HDMI audio output does not turn off automatically after disconnecting until suspend or reboot
HDMI sound output stays active after disconnecting TV (connected by HDMI) until suspend or reboot. I want audio output to switch to HDMI automatically when connected and revert to internal speakers on disconnect. I believe it switched automatically before. It does work correctly on Manjaro live launched from USB.
I have already disabling kernel parameters that could affect it in /etc/modprobe.d/ and /etc/default/grub.
Is there a way to restore this functionality? Maybe there is a way to compare configuration with stock Manjaro without installing in case I’ve missed something?
Steps to reproduce:
  1. Open Sound in KDE System Settings
  2. Notice there is a single Playback Device active: Speakers (Built-in Audio Analog Stereo)
  3. Notice there is a single Inactive Card: GA106 High Definition Audio Controller Digital Stereo (HDMI) with Profile Off
  4. Connect TV by HDMI
  5. Notice GA106 High Definition Audio Controller Digital Stereo (HDMI) become active Playback Device with Profile Digital Stereo (HDMI) Output
  6. Disconnect HDMI
  7. Notice GA106 High Definition Audio Controller Digital Stereo (HDMI) is still active.
  8. Suspend computer (systemctl suspend)
  9. Wake computer
  10. Notice GA106 High Definition Audio Controller Digital Stereo (HDMI) become Inactive Card with Profile Off
System info:
inxi -zv8:
  Kernel: 6.16.0-5-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/vmlinuz-6.16-x86_64
    root=UUID=c9a10ed1-1599-4863-9cbc-e97f71c5192e rw
    cryptdevice=UUID=f01aaf33-f660-4d40-b758-c7699008c7de:manjaro:allow-discards
    root=/dev/mapper/manjaro udev.log_priority=3 rd.luks.options=discard
    sysrq_always_enabled=1 zswap.enabled=0
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0
  Type: Laptop System: Acer product: Nitro AN517-52 v: V2.08
    serial: <superuser required>
  Mobo: CML model: Karoq_CMS v: V2.08 serial: <superuser required>
    part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 2.08
    date: 09/23/2022
  ID-1: BAT1 charge: 32.8 Wh (79.4%) condition: 41.3/57.5 Wh (71.9%)
    volts: 16.0 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
    status: not charging
  System RAM: total: 16 GiB available: 15.45 GiB used: 7.04 GiB (45.6%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB speed:
    spec: 3200 MT/s actual: 2933 MT/s volts: curr: 1 min: 2 max: 2 width (bits):
    data: 64 total: 64 manufacturer: SK Hynix part-no: HMA81GS6DJR8N-XN
    serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB speed:
    spec: 3200 MT/s actual: 2933 MT/s volts: curr: 1 min: 1.35 max: 2
    width (bits): data: 64 total: 64 manufacturer: SK Hynix
    part-no: HMA81GS6DJR8N-XN serial: <filter>
  Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 2 microcode: 0x100
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand
    rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: retbleed mitigation: Enhanced IBRS
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9bc4
    class-ID: 0300
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
    vendor: Acer Incorporated ALI driver: nvidia v: 575.64.05
    alternate: nouveau,nova_core,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none
    empty: HDMI-A-2 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
  Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0408:a061
    class-ID: 0e02
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
    unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
    display-ID: 0
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x175c built: 2018 res:
    mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 128 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
    x: 0.314 y: 0.329 size: 381x214mm (15x8.43") diag: 437mm (17.2")
    ratio: 16:9 modes: 1920x1080
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
    surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
    inactive: device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.7-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9bc4 memory: 15.08 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Laptop GPU driver: nvidia v: 575.64.05
    device-ID: 10de:2520 surfaces: N/A device: 1 type: integrated-gpu
    name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 25.1.7-arch1.1
    device-ID: 8086:9bc4 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: lact, nvidia-settings, nvidia-smi
  Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel alternate: nova_core pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1
    chip-ID: 10de:228e class-ID: 0403
  API: ALSA v: k6.16.0-5-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  Device-2: Realtek Killer E2600 GbE vendor: Acer Incorporated ALI
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
    bus-ID: 07:00.0 chip-ID: 10ec:2600 class-ID: 0200
  IF: enp7s0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0026
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Device-1: manjaro maj-min: 253:0 type: LUKS dm: dm-0 size: 1.82 TiB
  Components:
  p-1: nvme0n1p1 maj-min: 259:1 size: 1.82 TiB
  Local Storage: total: 3.22 TiB used: 1.92 TiB (59.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P2SSD8
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: P2CR031 temp: 44.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: GOODRAM model: SSDPR-CX400-01T-G2
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: LA.5 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: MZNLN512HCJH-000L2
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 3L0Q scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 1.48 TiB (83.0%)
    fs: ext4 dev: /dev/dm-0 maj-min: 253:0 mapped: manjaro label: N/A uuid: N/A
  ID-2: /boot raw-size: 1.95 GiB size: 1.95 GiB (99.80%)
    used: 361 MiB (18.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 1633-7B61
  ID-3: /vol/windows raw-size: 476.31 GiB size: 476.31 GiB (100.00%)
    used: 449.28 GiB (94.3%) fs: ntfs dev: /dev/sdb4 maj-min: 8:20
    label: OS SATA 500 uuid: 6ABCAC95BCAC5D77
  Kernel: swappiness: 180 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: zram size: 7.72 GiB used: 14.9 MiB (0.2%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 dev: /dev/zram0
  ID-1: /dev/sda1 maj-min: 8:1 size: 600 MiB fs: vfat label: N/A
    uuid: C9E3-965B
  ID-2: /dev/sda2 maj-min: 8:2 size: 1024 MiB fs: ext4 label: N/A
    uuid: 576808d4-537f-49d9-a969-3b8b7df5f75e
  ID-3: /dev/sdb1 maj-min: 8:17 size: 529 MiB fs: ntfs label: Recovery
    uuid: B840A0D740A09D9E
  ID-4: /dev/sdb2 maj-min: 8:18 size: 100 MiB fs: vfat label: N/A
    uuid: A4A1-54D7
  ID-5: /dev/sdb3 maj-min: 8:19 size: 16 MiB fs: <superuser required>
  Device-1: 1-3:2 info: EndGameGear XM1 Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3367:1903 class-ID: 0300
    serial: <filter>
  Device-2: 1-5:3 info: Quanta HD User Facing type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 0408:a061 class-ID: 0e02
  Device-3: 1-14:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  System Temperatures: cpu: 57.0 C pch: 50.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1856 pm: pacman pkgs: 1808 libs: 437 tools: octopi,pamac,yay
    pm: flatpak pkgs: 48
