I am new to linux and Manjaro. I downloaded and installed Manjaro Gnome edition as it came in most recommended for touch screen devices.
Well, my device is a 2 in 1 detachable that has a full qwerty keyboard. It is powered by an Intel Atom x5 Z83xx CPU and has 4 gigs of ram.
I’ve installed the manjaro os successfully but I can’t get the touchscreen to work and I am having issues with the WiFi adapter being recognized by the OS. The wifi should be a Broadcom BCM 43438 chip. When I run <sudo dmesg | grep BCM> I don’t get any return whatsoever. I got Bluetooth to work and I am so confused as both of these features are from the same chip.
I am planning on fully converting to linux as it absolutely less resource demanding, I get 5 hours of battery life while on Windows 10 that drops down to 2.5 hours. The main use for this device is for media playback.
Any help with figuring out the touchscreen and the wifi adapter would be awesome. Right now I am using the keyboard and the touchpad and running a tethered internet connection through my phone.
Thanks!
Fabby
21 April 2021 09:29
2
Welcome to Manjaro!
Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text .
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
Thank you for your response I read the good information article and I’ll keep that in mind for any future requests and questions I may have.
Here is the inxi output:
Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=34931d77-9826-40fd-87d6-25721abf8fc8 rw quiet splash apparmor=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: jumper product: EZpad6 v: N/A serial: <filter>
Mobo: Insyde model: Cherry Trail CR v: Type2 - Board Version
serial: <filter> UEFI: INSYDE v: JP9x.WT211Q.OLBKEEA03 date: 02/27/2017
ID-1: axp288_fuel_gauge charge: 90% condition: N/A volts: 3.6 min: N/A
model: N/A type: Li-ion serial: N/A status: Discharging
RAM: total: 3.75 GiB used: 1.86 GiB (49.7%)
Info: Quad Core model: Intel Atom x5-Z8350 bits: 64 type: MCP arch: Airmont
family: 6 model-id: 4C (76) stepping: 4 microcode: 411 cache: L2: 1024 KiB
bogomips: 11520
Speed: 1919 MHz min/max: 480/1920 MHz Core speeds (MHz): 1: 1919 2: 1778
3: 1897 4: 1508
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts clflush
cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept erms
est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs
pge pni popcnt pse pse36 pti rdrand rdtscp rep_good sep smep ss sse sse2
tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi vpid xtopology
xtpr
Type: spec_store_bypass status: Not affected
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:22b0 class-ID: 0300
Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: Mesa DRI Intel HD Graphics (CHV) v: 4.6 Mesa 21.0.2
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
Imaging Unit
driver: N/A alternate: atomisp bus-ID: 00:03.0 chip-ID: 8086:22b8
class-ID: 0480
Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: no
Message: No device data found.
IF-ID-1: enp0s20u1 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Xiaomi MI 3W type: USB driver: rndis_host v: kernel bus-ID: 1-1:6
chip-ID: 2717:0388 class-ID: 0a00 serial: <filter>
Report-ID: ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 87.16 GiB used: 8.26 GiB (9.5%)
ID-1: /dev/mmcblk0 maj-min: 179:24 model: USD00 size: 28.92 GiB block-size:
physical: 512 B logical: 512 B rotation: SSD serial: <filter> scheme: MBR
ID-2: /dev/mmcblk1 maj-min: 179:0 vendor: Samsung model: CJNB4R
size: 58.24 GiB block-size: physical: 512 B logical: 512 B rotation: SSD
serial: <filter> rev: 0x8 scheme: GPT
ID-1: / raw-size: 19.85 GiB size: 19.37 GiB (97.58%) used: 8.22 GiB (42.4%)
fs: ext4 dev: /dev/mmcblk1p5 maj-min: 179:5 label: N/A
uuid: 34931d77-9826-40fd-87d6-25721abf8fc8
used: 43.7 MiB (45.5%) fs: vfat dev: /dev/mmcblk1p1 maj-min: 179:1
label: SYSTEM uuid: 90B9-6063
ID-1: /dev/mmcblk0p1 maj-min: 179:25 size: 2.59 GiB fs: iso9660
label: MANJARO_GNOME_2101 uuid: 2021-04-10-10-44-02-00
