Help installing optional dependency files and fixing system errors
Hello!
I’m new to Linux. Manjaro is my first Linux install. I’ve recently installed some video editing software (Shotcut). Once I updated pacmanager shotcut worked much better however there are still some problems.
I thought if I installed some of the optional/make dependency files for Shotcut that maybe this would resolve the problems. However, when I tried to do this I got the message ‘target cannot be found’!
I updated the kernel to the most recent edition. I then followed the advise on this video:
“10 Things to do after installing Manjaro”
Which is basically:
  1. Set the fastest mirror
    sudo pacman-mirrors --fasttrack
  2. Update your system
    sudo pacman -Syu
  3. Enable AUR support
  4. Enable TRIM (SSD only)
  5. Reduce swappiness
  6. Installing Snapd
  7. Check for errors
  8. Firewall Configuration
  9. Remove Orphans (Unused) packages
  10. Backup the system
I did not complete steps 9 nor 10, however the check for errors came back with the following:
sudo journalctl -p 3 -xb                                         ✔
-- Journal begins at Fri 2021-02-05 21:24:18 GMT, ends at Fri 2021-03-05 02:09:>
Mar 04 23:04:34 manjaro kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Mar 04 23:04:34 manjaro kernel: sd 6:0:0:0: [sdb] No Caching mode page found
Mar 04 23:04:34 manjaro kernel: sd 6:0:0:0: [sdb] Assuming drive cache: write t>
Mar 04 23:05:37 manjaro kernel: FAT-fs (sdb): unable to read boot sector to mar>
Mar 04 23:05:59 manjaro systemd[878]: Failed to start GNOME Terminal Server.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ Support: forum manjaro
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 481 and the job result is failed.
Mar 04 23:10:27 manjaro systemd-coredump[1939]: Process 1930 (pipewire-media-) >
                                                Stack trace of thread 1930:
                                                #0  0x000055e029c5503b n/a (pip>
                                                #1  0x000055e029c53a6b n/a (pip>
                                                #2  0x00007f35abe3fdf4 n/a (lib>
                                                #3  0x00007f35abe39aa2 n/a (lib>
                                                #4  0x00007f35abe39ff8 n/a (lib>
                                                #5  0x00007f35acf1fd9b n/a (lib>
                                                #6  0x00007f35ace9b5ab pw_main_>
lines 1-23...skipping...
-- Journal begins at Fri 2021-02-05 21:24:18 GMT, ends at Fri 2021-03-05 02:09:49 GMT. --
Mar 04 23:04:34 manjaro kernel: sd 6:0:0:0: [sdb] Assuming drive cache: write through
Mar 04 23:05:37 manjaro kernel: FAT-fs (sdb): unable to read boot sector to mark fs as dirty
Mar 04 23:10:27 manjaro systemd-coredump[1939]: Process 1930 (pipewire-media-) of user 1000 dumped core.
                                                #0  0x000055e029c5503b n/a (pipewire-media-session + 0x2003b)
                                                #1  0x000055e029c53a6b n/a (pipewire-media-session + 0x1ea6b)
                                                #2  0x00007f35abe3fdf4 n/a (libpipewire-module-protocol-native.so + 0x16df4)
                                                #3  0x00007f35abe39aa2 n/a (libpipewire-module-protocol-native.so + 0x10aa2)
                                                #4  0x00007f35abe39ff8 n/a (libpipewire-module-protocol-native.so + 0x10ff8)
                                                #5  0x00007f35acf1fd9b n/a (libspa-support.so + 0x6d9b)
                                                #6  0x00007f35ace9b5ab pw_main_loop_run (libpipewire-0.3.so.0 + 0x425ab)
                                                #7  0x000055e029c417dc n/a (pipewire-media-session + 0xc7dc)
                                                #8  0x00007f35acb5eb25 __libc_start_main (libc.so.6 + 0x27b25)
                                                #9  0x000055e029c41c5e n/a (pipewire-media-session + 0xcc5e)
                                                Stack trace of thread 1932:
                                                #0  0x00007f35acc3639e epoll_wait (libc.so.6 + 0xff39e)
                                                #1  0x00007f35acf291f1 n/a (libspa-support.so + 0x101f1)
                                                #2  0x00007f35acf1fd04 n/a (libspa-support.so + 0x6d04)
                                                #3  0x00007f35ace81f50 n/a (libpipewire-0.3.so.0 + 0x28f50)
                                                #4  0x00007f35acd0d299 start_thread (libpthread.so.0 + 0x9299)
                                                #5  0x00007f35acc36053 __clone (libc.so.6 + 0xff053)
░░ Subject: Process 1930 (pipewire-media-) dumped core
░░ Documentation: man:core(5)
░░ Process 1930 (pipewire-media-) crashed and dumped core.
lines 1-40
I’m assuming there are loads of errors and I’m hoping someone can advise me the best way to proceed if so!!
A strange thing happened when I changed the layout and double clicked on the home icon, it automatically opened up VLC player and started playing some Bob Marley. Another problem i had was resizing the windows when opening up shotcut or osb, i think this is working okay now.
That is all for now, please let me know if you need further info, many thanks.
d_sunny
:+1: Welcome to Manjaro! :+1:
Can you edit your question and provide exact commands, please?
Also, Please read this:
[HowTo] Provide System Information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies as an inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
:+1:
