My apologies if this doesn’t belong here.
Using hdparm I’ve found issues with my M.2 NVMe drive. These are the results of the commands
sudo hdparm --dco-identify /dev/sda ✔
/dev/sda:
SG_IO: bad/missing sense data, sb[]: 70 00 05 00 00 00 00 0a 00 00 00 00 24 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DCO Checksum verified.
DCO Revision: 0x0000 -- unknown, treating as 0002
The following features can be selectively disabled via DCO:
Transfer modes:
Real max sectors: 1
ATA command/feature sets:
and
sudo hdparm -N /dev/nvme0n1 ✔
/dev/nvme0n1:
(I hope that I formatted the text correctly.)
I’m currently booted into my copy of Manjaro USB drive. Can anyone give me some advice on how to fix these issues? The dco ID shows bad/missing sense data and the N command fails to give any data at all.
If you need any more information, I’ll be happy to provide it. Thank you.
Please check the most recent Announcement posts and search the forum before posting: Announcements - Manjaro Linux Forum
Please also see [HowTo] Request support: [HowTo] Request support
Note that this is a hidden template and will not appear in your post.
Please type below the arrow.
I’ve just tried to reinstall Manjaro and the bootloader failed.
=== START CALAMARES 3.3.1
2024-02-28 - 11:46:13 [6]: void CalamaresApplication::init()
2024-02-28 - 11:46:13 [6]: Calamares version: 3.3.1
2024-02-28 - 11:46:13 [6]: .. Using settings: "/etc/calamares/settings.conf"
2024-02-28 - 11:46:13 [6]: .. Using log file: "/home/manjaro/.cache/calamares/session.log"
2024-02-28 - 11:46:13 [6]: .. languages: ("ar", "as", "ast", "az", "az_AZ", "be", "bg", "bn", "ca", "ca@valencia", "cs_CZ", "da", "de", "el", "en", "en_GB", "eo", "es", "es_AR", "es_MX", "et", "eu", "fa", "fi_FI", "fr", "fur", "gl", "he", "hi", "hr", "hu", "id", "is", "it_IT", "ja", "ko", "lt", "ml", "mr", "nb", "nl", "oc", "pl", "pt_BR", "pt_PT", "ro", "ru", "si", "sk", "sl", "sq", "sr", "sr@latin", "sv", "tg", "th", "tr_TR", "uk", "vi", "zh_CN", "zh_TW")
2024-02-28 - 11:46:13 [6]: bool Calamares::initQmlModulesDir()
2024-02-28 - 11:46:13 [6]: Using Calamares QML directory "/usr/share/calamares/qml"
2024-02-28 - 11:46:13 [6]: Calamares::Branding::Branding(const QString&, QObject*, qreal)
2024-02-28 - 11:46:13 [6]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
2024-02-28 - 11:46:13 [2]: Calamares::Branding::Branding(const QString&, QObject*, qreal)
2024-02-28 - 11:46:13 [2]: WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
2024-02-28 - 11:46:13 [6]: Loaded branding component "manjaro"
2024-02-28 - 11:46:13 [2]: bool Calamares::validateStyleEntries(const QMap<QString, QString>&)
2024-02-28 - 11:46:13 [2]: WARNING: Unknown branding *style* entry "sidebarBackground"
2024-02-28 - 11:46:13 [2]: WARNING: .. Unknown branding *style* entry "sidebarText"
2024-02-28 - 11:46:13 [2]: WARNING: .. Unknown branding *style* entry "sidebarTextHighlight"
2024-02-28 - 11:46:13 [2]: WARNING: .. Unknown branding *style* entry "sidebarTextSelect"
2024-02-28 - 11:46:13 [6]: .. Loaded QRC translation "tz_" "en_US"
2024-02-28 - 11:46:13 [6]: .. Loaded QRC translation "calamares_" "en_US"
2024-02-28 - 11:46:13 [6]: .. STARTUP: initSettings, initQmlPath, initBranding done
2024-02-28 - 11:46:13 [6]: .. STARTUP: initModuleManager: module init started
2024-02-28 - 11:46:13 [2]: static Calamares::ModuleSystem::Descriptor Calamares::ModuleSystem::Descriptor::fromDescriptorData(const QVariantMap&, const QString&)
2024-02-28 - 11:46:13 [2]: WARNING: Descriptor file "/usr/lib/calamares/modules/servicescfg/module.desc"
2024-02-28 - 11:46:13 [2]: WARNING: .. Module descriptor contains extra keys:
"requires"
2024-02-28 - 11:46:13 [6]: void Calamares::ModuleManager::doInit()
2024-02-28 - 11:46:13 [6]: Found 57 modules
2024-02-28 - 11:46:13 [6]: void CalamaresApplication::initView()
2024-02-28 - 11:46:13 [6]: STARTUP: initModuleManager: all modules init done
2024-02-28 - 11:46:13 [6]: STARTUP: initJobQueue done
2024-02-28 - 11:46:13 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
2024-02-28 - 11:46:13 [6]: Available desktop QSize(3840, 2110) minimum size QSize(1024, 520)
2024-02-28 - 11:46:13 [6]: .. Proposed window size: 1024 520
2024-02-28 - 11:46:13 [6]: QString Calamares::searchQmlFile(QmlSearch, const QString&)
2024-02-28 - 11:46:13 [6]: Looking for QML for "calamares-sidebar"
2024-02-28 - 11:46:13 [6]: .. Looking at QML file "/usr/share/calamares/branding/manjaro/calamares-sidebar.qml"
2024-02-28 - 11:46:13 [6]: STARTUP: CalamaresWindow created; loadModules started
2024-02-28 - 11:46:13 [6]: void Config::initLanguages()
2024-02-28 - 11:46:13 [6]: Trying to match locale "en_US"
2024-02-28 - 11:46:13 [6]: Trying to match locale QLocale(English, Latin, United States)
2024-02-28 - 11:46:13 [6]: void Config::setLocaleIndex(int)
2024-02-28 - 11:46:13 [6]: Index 14 Selected locale "en"
2024-02-28 - 11:46:13 [6]: .. Loaded QRC translation "tz_" "en"
2024-02-28 - 11:46:13 [6]: .. Loaded QRC translation "calamares_" "en"
2024-02-28 - 11:46:13 [6]: virtual void Calamares::ViewModule::loadSelf()
2024-02-28 - 11:46:13 [6]: ViewModule "welcome@welcome" loading complete.
2024-02-28 - 11:46:13 [6]: QStringList loadLocales(const QString&)
2024-02-28 - 11:46:13 [6]: Loading locales from "/usr/share/i18n/SUPPORTED"
2024-02-28 - 11:46:13 [6]: .. Read 498 lines
2024-02-28 - 11:46:13 [6]: .. After filtering 323 lines
2024-02-28 - 11:46:13 [6]: ViewModule "locale@locale" loading complete.