    1: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    2: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    3: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    4: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    5: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    6: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    7: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    9: https://manjaro.ynh.ovh/stable/$repo/$arch
    10: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    12: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    13: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    14: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    15: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    16: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    17: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    18: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    19: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    20: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    22: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    24: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    25: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    26: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    27: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    28: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    29: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    30: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    32: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    33: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    34: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    35: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    36: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    37: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    38: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    39: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    40: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    41: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    42: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    43: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    44: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    45: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    46: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    47: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
    48: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    49: https://mirrors2.manjaro.org/stable/$repo/$arch
    50: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    51: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    52: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    53: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    54: https://mirror.init7.net/manjaro/stable/$repo/$arch
    55: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    56: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    57: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    58: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    59: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    60: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    61: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    62: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    63: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    64: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    65: https://manjaro.kurdy.org/stable/$repo/$arch
    66: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    67: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    68: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    69: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    70: https://mirror.mobinhost.com/manjaro/stable/$repo/$arch
    71: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    72: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    73: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    74: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    75: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    76: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    77: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    78: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    79: https://mirror.23m.com/manjaro/stable/$repo/$arch
    80: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    81: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    82: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 360
  1: cpu: 13.5% command: brave pid: 1726 mem: 982.2 MiB (6.2%)
  2: cpu: 7.3% command: brave pid: 3677 mem: 264.8 MiB (1.6%)
  3: cpu: 6.7% command: kwin_wayland pid: 993 mem: 244.4 MiB (1.5%)
  4: cpu: 6.2% command: plasmashell pid: 1174 mem: 435.2 MiB (2.7%)
  5: cpu: 5.6% command: nvim pid: 4412 mem: 30.6 MiB (0.1%)
  Memory top: 5 of 360
  1: mem: 1002.8 MiB (6.3%) command: pamac-manager pid: 1753 cpu: 5.3%
  2: mem: 982.2 MiB (6.2%) command: brave pid: 1726 cpu: 13.5%
  3: mem: 435.2 MiB (2.7%) command: plasmashell pid: 1174 cpu: 6.2%
  4: mem: 264.8 MiB (1.6%) command: brave pid: 3677 cpu: 7.3%
  5: mem: 244.4 MiB (1.5%) command: kwin_wayland pid: 993 cpu: 6.7%
  Processes: 360 Power: uptime: 7m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.16 GiB services: org_kde_powerdevil,
    power-profiles-daemon, thermald, upowerd Init: systemd v: 257
  Compilers: clang: 20.1.8 gcc: 15.1.1 alt: 14 Shell: Zsh v: 5.9
    running-in: tmux: inxi: 3.3.38
mhwd -li:
> Installed PCI configs:
video-hybrid-intel-nvidia-prime            2025.01.13               false            PCI
           video-linux            2024.05.06                true            PCI
aplay -L:
null
    Discard all samples (playback) or generate zero samples (capture)
lavrate
    Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pipewire
    PipeWire Sound Server
pulse
    PulseAudio Sound Server
speex
    Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default
    Default ALSA Output (currently PipeWire Media Server)
hdmi:CARD=NVidia,DEV=0
    HDA NVidia, HDMI 0
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
    HDA NVidia, HDMI 1
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
    HDA NVidia, HDMI 2
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 3
    HDMI Audio Output
usbstream:CARD=NVidia
    HDA NVidia
    USB Stream Output
sysdefault:CARD=PCH
    HDA Intel PCH, ALC295 Analog
    Default Audio Device
front:CARD=PCH,DEV=0
    Front output / input
surround21:CARD=PCH,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
hdmi:CARD=PCH,DEV=0
    HDA Intel PCH, HDMI 0
    HDMI Audio Output
hdmi:CARD=PCH,DEV=1
    HDA Intel PCH, HDMI 1
    HDMI Audio Output
hdmi:CARD=PCH,DEV=2
    HDA Intel PCH, HDMI 2
    HDMI Audio Output
usbstream:CARD=PCH
    HDA Intel PCH
    USB Stream Output
wiki.archlinux.org/title/PipeWire#Troubleshooting
Sound does not automatically switch when connecting a new device
To automatically switch to newly connected devices, create this file:
# ~/.config/pipewire/pipewire-pulse.conf.d/switch-on-connect.conf
pulse.cmd = [
    { cmd = "load-module" args = "module-switch-on-connect" }
Then restart the pipewire-pulse.service with systemctl --user
systemctl --user restart pipewire-pulse
and check that module-switch-on-connect is loaded.
