Just a quick headsup for Cinnamon users (and yeah, when I find some time, I’ll try to dig up my Mint forum account and report back there too):
The Cinnamon 5.4 release apparently reworked some things, so other things are now kinda broken. Stuff I noticed (and some I reported before ):
all display settings were gone after updating, so monitor layout and orientation was back to default: fixed by going into the Cinnamon System Settings > Display dialog and redoing them
touchpad settings were gone, so for example “Tap to click” was disabled: fixed by going into the Cinnamon System Settings > Mouse and Touchpad dialog and enabling that feature
the input level meter in the System Settings > Sound dialog is broken and not showing if a microphone is active: using the PulseAudio Volume Control app works correctly
all individual Cinnamon Settings dialogs are gone from the Start menu, so typing “sound” or “display” in the Start menu does not work anymore and you have to go through the System Settings dialog
Agreed display doesn’t work but most of the others do.
Display works now!
Same issues here and I add another one: The keyboard applet on the status bar made the whole right part of the bar grow and overflow off the screen whenever I changed keyboard layouts. Removing the applet and adding it back again seems to have fixed the issue.
Edit: it broke again after restarting
For me all my Extensions stopped working. Cinnamon Maximus, gTile, Smart Panel, Transparent Panel. I’ve got 7 computers running Manjaro Cinnamon. 2 of them are production machines where I really need the desktop working perfectly. I’ve downgraded one of them and the other one I’m not touching until I’m sure the extensions works again. Updating the other machines rolling to be aware of when the extensions are working again.
Hello, I used another topic for relating some cinnamon bugs since 5.4 update, but it seems here is a better place. (look for “cinnamon-update-problem” in the forum, for some reason I can’t include links…)
Hello, since last update of manjaro / cinnamon, i have problems too :
Hot corners doesn’t work anymore : I have to deactivate / activate them in parameters to let them work … only some minutes
Screen Power Saving mode doesn’t work anoymore : Screensaver works but screen does not turn off anymore after 10 minutes as before (my own delay). It seems it turns off 2 seconds (black screen), and then wakes up for another 10 minutes screensaver round …
Note that my manjaro install is from 2015 … never had to reinstall since
Should I change some parameters ? Where are cinnamon config files ?
thanks for your help
If you check the github of most of the extensions you’ll see they’re not working on any distro running 5.4 not just manjaro. I know transparent panels extension hasn’t been updated on over 12 months so may not be maintained any more
I’ve just updated and also encountered problems. The main one for me is that the window-list applet won’t load, so I can only switch windows via Alt-Tab, not by clicking buttons on the panel.
There are a load of related errors in .xsession-errors that seem related, although I’m not really sure how to interpret them.
Yeah, Linux Mint is getting ready for the Linux Mint 21 release. They did some major overhaul of various parts, rebasing the window manager, changing how display configs are handled, and much more. Article link .
Maybe Linux Mint applies migration scripts for updates, but I guess we just get the packages when we update.
So, depending on what you’re using and what got changed around, different stuff may have got broken for different people/systems.
I’m using pretty much bog standard Cinnamon: no extensions and just a few standard settings changed around or features such as hot corners disabled. Apart from some annoyances and the display settings shakeup, I’ve been relatively okay. But yeah, if you’re stuck with something you use all the time now broken, that’s pretty annoying.
That said, I’d give it a couple of months if you can live with that. Linux Mint 21 is supposed to be released soon (Any Time Now ™) and when they do, there will be plenty of extra eyes on the changes/brokeness and I expect some more fixes then. Manjaro being what it is, we’ll see those fixes sooner rather than later.
COD
July 19, 2022, 8:55pm
#10
What bugs me the most is that the systray applet doesn’t work properly and the icons it contains are not accessible when the taskbar is set to auto-hide.
And that the taskbar always twitches around when you move the cursor to the bottom of the screen to open it (in auto-hide mode) is the second point that bugs me a lot.
The fact that the extension for the bar transparency does not work at the moment I find not quite so tragic because I have changed the appropriate transparency values directly in the theme.
However, the prospect of having to wait for months for the fixes for the two problems mentioned above I find again super tragic…
I think I would like to downgrade cinnamon since I’m also missing the separate control for the window borders but I honestly don’t know exactly how to do it, it seems quite complicated if not impossible…
I’m adding another problem since this update :
If I switch on my PC while monitor is off, when I switch on the monitor,… black screen…
I have to reset PC
If monitor and PC are both on, it seems OK
Nothing in journalctl that i can understand…
There’s some new cinnamon updates been pushed to testing this morning. I’ll see if I can replicate your error.