2024-02-28 - 11:46:13 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
2024-02-28 - 11:46:13 [6]: Loaded 186 keyboard models
2024-02-28 - 11:46:13 [6]: KeyboardGroupsSwitchersModel::KeyboardGroupsSwitchersModel(QObject*)
2024-02-28 - 11:46:13 [6]: Loaded 40 keyboard groups
2024-02-28 - 11:46:13 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
2024-02-28 - 11:46:13 [6]: Variants now total= 0 selected= -1
2024-02-28 - 11:46:13 [6]: Groups now total= 40 selected= -1
2024-02-28 - 11:46:13 [6]: .. Loaded QRC translation "kb_" "en"
2024-02-28 - 11:46:13 [6]: void Config::getCurrentKeyboardLayoutXkb(QString&, QString&, QString&)
2024-02-28 - 11:46:13 [6]: ("pc", "us", "inet(evdev)", "terminate(ctrl_alt_bksp)\"")
2024-02-28 - 11:46:13 [6]: ViewModule "keyboard@keyboard" loading complete.
2024-02-28 - 11:46:13 [6]: Calamares::Partition::InternalManager::InternalManager()
2024-02-28 - 11:46:13 [6]: KPMCore backend starting ..
2024-02-28 - 11:46:13 [6]: DEBUG (Qt): Loaded backend plugin: "pmsfdiskbackendplugin"
2024-02-28 - 11:46:13 [6]: .. Backend @0x556ac49fc950 "pmsfdiskbackendplugin" "1"
2024-02-28 - 11:46:13 [2]: void Config::fillConfigurationFSTypes(const QVariantMap&)
2024-02-28 - 11:46:13 [2]: WARNING: Partition-module setting *luksGeneration* not found or invalid. Defaulting to luks1.
2024-02-28 - 11:46:13 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
2024-02-28 - 11:46:13 [2]: WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
2024-02-28 - 11:46:13 [6]: ViewModule "partition@partition" loading complete.
2024-02-28 - 11:46:13 [2]: bool addPasswordCheck(const QString&, const QVariant&, PasswordCheckList&)
2024-02-28 - 11:46:13 [2]: WARNING: nonempty check is ignored; use minLength: 1
2024-02-28 - 11:46:13 [6]: ViewModule "users@users" loading complete.
2024-02-28 - 11:46:13 [6]: virtual void Config::setConfigurationMap(const QVariantMap&)
2024-02-28 - 11:46:13 [6]: Using module ID "packagechooser@packagechooser"
2024-02-28 - 11:46:13 [6]: void fillModel(PackageListModel*, const QVariantList&)
2024-02-28 - 11:46:13 [6]: Loading PackageChooser model items from config
2024-02-28 - 11:46:13 [6]: .. Loaded PackageChooser with 3 entries.
2024-02-28 - 11:46:13 [2]: WARNING (Qt): QPixmap::scaled: Pixmap is a null pixmap
2024-02-28 - 11:46:13 [6]: ViewModule "packagechooser@packagechooser" loading complete.
2024-02-28 - 11:46:13 [6]: ViewModule "summary@summary" loading complete.
2024-02-28 - 11:46:13 [6]: void Calamares::ModuleManager::loadModules()
2024-02-28 - 11:46:13 [6]: Module "partition@partition" already loaded.
2024-02-28 - 11:46:13 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
2024-02-28 - 11:46:13 [6]: QML import paths:
"/usr/bin"
"qrc:/qt-project.org/imports"
"/usr/lib/qt/qml"
2024-02-28 - 11:46:13 [6]: QML load on startup, API 2.
2024-02-28 - 11:46:13 [2]: WARNING (Qt): QThread::setPriority: Cannot set priority, thread is not running
2024-02-28 - 11:46:13 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
2024-02-28 - 11:46:13 [2]: WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
2024-02-28 - 11:46:13 [6]: virtual void Calamares::CppJobModule::loadSelf()
2024-02-28 - 11:46:13 [6]: CppJobModule "machineid@machineid" loading complete.
2024-02-28 - 11:46:13 [6]: Module "locale@locale" already loaded.
2024-02-28 - 11:46:13 [6]: Module "keyboard@keyboard" already loaded.
2024-02-28 - 11:46:13 [6]: CppJobModule "luksopenswaphookcfg@luksopenswaphookcfg" loading complete.
2024-02-28 - 11:46:13 [6]: CppJobModule "luksbootkeyfile@luksbootkeyfile" loading complete.
2024-02-28 - 11:46:13 [6]: CppJobModule "initcpio@initcpio" loading complete.
2024-02-28 - 11:46:13 [6]: Module "users@users" already loaded.
2024-02-28 - 11:46:13 [6]: CppJobModule "umount@umount" loading complete.
2024-02-28 - 11:46:13 [2]: void Config::setConfigurationMap(const QVariantMap&)
2024-02-28 - 11:46:13 [2]: WARNING: Configuring the finished module with deprecated restartNowEnabled settings
2024-02-28 - 11:46:13 [6]: ViewModule "finished@finished" loading complete.
2024-02-28 - 11:46:13 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
2024-02-28 - 11:46:13 [6]: GeoIP result for welcome= "US"
2024-02-28 - 11:46:13 [6]: void setCountry(Config*, const QString&, Calamares::GeoIP::Handler*)
2024-02-28 - 11:46:13 [6]: Unusable country code "US"
2024-02-28 - 11:46:13 [6]: .. Obtained from "https://ipapi.co/json" ( 1 "country" )
2024-02-28 - 11:46:13 [6]: void CalamaresApplication::initViewSteps()
2024-02-28 - 11:46:13 [6]: STARTUP: loadModules for all modules done
2024-02-28 - 11:46:13 [6]: void Calamares::ModuleManager::checkRequirements()
2024-02-28 - 11:46:13 [6]: Checking module requirements ..
2024-02-28 - 11:46:14 [6]: DEBUG (Qt): getting temp failed for "/dev/nvme0n1" : Success
2024-02-28 - 11:46:14 [6]: DEBUG (Qt): getting powered on time failed for "/dev/nvme0n1" : Success
2024-02-28 - 11:46:14 [6]: DEBUG (Qt): getting power cycles failed for "/dev/nvme0n1" : Success
2024-02-28 - 11:46:14 [6]: void CalamaresApplication::initViewSteps()
2024-02-28 - 11:46:14 [6]: STARTUP: Window now visible and ProgressTreeView populated
2024-02-28 - 11:46:14 [6]: .. 9 view steps loaded.
2024-02-28 - 11:46:14 [6]: void Calamares::SlideshowQML::loadQmlV2Complete()
2024-02-28 - 11:46:14 [6]: QML component complete, API 2
2024-02-28 - 11:46:14 [2]: WARNING (Qt): file:///usr/share/calamares/branding/manjaro/slideshow/sponsor/SponsoredBy.qml: No such file or directory
2024-02-28 - 11:46:14 [6]: .. Loading "/usr/share/calamares/branding/manjaro/slideshow/SlideShow.qml"
2024-02-28 - 11:46:15 [6]: void Config::xkbApply()
2024-02-28 - 11:46:15 [6]: xkbmap selection changed to: "us" - ""
2024-02-28 - 11:46:15 [6]: QList<Device*> PartUtils::getDevices(DeviceType)
2024-02-28 - 11:46:15 [6]: Removing unsuitable devices: 1 candidates.