ID-2: /dev/mmcblk0p2 maj-min: 179:26 size: 4 MiB fs: vfat label: MISO_EFI
uuid: C29E-F10D
ID-3: /dev/mmcblk1p2 maj-min: 179:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/mmcblk1p3 maj-min: 179:3 size: 37.42 GiB fs: ntfs label: Windows
uuid: ECECBDD2ECBD96F4
ID-5: /dev/mmcblk1p4 maj-min: 179:4 size: 764 MiB fs: ntfs label: Recovery
uuid: 5C4ABE884ABE5E88
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 7 rev: 2.0
Device-1: 1-1:6 info: Xiaomi MI 3W type: Bluetooth,CDC-Data
driver: rndis_host interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 500mA
Hub-2: 1-4:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-4.1:3 info: GreenAsia USB Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 0e8f:00fb class-ID: 0301
Device-2: 1-4.3:4 info: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD
type: Keyboard,HID driver: itetech,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 258a:6a88 class-ID: 0300
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 209 Uptime: 9m wakeups: 3 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 1149 lib: 293 flatpak: 0 Shell: Zsh
v: 5.8 running-in: gnome-terminal inxi: 3.3.04
I am going to add the most relevant stuff to my profile as well.
Fabby
23 April 2021 19:47
4
You have an LTS kernel, and that’s good, but 5.4 LTS is a little bit more stable than 5.10 so could you try that one first before we do anything else?
If you’ve tried that already:
markojs:
Never heard about that brand, so try the latest and greatest newest kernel then: 5.12.
If you don’t kow how to do that, shout out!
pobrn
23 April 2021 20:30
5
Please post the output of
sudo libinput list-devices
Tried installing and booting on both Kernel Versions. I didn’t notice any changes in the system. Currently running on 5.12.
Device: Power Button
Kernel: /dev/input/event2
Group: 1
Seat: seat0, default
Capabilities: keyboard
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Middle emulation: n/a
Calibration: n/a
Scroll methods: none
Click methods: none
Disable-w-typing: n/a
Accel profiles: n/a
Rotation: n/a
Device: Video Bus
Kernel: /dev/input/event5
Group: 2
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Kernel: /dev/input/event1
Group: 3
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: Lid Switch
Kernel: /dev/input/event0
Group: 4
Capabilities: switch
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: YSTEK USB Mouse
Kernel: /dev/input/event13
Group: 5
Capabilities: pointer
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: disabled
Nat.scrolling: disabled
Middle emulation: disabled
Calibration: n/a
Scroll methods: button
Click methods: none
Accel profiles: flat *adaptive
Rotation: n/a
Device: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD
Kernel: /dev/input/event14
Group: 6
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Kernel: /dev/input/event15
Group: 6
Capabilities: keyboard pointer
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Calibration: n/a
Click methods: none
Rotation: n/a
Device: bytcht-es8316 Headset
Kernel: /dev/input/event9
Group: 7
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: Intel HID events
Kernel: /dev/input/event3
Group: 8
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: gpio-keys
Kernel: /dev/input/event6
Group: 9
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: gpio-keys
Kernel: /dev/input/event7
Group: 9
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: gpio-keys
Kernel: /dev/input/event8
Group: 9
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
pobrn
23 April 2021 21:08
7
Sad news is that the touchscreen is not recognized. Please post the output of
ls -l /sys/bus/acpi/devices/
ls -l /sys/bus/i2c/devices/
sudo dmesg | egrep -i '(hid|input|touch|screen)'
I am playing around in the bios of the device and found a section inside the Setup Utility panel called I2C Touch Devics I was set to Goodix.
I have MSSL 1680 and Focaltech as alternatives. Should I try to boot with other option selected than Goodix?
