Hello there! I’ve been trying to solve it on my own but after 7 hours of work I just gave up. After some pondering I’ve decided to install manjaro because I have heard that this distro is fine for “gamers”. So after installing cs2 I found myself in disbelieve because in run better than on Win 10. After two competitive games I downloaded Helldivers 2. And here began my fight with this error. I do not know what to do. Any ideas?
the version helldivers2 is not for linux at this time
check always if this can run on others os
According to https://www.protondb.com/app/553850 users have had succes on proton, run it through steam?
It worked on Ubuntu (but poorly), and it works on SteamOS, which is based on archlinux. But I still have issues here on manjaro.
I did run Helldivers 2 on steam. And even tried different versions of Proton that are available on steam. Still no success.
I’m not sure if GE proton is something that steam provides, this used to help me get some games running.
I’ve got the same error on GE proton. I dunno what to do. Is there a possibility that some debugger is causing this? If yes, how can I disable it?
The game works great on SteamOS which is based on Arch like manjaro as far as I know. So it should work fine.
He used Manjaro and it worked, use starting parameter:
--use-d3d11
Alot people also reported a fullscreen issue, a ini file can be tweaked for borderless window mode.
other Manjaro users:
The game has big problems with AMD GPU’s also, post your system plz.
Even alot Windows gamers, got problems with Helldivers2.
Im also bought this game yesterday from a keystore for only 30€ but i had no time yet to install it.
Anyways, this game need patches and you will get better results after adjustments from Proton and the developer… the game not running away, i normaly wait for first discounts on new games
to play it with greater quality ![]()
Here is info about my pc. I tried using the starting parameter that you’ve provided but the same error persists. Meaning there is an issue with GameGuard which is an Kernel-Level Anti-Cheat. But I still do wonder why am I the only one who’s got this error message on the internet. Before I came here I’d been googling for hours with no real results. What really bugs me is this WinLicense error of which screenshot I’ve had provided in the post at the beginning. I am sure that I mentioned that the game worked on Ubuntu, in the answer to the user stephane. It worked very poorly but there wasn’t any error with GameGuard nor with WinLicense. So my focus would be on these two rather on the starting parameter of the game itself.
Kernel: 6.6.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1398a57d-d9a2-4231-b2e3-0bbb239eedfc rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASRock model: Z370 Extreme4 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: L4.21B
date: 04/01/2021
ID-1: hidpp_battery_0 charge: 49% condition: N/A volts: 3.8 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
status: discharging
System RAM: total: 32 GiB available: 31.28 GiB used: 3.51 GiB (11.2%)
Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-3000C16-8GISB serial: N/A
Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous unbuffered
Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous unbuffered
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 811 high: 935 min/max: 800/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 935 10: 800 11: 800 12: 800 bogomips: 88824
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel DG2 [Arc A770] vendor: ASRock driver: i915 v: kernel
arch: Gen-12.7 code: Alchemist process: TSMC n6 (7nm) built: 2022+ pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 ports: active: DP-1 empty: DP-2, DP-3,
DP-4, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 03:00.0 chip-ID: 8086:56a0
class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: DP-1 model: Acer PG241Y P serial: <filter> built: 2022
res: 1920x1080 dpi: 92 gamma: 1.2 size: 609x348mm (23.98x13.7")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.5-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc A770 Graphics (DG2)
device-ID: 8086:56a0 memory: 7.75 GiB unified: no
API: Vulkan v: 1.3.276 layers: N/A device: 0 type: discrete-gpu name: Intel
Arc A770 Graphics (DG2) driver: mesa intel v: 23.3.5-manjaro1.1
device-ID: 8086:56a0 surfaces: xcb,xlib
Device-1: Intel DG2 Audio vendor: ASRock driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:4f90
class-ID: 0403
Device-2: Universal Audio Volt 2 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:5
chip-ID: 2b5a:0021 class-ID: 0300 serial: <filter>
API: ALSA v: k6.6.16-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Local Storage: total: 1.59 TiB used: 147.19 GiB (9.0%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 33.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B7QCXE7 temp: 35.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
tech: SSD serial: <filter> fw-rev: 043 scheme: GPT
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-224DB rev: SB01