2024-02-28 - 11:46:15 [6]: .. Running ("blkid", "/dev/nvme0n1")
2024-02-28 - 11:46:15 [6]: .. Running ("blkid", "")
2024-02-28 - 11:46:15 [6]: .. Target cmd: ("blkid", "") Exit code: 2 (no output)
2024-02-28 - 11:46:15 [6]: .. Running ("blkid", "/dev/nvme0n1p1")
2024-02-28 - 11:46:15 [6]: .. Running ("blkid", "/dev/nvme0n1p2")
2024-02-28 - 11:46:15 [6]: .. there are 1 devices left.
2024-02-28 - 11:46:15 [6]: void PartitionCoreModule::doInit()
2024-02-28 - 11:46:15 [6]: LIST OF DETECTED DEVICES:
2024-02-28 - 11:46:15 [6]: .. node capacity name prettyName
2024-02-28 - 11:46:15 [6]: .. "/dev/nvme0n1" 1024203640320 DevName$4a01455f DevNamePretty$b8fb0b13
2024-02-28 - 11:46:15 [6]: .. 1 devices detected.
2024-02-28 - 11:46:16 [6]: void Calamares::RequirementsChecker::reportProgress()
2024-02-28 - 11:46:16 [6]: Remaining modules: 2
"partition"
"welcome"
2024-02-28 - 11:46:16 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
2024-02-28 - 11:46:16 [6]: GeneralRequirements output:
storage : 8482560409
enoughStorage : true
RAM : 1073741824
enoughRam : true
hasPower : true
hasInternet : true
isRoot : true
2024-02-28 - 11:46:16 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
2024-02-28 - 11:46:16 [6]: Got 5 requirement results from "welcome"
2024-02-28 - 11:46:17 [6]: void Calamares::RequirementsChecker::reportProgress()
2024-02-28 - 11:46:17 [6]: Remaining modules: 1
"partition"
2024-02-28 - 11:46:18 [6]: OsproberEntryList PartUtils::runOsprober(DeviceModel*)
2024-02-28 - 11:46:18 [6]: os-prober gave no output.
2024-02-28 - 11:46:18 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
2024-02-28 - 11:46:18 [6]: Got 1 requirement results from "partition"
2024-02-28 - 11:46:18 [6]: void ChoicePage::updateDeviceStatePreview()
2024-02-28 - 11:46:18 [6]: Updating partitioning state widgets.
2024-02-28 - 11:46:18 [6]: void ChoicePage::setupActions()
2024-02-28 - 11:46:18 [6]: Setting up actions for "/dev/nvme0n1" with 0 entries.
2024-02-28 - 11:46:18 [6]: .. Can not resize "/dev/nvme0n1" , filesystem "unknown" does not support resize.
2024-02-28 - 11:46:18 [6]: .. Checking if "/dev/nvme0n1" can be replaced.
2024-02-28 - 11:46:18 [6]: .. NO, insufficient storage
Required storage B: 9019431321 "(7.9GiB)"
Available storage B: 1048576 "(0GiB)"
2024-02-28 - 11:46:18 [6]: .. Can not resize "/dev/nvme0n1p1" , filesystem "fat32" does not support resize.
2024-02-28 - 11:46:18 [6]: .. Checking if "/dev/nvme0n1p1" can be replaced.
Available storage B: 314572800 "(0GiB)"
2024-02-28 - 11:46:18 [6]: .. Can not resize "/dev/nvme0n1p2" , filesystem "luks2" does not support resize.
2024-02-28 - 11:46:18 [6]: .. Checking if "/dev/nvme0n1p2" can be replaced.
2024-02-28 - 11:46:18 [6]: .. Partition "/dev/nvme0n1p2" authorized for replace install.
2024-02-28 - 11:46:18 [6]: .. contains replaceable "/dev/nvme0n1p2"
Available storage B: 5885952 "(0GiB)"
2024-02-28 - 11:46:18 [6]: ChoicePage::setupActions()::<lambda()>
2024-02-28 - 11:46:18 [6]: Setting texts for 0 osprober entries
2024-02-28 - 11:46:18 [6]: No partitions available for resize-action.
2024-02-28 - 11:46:18 [6]: void ChoicePage::continueApplyDeviceChoice()
2024-02-28 - 11:46:18 [6]: Previous device -1 new device 0
2024-02-28 - 11:46:18 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2024-02-28 - 11:46:18 [6]: InstallChoice Config::Erase "erase"
2024-02-28 - 11:46:18 [6]: PartitionTable* CreatePartitionTableJob::createTable()
2024-02-28 - 11:46:18 [6]: CreatePartitionTableJob::createTable trying to make table for device "/dev/nvme0n1"
2024-02-28 - 11:46:18 [6]: void Calamares::RequirementsChecker::finished()
2024-02-28 - 11:46:18 [6]: All requirements have been checked.
2024-02-28 - 11:46:18 [6]: void Calamares::RequirementsModel::describe() const
2024-02-28 - 11:46:18 [6]: Requirements model has 6 items
2024-02-28 - 11:46:18 [6]: .. requirement 0 "storage" satisfied? true mandatory? true
2024-02-28 - 11:46:18 [6]: .. requirement 1 "ram" satisfied? true mandatory? true
2024-02-28 - 11:46:18 [6]: .. requirement 2 "power" satisfied? true mandatory? false
2024-02-28 - 11:46:18 [6]: .. requirement 3 "internet" satisfied? true mandatory? false
2024-02-28 - 11:46:18 [6]: .. requirement 4 "root" satisfied? true mandatory? true
2024-02-28 - 11:46:18 [6]: .. requirement 5 "partitions" satisfied? true mandatory? true
2024-02-28 - 11:46:18 [6]: void PartitionCoreModule::dumpQueue() const
2024-02-28 - 11:46:18 [6]: # Queue:
2024-02-28 - 11:46:18 [6]: .. ## Device: "/dev/nvme0n1"
2024-02-28 - 11:46:18 [6]: .. - CreatePartitionTableJob
2024-02-28 - 11:46:18 [6]: .. - CreatePartitionJob
2024-02-28 - 11:46:18 [6]: .. - SetPartFlagsJob
2024-02-28 - 11:46:18 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2024-02-28 - 11:46:18 [6]: Updating partitioning preview widgets.
2024-02-28 - 11:46:21 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
2024-02-28 - 11:46:21 [6]: Mapping "en" in "US" to locale.