All the other errors seem to be extensions /add ons etc which obviously need to be updated to work with cinnamon 5.4. There’s no much manjaro can do about them, but that’s up to the extensions maintainers
Apparently that is a feature not a bug
With The 5.4.0 update to cinnamon the Title Headers & Bordes Icon is missing in the theme in the settings. The org.cinnamon.desktop.wm.preferences still exists in the dconf but now has no effect.
@oberon & @Yochanan
If you downgrade you are going to have issues on a rolling release sooner or later
COD
July 20, 2022, 2:12pm
#14
Yes, I know that it’s a feature but I feel it is an unnecessary restriction of possibilities.
And yes, you are right with the rolling release aspect and therefore I’m feeling a bit trapped right now…
I tried many desktops and settled on Gnome until Unity drove me from Ubuntu to Mint. Needing a bleeding edge kernel for new hardware drove me from Mint to Manjaro, where I was happy to find the Cinnamon community edition. Lately I have been thinking of giving KDE another try as a more mainstream and officially supported Manjaro desktop. I mean, the grudges I hold are against KDE 3/3.5. Much has changed.
So, don’t feel trapped. Make some time and experiment. The conclusion may be that it’s worth holding out for a bit and sticking with Cinnamon and/or even compromising on some changes you don’t like. But by then it will be your choice to do so and not something forced onto you.
Reading this
opened 11:56PM - 18 Jul 22 UTC
* Cinnamon version (cinnamon --version)
5.4.3
* Distribution - (Min… t 17.2, Arch, Fedora 25, etc...)
EndeavourOS (Arch)
* Graphics hardware *and* driver used
AMD Open Source Driver
* 32 or 64 bit
*64 bit
* Attach ~/.xsession-errors, or /var/log/syslog
discover_other_daemon: 1discover_other_daemon: 1discover_other_daemon: 1[cinnamon-settings-daemon-smartcard] Failed to start: no suitable smartcard driver could be found
mutter-Message: 19:13:56.992: Enabling experimental feature 'x11-randr-fractional-scaling'
Gjs-Message: 19:14:00.002: JS LOG: About to start Cinnamon
Gjs-Message: 19:14:02.522: JS LOG: [LookingGlass/info] Cinnamon.AppSystem.get_default() started in 2476 ms
Gjs-Message: 19:14:02.579: JS LOG: [LookingGlass/info] loading user theme: /home/jkmooney/.themes/Eleganse/cinnamon/cinnamon.css
Gjs-Message: 19:14:02.662: JS LOG: [LookingGlass/info] added icon directory: /home/jkmooney/.themes/Eleganse/cinnamon
Gjs-Message: 19:14:03.335: JS LOG: [LookingGlass/info] loaded at Mon Jul 18 2022 19:14:03 GMT-0400 (Eastern Daylight Time)
Gjs-Message: 19:14:03.335: JS LOG: Cinnamon started at Mon Jul 18 2022 19:14:03 GMT-0400 (Eastern Daylight Time)
Gjs-Message: 19:14:03.336: JS LOG: GPU offload supported: false
Gjs-Message: 19:14:03.406: JS LOG: [LookingGlass/info] ExtensionSystem started in 0 ms
Gjs-Message: 19:14:03.407: JS LOG: [LookingGlass/info] DeskletManager started in 1 ms
Gjs-Message: 19:14:03.407: JS LOG: [LookingGlass/info] SearchProviderManager started in 1 ms
** (nemo-desktop:1134): WARNING **: 19:14:06.340: Current gtk theme is not known to have nemo support (CBlack) - checking...
