Indeed that is the usb modem. And here is the output of the inxi -Fazy and I also ran lsusb -tv : Thank you.
Kernel: 5.9.1-RAVEN x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-raven-latest
root=UUID=c85b42e2-0745-4a70-9df0-0fc013f7332a rw quiet apparmor=1
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-GAMING/BR v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 2202 date: 07/14/2020
Topology: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics
socket: AM4 bits: 64 type: MT MCP arch: Zen+ family: 17 (23)
model-id: 18 (24) stepping: 1 microcode: 8108109 L1 cache: 384 KiB
L2 cache: 2048 KiB L3 cache: 4096 KiB
bogomips: 65628
Speed: 1259 MHz min/max: 1400/4100 MHz base/boost: 4100/4200 boost: enabled
volts: 1.5 V ext-clock: 100 MHz Core speeds (MHz): 1: 1259 2: 1256 3: 1259
4: 1259 5: 1258 6: 1260 7: 1258 8: 1259
disabled, RSB filling
Device-1: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus ID: 08:00.0 chip ID: 1002:15d8
Display: server: X.Org 1.20.9 driver: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1280x1024 s-dpi: 96 s-size: 338x270mm (13.3x10.6")
s-diag: 433mm (17")
Monitor-1: DisplayPort-0 res: 1280x1024 hz: 60 dpi: 102
size: 320x240mm (12.6x9.4") diag: 400mm (15.7")
OpenGL: renderer: AMD RAVEN (DRM 3.39.0 5.9.1-RAVEN LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 08:00.1 chip ID: 1002:15de
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 08:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.1-RAVEN
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 07:00.0
chip ID: 10ec:8168
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Argument "0x012500500125" isn't numeric in numeric gt (>) at /usr/bin/inxi line 9412.
Local Storage: total: 3.62 TiB used: 340.41 GiB (9.2%)
ID-1: /dev/sda vendor: Seagate model: ST2000DM005-2CW102
family: Barracuda Compute size: 1.82 TiB block size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s rotation: 5425 rpm serial: <filter>
rev: 0001 temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 29d 15h cycles: 131
read: 1.34 TiB written: 1.44 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-2: /dev/sdb vendor: Samsung model: HD154UI family: SpinPoint F2 EG
size: 1.36 TiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 1118 temp: 29 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 294d 17h cycles: 3299 Pre-Fail:
reallocated sector: 99 threshold: 10
ID-3: /dev/sdc vendor: Western Digital model: WDS480G2G0B-00EPW0
family: WD Blue and Green SSDs size: 447.14 GiB block size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s serial: <filter> rev: 0000
temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 35d 12h cycles: 208
ID-1: / raw size: 34.18 GiB size: 33.39 GiB (97.70%) used: 21.69 GiB (65.0%)
fs: ext4 block size: 4096 B dev: /dev/sdc7
ID-1: swap-1 type: partition size: 13.67 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdc9
System Temperatures: cpu: 41.9 C mobo: N/A gpu: amdgpu temp: 41 C
Processes: 233 Uptime: 2h 43m Memory: 6.72 GiB used: 2.19 GiB (32.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1401 lib: 413
flatpak: 0 Shell: Bash (sudo) v: 5.0.18 running in: xfce4-terminal
inxi: 3.1.05
[ejaro-pc ejaro]# lsusb -tv
/: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 10000M
ID 1d6b:0003 Linux Foundation 3.0 root hub
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
ID 1d6b:0002 Linux Foundation 2.0 root hub
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 10000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 2: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
ID 046d:c31c Logitech, Inc. Keyboard K120
|__ Port 2: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
ID 046d:c077 Logitech, Inc. M105 Optical Mouse
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 10000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/10p, 480M
|__ Port 3: Dev 2, If 0, Class=Vendor Specific Class, Driver=, 480M
ID 2357:010c TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS]
|__ Port 4: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 12M
ID 1ea7:0064 SHARKOON Technologies GmbH 2.4GHz Wireless rechargeable vertical mouse [More&Better]