pactl list modules
I’m sorry, maybe it’s not clear enough, but that’s not what I mean.
At first I have this:
Then I connect TV by HDMI and HDMI audio outputs becomes available:
Then I disconnect TV but audio output is still available:
But I want it to get back to being disabled like this:
It works on live USB and it worked before, so surely it is possible.
If you cannot find a way to change the HDMI audio card profile to off in KDE GUI controls, please post more information about audio cards and sinks detected in PipeWire
pactl list cards short; pactl list sinks short; pactl get-default-sink
I can disable it manually in the settings, but I want it to happen automatically when I disconnect the HDMI.
Results of pactl list cards short; pactl list sinks short; pactl get-default-sink:
  • before connecting HDMI
3075	alsa_card.pci-0000_01_00.1	alsa
3076	alsa_card.pci-0000_00_1f.3	alsa
3082	alsa_output.pci-0000_00_1f.3.analog-stereo	PipeWire	s32le 2ch 48000Hz	SUSPENDED
  • after connecting HDMI
3191	alsa_output.pci-0000_01_00.1.hdmi-stereo	PipeWire	s32le 2ch 48000Hz	IDLE
  • after disconnecting HDMI
3191	alsa_output.pci-0000_01_00.1.hdmi-stereo	PipeWire	s32le 2ch 48000Hz	SUSPENDED
Only when I suspend or reboot then it goes back to state “Before connecting HDMI”.
Before connecting HDMI - default-sink is alsa_output.pci-0000_00_1f.3.analog-stereo
After connecting HDMI - default-sink is alsa_output.pci-0000_01_00.1.hdmi-stereo
After disconnecting HDMI - default-sink does not change back to original state
and the card profile does not change back to off
Change HDMI card profile back to original state:
pactl set-card-profile alsa_output.pci-0000_01_00.1.hdmi-stereo off
If the HDMI card is disabled the default-sink will change back to original state automatically
PipeWire should also clear any user reconfigurations of the HDMI card that may be overriding default configuration
Running pactl set-card-profile alsa_output.pci-0000_01_00.1.hdmi-stereo off results in Failure: No such entity. Looks like set-card-profile can only target cards, and available cards according to pactl list cards short are:
42      alsa_card.pci-0000_01_00.1      alsa
43      alsa_card.pci-0000_00_1f.3      alsa
So I believe you wanted me to run this command instead:
pactl set-card-profile alsa_card.pci-0000_01_00.1 off
This leads to HDMI output being disabled, and it won’t enable itself again when I connect HDMI, the only way to bring it back is to manually select back “Digital Stereo (HDMI) Output”.
Any other ideas?
EDIT: On Fedora 42 (installed and updated) I have exactly the same problem, but on live USB of Manjaro KDE 25.0.4-minimal it works as expected.
25.0.4 ISOs are about 2 months out of date so I suggest using latest KDE ISO 25.0.7
(and maybe also use Xfce ISO to check if audio devices work similar in a different environment)
Run diagnostic commands on Live ISO to check card profiles, active sinks and default-sink and compare it to data from installed OS
I have checked Manjaro 25.0.7 live USB and it works correctly. I’ve run the commands you’ve mentioned before before connecting and after disconnecting and they are the same - alsa_output.pci-0000_01_00.1.hdmi-stereo PipeWire s32le 2ch 48000Hz disappears and laptop switches to internal speakers.
I have nothing under ~/.config/pipewire or ~/.config/wireplumber, I have deleted /etc/pipewire and ~/.local/state/wireplumber but there is no change.