2024-02-28 - 11:46:21 [6]: .. Got best match for "en" as "en_AG"
2024-02-28 - 11:46:21 [6]: .. Got best match for "en_US" as "en_US.UTF-8"
2024-02-28 - 11:46:26 [6]: void Config::guessLocaleKeyboardLayout()
2024-02-28 - 11:46:26 [6]: Got locale language "en_US.UTF-8"
2024-02-28 - 11:46:26 [6]: .. looking for locale part "US"
2024-02-28 - 11:46:26 [6]: .. matched "us"
2024-02-28 - 11:46:26 [6]: void guessLayout(const QStringList&, KeyboardLayoutModel*, KeyboardVariantsModel*)
2024-02-28 - 11:46:26 [6]: Next level: "en"
2024-02-28 - 11:46:34 [6]: void PartitionCoreModule::setBootLoaderInstallPath(const QString&)
2024-02-28 - 11:46:34 [6]: PCM::setBootLoaderInstallPath "/dev/nvme0n1"
2024-02-28 - 11:53:16 [6]: void Config::updateGlobalStorage(const QStringList&) const
2024-02-28 - 11:53:16 [6]: std::pair("packagechooser","packagechooser") selected "libreoffice-still"
2024-02-28 - 11:53:16 [2]: WARNING (Qt): QObject::setParent: Cannot set parent, new parent is in a different thread
2024-02-28 - 11:53:16 [6]: virtual QString PartitionViewStep::prettyStatus() const
2024-02-28 - 11:53:16 [6]: Summary for Partition 1 Config::Erase
2024-02-28 - 11:53:16 [6]: QStringList findEssentialLVs(const QList<PartitionCoreModule::DeviceInfo*>&)
2024-02-28 - 11:53:16 [6]: Checking LVM use on 1 devices
2024-02-28 - 11:53:16 [6]: QVariantList FillGlobalStorageJob::createPartitionList() const
2024-02-28 - 11:53:16 [6]: Building partition information map
2024-02-28 - 11:53:16 [6]: .. partitions on "/dev/nvme0n1"
2024-02-28 - 11:53:16 [6]: .. mapping for "" "New Partition"
partlabel : "root"
partition-uuid (partuuid) : "PartUUID$9b67f39"
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "ext4"
fsName : "ext4"
filesystem-uuid (uuid) : "FSUUID$aa8bddfc"
claimed : "true"
partlabel : "root"
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "ext4"
fsName : "ext4"
claimed : "true"
2024-02-28 - 11:53:16 [2]: WARNING (Qt): QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
partlabel : "root"
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "ext4"
fsName : "ext4"
claimed : "true"
partlabel : "root"
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "ext4"
fsName : "ext4"
claimed : "true"
2024-02-28 - 11:53:16 [6]: void ensureSize(QWidget*, QScrollArea*, Calamares::ViewStep*)
2024-02-28 - 11:53:16 [6]: Summary widget is larger than viewport, enlarge by 174 to QSize(834, 662)
2024-02-28 - 11:53:30 [6]: QStringList findEssentialLVs(const QList<PartitionCoreModule::DeviceInfo*>&)
2024-02-28 - 11:53:30 [6]: Checking LVM use on 1 devices
2024-02-28 - 11:53:30 [6]: void Calamares::JobThread::finalize()
2024-02-28 - 11:53:30 [6]: There are 34 jobs, total weight 33
2024-02-28 - 11:53:30 [6]: .. Job 1 "Managing auto-mount settings…" +wt 0.125 tot.wt 0.125
2024-02-28 - 11:53:30 [6]: .. Job 2 "Clearing all temporary mounts…" +wt 0.125 tot.wt 0.25
2024-02-28 - 11:53:30 [6]: .. Job 3 "Clear mounts for partitioning operations on /dev/nvme0n1" +wt 0.125 tot.wt 0.375
2024-02-28 - 11:53:30 [6]: .. Job 4 "Creating new msdos partition table on /dev/nvme0n1. {1 ?} {2…?}" +wt 0.125 tot.wt 0.5
2024-02-28 - 11:53:30 [6]: .. Job 5 "Create new 976755MiB partition on /dev/nvme0n1 (TEAM TM8FP6001T) with file system ext4" +wt 0.125 tot.wt 0.625
2024-02-28 - 11:53:30 [6]: .. Job 6 "Set flags on 976755MiB ext4 partition" +wt 0.125 tot.wt 0.75
2024-02-28 - 11:53:30 [6]: .. Job 7 "Set partition information" +wt 0.125 tot.wt 0.875
2024-02-28 - 11:53:30 [6]: .. Job 8 "Managing auto-mount settings…" +wt 0.125 tot.wt 1
2024-02-28 - 11:53:30 [6]: .. Job 9 "mount" +wt 1 tot.wt 2
2024-02-28 - 11:53:30 [6]: .. Job 10 "unpackfs" +wt 12 tot.wt 14
2024-02-28 - 11:53:30 [6]: .. Job 11 "networkcfg" +wt 1 tot.wt 15
2024-02-28 - 11:53:30 [6]: .. Job 12 "Generate machine-id." +wt 1 tot.wt 16
2024-02-28 - 11:53:30 [6]: .. Job 13 "fstab" +wt 1 tot.wt 17
2024-02-28 - 11:53:30 [6]: .. Job 14 "Setting timezone to America/Chicago…" +wt 1 tot.wt 18
2024-02-28 - 11:53:30 [6]: .. Job 15 "Setting keyboard model to pc105, layout as us-…" +wt 1 tot.wt 19
2024-02-28 - 11:53:30 [6]: .. Job 16 "localecfg" +wt 1 tot.wt 20
2024-02-28 - 11:53:30 [6]: .. Job 17 "Configuring encrypted swap." +wt 1 tot.wt 21
2024-02-28 - 11:53:30 [6]: .. Job 18 "Configuring LUKS key file." +wt 1 tot.wt 22
2024-02-28 - 11:53:30 [6]: .. Job 19 "initcpiocfg" +wt 1 tot.wt 23
2024-02-28 - 11:53:30 [6]: .. Job 20 "Creating initramfs with mkinitcpio…" +wt 1 tot.wt 24
2024-02-28 - 11:53:30 [6]: .. Job 21 "Configuring <pre>sudo</pre> users…" +wt 0.166667 tot.wt 24.1667
2024-02-28 - 11:53:30 [6]: .. Job 22 "Preparing groups…" +wt 0.166667 tot.wt 24.3333
2024-02-28 - 11:53:30 [6]: .. Job 23 "Create user glen" +wt 0.166667 tot.wt 24.5
2024-02-28 - 11:53:30 [6]: .. Job 24 "Set password for user glen" +wt 0.166667 tot.wt 24.6667
2024-02-28 - 11:53:30 [6]: .. Job 25 "Set password for user root" +wt 0.166667 tot.wt 24.8333
2024-02-28 - 11:53:30 [6]: .. Job 26 "Set hostname backup-linux-box" +wt 0.166667 tot.wt 25
2024-02-28 - 11:53:30 [6]: .. Job 27 "displaymanager" +wt 1 tot.wt 26
2024-02-28 - 11:53:30 [6]: .. Job 28 "mhwdcfg" +wt 1 tot.wt 27
2024-02-28 - 11:53:30 [6]: .. Job 29 "hwclock" +wt 1 tot.wt 28
2024-02-28 - 11:53:30 [6]: .. Job 30 "services" +wt 1 tot.wt 29
2024-02-28 - 11:53:30 [6]: .. Job 31 "grubcfg" +wt 1 tot.wt 30
2024-02-28 - 11:53:30 [6]: .. Job 32 "bootloader" +wt 1 tot.wt 31
2024-02-28 - 11:53:30 [6]: .. Job 33 "postcfg" +wt 1 tot.wt 32
2024-02-28 - 11:53:30 [6]: .. Job 34 "Unmounting file systems…" +wt 1 tot.wt 33
2024-02-28 - 11:53:30 [6]: virtual void Calamares::JobThread::run()
2024-02-28 - 11:53:30 [6]: Starting job "Managing auto-mount settings…" ( 1 / 34 )
2024-02-28 - 11:53:30 [6]: virtual Calamares::JobResult AutoMountManagementJob::exec()
2024-02-28 - 11:53:30 [6]: Set automount to disable
