Note that pi-hole-ftl-6.7 and pi-hole-core-6.5 are incompatible (pi-hole-core-6.4.3 works). It’s devilish because pihole service is running and examing domains, but the gravity database is completely broken so nothing get actually blocked.
You might want to read through the comments on each package’s AUR page to see if there is any solution, and leave your own comments if necessary to make the packager/s aware of the issue.
sorry, I was unclear pi-hole-ftl-6.7-1 is incompatible with pi-hole-core-6.5-2. I didn’t know about the bin package but it does fix the problem. Thanks.
AgentMat commented on 2026-10-24 22:48 (UTC) (edited on 2026-10-24 22:53 (UTC) by AgentMat))
Following up on my earlier comments about updating the PKGBUILD, here’s the incident that prompted them. I’ve since put together a post-mortem to share, in the hope it pushes others to be more careful than I was.
My Pi-hole running FTL 6.7 was compromised on 19 September 2026, within hours of the advisories and PoCs going public (GHSA-ww5x-xx4x-qvjr, GHSA-2794-hrj8-5jg9), both fixed upstream in 6.7.1.
My config was careless: the web UI had its password disabled (a leftover from the nettle 3->4 breakage) and was reachable from the internet (IPv6 + a leftover 443 forward from a previous OpenVPN setup). On 6.7 that passwordless UI was enough for remote code execution and unauthenticated file read, the vectors (conf-script via misc.dnsmasq_lines; serve_all + webroot=/) were still open. The payload also inherited the service unit’s ambient CAP_CHOWN, which upstream drops before exec in 6.7.1+.
Write-up, decoded payload, timeline, forensics: Claude Artifact
@pzarycki: could you package 6.7.1 or 6.8? 6.7 carries the bugs above and the AUR has been on it since 18 Sep. I have already provided a PKGBUILD updated to 6.8 and a service-unit capability-hardening drop-in in earlier comments.
Everyone else: until it lands, build the latest upstream yourself, or at minimum set a web UI password and make sure it isn’t reachable from the internet (check IPv6, not just port forwards).