EDIT: Also tried copying config from live USB, from /usr/share and from ~/.state, for wireplumber and pipewire, nothing helps.
PipeWire - Wireplumber - (#777) After disconnecting HDMI cable, HDMI profiles still shown as available
Try capturing logs from wireplumber:
plug the HDMI cable, wait a second
wpctl set-log-level D
unplug HDMI, wait a second
wpctl set-log-level -
journalctl --user -b --user-unit=wireplumber > wireplumber.log
Check wireplumber.log file for device-related events
Not sure what I should make out of it. Here’s the wireplumber.log:
Aug 31 15:00:38 machine systemd[853]: Started Multimedia Service Session Manager.
Aug 31 15:00:38 machine wireplumber[1041]: wp-device: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
Aug 31 15:00:38 machine wireplumber[1041]: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
Aug 31 15:03:17 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'metadata-changed', prio 50, subject <WpMetadata:0x5569364f3ca0> (metadata)
Aug 31 15:03:17 machine wireplumber[1041]: D mod.protocol-native [connection.c:278:clear_buffer]: 0x5569364c2940 clear fds:0 n_fds:0
Aug 31 15:03:17 machine wireplumber[1041]: D wp-metadata [metadata.c:239:metadata_event_property]: <WpMetadata:31:0x5569364f3ca0> add id:41 key:log.level type: value:D
Aug 31 15:03:17 machine wireplumber[1041]: D pw.core [core.c:76:core_event_remove_id]: 0x5569364c1b20: object remove 46
Aug 31 15:03:17 machine wireplumber[1041]: D pw.proxy [proxy.c:245:pw_proxy_remove]: 0x5569367abc70: remove id:46 removed:0 destroyed:0 zombie:0 ref:1
Aug 31 15:03:17 machine wireplumber[1041]: D wp-registry [registry.c:137:registry_global_remove]: <WpCore:0x5569364a28a0> global removed:72 type:WpClient
Aug 31 15:03:17 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'client-removed', prio 200, subject <WpClient:0x5569367c3b40> (client)
Aug 31 15:03:17 machine wireplumber[1041]: D pw.proxy [proxy.c:210:pw_proxy_destroy]: 0x5569367abc70: destroy id:46 removed:1 zombie:0 ref:1
Aug 31 15:03:17 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpClient:0x5569367c3b40> features changed 0x11 -> 0x10
Aug 31 15:03:17 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpClient:0x5569367c3b40> features changed 0x10 -> 0x0
Aug 31 15:03:17 machine wireplumber[1041]: D pw.proxy [proxy.c:272:pw_proxy_unref]: 0x5569367abc70: free 4294967295
Aug 31 15:03:17 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569364f1bc0: id:72 key:(null) type:(null) value:(null)
Aug 31 15:03:17 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569364ff020: id:72 key:(null) type:(null) value:(null)
Aug 31 15:03:17 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936500110: id:72 key:(null) type:(null) value:(null)
Aug 31 15:03:17 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936528a40: id:72 key:(null) type:(null) value:(null)
Aug 31 15:03:17 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936581d70: id:72 key:(null) type:(null) value:(null)
Aug 31 15:03:17 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x55693655a1f0: id:72 key:(null) type:(null) value:(null)
Aug 31 15:03:17 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569365ba0d0: id:72 key:(null) type:(null) value:(null)
Aug 31 15:03:17 machine wireplumber[1041]: D mod.protocol-native [connection.c:278:clear_buffer]: 0x5569365c5220 clear fds:0 n_fds:0
Aug 31 15:03:17 machine wireplumber[1041]: D wp-registry [registry.c:137:registry_global_remove]: <WpCore:0x5569365b1690> global removed:72 type:WpClient
Aug 31 15:03:19 machine wireplumber[1041]: I s-node [suspend-node.lua:52:chunk]: <WpNode:51:0x556936836bc0> was idle for a while; suspending ...
Aug 31 15:03:19 machine wireplumber[1041]: I s-node [suspend-node.lua:52:chunk]: <WpNode:50:0x55693680b7d0> was idle for a while; suspending ...