2024-02-28 - 11:53:30 [6]: void Calamares::Partition::querySolidAutoMount(QDBusConnection&, AutoMountInfo&)
2024-02-28 - 11:53:30 [6]: Solid not available: "Not connected to D-Bus server"
2024-02-28 - 11:53:30 [6]: Starting job "Clearing all temporary mounts…" ( 2 / 34 )
2024-02-28 - 11:53:30 [6]: Starting job "Clear mounts for partitioning operations on /dev/nvme0n1" ( 3 / 34 )
2024-02-28 - 11:53:30 [6]: QStringList getPartitionsForDevice(const QString&)
2024-02-28 - 11:53:30 [6]: Reading from "/proc/partitions" looking for "nvme0n1"
2024-02-28 - 11:53:30 [6]: virtual Calamares::JobResult ClearMountsJob::exec()
2024-02-28 - 11:53:30 [6]: ClearMountsJob finished. Here's what was done:
2024-02-28 - 11:53:30 [6]: .. Running ("udevadm", "settle")
2024-02-28 - 11:53:30 [6]: .. Running ("sync")
2024-02-28 - 11:53:30 [6]: Starting job "Creating new msdos partition table on /dev/nvme0n1. {1 ?} {2…?}" ( 4 / 34 )
2024-02-28 - 11:53:30 [6]: virtual Calamares::JobResult CreatePartitionTableJob::exec()
2024-02-28 - 11:53:30 [6]: Creating new partition table of type "msdos" , uncommitted partitions:
2024-02-28 - 11:53:30 [6]: .. "New Partition"
2024-02-28 - 11:53:30 [6]: .. Running ("lsblk")
2024-02-28 - 11:53:30 [6]: .. lsblk output:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 80.7M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 1.1G 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1.7G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 767.4M 1 loop /run/miso/sfs/rootfs
sda 8:0 1 0B 0 disk
sdb 8:16 1 0B 0 disk
sdc 8:32 1 0B 0 disk
sdd 8:48 1 0B 0 disk
sde 8:64 1 58G 1 disk /run/miso/bootmnt
|-sde1 8:65 1 3.7G 1 part
`-sde2 8:66 1 4M 1 part
sr0 11:0 1 1024M 0 rom
nvme0n1 259:0 0 953.9G 0 disk
|-nvme0n1p1 259:1 0 300M 0 part
`-nvme0n1p2 259:2 0 953.6G 0 part
2024-02-28 - 11:53:30 [6]: .. Running ("mount")
2024-02-28 - 11:53:31 [6]: .. mount output:
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sys on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
dev on /dev type devtmpfs (rw,nosuid,relatime,size=16359332k,nr_inodes=4089833,mode=755,inode64)
run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
/dev/sde on /run/miso/bootmnt type iso9660 (ro,relatime,nojoliet,check=s,map=n,blocksize=2048,iocharset=utf8)
cowspace on /run/miso/cowspace type tmpfs (rw,relatime,size=262144k,mode=755,inode64)
overlay_root on /run/miso/overlay_root type tmpfs (rw,relatime,size=24587892k,mode=755,inode64)
/dev/loop0 on /run/miso/sfs/livefs type squashfs (ro,relatime,errors=continue,threads=single)
/dev/loop1 on /run/miso/sfs/mhwdfs type squashfs (ro,relatime,errors=continue,threads=single)
/dev/loop2 on /run/miso/sfs/desktopfs type squashfs (ro,relatime,errors=continue,threads=single)
/dev/loop3 on /run/miso/sfs/rootfs type squashfs (ro,relatime,errors=continue,threads=single)
overlay on / type overlay (rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work,index=off,uuid=on,xino=off)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=36,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5554)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,nosuid,nodev,relatime,pagesize=2M)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,size=16391928k,nr_inodes=1048576,inode64)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /etc/pacman.d/gnupg type tmpfs (rw,relatime,mode=755,inode64)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=3278384k,nr_inodes=819596,mode=700,uid=1000,gid=1000,inode64)
portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
2024-02-28 - 11:53:31 [6]: virtual void Calamares::JobThread::run()
2024-02-28 - 11:53:31 [6]: Starting job "Create new 976755MiB partition on /dev/nvme0n1 (TEAM TM8FP6001T) with file system ext4" ( 5 / 34 )
2024-02-28 - 11:53:48 [6]: virtual void Calamares::JobThread::run()
2024-02-28 - 11:53:48 [6]: Starting job "Set flags on partition /dev/nvme0n1p1" ( 6 / 34 )
2024-02-28 - 11:53:48 [6]: virtual Calamares::JobResult SetPartFlagsJob::exec()
2024-02-28 - 11:53:48 [6]: Setting flags on "/dev/nvme0n1" partition "/dev/nvme0n1p1"
"boot"
2024-02-28 - 11:53:49 [6]: virtual void Calamares::JobThread::run()
2024-02-28 - 11:53:49 [6]: Starting job "Set partition information" ( 7 / 34 )
2024-02-28 - 11:53:49 [6]: QVariantList FillGlobalStorageJob::createPartitionList() const
2024-02-28 - 11:53:49 [6]: Building partition information map
2024-02-28 - 11:53:49 [6]: .. partitions on "/dev/nvme0n1"
2024-02-28 - 11:53:49 [6]: .. mapping for "/dev/nvme0n1p1" "/dev/nvme0n1p1"
partlabel : "root"
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "ext4"
fsName : "ext4"
filesystem-uuid (uuid) : "FSUUID$19718844"
claimed : "true"
2024-02-28 - 11:53:49 [6]: virtual Calamares::JobResult FillGlobalStorageJob::exec()
2024-02-28 - 11:53:49 [6]: Saving partition information map to GlobalStorage["partitions"]
2024-02-28 - 11:53:49 [6]: FillGlobalStorageJob writing bootLoader path: QVariant(QVariantMap, QMap(("installPath", QVariant(QString, "/dev/nvme0n1"))))
2024-02-28 - 11:53:49 [6]: Starting job "Managing auto-mount settings…" ( 8 / 34 )
2024-02-28 - 11:53:49 [6]: virtual Calamares::JobResult AutoMountManagementJob::exec()
2024-02-28 - 11:53:49 [6]: Restore automount settings
2024-02-28 - 11:53:49 [6]: Starting job "mount" ( 9 / 34 )
2024-02-28 - 11:53:49 [6]: [PYTHON JOB]: Found gettext "en_US" in "/usr/share/locale/en_US"
2024-02-28 - 11:53:49 [6]: .. Running ("mount", "-t", "ext4", "-o", "defaults", "/dev/nvme0n1p1", "/tmp/calamares-root-7a_fcoxo/")
2024-02-28 - 11:53:49 [6]: .. Target cmd: ("mount", "-t", "ext4", "-o", "defaults", "/dev/nvme0n1p1", "/tmp/calamares-root-7a_fcoxo/") Exit code: 32 output:
mount: /tmp/calamares-root-7a_fcoxo: unknown filesystem type 'ext4'.
dmesg(1) may have more information after failed mount system call.