Guake not running, starting it
Loading Gnome schema from: /usr/share/glib-2.0/schemas
Language previously loaded from: /usr/share/locale
Guake Terminal 3.9.1.dev0
VTE 0.68.0
Gtk 3.24.34
created fresh notebook for workspace 0
Spawning new terminal at /home/jkmooney
current workspace is 0
can't bind show-focus key
cinnamon-session[859]: WARNING: t+19.60050s: Detected that screensaver has appeared on the bus
Guake tabs restored from /home/jkmooney/.config/guake/session.json
Guake initialized
** Message: 19:14:14.227: nemo-desktop: session is cinnamon, establishing proxy
Gjs-Message: 19:14:14.891: JS LOG: [LookingGlass/info] Loaded applet printers@cinnamon.org in 2640 ms
Gjs-Message: 19:14:16.101: JS LOG: [LookingGlass/info] Loaded applet calendar@cinnamon.org in 1210 ms
Gjs-Message: 19:14:16.102: JS LOG: [LookingGlass/error]
[xapp-status@cinnamon.org]: No JS module 'recordingIndicator' found in search path
[xapp-status@cinnamon.org]: Error importing applet.js from xapp-status@cinnamon.org
Gjs-Message: 19:14:16.102: JS LOG: [LookingGlass/trace]
anonymous@/usr/share/cinnamon/applets/xapp-status@cinnamon.org/applet.js:17:28
createExports@/usr/share/cinnamon/js/misc/fileUtils.js:219:11
requireModule/</<@/usr/share/cinnamon/js/misc/fileUtils.js:291:25
Gjs-Message: 19:14:16.141: JS LOG: [LookingGlass/info] Role locked: notifications
Gjs-Message: 19:14:16.145: JS LOG: [LookingGlass/info] Loaded applet notifications@cinnamon.org in 44 ms
Gjs-Message: 19:14:17.400: JS LOG: [LookingGlass/info] Role locked: windowattentionhandler
Gjs-Message: 19:14:17.402: JS LOG: [LookingGlass/info] Loaded applet grouped-window-list@cinnamon.org in 1257 ms
Gjs-Message: 19:14:19.166: JS LOG: [LookingGlass/info] [weather@mockturtl#16]: Internet access now available, resuming operations.
dropbox: load fq extension '/opt/dropbox/cryptography.hazmat.bindings._openssl.cpython-38-x86_64-linux-gnu.so'
Gjs-Message: 19:14:19.324: JS LOG: [LookingGlass/info] Loaded applet weather@mockturtl in 1922 ms
Gjs-Message: 19:14:19.921: JS LOG: [LookingGlass/info] Loaded applet sound@cinnamon.org in 597 ms
Gjs-Message: 19:14:20.538: JS LOG: [LookingGlass/info] Loaded applet network@cinnamon.org in 617 ms
dropbox: load fq extension '/opt/dropbox/cryptography.hazmat.bindings._padding.cpython-38-x86_64-linux-gnu.so'
/usr/bin/polychromatic-tray-applet:224: DeprecationWarning: Gtk.ImageMenuItem.set_image is deprecated
item.set_image(img) # GTK3: Deprecated, no replacement!
(cinnamon:1002): Gjs-WARNING **: 19:14:22.801: Some code tried to set a deprecated GObject property.
0 updateUI() ["/usr/share/cinnamon/js/misc/fileUtils.js line 211 > Function":2039:45]
1 updateLoop() ["/usr/share/cinnamon/js/misc/fileUtils.js line 211 > Function":2189:17]
2 on_applet_added_to_panel() ["/usr/share/cinnamon/js/misc/fileUtils.js line 211 > Function":2291:13]
3 on_applet_added_to_panel_internal() ["/usr/share/cinnamon/js/ui/applet.js":384:13]
4 addAppletToPanels() ["/usr/share/cinnamon/js/ui/appletManager.js":409:15]
5 finishExtensionLoad() ["/usr/share/cinnamon/js/ui/appletManager.js":97:13]
6 _init/<() ["/usr/share/cinnamon/js/ui/extension.js":276:31]
0 updateUI() ["/usr/share/cinnamon/js/misc/fileUtils.js line 211 > Function":2040:45]
Gjs-Message: 19:14:22.802: JS LOG: [LookingGlass/info] Loaded applet SpicesUpdate@claudiux in 2264 ms
dropbox: load fq extension '/opt/dropbox/psutil._psutil_linux.cpython-38-x86_64-linux-gnu.so'
dropbox: load fq extension '/opt/dropbox/psutil._psutil_posix.cpython-38-x86_64-linux-gnu.so'
Gjs-Message: 19:14:23.291: JS LOG: [LookingGlass/info] Loaded applet menu@cinnamon.org in 489 ms
Gjs-Message: 19:14:23.291: JS LOG: [LookingGlass/info] AppletManager started in 19955 ms
Gjs-Message: 19:14:23.293: JS LOG: [LookingGlass/info] Cinnamon took 23291 ms to start
dropbox: load fq extension '/opt/dropbox/apex._apex.cpython-38-x86_64-linux-gnu.so'
Gjs-Message: 19:14:23.896: JS LOG: Unknown network device type, is 14
Gjs-Message: 19:14:24.018: JS LOG: [LookingGlass/info] [weather@mockturtl#16]: Weather Information refreshed
(cinnamon:1002): St-WARNING **: 19:14:24.027: percentage lengths not currently supported
Gjs-Message: 19:14:28.409: JS LOG: calendar@cinnamon.org: Calendar events supported.