[ 1.391888] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 1.392092] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 1.496478] hid: raw HID events driver (C) Jiri Kosina
[ 6.628287] input: Intel HID events as /devices/pci0000:00/INT33D5:00/input/input3
[ 7.612028] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 8.136022] input: gpio-keys as /devices/platform/ACPI0011:00/gpio-keys.1.auto/input/input5
[ 8.158433] input: gpio-keys as /devices/platform/ACPI0011:00/gpio-keys.2.auto/input/input6
[ 8.161410] input: gpio-keys as /devices/platform/INT33D3:00/gpio-keys.3.auto/input/input7
[ 9.376843] input: bytcht-es8316 Headset as /devices/pci0000:00/808622A8:00/bytcht_es8316/sound/card0/input8
[ 9.882860] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input9
[ 11.718404] input: Intel HDMI/DP LPE Audio HDMI/DP,pcm=0 as /devices/pci0000:00/0000:00:02.0/hdmi-lpe-audio/sound/card1/input10
[ 11.718697] input: Intel HDMI/DP LPE Audio HDMI/DP,pcm=1 as /devices/pci0000:00/0000:00:02.0/hdmi-lpe-audio/sound/card1/input11
[ 11.720374] input: Intel HDMI/DP LPE Audio HDMI/DP,pcm=2 as /devices/pci0000:00/0000:00:02.0/hdmi-lpe-audio/sound/card1/input12
[ 11.859179] input: YSTEK USB Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.1/1-4.1:1.0/0003:0E8F:00FB.0001/input/input13
[ 11.867580] hid-generic 0003:0E8F:00FB.0001: input,hidraw0: USB HID v1.10 Mouse [YSTEK USB Mouse] on usb-0000:00:14.0-4.1/input0
[ 11.872304] input: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.0/0003:258A:6A88.0002/input/input14
[ 11.931769] hid-generic 0003:258A:6A88.0002: input,hidraw1: USB HID v1.10 Keyboard [EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD] on usb-0000:00:14.0-4.3/input0
[ 11.948616] input: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:258A:6A88.0003/input/input15
[ 11.948856] input: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:258A:6A88.0003/input/input16
[ 12.004362] input: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:258A:6A88.0003/input/input17
[ 12.004538] input: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD Wireless Radio Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:258A:6A88.0003/input/input18
[ 12.006336] hid-generic 0003:258A:6A88.0003: input,hiddev0,hidraw2: USB HID v1.10 Mouse [EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD] on usb-0000:00:14.0-4.3/input1
[ 12.006472] usbcore: registered new interface driver usbhid
[ 12.006478] usbhid: USB HID core driver
[ 12.144939] input: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.0/0003:258A:6A88.0002/input/input19
[ 12.201341] itetech 0003:258A:6A88.0002: input,hidraw1: USB HID v1.10 Keyboard [EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD] on usb-0000:00:14.0-4.3/input0
[ 12.393674] input: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:258A:6A88.0003/input/input20
[ 12.452654] itetech 0003:258A:6A88.0003: input,hiddev0,hidraw2: USB HID v1.10 Mouse [EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD] on usb-0000:00:14.0-4.3/input1
[ 23.830321] rfkill: input handler disabled
Awkward, I didn’t notice any change in the output for sudo libinput list-devices when using Focaltech or MSSL
pobrn
23 April 2021 22:31
11
Then can you go back to “Goodix” and post the output of the other two commands from my earlier comment?