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:51:0x556936836bc0> info, change_mask:0x8 [props,]
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:51:0x556936836bc0> info, change_mask:0x10 [params,]
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:58:0x5569364d3a00> info, change_mask:0x2 [params,]
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:59:0x5569364d3d20> info, change_mask:0x2 [params,]
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:51:0x556936836bc0> info, change_mask:0x4 []
Aug 31 15:03:19 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'node-state-changed', prio 50, subject <WpNode:0x556936836bc0> (node)
Aug 31 15:03:19 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569367ddb20> added <WpSimpleEventHook:0x5569365adfa0>(node/suspend-node)
Aug 31 15:03:19 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x5569367ddb20>node-state-changed@node)
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:50:0x55693680b7d0> info, change_mask:0x8 [props,]
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:50:0x55693680b7d0> info, change_mask:0x10 [params,]
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:54:0x5569364ce4b0> info, change_mask:0x2 [params,]
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:56:0x5569364cfdd0> info, change_mask:0x2 [params,]
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:55:0x5569364cfaa0> info, change_mask:0x2 [params,]
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:57:0x5569364d0110> info, change_mask:0x2 [params,]
Aug 31 15:03:19 machine wireplumber[1041]: D mod.protocol-native [connection.c:278:clear_buffer]: 0x5569364c2940 clear fds:0 n_fds:0
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:50:0x55693680b7d0> info, change_mask:0x4 []
Aug 31 15:03:19 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'node-state-changed', prio 50, subject <WpNode:0x55693680b7d0> (node)
Aug 31 15:03:19 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569367c57f0> added <WpSimpleEventHook:0x5569365adfa0>(node/suspend-node)
Aug 31 15:03:19 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x5569367c57f0>node-state-changed@node)
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:51:0x5569366e3780> info, change_mask:0x8 [props,]
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:51:0x5569366e3780> info, change_mask:0x10 [params,]
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:51:0x5569366e3780> info, change_mask:0x4 []
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:50:0x556936613b40> info, change_mask:0x8 [props,]
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:50:0x556936613b40> info, change_mask:0x10 [params,]
Aug 31 15:03:19 machine wireplumber[1041]: D mod.protocol-native [connection.c:278:clear_buffer]: 0x5569365c5220 clear fds:0 n_fds:0
Aug 31 15:03:19 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:50:0x556936613b40> info, change_mask:0x4 []
Aug 31 15:03:19 machine wireplumber[1041]: D s-node [suspend-node.lua:28:chunk]: <WpNode:51:0x556936836bc0> changed state to suspended
Aug 31 15:03:19 machine wireplumber[1041]: D s-node [suspend-node.lua:28:chunk]: <WpNode:50:0x55693680b7d0> changed state to suspended
Aug 31 15:03:20 machine wireplumber[1041]: I s-node [suspend-node.lua:52:chunk]: <WpNode:74:0x5569364eb9d0> was idle for a while; suspending ...
Aug 31 15:03:20 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569364eb9d0> info, change_mask:0x8 [props,]
Aug 31 15:03:20 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569364eb9d0> info, change_mask:0x10 [params,]
Aug 31 15:03:20 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:76:0x556936748e00> info, change_mask:0x2 [params,]
Aug 31 15:03:20 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:75:0x55693674a480> info, change_mask:0x2 [params,]
Aug 31 15:03:20 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:73:0x5569367e9dc0> info, change_mask:0x2 [params,]
Aug 31 15:03:20 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:77:0x556936749370> info, change_mask:0x2 [params,]
Aug 31 15:03:20 machine wireplumber[1041]: D mod.protocol-native [connection.c:278:clear_buffer]: 0x5569364c2940 clear fds:0 n_fds:0
Aug 31 15:03:20 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569364eb9d0> info, change_mask:0x4 []
Aug 31 15:03:20 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'node-state-changed', prio 50, subject <WpNode:0x5569364eb9d0> (node)
Aug 31 15:03:20 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569367b5e20> added <WpSimpleEventHook:0x5569365adfa0>(node/suspend-node)
Aug 31 15:03:20 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x5569367b5e20>node-state-changed@node)
Aug 31 15:03:20 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569366ff2e0> info, change_mask:0x8 [props,]
Aug 31 15:03:20 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569366ff2e0> info, change_mask:0x10 [params,]
Aug 31 15:03:20 machine wireplumber[1041]: D mod.protocol-native [connection.c:278:clear_buffer]: 0x5569365c5220 clear fds:0 n_fds:0
Aug 31 15:03:20 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569366ff2e0> info, change_mask:0x4 []
Aug 31 15:03:20 machine wireplumber[1041]: D s-node [suspend-node.lua:28:chunk]: <WpNode:74:0x5569364eb9d0> changed state to suspended