2024-02-28 - 11:53:49 [6]: .. Running ("udevadm", "settle")
2024-02-28 - 11:53:49 [6]: .. Running ("sync")
2024-02-28 - 11:53:49 [2]: WARNING: [PYTHON JOB]: "Cannot mount /dev/nvme0n1p1"
2024-02-28 - 11:53:49 [6]: .. Running ("mount", "-o", "bind", "/dev", "/tmp/calamares-root-7a_fcoxo/dev")
2024-02-28 - 11:53:50 [6]: .. Running ("sync")
2024-02-28 - 11:53:50 [6]: .. Running ("mount", "-t", "proc", "-o", "defaults", "proc", "/tmp/calamares-root-7a_fcoxo/proc")
2024-02-28 - 11:53:50 [6]: .. Running ("udevadm", "settle")
2024-02-28 - 11:53:50 [6]: .. Running ("mount", "-t", "tmpfs", "-o", "defaults", "tmpfs", "/tmp/calamares-root-7a_fcoxo/run")
2024-02-28 - 11:53:50 [6]: .. Running ("mount", "-o", "bind", "/run/udev", "/tmp/calamares-root-7a_fcoxo/run/udev")
2024-02-28 - 11:53:50 [6]: .. Running ("mount", "-t", "sysfs", "-o", "defaults", "sys", "/tmp/calamares-root-7a_fcoxo/sys")
2024-02-28 - 11:53:50 [6]: virtual void Calamares::JobThread::run()
2024-02-28 - 11:53:50 [6]: Starting job "unpackfs" ( 10 / 34 )
2024-02-28 - 11:53:50 [6]: [PYTHON JOB]: Found gettext "en_US" in "/usr/share/locale/en_US"
2024-02-28 - 11:53:50 [6]: .. Running ("mount", "-t", "squashfs", "-o", "loop", "/run/miso/bootmnt/manjaro/x86_64/rootfs.sfs", "/tmp/tmpd92ydu00/rootfs")
2024-02-28 - 11:53:50 [6]: .. Running ("unsquashfs", "-l", "/run/miso/bootmnt/manjaro/x86_64/rootfs.sfs")
2024-02-28 - 11:53:50 [6]: .. Running ("rsync", "-aHAXSr", "--filter=-x trusted.overlay.*", "--exclude", "/proc/", "--exclude", "/sys/", "--exclude", "/dev/", "--exclude", "/run/", "--exclude", "/run/udev/", "--progress", "/tmp/tmpd92ydu00/rootfs/", "/tmp/calamares-root-7a_fcoxo")
2024-02-28 - 11:54:28 [6]: .. Running ("mount", "-t", "squashfs", "-o", "loop", "/run/miso/bootmnt/manjaro/x86_64/desktopfs.sfs", "/tmp/tmpd92ydu00/desktopfs")
2024-02-28 - 11:54:28 [6]: .. Running ("udevadm", "settle")
2024-02-28 - 11:54:28 [6]: .. Running ("sync")
2024-02-28 - 11:54:28 [6]: .. Running ("unsquashfs", "-l", "/run/miso/bootmnt/manjaro/x86_64/desktopfs.sfs")
2024-02-28 - 11:54:28 [6]: .. Running ("rsync", "-aHAXSr", "--filter=-x trusted.overlay.*", "--exclude", "/proc/", "--exclude", "/sys/", "--exclude", "/dev/", "--exclude", "/run/", "--exclude", "/run/udev/", "--progress", "/tmp/tmpd92ydu00/desktopfs/", "/tmp/calamares-root-7a_fcoxo")
2024-02-28 - 11:56:06 [6]: virtual void Calamares::JobThread::run()
2024-02-28 - 11:56:06 [6]: Starting job "networkcfg" ( 11 / 34 )
2024-02-28 - 11:56:06 [6]: [PYTHON JOB]: Found gettext "en_US" in "/usr/share/locale/en_US"
2024-02-28 - 11:56:06 [6]: Starting job "Generate machine-id." ( 12 / 34 )
2024-02-28 - 11:56:06 [6]: .. Running ("systemd-machine-id-setup", "--root=/tmp/calamares-root-7a_fcoxo")
2024-02-28 - 11:56:06 [6]: .. Running ("ln", "-sf", "/etc/machine-id", "/var/lib/dbus/machine-id")
2024-02-28 - 11:56:06 [6]: Starting job "fstab" ( 13 / 34 )
2024-02-28 - 11:56:06 [6]: Starting job "Setting timezone to America/Chicago…" ( 14 / 34 )
2024-02-28 - 11:56:06 [6]: .. Running ("rm", "-f", "/etc/localtime")
2024-02-28 - 11:56:06 [6]: .. Running ("ln", "-s", "/usr/share/zoneinfo/America/Chicago", "/etc/localtime")
2024-02-28 - 11:56:06 [6]: Starting job "Setting keyboard model to pc105, layout as us-…" ( 15 / 34 )
2024-02-28 - 11:56:06 [6]: virtual Calamares::JobResult SetKeyboardLayoutJob::exec()
2024-02-28 - 11:56:06 [6]: Executing SetKeyboardLayoutJob
2024-02-28 - 11:56:06 [6]: bool SetKeyboardLayoutJob::writeVConsoleData(const QString&, const QString&) const
2024-02-28 - 11:56:06 [6]: Writing vconsole data to "/tmp/calamares-root-7a_fcoxo/etc/vconsole.conf"
2024-02-28 - 11:56:06 [6]: QString SetKeyboardLayoutJob::findConvertedKeymap(const QString&) const
2024-02-28 - 11:56:06 [6]: Looking for converted keymap in "/tmp/calamares-root-7a_fcoxo/lib/kbd/keymaps/xkb"
2024-02-28 - 11:56:06 [6]: QString findLegacyKeymap(const QString&, const QString&, const QString&)
2024-02-28 - 11:56:06 [6]: Looking for legacy keymap "us" "pc105" "" in QRC
2024-02-28 - 11:56:06 [6]: .. Found legacy keymap "us" with score 11
2024-02-28 - 11:56:06 [6]: .. Found legacy keymap "us-acentos" with score 11
2024-02-28 - 11:56:06 [6]: .. Found legacy keymap "dvorak" with score 11
2024-02-28 - 11:56:06 [6]: .. Written KEYMAP= "us" to vconsole.conf 0
2024-02-28 - 11:56:06 [6]: bool SetKeyboardLayoutJob::writeX11Data(const QString&) const
2024-02-28 - 11:56:06 [6]: Writing X11 configuration to "/tmp/calamares-root-7a_fcoxo/etc/X11/xorg.conf.d/00-keyboard.conf"
2024-02-28 - 11:56:06 [6]: .. Written XkbLayout "us" ; XkbModel "pc105" ; XkbVariant "" to X.org file "/tmp/calamares-root-7a_fcoxo/etc/X11/xorg.conf.d/00-keyboard.conf" 0
2024-02-28 - 11:56:06 [6]: bool SetKeyboardLayoutJob::writeDefaultKeyboardData(const QString&) const
2024-02-28 - 11:56:06 [6]: Writing default keyboard data to "/tmp/calamares-root-7a_fcoxo/etc/default/keyboard"
2024-02-28 - 11:56:06 [6]: .. Written XKBMODEL "pc105" ; XKBLAYOUT "us" ; XKBVARIANT "" to /etc/default/keyboard file "/tmp/calamares-root-7a_fcoxo/etc/default/keyboard" 0
2024-02-28 - 11:56:06 [6]: Starting job "localecfg" ( 16 / 34 )
2024-02-28 - 11:56:06 [6]: .. Running ("locale-gen")
2024-02-28 - 11:56:08 [6]: [PYTHON JOB]: "/tmp/calamares-root-7a_fcoxo/etc/locale.gen done"
2024-02-28 - 11:56:08 [6]: [PYTHON JOB]: "/tmp/calamares-root-7a_fcoxo/etc/locale.conf done"
2024-02-28 - 11:56:08 [6]: [PYTHON JOB]: "/tmp/calamares-root-7a_fcoxo/etc/default done"
2024-02-28 - 11:56:08 [6]: virtual void Calamares::JobThread::run()
2024-02-28 - 11:56:08 [6]: Starting job "Configuring encrypted swap." ( 17 / 34 )
2024-02-28 - 11:56:08 [6]: void write_openswap_conf(const QString&, QStringList&, const LOSHInfo&)
2024-02-28 - 11:56:08 [6]: Will not write an invalid configuration to "/etc/openswap.conf"
2024-02-28 - 11:56:08 [6]: Starting job "Configuring LUKS key file." ( 18 / 34 )
2024-02-28 - 11:56:08 [6]: virtual Calamares::JobResult LuksBootKeyFileJob::exec()
2024-02-28 - 11:56:08 [6]: There are 0 LUKS partitions
2024-02-28 - 11:56:08 [6]: .. Nothing to do for LUKS.