dropbox: load fq extension '/opt/dropbox/tornado.speedups.cpython-38-x86_64-linux-gnu.so'
(xapp-sn-watcher:1114): GLib-GObject-CRITICAL **: 19:14:35.166: g_object_set: assertion 'G_IS_OBJECT (object)' failed
(xapp-sn-watcher:1114): GLib-GIO-CRITICAL **: 19:14:35.167: g_dbus_interface_skeleton_flush: assertion 'G_IS_DBUS_INTERFACE_SKELETON (interface_)' failed
(xapp-sn-watcher:1114): GLib-GObject-CRITICAL **: 19:14:35.167: g_object_set: assertion 'G_IS_OBJECT (object)' failed
(xapp-sn-watcher:1114): GLib-GObject-WARNING **: 19:14:35.167: invalid (NULL) pointer instance
(xapp-sn-watcher:1114): GLib-GObject-CRITICAL **: 19:14:35.167: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(cinnamon:1002): Gjs-CRITICAL **: 19:14:38.445: Object St.Button (0x557f5b2e2270), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
== Stack trace for context 0x557f5ae441b0 ==
#0 557f5ae663b0 i /usr/share/cinnamon/js/ui/environment.js:280 (18b2c5dafec0 @ 42)
#1 557f5ae66320 i /usr/share/cinnamon/js/ui/messageTray.js:610 (208255a626f0 @ 35)
#2 557f5ae66270 i /usr/share/cinnamon/js/ui/messageTray.js:595 (208255a62790 @ 77)
#3 557f5ae661e8 i /usr/share/cinnamon/js/ui/messageTray.js:268 (208255a62d30 @ 12)
cinnamon-session[859]: WARNING: t+49.60377s: Detected that screensaver has left the bus
dropbox: load fq extension '/opt/dropbox/wrapt._wrappers.cpython-38-x86_64-linux-gnu.so'
WARNING: 2022-07-18 19:14:44,627: create_menu() 'Variety Slideshow is not installed. This is an optional extension adding pan-and-zoom slideshows to Variety: see https://github.com/peterlevi/variety-slideshow for details'
Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x360000c
Gjs-Message: 19:14:47.053: JS LOG: [LookingGlass/info] BackgroundManager: picture-uri changed (file:///home/jkmooney/.config/variety/wallpaper/wallpaper-auto-rotated-73ae01260ffe0c552a2260e89eaedb69.jpg --> file:///home/jkmooney/.config/variety/wallpaper/wallpaper-auto-rotated-d6d978ed46aa6a94c8e1d7869d0a2cb6.jpg)
dropbox: load fq extension '/home/jkmooney/.dropbox-dist/dropbox-lnx.x86_64-152.4.4880/cryptography.hazmat.bindings._openssl.cpython-38-x86_64-linux-gnu.so'
dropbox: load fq extension '/home/jkmooney/.dropbox-dist/dropbox-lnx.x86_64-152.4.4880/cryptography.hazmat.bindings._padding.cpython-38-x86_64-linux-gnu.so'
dropbox: load fq extension '/home/jkmooney/.dropbox-dist/dropbox-lnx.x86_64-152.4.4880/psutil._psutil_linux.cpython-38-x86_64-linux-gnu.so'
dropbox: load fq extension '/home/jkmooney/.dropbox-dist/dropbox-lnx.x86_64-152.4.4880/psutil._psutil_posix.cpython-38-x86_64-linux-gnu.so'
dropbox: load fq extension '/home/jkmooney/.dropbox-dist/dropbox-lnx.x86_64-152.4.4880/apex._apex.cpython-38-x86_64-linux-gnu.so'
dropbox: load fq extension '/home/jkmooney/.dropbox-dist/dropbox-lnx.x86_64-152.4.4880/tornado.speedups.cpython-38-x86_64-linux-gnu.so'
mutter-Message: 19:14:54.156: Enabling experimental feature 'x11-randr-fractional-scaling'