Aug 31 15:03:22 machine wireplumber[1041]: D spa.v4l2 [v4l2-udev.c:365:check_access]: /dev/video0 accessible:1
Aug 31 15:03:22 machine wireplumber[1041]: D spa.v4l2 [v4l2-udev.c:365:check_access]: /dev/video1 accessible:1
Aug 31 15:03:22 machine wireplumber[1041]: D mod.protocol-native [connection.c:278:clear_buffer]: 0x5569364c2940 clear fds:0 n_fds:0
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:105:registry_global]: <WpCore:0x5569364a28a0> global:72 perm:0x1c8 type:PipeWire:Interface:Node/3 -> WpNode
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:342:wp_registry_prepare_new_global]: <WpCore:0x5569364a28a0> new WpGlobal:72 type:WpNode proxy:(nil)
Aug 31 15:03:22 machine wireplumber[1041]: D mod.protocol-native [connection.c:278:clear_buffer]: 0x5569365c5220 clear fds:0 n_fds:0
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:105:registry_global]: <WpCore:0x5569365b1690> global:72 perm:0x1c8 type:PipeWire:Interface:Node/3 -> WpNode
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:342:wp_registry_prepare_new_global]: <WpCore:0x5569365b1690> new WpGlobal:72 type:WpNode proxy:(nil)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:262:expose_tmp_globals]: <WpCore:0x5569364a28a0> exposing 1 new globals
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:262:expose_tmp_globals]: <WpCore:0x5569365b1690> exposing 1 new globals
Aug 31 15:03:22 machine wireplumber[1041]: D pw.proxy [proxy.c:92:pw_proxy_new]: 0x5569367c4980: new 46 type PipeWire:Interface:Node/3 core-proxy:0x5569364c1b20, marshal:0x7f46bbc25e00
Aug 31 15:03:22 machine wireplumber[1041]: D pw.core [core.c:86:core_event_bound_id]: 0x5569364c1b20: proxy id 46 bound 72
Aug 31 15:03:22 machine wireplumber[1041]: D pw.proxy [proxy.c:143:pw_proxy_set_bound_id]: 0x5569367c4980: id:46 bound:72
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpNode:72:0x5569367ed5d0> features changed 0x0 -> 0x1
Aug 31 15:03:22 machine wireplumber[1041]: D pw.core [core.c:115:core_event_bound_props]: 0x5569364c1b20: proxy id 46 bound 72
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:72:0x5569367ed5d0> info, change_mask:0x1f [props,params,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpNode:72:0x5569367ed5d0> features changed 0x1 -> 0x11
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpNode:72:0x5569367ed5d0> enum id 1 (PropInfo), seq 0x40000489 (1073742985), task <GTask:0x5569367a6710>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x4000048a, task <GTask:0x5569367e1760>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpNode:72:0x5569367ed5d0> enum id 2 (Props), seq 0x4000048b (1073742987), task <GTask:0x5569367e1890>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x4000048c, task <GTask:0x5569367e1980>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpNode:72:0x5569367ed5d0> enum id 3 (EnumFormat), seq 0x4000048d (1073742989), task <GTask:0x5569367a9d10>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x4000048e, task <GTask:0x556936701330>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpNode:72:0x5569367ed5d0> enum id 10 (EnumPortConfig), seq 0x4000048f (1073742991), task <GTask:0x556936701da0>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x40000490, task <GTask:0x55693674bfe0>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpNode:72:0x5569367ed5d0> enum id 11 (PortConfig), seq 0x40000491 (1073742993), task <GTask:0x5569366fc5f0>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x40000492, task <GTask:0x55693660a370>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x40000493, task <GTask:0x55693660ac60>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x4000048a, task <GTask:0x5569367e1760>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpNode:72:0x5569367ed5d0> got 30 params, ok, task <GTask:0x5569367a6710>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:595:enum_params_for_cache_done]: <WpNode:72:0x5569367ed5d0> cached params id:1 (PropInfo), n_params:30
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x4000048c, task <GTask:0x5569367e1980>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpNode:72:0x5569367ed5d0> got 1 params, ok, task <GTask:0x5569367e1890>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:595:enum_params_for_cache_done]: <WpNode:72:0x5569367ed5d0> cached params id:2 (Props), n_params:1
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x4000048e, task <GTask:0x556936701330>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpNode:72:0x5569367ed5d0> got 1 params, ok, task <GTask:0x5569367a9d10>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:595:enum_params_for_cache_done]: <WpNode:72:0x5569367ed5d0> cached params id:3 (EnumFormat), n_params:1
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x40000490, task <GTask:0x55693674bfe0>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpNode:72:0x5569367ed5d0> got 1 params, ok, task <GTask:0x556936701da0>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:595:enum_params_for_cache_done]: <WpNode:72:0x5569367ed5d0> cached params id:10 (EnumPortConfig), n_params:1