2024-02-28 - 11:56:08 [6]: Starting job "initcpiocfg" ( 19 / 34 )
2024-02-28 - 11:56:08 [6]: [PYTHON JOB]: Found gettext "en_US" in "/usr/share/locale/en_US"
2024-02-28 - 11:56:08 [6]: .. Running ("sh", "-c", "which plymouth")
2024-02-28 - 11:56:08 [6]: Starting job "Creating initramfs with mkinitcpio…" ( 20 / 34 )
2024-02-28 - 11:56:08 [6]: virtual Calamares::JobResult InitcpioJob::exec()
2024-02-28 - 11:56:08 [6]: Updating initramfs with kernel "linux66"
2024-02-28 - 11:56:08 [6]: .. Running ("mkinitcpio", "-p", "linux66")
2024-02-28 - 11:57:09 [6]: virtual void Calamares::JobThread::run()
2024-02-28 - 11:57:09 [6]: Starting job "Configuring <pre>sudo</pre> users…" ( 21 / 34 )
2024-02-28 - 11:57:09 [6]: Starting job "Preparing groups…" ( 22 / 34 )
2024-02-28 - 11:57:09 [6]: Starting job "Create user glen" ( 23 / 34 )
2024-02-28 - 11:57:09 [6]: virtual Calamares::JobResult CreateUserJob::exec()
2024-02-28 - 11:57:09 [6]: [CREATEUSER]: creating user
2024-02-28 - 11:57:09 [6]: .. Running ("useradd", "-m", "-U", "-s", "/bin/bash", "-c", "Glen", "glen")
2024-02-28 - 11:57:09 [6]: .. Running "usermod" "-aG" "lp,network,power,sys,wheel" "glen"
2024-02-28 - 11:57:09 [6]: .. Running ("chown", "-R", "glen:glen", "/home/glen")
2024-02-28 - 11:57:09 [6]: Starting job "Set password for user glen" ( 24 / 34 )
2024-02-28 - 11:57:09 [6]: .. Running "usermod" "-p" "$y$j9T$3atOyekeY58jkPVT1M7ef1$bJuliyhr2d4BGWILwkWDqyjySaeTWaUBPCXP957tYq." "glen"
2024-02-28 - 11:57:09 [6]: Starting job "Set password for user root" ( 25 / 34 )
2024-02-28 - 11:57:09 [6]: .. Running "usermod" "-p" "$y$j9T$upmt4CmT2CkRggdUHQn4V1$jrNN2zltmq8Nqjs5/YHGxOZSBMO7N9bp69/CX7Egkc7" "root"
2024-02-28 - 11:57:09 [6]: Starting job "Set hostname backup-linux-box" ( 26 / 34 )
2024-02-28 - 11:57:09 [6]: Starting job "displaymanager" ( 27 / 34 )
2024-02-28 - 11:57:09 [6]: [PYTHON JOB]: Found gettext "en_US" in "/usr/share/locale/en_US"
2024-02-28 - 11:57:09 [6]: [PYTHON JOB]: "lightdm selected but not installed"
2024-02-28 - 11:57:09 [6]: [PYTHON JOB]: "gdm selected but not installed"
2024-02-28 - 11:57:09 [6]: [PYTHON JOB]: "mdm selected but not installed"
2024-02-28 - 11:57:09 [6]: [PYTHON JOB]: "lxdm selected but not installed"
2024-02-28 - 11:57:09 [6]: [PYTHON JOB]: "slim selected but not installed"
2024-02-28 - 11:57:09 [6]: [PYTHON JOB]: "Using rootMountPoint '/tmp/calamares-root-7a_fcoxo'"
2024-02-28 - 11:57:09 [6]: [PYTHON JOB]: ".. selected DE plasma"
2024-02-28 - 11:57:09 [2]: Calamares::Python::Object Calamares::Python::GlobalStorageProxy::value(const std::string&) const
2024-02-28 - 11:57:09 [2]: WARNING: Unknown GS key autoLoginUser
2024-02-28 - 11:57:09 [6]: [PYTHON JOB]: "Unsetting autologin."
2024-02-28 - 11:57:09 [6]: Starting job "mhwdcfg" ( 28 / 34 )
2024-02-28 - 11:57:09 [6]: .. Running ("mhwd", "-a", "pci", "nonfree", "0200", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2024-02-28 - 11:58:11 [6]: .. Target cmd: ("mhwd", "-a", "pci", "nonfree", "0200", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf") Exit code: 1 output:
e[1me[31m> e[mUsing config 'network-r8168' for device: 0000:09:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
e[1me[31m> e[mInstalling network-r8168...
e[0;32mwarning: database file for 'core' does not exist (use '-Sy' to download)
e[me[0;32mwarning: database file for 'extra' does not exist (use '-Sy' to download)
e[me[0;32mwarning: database file for 'multilib' does not exist (use '-Sy' to download)
e[me[0;32mSourcing /etc/mhwd-x86_64.conf
e[me[0;32mHas lib32 support: true
e[me[0;32mSourcing /var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG
e[me[0;32mProcessing classid: 0200
e[me[0;32mwarning: database file for 'core' does not exist (use '-Sy' to download)
e[me[0;32m:: Synchronizing package databases...
e[me[0;32m mhwd downloading...
e[me[0;32merror: target not found: linux66-r8168
e[me[0;32mError: pacman failed!
e[me[1me[31mError: e[mscript failed!