** (nemo:1864): WARNING **: 19:14:54.164: Current gtk theme is not known to have nemo support (CBlack) - checking...
(cinnamon:1002): Clutter-CRITICAL **: 19:14:54.274: clutter_actor_destroy: assertion 'CLUTTER_IS_ACTOR (self)' failed
dropbox: load fq extension '/home/jkmooney/.dropbox-dist/dropbox-lnx.x86_64-152.4.4880/wrapt._wrappers.cpython-38-x86_64-linux-gnu.so'
System doesn't support transparency
Gjs-Message: 19:14:54.433: JS LOG: About to start Cinnamon
Gjs-Message: 19:14:54.448: JS LOG: [LookingGlass/info] Cinnamon.AppSystem.get_default() started in 14 ms
Gjs-Message: 19:14:54.450: JS LOG: [LookingGlass/info] loading user theme: /home/jkmooney/.themes/Eleganse/cinnamon/cinnamon.css
Gjs-Message: 19:14:54.457: JS LOG: [LookingGlass/info] added icon directory: /home/jkmooney/.themes/Eleganse/cinnamon
Gjs-Message: 19:14:54.511: JS LOG: [LookingGlass/info] loaded at Mon Jul 18 2022 19:14:54 GMT-0400 (Eastern Daylight Time)
Gjs-Message: 19:14:54.511: JS LOG: Cinnamon started at Mon Jul 18 2022 19:14:54 GMT-0400 (Eastern Daylight Time)
Gjs-Message: 19:14:54.511: JS LOG: GPU offload supported: false
Gjs-Message: 19:14:54.513: JS LOG: [LookingGlass/info] ExtensionSystem started in 0 ms
Gjs-Message: 19:14:54.513: JS LOG: [LookingGlass/info] DeskletManager started in 0 ms
Gjs-Message: 19:14:54.513: JS LOG: [LookingGlass/info] SearchProviderManager started in 0 ms
Gjs-Message: 19:14:54.577: JS LOG: [LookingGlass/info] [weather@mockturtl#16]: Internet access now available, resuming operations.
Gjs-Message: 19:14:54.583: JS LOG: [LookingGlass/info] Loaded applet weather@mockturtl in 60 ms
Gjs-Message: 19:14:54.590: JS LOG: [LookingGlass/info] Loaded applet printers@cinnamon.org in 7 ms
Gjs-Message: 19:14:54.592: JS LOG: [LookingGlass/info] Role locked: notifications
Gjs-Message: 19:14:54.597: JS LOG: [LookingGlass/info] Loaded applet notifications@cinnamon.org in 7 ms
Gjs-Message: 19:14:54.612: JS LOG: [LookingGlass/info] Loaded applet calendar@cinnamon.org in 15 ms
Gjs-Message: 19:14:54.646: JS LOG: [LookingGlass/error]
Gjs-Message: 19:14:54.646: JS LOG: [LookingGlass/trace]
Gjs-Message: 19:14:54.646: JS LOG: calendar@cinnamon.org: Calendar events supported.
Gjs-Message: 19:14:54.654: JS LOG: [LookingGlass/info] Role locked: windowattentionhandler
Gjs-Message: 19:14:54.655: JS LOG: [LookingGlass/info] Loaded applet grouped-window-list@cinnamon.org in 43 ms
Gjs-Message: 19:14:54.671: JS LOG: [LookingGlass/info] Loaded applet sound@cinnamon.org in 15 ms
Gjs-Message: 19:14:54.693: JS LOG: [LookingGlass/info] Loaded applet network@cinnamon.org in 22 ms
(cinnamon:1871): Gjs-WARNING **: 19:14:55.116: Some code tried to set a deprecated GObject property.
(cinnamon:1871): Gjs-WARNING **: 19:14:55.117: Some code tried to set a deprecated GObject property.