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x40000492, task <GTask:0x55693660a370>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpNode:72:0x5569367ed5d0> got 1 params, ok, task <GTask:0x5569366fc5f0>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:595:enum_params_for_cache_done]: <WpNode:72:0x5569367ed5d0> cached params id:11 (PortConfig), n_params:1
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x40000493, task <GTask:0x55693660ac60>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpNode:72:0x5569367ed5d0> features changed 0x11 -> 0x171
Aug 31 15:03:22 machine wireplumber[1041]: D wp-node [node.c:170:wp_node_enable_feature_ports]: <WpNode:72:0x5569367ed5d0> enabling WP_NODE_FEATURE_PORTS, bound_id:72
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpNode:72:0x5569367ed5d0> features changed 0x171 -> 0x10171
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'node-added', prio 130, subject <WpNode:0x5569367ed5d0> (node)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569364ee5f0> added <WpSimpleEventHook:0x5569365a38a0>(lib/audio-group-utils/create-audio-group-loopback)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569364ee5f0> added <WpAsyncEventHook:0x5569365a8890>(node/create-item)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569364ee5f0> added <WpSimpleEventHook:0x5569365765e0>(node/restore-stream)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x5569364ee5f0>node-added@node)
Aug 31 15:03:22 machine wireplumber[1041]: I m-lua-scripting [audio-group.lua:151:chunk]: <WpNode:72:0x5569367ed5d0> Cannot get audio group, not grouping audio stream
Aug 31 15:03:22 machine wireplumber[1041]: I s-node [create-item.lua:89:chunk]: <WpNode:72:0x5569367ed5d0> creating item for node -> si-audio-adapter
Aug 31 15:03:22 machine wireplumber[1041]: D m-mixer-api [module-mixer-api.c:288:on_objects_changed]: <WpMixerApi:0x556936589910> node 72 changed volume props
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpSiAudioAdapter:0x5569367528d0> features changed 0x0 -> 0x1
Aug 31 15:03:22 machine wireplumber[1041]: I s-node [create-item.lua:120:chunk]: <WpSiAudioAdapter:0x5569367528d0> activated item for node 72
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'session-item-added', prio 110, subject <WpSiAudioAdapter:0x5569367528d0> (session-item)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x55693660ac60> added <WpSimpleEventHook:0x556936585f80>(linking/rescan-trigger)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x55693660ac60> added <WpSimpleEventHook:0x5569365865a0>(linking/session-item-added)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x55693660ac60> added <WpSimpleEventHook:0x5569365bf890>(node/filter-forward-format)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x55693660ac60>session-item-added@session-item)
Aug 31 15:03:22 machine wireplumber[1041]: I s-node [state-stream.lua:80:chunk]: <WpNode:72:0x5569367ed5d0> restore values from Output/Audio:media.role:Notification
Aug 31 15:03:22 machine wireplumber[1041]: D s-node [state-stream.lua:83:chunk]: <WpSpaPod:0x556936757f60> setting props on :
                                                         Object: size 120, type Spa:Pod:Object:Param:Props (262146), id Spa:Enum:ParamId:Props (2)
                                                           Prop: key Spa:Pod:Object:Param:Props:mute (65540), flags 00000000
                                                             Bool false
                                                           Prop: key Spa:Pod:Object:Param:Props:volume (65539), flags 00000000
                                                             Float 1.000000
                                                           Prop: key Spa:Pod:Object:Param:Props:channelMap (65547), flags 00000000
                                                             Array: child.size 4, child.type Spa:Id
                                                               Id 3        (Spa:Enum:AudioChannel:FL)
                                                               Id 4        (Spa:Enum:AudioChannel:FR)
                                                           Prop: key Spa:Pod:Object:Param:Props:channelVolumes (65544), flags 00000000
                                                             Array: child.size 4, child.type Spa:Float
                                                               Float 1.000000
                                                               Float 1.000000
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'rescan-for-linking', prio -500, subject <invalid:(nil)> ((null))
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x556936806a50> added <WpSimpleEventHook:0x556936582ab0>(lib/filter-utils/rescan)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x556936806a50> added <WpSimpleEventHook:0x556936583d80>(linking/rescan)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x556936806a50> added <WpSimpleEventHook:0x55693655a2c0>(m-standard-event-source/rescan-done)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x556936806a50>rescan-for-linking)
Aug 31 15:03:22 machine wireplumber[1041]: I m-lua-scripting [filter-utils.lua:292:rescanFilters]: rescanning filters...
Aug 31 15:03:22 machine wireplumber[1041]: I s-linking [rescan.lua:150:chunk]: rescanning...