dev-links: cdrom
Features: speed: 48 multisession: no audio: yes dvd: yes
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 147.19 GiB (64.6%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2
label: N/A uuid: 1398a57d-d9a2-4231-b2e3-0bbb239eedfc
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: N/A
uuid: C3B6-0402
ID-1: /dev/nvme0n1p1 maj-min: 259:4 size: 100 MiB fs: vfat label: N/A
uuid: 0C05-8390
ID-2: /dev/nvme0n1p2 maj-min: 259:5 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:6 size: 930.89 GiB fs: ntfs label: N/A
uuid: E0502B81502B5E12
ID-4: /dev/nvme0n1p4 maj-min: 259:7 size: 522 MiB fs: ntfs label: N/A
uuid: 12F05F16F05EFF81
ID-5: /dev/sda1 maj-min: 8:1 size: 465.75 GiB fs: ntfs label: New Volume
uuid: BA76A5C176A57F2F
Hub-2: 1-3:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Device-1: 1-5:3 info: Logitech Lightspeed Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c539 class-ID: 0300
Device-2: 1-6:4 info: CHERRY Stream Keyboard TKL type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 046a:c099 class-ID: 0300
Device-3: 1-7:5 info: Universal Audio Volt 2 type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 7 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2b5a:0021
Hub-3: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
Hub-4: 2-7:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 31.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 409 Power: uptime: 32m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.5 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1158 pm: pacman pkgs: 1136 libs: 326 tools: pamac pm: flatpak
pkgs: 14 pm: snap pkgs: 8 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh
v: 5.9 default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
Oh and btw I’ve seen your post on steam forum which got me thinking to try manjaro ^^
From what I’ve heard Intel Arc on Linux has not been a great experience. They’ve focused much more of their efforts on the Windoze drivers and Vulkan performance (which is the most important thing for Proton) is lacking. Apparently some improvements are coming in Mesa 24 - Intel Vulkan drivers on Linux should run more games with Mesa 24.0 | GamingOnLinux
However, none of that explains why you’re having an anti-cheat issue when no-one else on protondb is. I have no idea what could be causing that.
many thing will coming with mesa 24.0
This might not be an issue with Linux/Proton etc. Some Googling for “Gameguard error code 114” suggests that people on Windows are encountering the same error, and it’s being looked into by the developers. There was at least one patch for it, but people are still reporting problems as of the 23rd.
Apparently one estimate is that about 1 in 150 people encounter the error, so it’s rare but not that rare.
Interesting, especially the fact that it happens on Windows too. Those 1 in 150 people aren’t all running Intel Arc gfx by any chance? ![]()
I’ve got no issues on my Win 10. The game works smooth on High/Very High settings (70-90 fps). Neither did I get any issues with Counter-Strike 2 on manjaro. CS2 works here even better than on my win 10 (fps rate is more stable). So I wouldn’t blame intel for the error.
That has changed over the last year. As far as I know (from my own experience and from the internet), the drivers has been significantly improved (on windows and linux as well). And the Anti-cheat thing is very frustrating. I even have reinstalled the whole OS.
Thanks for the information. The future looks promising ![]()
As far as I understood the reports, there wasn’t any conclusion on hardware for the current issues. At launch, it seems that anecdotally it appeared more likely to happen with AMD CPUs, but that should be taken with a pinch of salt as gamers who can’t game are a) salty and b) not the most reliable sources of information. Obviously that doesn’t apply here, though.
One thing that might be worth checking: when installing Steam on Manjaro, there’s “Steam (Runtime)” and “Steam (Native)”. If you’re running “Steam (Native)”, that is very likely to trigger weirdness with things like anti-cheat (as the runtime the anticheat is checking will not be as it expects), so swap to the Runtime version.
Is it possible that you are talking about official repo’s (pre-installed steamversion) and flatpak installation?
When i look at pamac UI i only see a version called: Steam-Native-Runtime ![]()
No; Manjaro has two Steam packages, with the Flatpak version being a third option. In any case, if you’re using steam-native-runtime, this is probably the reason why there’s an issue as that’s linking to system libraries rather than using the official Steam runtime.
The package you should install in Pamac is just steam, and should show up in Pamac’s GUI as “Steam (steam)” - as opposed to the Flatpak version, which is just listed as “Steam”. That will give you an application in your GUI launcher named “Steam (Runtime)”, which should use the official Steam runtime, and might have a bit more luck with anticheat.