Gjs-Message: 19:14:55.117: JS LOG: [LookingGlass/info] Loaded applet SpicesUpdate@claudiux in 424 ms
Gjs-Message: 19:14:55.544: JS LOG: Unknown network device type, is 14
Gjs-Message: 19:14:55.613: JS LOG: [LookingGlass/info] Loaded applet menu@cinnamon.org in 495 ms
Gjs-Message: 19:14:55.613: JS LOG: [LookingGlass/info] AppletManager started in 1102 ms
Gjs-Message: 19:14:55.614: JS LOG: [LookingGlass/info] Cinnamon took 1181 ms to start
dropbox: load fq extension '/home/jkmooney/.dropbox-dist/dropbox-lnx.x86_64-152.4.4880/PyQt5.QtCore.cpython-38-x86_64-linux-gnu.so'
(cinnamon:1871): St-WARNING **: 19:14:55.636: percentage lengths not currently supported
dropbox: load fq extension '/home/jkmooney/.dropbox-dist/dropbox-lnx.x86_64-152.4.4880/PyQt5.QtGui.cpython-38-x86_64-linux-gnu.so'
Gjs-Message: 19:14:56.031: JS LOG: [LookingGlass/info] [weather@mockturtl#16]: Weather Information refreshed
dropbox: load fq extension '/home/jkmooney/.dropbox-dist/dropbox-lnx.x86_64-152.4.4880/PyQt5.QtWidgets.cpython-38-x86_64-linux-gnu.so'
dropbox: load fq extension '/home/jkmooney/.dropbox-dist/dropbox-lnx.x86_64-152.4.4880/PyQt5.QtDBus.cpython-38-x86_64-linux-gnu.so'
Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x360002f
(cinnamon:1871): Gjs-WARNING **: 19:15:55.198: Some code called array.toString() on a Uint8Array instance. Previously this would have interpreted the bytes of the array as a string, but that is nonstandard. In the future this will return the bytes as comma-separated digits. For the time being, the old behavior has been preserved, but please fix your code anyway to explicitly call ByteArray.toString(array).
(Note that array.toString() may have been called implicitly.)
0 _load_cache() ["/usr/share/cinnamon/js/misc/fileUtils.js line 211 > Function":1218:71]
1 updateLoop() ["/usr/share/cinnamon/js/misc/fileUtils.js line 211 > Function":2118:61]
2 updateLoop/this.loopId<() ["/usr/share/cinnamon/js/misc/fileUtils.js line 211 > Function":2201:88]
(cinnamon:1871): Gjs-WARNING **: 19:15:55.206: Some code called array.toString() on a Uint8Array instance. Previously this would have interpreted the bytes of the array as a string, but that is nonstandard. In the future this will return the bytes as comma-separated digits. For the time being, the old behavior has been preserved, but please fix your code anyway to explicitly call ByteArray.toString(array).
0 _get_last_edited_from_metadata() ["/usr/share/cinnamon/js/misc/fileUtils.js line 211 > Function":1370:75]
1 get_must_be_updated() ["/usr/share/cinnamon/js/misc/fileUtils.js line 211 > Function":1577:26]
2 updateLoop() ["/usr/share/cinnamon/js/misc/fileUtils.js line 211 > Function":2122:51]
3 updateLoop/this.loopId<() ["/usr/share/cinnamon/js/misc/fileUtils.js line 211 > Function":2201:88]
(cinnamon:1871): Clutter-CRITICAL **: 19:16:49.887: clutter_actor_destroy: assertion 'CLUTTER_IS_ACTOR (self)' failed
(polychromatic-tray-applet:1336): Gdk-CRITICAL **: 19:23:15.956: gdk_window_thaw_toplevel_updates: assertion 'window->update_and_descendants_freeze_count > 0' failed
(variety:1139): Gdk-CRITICAL **: 19:23:15.956: gdk_window_thaw_toplevel_updates: assertion 'window->update_and_descendants_freeze_count > 0' failed
(arch-audit-gtk:1131): Gdk-CRITICAL **: 19:23:15.956: gdk_window_thaw_toplevel_updates: assertion 'window->update_and_descendants_freeze_count > 0' failed
** (nemo:6325): WARNING **: 19:44:52.352: Current gtk theme is not known to have nemo support (CBlack) - checking...
mutter-Message: 19:44:52.407: Enabling experimental feature 'x11-randr-fractional-scaling'
Gjs-Message: 19:44:52.597: JS LOG: About to start Cinnamon
Gjs-Message: 19:44:52.615: JS LOG: [LookingGlass/info] Cinnamon.AppSystem.get_default() started in 16 ms
Gjs-Message: 19:44:52.616: JS LOG: [LookingGlass/info] loading user theme: /home/jkmooney/.themes/Eleganse/cinnamon/cinnamon.css
Gjs-Message: 19:44:52.624: JS LOG: [LookingGlass/info] added icon directory: /home/jkmooney/.themes/Eleganse/cinnamon
Gjs-Message: 19:44:52.679: JS LOG: [LookingGlass/info] loaded at Mon Jul 18 2022 19:44:52 GMT-0400 (Eastern Daylight Time)
Gjs-Message: 19:44:52.679: JS LOG: Cinnamon started at Mon Jul 18 2022 19:44:52 GMT-0400 (Eastern Daylight Time)
Gjs-Message: 19:44:52.679: JS LOG: GPU offload supported: false
Gjs-Message: 19:44:52.681: JS LOG: [LookingGlass/info] ExtensionSystem started in 0 ms
Gjs-Message: 19:44:52.681: JS LOG: [LookingGlass/info] DeskletManager started in 0 ms
Gjs-Message: 19:44:52.681: JS LOG: [LookingGlass/info] SearchProviderManager started in 0 ms
Gjs-Message: 19:44:52.729: JS LOG: [LookingGlass/info] Role locked: tray
Gjs-Message: 19:44:52.730: JS LOG: [LookingGlass/info] Loaded applet systray@cinnamon.org in 29 ms
Gjs-Message: 19:44:52.754: JS LOG: [LookingGlass/info] [weather@mockturtl#16]: Internet access now available, resuming operations.
