Hello,
I’m back to Manjaro, and yesterday night I just finished a fresh install with the latest ISO available. After everything was done I realized that my keyboard accents was not working properly. I made some investigation here on the forum but one solution pointed from other user is not working see post below ![]()
My locale language is set to American English, this way is better to find documentation and support.
System Settings → input device → Keyboard → Hardware → Set to Generic 105 keys
System Settings → input device → Keyboard → Layout → Set to Portuguese (Brazil) No dead keys
Manjaro Setting Manager → Keyboard Settings → Portuguese Brazil no dead keys
The 1st foot print i found that an issue is because changing Manjaro Setting Manager Keyboard don’t make the accent works.
The 2nd foot print I found about it’s an issue is because when I reboot my machine the Manjaro Setting Manager back the Keyboard Settings automatically to English Default, it suggests conflicts anywhere in the config files. Maybe once it’s see my locale defined as English and changes my keyboard and do not respect user choice.
Previously, when I was using xorg some year ago, the way to fix it was only using the command line: “setxkbmap -model abnt2 -layout br -variant abnt2”
Since Wayland, time to time I face issues
and I didn’t find the correct way to fix it, with all improvements from plasma, it should work by default.
expected behavior: ã or ô
current behavior: ~a or ^o
Thanks in advance.
Regards
Marcelo
Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=84e0bfca-0d47-4324-b85a-614ea38dc5f9 rw rootflags=subvol=@ quiet
splash udev.log_priority=3
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Type: Desktop Mobo: MACHINIST model: E5-MR9A v: V1.0
serial: <superuser required> UEFI: American Megatrends v: 5.11
date: 10/25/2022
System RAM: total: 32 GiB note: est. available: 31.19 GiB
used: 2.79 GiB (9.0%)
Info: model: Intel Xeon E5-2667 v4 bits: 64 type: MT MCP arch: Broadwell
level: v3 note: check built: 2015-18 process: Intel 14nm family: 6
model-id: 0x4F (79) stepping: 1 microcode: 0xB000040
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 25 MiB
desc: 1x25 MiB
Speed (MHz): avg: 1568 high: 3600 min/max: 1200/3600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1245 2: 1200 3: 1200
4: 3492 5: 1197 6: 1200 7: 1198 8: 1200 9: 1200 10: 1200 11: 1197 12: 3600
13: 1197 14: 2366 15: 1200 16: 1200 bogomips: 102198
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts cat_l3 cdp_l3 clflush cmov constant_tsc cpuid
cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cx16 cx8
dca de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr hle ht ibpb ibrs ida intel_ppin intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
pln pni popcnt pse pse36 pti pts rdrand rdseed rdt_a rdtscp rep_good rtm
sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-2 empty: DP-1,DP-3,HDMI-A-1 bus-ID: 05:00.0
chip-ID: 1002:731f class-ID: 0300
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon RX 5700 XT (navi10
LLVM 15.0.7 DRM 3.49 6.1.44-1-MANJARO) direct-render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:ab38
class-ID: 0403
API: ALSA v: k6.1.44-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.77 status: off with: wireplumber status: active
tools: pw-cli,wpctl
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Local Storage: total: 2.73 TiB used: 1.46 TiB (53.7%)
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 234100WD temp: 27.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: A-Data model: LEGEND 850 Lite
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: V0922A0 temp: 25.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20PURZ-85GU6Y0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80 scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
used: 29.45 GiB (6.3%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
label: N/A uuid: 84e0bfca-0d47-4324-b85a-614ea38dc5f9
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3 label: N/A
uuid: 21D8-DE05
ID-3: /home raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
ID-4: /home/<filter>/Games raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 106.46 GiB (23.3%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
label: GAMES uuid: b5780269-0438-4193-9b38-7df4aaf9b229
ID-5: /home/<filter>/HDD-2TB raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 1.33 TiB (74.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: 2TB-EXT4
uuid: b9d4d0f9-d1ce-425d-8fe4-e2f830005289
ID-6: /swap raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
ID-7: /var/cache raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
ID-8: /var/log raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 25.7 MiB (5.0%) priority: -2
file: /swap/swapfile
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 15 rev: 2.0
Device-1: 3-1:2 info: SINO WEALTH Gaming KB type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 258a:002a class-ID: 0300
Device-2: 3-2:3 info: [Maxxter] USB GAMING MOUSE type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 18f8:0fc0 class-ID: 0301
Hub-6: 4-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 21.0 C mobo: N/A gpu: amdgpu temp: 31.0 C
mem: 32.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 843
Processes: 361 Uptime: 5m wakeups: 0 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7 Packages: 1283
pm: pacman pkgs: 1254 libs: 409 tools: pamac pm: flatpak pkgs: 29 Shell: Zsh
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