2024-02-28 - 11:58:11 [6]: .. Running ("mhwd", "-a", "pci", "nonfree", "0280", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2024-02-28 - 11:58:12 [6]: .. Running ("mhwd", "-a", "pci", "nonfree", "0300", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2024-02-28 - 11:58:14 [6]: .. Target cmd: ("mhwd", "-a", "pci", "nonfree", "0300", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf") Exit code: 1 output:
e[1me[31m> e[mUsing config 'video-nvidia' for device: 0000:0a:00.0 (0300:10de:1e89) Display controller nVidia Corporation TU104 [GeForce RTX 2060]
e[1me[31m> e[mInstalling video-nvidia...
e[me[0;32mSourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
e[me[0;32mProcessing classid: 0300
e[me[0;32mSourcing /var/lib/mhwd/scripts/include/0300
e[me[0;32mProcessing classid: 0302
e[me[0;32mresolving dependencies...
e[me[0;32mlooking for conflicting packages...
e[me[0;32mwarning: dependency cycle detected:
e[me[0;32mwarning: eglexternalplatform will be installed before its nvidia-utils dependency
e[me[0;32m
e[me[0;32mPackages (7) egl-wayland-2:1.1.13-1 eglexternalplatform-1.1-2 lib32-nvidia-utils-545.29.06-1 libxnvctrl-545.29.06-1 linux66-nvidia-545.29.06-29 nvidia-settings-545.29.06-1 nvidia-utils-545.29.06-2
e[me[0;32m
e[me[0;32mTotal Download Size: 350.33 MiB
e[me[0;32mTotal Installed Size: 893.41 MiB
e[me[0;32m
e[me[0;32m:: Proceed with installation? [Y/n] error: could not determine cachedir mount point /var/cache/pacman/pkg
e[me[0;32merror: failed to commit transaction (not enough free disk space)
e[me[0;32m
e[me[0;32mErrors occurred, no packages were upgraded.
2024-02-28 - 11:58:14 [6]: .. Running ("mhwd", "-a", "pci", "nonfree", "0302", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2024-02-28 - 11:58:15 [6]: .. Running ("mhwd", "-a", "pci", "nonfree", "0380", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2024-02-28 - 11:58:16 [6]: virtual void Calamares::JobThread::run()
2024-02-28 - 11:58:16 [6]: Starting job "hwclock" ( 29 / 34 )
2024-02-28 - 11:58:16 [6]: [PYTHON JOB]: Found gettext "en_US" in "/usr/share/locale/en_US"
2024-02-28 - 11:58:16 [6]: .. Running ("hwclock", "--systohc", "--utc")
2024-02-28 - 11:58:17 [6]: [PYTHON JOB]: "Hwclock set using RTC method."
2024-02-28 - 11:58:17 [6]: virtual void Calamares::JobThread::run()
2024-02-28 - 11:58:17 [6]: Starting job "services" ( 30 / 34 )
2024-02-28 - 11:58:17 [6]: [PYTHON JOB]: Found gettext "en_US" in "/usr/share/locale/en_US"
2024-02-28 - 11:58:17 [6]: Starting job "grubcfg" ( 31 / 34 )
2024-02-28 - 11:58:17 [6]: .. Running ("sh", "-c", "which dracut")
2024-02-28 - 11:58:17 [6]: .. Target cmd: ("sh", "-c", "which dracut") Exit code: 1 output:
which: no dracut in (/usr/sbin:/usr/bin:/sbin:/bin:/root/bin)
2024-02-28 - 11:58:17 [6]: .. Running ("sh", "-c", "which plymouth")
2024-02-28 - 11:58:17 [6]: .. Running ("sh", "-c", "grep -q \"^HOOKS.*systemd\" /etc/mkinitcpio.conf")
2024-02-28 - 11:58:17 [6]: .. Target cmd: ("sh", "-c", "grep -q \"^HOOKS.*systemd\" /etc/mkinitcpio.conf") Exit code: 1 (no output)
2024-02-28 - 11:58:17 [6]: Starting job "bootloader" ( 32 / 34 )
2024-02-28 - 11:58:17 [6]: [PYTHON JOB]: "Bootloader: grub (bios)"
2024-02-28 - 11:58:17 [6]: .. Running ("grub-install", "--target=i386-pc", "--recheck", "--force", "/dev/nvme0n1")
2024-02-28 - 11:58:17 [6]: .. Target cmd: ("grub-install", "--target=i386-pc", "--recheck", "--force", "/dev/nvme0n1") Exit code: 1 output:
Installing for i386-pc platform.
grub-install: error: cannot find a device for /boot/grub (is /dev mounted?).
2024-02-28 - 11:58:17 [2]: WARNING: [PYTHON JOB]: "Command 'grub-install --target=i386-pc --recheck --force /dev/nvme0n1' returned non-zero exit status 1."
2024-02-28 - 11:58:17 [6]: [PYTHON JOB]: "stdout:Installing for i386-pc platform.\ngrub-install: error: cannot find a device for /boot/grub (is /dev mounted?)."
2024-02-28 - 11:58:17 [6]: [PYTHON JOB]: "stderr:None"
2024-02-28 - 11:58:17 [6]: Skipping non-emergency job "postcfg"
2024-02-28 - 11:58:17 [6]: .. Starting EMERGENCY JOB "Unmounting file systems…" ( 34 / 34 )
2024-02-28 - 11:58:17 [6]: Calamares::JobResult unmountTargetMounts(const QString&)
2024-02-28 - 11:58:17 [6]: Read 5 entries from "/tmp/calamares-root-7a_fcoxo/"
2024-02-28 - 11:58:17 [6]: .. Running ("umount", "-lv", "/tmp/calamares-root-7a_fcoxo/sys")
2024-02-28 - 11:58:17 [6]: .. Running ("udevadm", "settle")
2024-02-28 - 11:58:17 [6]: .. Running ("sync")
2024-02-28 - 11:58:17 [6]: .. Running ("umount", "-lv", "/tmp/calamares-root-7a_fcoxo/run/udev")
2024-02-28 - 11:58:18 [6]: .. Running ("umount", "-lv", "/tmp/calamares-root-7a_fcoxo/run")
2024-02-28 - 11:58:18 [6]: .. Running ("udevadm", "settle")
2024-02-28 - 11:58:18 [6]: .. Running ("sync")
2024-02-28 - 11:58:18 [6]: .. Running ("umount", "-lv", "/tmp/calamares-root-7a_fcoxo/proc")
2024-02-28 - 11:58:18 [6]: .. Running ("umount", "-lv", "/tmp/calamares-root-7a_fcoxo/dev")
2024-02-28 - 11:58:18 [1]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
2024-02-28 - 11:58:18 [1]: ERROR: Installation failed: "Bootloader installation error"
2024-02-28 - 11:58:18 [6]: .. - message: "Bootloader installation error"
2024-02-28 - 11:58:18 [6]: .. - details: The bootloader could not be installed. The installation command <pre>grub-install --target=i386-pc --recheck --force /dev/nvme0n1</pre> returned error code 1.
2024-02-28 - 11:58:18 [6]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
2024-02-28 - 11:58:18 [6]: Calamares will quit when the dialog closes.
2024-02-28 - 11:58:18 [6]: void Config::doNotify(bool, bool)
2024-02-28 - 11:58:18 [6]: Notification not sent; completion: failed
Thanks