Gjs-Message: 19:44:52.760: JS LOG: [LookingGlass/info] Loaded applet weather@mockturtl in 30 ms
Gjs-Message: 19:44:52.762: JS LOG: [LookingGlass/info] Role locked: notifications
Gjs-Message: 19:44:52.766: JS LOG: [LookingGlass/info] Loaded applet notifications@cinnamon.org in 6 ms
Gjs-Message: 19:44:52.781: JS LOG: [LookingGlass/info] Loaded applet calendar@cinnamon.org in 15 ms
Gjs-Message: 19:44:52.788: JS LOG: [LookingGlass/info] Loaded applet printers@cinnamon.org in 7 ms
Gjs-Message: 19:44:52.822: JS LOG: [LookingGlass/error]
Gjs-Message: 19:44:52.822: JS LOG: [LookingGlass/trace]
Gjs-Message: 19:44:52.822: JS LOG: calendar@cinnamon.org: Calendar events supported.
Gjs-Message: 19:44:52.830: JS LOG: [LookingGlass/info] Role locked: windowattentionhandler
Gjs-Message: 19:44:52.831: JS LOG: [LookingGlass/info] Loaded applet grouped-window-list@cinnamon.org in 43 ms
Gjs-Message: 19:44:52.847: JS LOG: [LookingGlass/info] Loaded applet sound@cinnamon.org in 16 ms
Gjs-Message: 19:44:52.869: JS LOG: [LookingGlass/info] Loaded applet network@cinnamon.org in 22 ms
(cinnamon:6336): Gjs-WARNING **: 19:44:53.079: Some code tried to set a deprecated GObject property.
Gjs-Message: 19:44:53.079: JS LOG: [LookingGlass/info] Loaded applet SpicesUpdate@claudiux in 209 ms
Gjs-Message: 19:44:53.338: JS LOG: Unknown network device type, is 14
Gjs-Message: 19:44:53.405: JS LOG: [LookingGlass/info] Loaded applet menu@cinnamon.org in 326 ms
Gjs-Message: 19:44:53.405: JS LOG: [LookingGlass/info] AppletManager started in 726 ms
Gjs-Message: 19:44:53.406: JS LOG: [LookingGlass/info] Cinnamon took 809 ms to start
Gjs-Message: 19:44:53.420: JS LOG: [LookingGlass/info] Adding systray: dropbox (22x22px)
Gjs-Message: 19:44:53.422: JS LOG: [LookingGlass/info] Adding systray: arch-audit-gtk (24x24px)
Gjs-Message: 19:44:53.423: JS LOG: [LookingGlass/info] Adding systray: variety (24x24px)
Gjs-Message: 19:44:53.423: JS LOG: [LookingGlass/info] Adding systray: polychromatic-tray-applet (24x24px)
Gjs-Message: 19:44:53.424: JS LOG: [LookingGlass/info] Adding systray: proton mail bridge (22x22px)
Gjs-Message: 19:44:53.425: JS LOG: [LookingGlass/info] Adding systray: firewall-applet (22x22px)
Gjs-Message: 19:44:53.426: JS LOG: [LookingGlass/info] Hiding systray: network
(cinnamon:6336): St-WARNING **: 19:44:53.458: percentage lengths not currently supported
Gjs-Message: 19:44:53.765: JS LOG: [LookingGlass/info] [weather@mockturtl#16]: Weather Information refreshed
(cinnamon:6336): Gjs-WARNING **: 19:45:53.160: Some code called array.toString() on a Uint8Array instance. Previously this would have interpreted the bytes of the array as a string, but that is nonstandard. In the future this will return the bytes as comma-separated digits. For the time being, the old behavior has been preserved, but please fix your code anyway to explicitly call ByteArray.toString(array).
