Hello!
I’ve opened System Settings - Hardware Configuration
Clicked on Auto install open source driver
It tells me it’s already installed:
Skipping already installed config ‘video-linux’ for device: 0000:01:00.0 (0300:10de:1b81) Display controller nVidia Corporation GP104 [GeForce GTX 1070]
I have two kernels installed (5.10 and 5.4), so I removed this packages:
linux54-nvidia, linux510-nvidia, nvidia-utils
Unblacklisted the nouveau driver
Restarted my system and I got a black screen
(restored my system with timeshift to quickly continue working)
Am I doing something wrong? missing some step?
Help appreciated
jacko
20 July 2021 13:11
2
Hello,
try to change TTY, if it’s possible it will not be so hard to repair.
Yes, I can go to tty2 and login as my regular user, but I don’t know what to do there
jacko
20 July 2021 13:24
4
startx, if it works try to setup DM or reinstall it
Some files need to be rewritten/replaced?
jacko
20 July 2021 20:44
6
If you can get to desktop withstartx command is good and we will search for DM issue.
Fabby
21 July 2021 12:12
7
Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text .
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
Yes, sorry about that
Here is its output:
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64
root=UUID=60600c65-cd66-4f46-9614-8528e08bd235 rw rootflags=subvol=@ quiet
Console: tty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: MSI model: Z97 GAMING 5 (MS-7917) v: 1.0 serial: N/A
UEFI: American Megatrends v: 1.9 date: 12/23/2014
RAM: total: 15.59 GiB used: 2.06 GiB (13.2%)
Array-1: capacity: 32 GiB slots: 4 EC: None max-module-size: 8 GiB
note: est.
Device-1: ChannelA-DIMM0 size: No Module Installed
Device-2: ChannelA-DIMM1 size: 8 GiB speed: 1600 MT/s type: DDR3
detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: 0420
part-no: F3-12800CL10-8GBXL serial: N/A
Device-3: ChannelB-DIMM0 size: No Module Installed
Device-4: ChannelB-DIMM1 size: 8 GiB speed: 1600 MT/s type: DDR3
Info: Quad Core model: Intel Core i5-4460 socket: BGA1155 bits: 64 type: MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
L1: 256 KiB L2: 6 MiB L3: 6 MiB bogomips: 25608
Speed: 3400 MHz min/max: 800/3400 MHz base/boost: 3200/3800 volts: 1.2 V
ext-clock: 100 MHz Core speeds (MHz): 1: 3400 2: 3388 3: 3346 4: 3300
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Type: l1tf
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Micro-Star MSI
driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1b81 class-ID: 0300
Display: server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 95 s-size: 513x292mm (20.2x11.5")
s-diag: 590mm (23.2")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 96
size: 510x287mm (20.1x11.3") diag: 585mm (23")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31
direct render: Yes
Device-1: Intel 9 Series Family HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f0
class-ID: 0403
Device-3: C-Media CM108 Audio Controller type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-9:4 chip-ID: 0d8c:013c
class-ID: 0300
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: d000 bus-ID: 03:00.0
chip-ID: 1969:e091 class-ID: 0200
Local Storage: total: 3.17 TiB used: 2.09 TiB (66.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 480GB SSD
family: Driven SSDs size: 447.13 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: 0KB3 temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 245d 17h cycles: 612
written: 5385 GiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA300
family: 3.5" DT01ACA... Desktop HDD size: 2.73 TiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: ABB0 temp: 24 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 3y 310d 5h cycles: 2815
Optical-1: /dev/sr0 vendor: ASUS model: DRW-24F1ST a rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 111.28 GiB size: 111.28 GiB (100.00%)
used: 31.12 GiB (28.0%) fs: btrfs block-size: 4096 B dev: /dev/sda5
maj-min: 8:5 label: N/A uuid: 60600c65-cd66-4f46-9614-8528e08bd235
used: 656 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda6 maj-min: 8:6
label: N/A uuid: 86AC-BE7F
ID-3: /home raw-size: 146.4 GiB size: 146.4 GiB (100.00%)
used: 27.58 GiB (18.8%) fs: btrfs block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: ac44423d-2d5c-4271-b43f-50fee9cb30db
ID-4: /mnt/ntfs raw-size: 2.59 TiB size: 2.59 TiB (100.00%)
used: 2.04 TiB (78.7%) fs: fuseblk block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17 label: DATA_POOL uuid: 78C2F9FAC2F9BD06
ID-1: /dev/sda1 maj-min: 8:1 size: 529 MiB fs: ntfs label: Recovery
uuid: 6E969BE9969BB057
ID-2: /dev/sda2 maj-min: 8:2 size: 99 MiB fs: fat (32 bit) label: N/A
uuid: A89C-8BC5
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 334.72 GiB fs: ntfs label: SYSTEM
uuid: F8C8AEC0C8AE7D0E
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel ports: 6 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8009 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8001 class-ID: 0900
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
Device-1: 3-3:2 info: Kingston HyperX Alloy FPS Mechanical Gaming Keyboard
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0951:16b7 class-ID: 0301
Device-2: 3-4:3 info: DEXIN Tt eSPORTS THERON type: Mouse,Keyboard
power: 100mA chip-ID: 12cf:0200 class-ID: 0301
Device-3: 3-9:4 info: C-Media CM108 Audio Controller type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:013c class-ID: 0300
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 31 C
Processes: 211 Uptime: 6m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1383 lib: 417
flatpak: 0 Shell: Bash (sudo) v: 5.1.8 running-in: yakuake inxi: 3.3.05
Thanks. Since there is a new system update today, I’ll first give that new nvidia driver a try
If problems arise, I’ll try using nouveau
Very clear and handy
Thanks Fabby!
system
Closed
10 August 2021 12:36
11