Full output for those commands under Goodix:
lrwxrwxrwx 1 root root 0 апр 24 00:47 10EC5640:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/10EC5640:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 10EC5651:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/10EC5651:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 10TI3100:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/10TI3100:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 80860F14:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/80860F14:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 80860F14:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/80860F14:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 80860F14:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/80860F14:02
lrwxrwxrwx 1 root root 0 апр 24 00:47 80860F14:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/80860F14:03
lrwxrwxrwx 1 root root 0 апр 24 00:47 80862286:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/80862286:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 80862288:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/80862288:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 80862289:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/80862289:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 8086228A:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228A:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 8086228A:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228A:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 8086228E:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228E:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 8086228E:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228E:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 8086228E:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228E:02
lrwxrwxrwx 1 root root 0 апр 24 00:47 8086229C:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/8086229C:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 808622A8:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622A8:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 808622C0:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C0:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 808622C1:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 808622C1:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 808622C1:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:02
lrwxrwxrwx 1 root root 0 апр 24 00:47 808622C1:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:03
lrwxrwxrwx 1 root root 0 апр 24 00:47 808622C1:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:04
lrwxrwxrwx 1 root root 0 апр 24 00:47 808622C1:05 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:05
lrwxrwxrwx 1 root root 0 апр 24 00:47 808622C1:06 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:06
lrwxrwxrwx 1 root root 0 апр 24 00:47 808622D8:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622D8:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 ACPI0003:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0003:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 ACPI000C:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/ACPI000C:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 ACPI0011:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0011:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 ADMA22A8:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622A8:00/ADMA22A8:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 AMCR22A8:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/AMCR22A8:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 APTA0330:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:06/APTA0330:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 APTA0330:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:06/APTA0330:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 AUTH2750:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228E:00/AUTH2750:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 BCM2E1A:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228A:00/BCM2E1A:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 BCM2E3A:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228A:00/BCM2E3A:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 BCM2E64:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228A:00/BCM2E64:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 BCM2E74:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228A:00/BCM2E74:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 BCM2E7B:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228A:00/BCM2E7B:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 BCM4356:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/BCM4356:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 BCM4752:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228A:01/BCM4752:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 BOSC0200:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:02/BOSC0200:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:04
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:05 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:05
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:06 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:06
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:07 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:07
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:08 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:08
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:09 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:09
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:0a -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:09/device:0a
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:0b -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:0b
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:0c -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:0b/device:0c
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:0d -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:0d
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:0e -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:0e
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:0f -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:0f
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:10 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:10
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:11 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:11
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:12 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:11/device:12
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:13 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:13
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:14 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:13/device:14
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:15 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:15
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:16 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:15/device:16
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:17 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:17
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:18 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:17/device:18
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:19 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/device:19
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:1a -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1a
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:1b -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/80860F14:00/device:1b
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:1c -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1c
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:1d -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1c/device:1d
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:1e -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:1f -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/device:1f
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:20 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:21 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/device:21
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:22 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:22
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:23 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:22/device:23
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:24 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:24