(cinnamon:6336): Gjs-WARNING **: 19:45:53.167: Some code called array.toString() on a Uint8Array instance. Previously this would have interpreted the bytes of the array as a string, but that is nonstandard. In the future this will return the bytes as comma-separated digits. For the time being, the old behavior has been preserved, but please fix your code anyway to explicitly call ByteArray.toString(array).
(cinnamon:6336): St-WARNING **: 19:47:01.403: percentage lengths not currently supported
(cinnamon:6336): St-WARNING **: 19:47:01.406: percentage lengths not currently supported
(cinnamon:6336): St-WARNING **: 19:47:01.410: percentage lengths not currently supported
(cinnamon:6336): St-WARNING **: 19:47:01.416: percentage lengths not currently supported
(cinnamon:6336): Gtk-WARNING **: 19:47:01.451: Could not load a pixbuf from icon theme.
This may indicate that pixbuf loaders or the mime database could not be found.
**Issue**
Error message on start, systray and other applets no loading (but can be manually loaded after start).
From cinnamon-looking-glass; the error seems to be that it can't find a .js module..
error t=2022-07-18T19:44:52Z
**Steps to reproduce**
Happens on desktop restart or PC reboot
**Expected behaviour**
All apps load normally
**Other information**
**Configuration info, if applicable**
If this bug report is related to an Applet, Desklet or Extension, please paste (or use a pastebin service) the offending extension's settings, if it has any. You can obtain this by opening its configuration, clicking the 'hamburger' button in the upper-right corner of the window, and selecting "Export to a file". **Please be sure to review the contents and remove any personal data it may contain.**
Please paste here
Hopefully the applet /extension issues might be fixed when the next update is pushed
COD
July 24, 2022, 6:27am
#17
Everything’s fine here since the last Manjaro / Cinnamon update - systray and taskbar are working correctly since…
Good! The latest update didn’t change a lot for me, since systray was already/still working as expected for me. The only thing I still notice is that the keybindings for snapping/positioning of windows are behaving a little different when you have multiple displays and occasionally I have trouble moving a window to another screen with the key combinations.
I followed the steps after a lot of research:
sudo pacman -S manjaro-cinnamon-settings;
sudo pamac reinstall cinnamon;
sudo pacman -Syyu
the last one showed me that many packages were missing, however it brought my system back and so far everything is working
I hope it helps
Not sure how many extensions have been fixed but transparent windows works now but you need to download/install in manually from here GitHub - yuansl/cinnamon-spices-extensions: Extensions for the Cinnamon desktop until they get merged into the linuxmint master
zxuiji
September 6, 2022, 4:51pm
#21
Not sure if this is specific to manjaro cinnamon or across the board but there’s an issue with libc or something:
cd "dst/_x86_64_linux_cc/DEBUG/output" && valgrind --leak-check=full --show-leak-kinds=all ./trypaw.elf -D APP_DATA=...
==105513== Memcheck, a memory error detector
==105513== Copyright (C) 2002-2022, and GNU GPL'd, by Julian Seward et al.
==105513== Using Valgrind-3.19.0 and LibVEX; rerun with -h for copyright info
==105513== Command: ./trypaw.elf -D APP_DATA=...
==105513==
valgrind: Fatal error at startup: a function redirection
valgrind: which is mandatory for this platform-tool combination
valgrind: cannot be set up. Details of the redirection are:
valgrind:
valgrind: A must-be-redirected function
valgrind: whose name matches the pattern: strlen
valgrind: in an object with soname matching: ld-linux-x86-64.so.2
valgrind: was not found whilst processing
valgrind: symbols from the object with soname: ld-linux-x86-64.so.2
valgrind:
valgrind: Possible fixes: (1, short term): install glibc's debuginfo
valgrind: package on this machine. (2, longer term): ask the packagers
valgrind: for your Linux distribution to please in future ship a non-
valgrind: stripped ld.so (or whatever the dynamic linker .so is called)
valgrind: that exports the above-named function using the standard
valgrind: calling conventions for this platform. The package you need
valgrind: to install for fix (1) is called
valgrind:
valgrind: On Debian, Ubuntu: libc6-dbg
valgrind: On SuSE, openSuSE, Fedora, RHEL: glibc-debuginfo
valgrind:
valgrind: Note that if you are debugging a 32 bit process on a
valgrind: 64 bit system, you will need a corresponding 32 bit debuginfo
valgrind: package (e.g. libc6-dbg:i386).
valgrind:
valgrind: Cannot continue -- exiting now. Sorry.
