
used: 150.75 GiB (30.9%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: 858f7022-23f6-49c3-8cbf-9956643da584
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)
used: 91.7 MiB (46.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: ESP uuid: 7459-6D7E
ID-3: /home raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
ID-4: /home/<filter>/ ...
ID-5: /swap raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
ID-6: /var/cache raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
ID-7: /var/log raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
ID-1: swap-1 type: file size: 20 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 444.59 GiB fs: ntfs label: OS
uuid: A4D29308D292DE3C
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.09 GiB fs: ntfs label: N/A
uuid: 76EA9B9CEA9B56E9
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 18.14 GiB fs: ntfs label: Image
uuid: 8664431964430AFF
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.43 GiB fs: ntfs
label: DELLSUPPORT uuid: 06E4D2BFE4D2B063
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-5:2 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:639c class-ID: ef00 serial: <filter>
Device-2: 3-6:3 info: Microdia Integrated_Webcam_FHD type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0c45:673f class-ID: 0e02
Device-3: 3-10:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
System Temperatures: cpu: 52.0 C mobo: 48.0 C sodimm: 48.0 C
Fan Speeds (rpm): cpu: 2608
Packages: 1392 pm: pacman pkgs: 1382 libs: 373 tools: pamac pm: flatpak
pkgs: 10
1: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/testing/$repo/$arch
2: https://mirror.2degrees.nz/manjaro/testing/$repo/$arch
3: https://ct.mirror.garr.it/mirrors/manjaro/testing/$repo/$arch
... I don't think these are all required
74: https://nnenix.mm.fcix.net/manjaro/testing/$repo/$arch
75: https://mirror.fcix.net/manjaro/testing/$repo/$arch
76: https://kartolo.sby.datautama.net.id/manjaro/testing/$repo/$arch
Processes:
CPU top: 5 of 387
1: cpu: 11.9% command: firefox pid: 3000 mem: 765.1 MiB (4.8%)
Memory top: 5 of 387
1: mem: 765.1 MiB (4.8%) command: firefox pid: 3000 cpu: 11.9%
Processes: 387 Power: uptime: 7m states: freeze,mem,disk suspend: s2idle
image: 6.02 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 260 default: graphical tool: systemctl
Compilers: clang: 22.1.3 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.40
Parts I have removed are marked with “…”
Mod Edit: Fixed formatting
I should also mention that I have tried some things and currently the systems pretends to hibernate but at the same time managed to lose 80%(until empty) battery in under 24 hours while it should have been in hibernation
I get HOOKS=(base udev autodetect microcode kms modconf block keyboard keymap consolefont plymouth filesystems resume)
resume seems to be present
I have been on the mentioned arch wiki site already, that’s how I got it to a place where it was running, or so I think, sometime ago
If I didn’t miss anything the second page is general information about sleep states which I roughly knew but not in the detail provided here
When checking what exactly my Power Management settings where I discovered The action you had previously configured for when the lid is closed is now unsupported on your system. Please select a different one. where I had previously set it to hibernate
Mod edit: Merged consecutive posts. Please use the Edit feature to add more information.