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:25 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:24/device:25
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:26 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:26
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:27 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:27
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:28 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:28
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:29 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:29
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:2a -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:2a
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:2b -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:2b
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:2c -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:2c
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:2d -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:2d
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:2e -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:2e
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:2f -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:2f
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:30 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:30
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:31 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:31
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:32 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:32
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:33 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/80860F14:02/device:33
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:34 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/80860F14:02/device:34
lrwxrwxrwx 1 root root 0 апр 24 00:47 device:35 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/USBC000:00/device:35
lrwxrwxrwx 1 root root 0 апр 24 00:47 DMY0001:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:05/DMY0001:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 ESSX8316:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/ESSX8316:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 ESSX8316:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:02/ESSX8316:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 ESSX8396:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/ESSX8396:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 FTSC0001:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:04/FTSC0001:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 FUSB0300:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/FUSB0300:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 GDIX1001:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:04/GDIX1001:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 GPTC0001:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/GPTC0001:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 HAD022A8:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/HAD022A8:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 HIMX2051:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/HIMX2051:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 HIMX2051:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/HIMX2051:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 HIMX5040:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/HIMX5040:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 HIMX5040:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/HIMX5040:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 IMPJ0003:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/IMPJ0003:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 IMPJ0003:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/IMPJ0003:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT0002:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT0002:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT0800:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/INT0800:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT339A:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:03/INT339A:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33A2:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228A:01/INT33A2:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33A2:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228A:01/INT33A2:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33A4:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/INT33A4:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33BD:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33BD:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33BE:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:06/INT33BE:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33CF:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:06/INT33CF:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33D3:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33D3:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33D5:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/INT33D5:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33E1:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/8086228A:00/INT33E1:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33F4:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:05/INT33F4:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33F5:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:05/INT33F5:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33F8:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/INT33F8:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33F8:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:02/INT33F8:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33FB:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:06/INT33FB:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33FD:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:05/INT33FD:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33FE:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:02/INT33FE:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33FE:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:05/INT33FE:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33FE:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:05/INT33FE:02
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33FF:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33FF:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33FF:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33FF:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33FF:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33FF:02
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33FF:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33FF:03
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT33FF:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33FF:04
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT3400:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3400:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT3403:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3403:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT3403:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3403:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT3403:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3403:02
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT3403:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3403:03
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT3403:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3403:04
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT3406:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3406:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT3407:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3407:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT3408:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3408:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT3409:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3409:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT3409:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3409:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT3477:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/INT3477:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT3477:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:06/INT3477:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT3496:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/INT3496:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT34D0:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT34D0:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT34D3:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:05/INT34D3:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT5648:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/INT5648:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INT8260:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/INT8260:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INTA4321:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INTA4321:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INTA4322:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INTA4322:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INTCF1C:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/INTCF1C:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INTCF1D:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:02/INTCF1D:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INTCFD9:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INTCFD9:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INTL9C60:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/INTL9C60:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 INTL9C60:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/INTL9C60:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXCPU:00 -> ../../../devices/LNXSYSTM:00/LNXCPU:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXCPU:01 -> ../../../devices/LNXSYSTM:00/LNXCPU:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXCPU:02 -> ../../../devices/LNXSYSTM:00/LNXCPU:02
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXCPU:03 -> ../../../devices/LNXSYSTM:00/LNXCPU:03
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/LNXPOWER:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/LNXPOWER:02
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/LNXPOWER:03
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/LNXPOWER:04
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:05 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/LNXPOWER:05
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:06 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/device:03/LNXPOWER:06
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:07 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/LNXPOWER:07
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:08 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/LNXPOWER:08
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:09 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/LNXPOWER:09
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:0a -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/LNXPOWER:0a
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:0b -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/LNXPOWER:0b
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:0c -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/LNXPOWER:0c
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:0d -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/LNXPOWER:0d
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:0e -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/LNXPOWER:0e
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:0f -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/LNXPOWER:0f
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:10 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/LNXPOWER:10
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:11 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:02/LNXPOWER:11
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:12 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:02/LNXPOWER:12
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:13 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:02/LNXPOWER:13
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:14 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:03/LNXPOWER:14
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:15 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:04/LNXPOWER:15
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:16 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:04/LNXPOWER:16
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:17 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:27/LNXPOWER:17
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:18 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:18
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:19 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:19
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:1a -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:1a
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:1b -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:1b
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:1c -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:1c
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:1d -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:1d
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:1e -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:1e
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:1f -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:1f
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:20 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:20
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:21 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:21
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:22 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:22
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:23 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:23
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:24 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:24
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:25 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:25
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:26 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:26
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:27 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:27
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:28 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:28
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:29 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:29
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:2a -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:2a
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:2b -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:06/LNXPOWER:2b
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPOWER:2c -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:06/LNXPOWER:2c
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXPWRBN:00 -> ../../../devices/LNXSYSTM:00/LNXPWRBN:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXSYBUS:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXSYBUS:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXSYSTM:00 -> ../../../devices/LNXSYSTM:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXTHERM:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:01/LNXTHERM:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 LNXVIDEO:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 MAX17047:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/MAX17047:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 MCD0001:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/MCD0001:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 MCD0001:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/MCD0001:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 MCD0001:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/MCD0001:02
lrwxrwxrwx 1 root root 0 апр 24 00:47 MCD0001:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/MCD0001:03
lrwxrwxrwx 1 root root 0 апр 24 00:47 MCD0001:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/MCD0001:04
lrwxrwxrwx 1 root root 0 апр 24 00:47 MCD0001:05 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/MCD0001:05
lrwxrwxrwx 1 root root 0 апр 24 00:47 MSSL1680:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:04/MSSL1680:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 OVTI2680:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/OVTI2680:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 OVTI2680:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:01/OVTI2680:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 OVTI8835:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:06/OVTI8835:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 PI330532:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/PI330532:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0000:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0000:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0100:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0100:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0103:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0103:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0501:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0501:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0A08:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0B00:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0B00:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C02:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C02:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C02:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C02:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C02:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C02:02
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C0A:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/PNP0C0A:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C0A:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:05/PNP0C0A:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C0C:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C0D:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C0F:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C0F:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C0F:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:02
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C0F:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:03
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C0F:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:04
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C0F:05 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:05
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C0F:06 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:06
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C0F:07 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:07
lrwxrwxrwx 1 root root 0 апр 24 00:47 PNP0C14:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C14:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 SMB0349:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/SMB0349:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 TBQ24296:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:02/TBQ24296:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 TIMC22A8:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/TIMC22A8:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 TXN24292:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/TXN24292:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 TXN27501:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/808622C1:00/TXN27501:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 USBC000:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/USBC000:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 VIBR22A8:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/VIBR22A8:00
total 0
lrwxrwxrwx 1 root root 0 апр 24 00:47 i2c-0 -> ../../../devices/pci0000:00/808622C1:00/i2c-0
lrwxrwxrwx 1 root root 0 апр 24 00:47 i2c-1 -> ../../../devices/pci0000:00/808622C1:01/i2c-1
lrwxrwxrwx 1 root root 0 апр 24 00:49 i2c-10 -> ../../../devices/pci0000:00/0000:00:02.0/i2c-10
lrwxrwxrwx 1 root root 0 апр 24 00:49 i2c-11 -> ../../../devices/pci0000:00/0000:00:02.0/i2c-11
lrwxrwxrwx 1 root root 0 апр 24 00:49 i2c-12 -> ../../../devices/pci0000:00/0000:00:02.0/i2c-12
lrwxrwxrwx 1 root root 0 апр 24 00:49 i2c-13 -> ../../../devices/pci0000:00/0000:00:02.0/drm/card0/card0-eDP-1/i2c-13
lrwxrwxrwx 1 root root 0 апр 24 00:49 i2c-14 -> ../../../devices/pci0000:00/0000:00:02.0/drm/card0/card0-DP-1/i2c-14
lrwxrwxrwx 1 root root 0 апр 24 00:47 i2c-2 -> ../../../devices/pci0000:00/808622C1:02/i2c-2
lrwxrwxrwx 1 root root 0 апр 24 00:47 i2c-3 -> ../../../devices/pci0000:00/808622C1:03/i2c-3
lrwxrwxrwx 1 root root 0 апр 24 00:47 i2c-4 -> ../../../devices/pci0000:00/808622C1:04/i2c-4
lrwxrwxrwx 1 root root 0 апр 24 00:47 i2c-5 -> ../../../devices/pci0000:00/808622C1:06/i2c-5
lrwxrwxrwx 1 root root 0 апр 24 00:47 i2c-6 -> ../../../devices/pci0000:00/808622C1:05/i2c-6
lrwxrwxrwx 1 root root 0 апр 24 00:49 i2c-7 -> ../../../devices/pci0000:00/0000:00:02.0/i2c-7
lrwxrwxrwx 1 root root 0 апр 24 00:49 i2c-8 -> ../../../devices/pci0000:00/0000:00:02.0/i2c-8
lrwxrwxrwx 1 root root 0 апр 24 00:49 i2c-9 -> ../../../devices/pci0000:00/0000:00:02.0/i2c-9
lrwxrwxrwx 1 root root 0 апр 24 00:47 i2c-BOSC0200:00 -> ../../../devices/pci0000:00/808622C1:02/i2c-2/i2c-BOSC0200:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 i2c-ESSX8316:01 -> ../../../devices/pci0000:00/808622C1:02/i2c-2/i2c-ESSX8316:01
lrwxrwxrwx 1 root root 0 апр 24 00:47 i2c-GDIX1001:00 -> ../../../devices/pci0000:00/808622C1:04/i2c-4/i2c-GDIX1001:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 i2c-INT33F4:00 -> ../../../devices/pci0000:00/808622C1:05/i2c-6/i2c-INT33F4:00
lrwxrwxrwx 1 root root 0 апр 24 00:47 i2c-OVTI2680:01 -> ../../../devices/pci0000:00/808622C1:01/i2c-1/i2c-OVTI2680:01
[ 1.363506] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 1.363694] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 1.363903] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 1.465803] hid: raw HID events driver (C) Jiri Kosina
[ 7.555279] input: Intel HID events as /devices/pci0000:00/INT33D5:00/input/input3
[ 8.395733] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 9.577402] input: gpio-keys as /devices/platform/ACPI0011:00/gpio-keys.1.auto/input/input5
[ 9.577885] input: gpio-keys as /devices/platform/ACPI0011:00/gpio-keys.2.auto/input/input6
[ 9.578333] input: gpio-keys as /devices/platform/INT33D3:00/gpio-keys.3.auto/input/input7
[ 10.524192] input: bytcht-es8316 Headset as /devices/pci0000:00/808622A8:00/bytcht_es8316/sound/card0/input8
[ 11.003436] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input9
[ 12.362614] input: YSTEK USB Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.1/1-4.1:1.0/0003:0E8F:00FB.0001/input/input10
[ 12.364618] hid-generic 0003:0E8F:00FB.0001: input,hidraw0: USB HID v1.10 Mouse [YSTEK USB Mouse] on usb-0000:00:14.0-4.1/input0
[ 12.369839] input: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.0/0003:258A:6A88.0002/input/input11
[ 12.427884] hid-generic 0003:258A:6A88.0002: input,hidraw1: USB HID v1.10 Keyboard [EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD] on usb-0000:00:14.0-4.3/input0
[ 12.447939] input: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:258A:6A88.0003/input/input12
[ 12.449103] input: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:258A:6A88.0003/input/input13
[ 12.506932] input: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:258A:6A88.0003/input/input14
[ 12.507625] input: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD Wireless Radio Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:258A:6A88.0003/input/input15
[ 12.509377] hid-generic 0003:258A:6A88.0003: input,hiddev0,hidraw2: USB HID v1.10 Mouse [EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD] on usb-0000:00:14.0-4.3/input1
[ 12.509824] usbcore: registered new interface driver usbhid
[ 12.509843] usbhid: USB HID core driver
[ 12.698176] input: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.0/0003:258A:6A88.0002/input/input16
[ 12.755708] itetech 0003:258A:6A88.0002: input,hidraw1: USB HID v1.10 Keyboard [EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD] on usb-0000:00:14.0-4.3/input0
[ 12.768070] input: Intel HDMI/DP LPE Audio HDMI/DP,pcm=0 as /devices/pci0000:00/0000:00:02.0/hdmi-lpe-audio/sound/card1/input17
[ 12.792665] input: Intel HDMI/DP LPE Audio HDMI/DP,pcm=1 as /devices/pci0000:00/0000:00:02.0/hdmi-lpe-audio/sound/card1/input18
[ 12.793042] input: Intel HDMI/DP LPE Audio HDMI/DP,pcm=2 as /devices/pci0000:00/0000:00:02.0/hdmi-lpe-audio/sound/card1/input19
[ 12.914019] input: EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:258A:6A88.0003/input/input20
[ 12.969081] itetech 0003:258A:6A88.0003: input,hiddev0,hidraw2: USB HID v1.10 Mouse [EBITS-EB_WIN11_4-US-A1-16-00 USB KEYBOARD] on usb-0000:00:14.0-4.3/input1
[ 24.552450] rfkill: input handler disabled```
Well, after messing around with the BIOS and trying to change some settings from SDIO to PCI, I now have a soft bricked device. The tablet boots up and shuts down, but the screen doesn’t turn on at all. I tried to connect the tablet to a TV screen and I was so happy to see that it has booted into Manjaro and it was sitting on the desktop with Manjaro Hello.
I tried to restart into BIOS but the HDMI port is inactive while in bios so I can’t really restore to factory defaults. I was wondering if there is a command to restore factory bios settings through the OS? My gut says no, but I am curious.