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'select-target', prio 500, subject <WpSiAudioAdapter:0x5569367528d0> (session-item)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569365c7940> added <WpSimpleEventHook:0x556936592d10>(linking/prepare-link)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569365c7940> added <WpAsyncEventHook:0x556936598e10>(linking/link-target)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569365c7940> added <WpSimpleEventHook:0x55693659a1e0>(linking/find-media-role-target)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569365c7940> added <WpSimpleEventHook:0x55693659d180>(linking/find-defined-target)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569365c7940> added <WpSimpleEventHook:0x5569365a4480>(linking/find-audio-group-target)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569365c7940> added <WpSimpleEventHook:0x55693656e340>(linking/find-filter-target)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569365c7940> added <WpSimpleEventHook:0x5569365a4aa0>(linking/find-default-target)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569365c7940> added <WpSimpleEventHook:0x556936582b40>(linking/find-best-target)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569365c7940> added <WpSimpleEventHook:0x55693659d600>(linking/get-filter-from-target)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x5569365c7940>select-target@session-item)
Aug 31 15:03:22 machine wireplumber[1041]: I s-linking [find-defined-target.lua:33:chunk]: <WpSiAudioAdapter:0x5569367528d0> handling item 181:  (72)
Aug 31 15:03:22 machine wireplumber[1041]: I s-linking [find-audio-group-target.lua:38:chunk]: <WpSiAudioAdapter:0x5569367528d0> handling item 181:  (72)
Aug 31 15:03:22 machine wireplumber[1041]: I s-linking [find-filter-target.lua:56:chunk]: <WpSiAudioAdapter:0x5569367528d0> handling item 181:  (72)
Aug 31 15:03:22 machine wireplumber[1041]: I s-linking [find-media-role-target.lua:36:chunk]: <WpSiAudioAdapter:0x5569367528d0> handling item 181:  (72) role (Notification)
Aug 31 15:03:22 machine wireplumber[1041]: I s-linking [find-default-target.lua:34:chunk]: <WpSiAudioAdapter:0x5569367528d0> handling item:  (72)
Aug 31 15:03:22 machine wireplumber[1041]: I s-linking [find-default-target.lua:49:chunk]: <WpSiAudioAdapter:0x5569367528d0> ... default target picked: alsa_output.pci-0000_01_00.1.hdmi-stereo (74), can_passthrough:false
Aug 31 15:03:22 machine wireplumber[1041]: I s-linking [get-filter-from-target.lua:89:chunk]: <WpSiAudioAdapter:0x5569367528d0> ... target picked: alsa_output.pci-0000_01_00.1.hdmi-stereo (74), can_passthrough:false
Aug 31 15:03:22 machine wireplumber[1041]: I s-linking [prepare-link.lua:31:chunk]: <WpSiAudioAdapter:0x5569367528d0> handling item 181:  (72)
Aug 31 15:03:22 machine wireplumber[1041]: I s-linking [link-target.lua:41:chunk]: <WpSiAudioAdapter:0x5569367528d0> handling item 181:  (72)
Aug 31 15:03:22 machine wireplumber[1041]: I s-linking [link-target.lua:68:chunk]: <WpSiAudioAdapter:0x5569367528d0> link  <-> alsa_output.pci-0000_01_00.1.hdmi-stereo passthrough:false, exclusive:nil, media role link:nil
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'session-item-added', prio 110, subject <WpSiStandardLink:0x5569367d9800> (session-item)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569367e7f60> added <WpSimpleEventHook:0x5569365865a0>(linking/session-item-added)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x5569367e7f60>session-item-added@session-item)
Aug 31 15:03:22 machine wireplumber[1041]: D s-linking [link-target.lua:123:chunk]: <WpSiStandardLink:0x5569367d9800> registered link between <WpSiAudioAdapter:0x5569367528d0> and <WpSiAudioAdapter:0x5569366f7ec0>
Aug 31 15:03:22 machine wireplumber[1041]: D m-si-standard-link [module-si-standard-link.c:562:configure_and_link_adapters]: <WpSiStandardLink:0x5569367d9800> out [device:0, dont_remix 0, unpos 0], in: [device 1, dont_remix 0, unpos 0]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:72:0x5569367ed5d0> info, change_mask:0x10 [params,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpNode:72:0x5569367ed5d0> enum id 2 (Props), seq 0x40000496 (1073742998), task <GTask:0x5569367a9d10>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x40000497, task <GTask:0x5569367e1980>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:105:registry_global]: <WpCore:0x5569364a28a0> global:79 perm:0x148 type:PipeWire:Interface:Port/3 -> WpPort
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:342:wp_registry_prepare_new_global]: <WpCore:0x5569364a28a0> new WpGlobal:79 type:WpPort proxy:(nil)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:105:registry_global]: <WpCore:0x5569364a28a0> global:81 perm:0x148 type:PipeWire:Interface:Port/3 -> WpPort
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:342:wp_registry_prepare_new_global]: <WpCore:0x5569364a28a0> new WpGlobal:81 type:WpPort proxy:(nil)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:72:0x5569367ed5d0> info, change_mask:0x12 [params,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpNode:72:0x5569367ed5d0> enum id 2 (Props), seq 0x40000498 (1073743000), task <GTask:0x5569367e1890>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x40000499, task <GTask:0x5569367e1760>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpNode:72:0x5569367ed5d0> enum id 11 (PortConfig), seq 0x4000049a (1073743002), task <GTask:0x5569367a6710>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x4000049b, task <GTask:0x556936808800>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:105:registry_global]: <WpCore:0x5569365b1690> global:79 perm:0x148 type:PipeWire:Interface:Port/3 -> WpPort
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:342:wp_registry_prepare_new_global]: <WpCore:0x5569365b1690> new WpGlobal:79 type:WpPort proxy:(nil)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:105:registry_global]: <WpCore:0x5569365b1690> global:81 perm:0x148 type:PipeWire:Interface:Port/3 -> WpPort
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:342:wp_registry_prepare_new_global]: <WpCore:0x5569365b1690> new WpGlobal:81 type:WpPort proxy:(nil)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x40000497, task <GTask:0x5569367e1980>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x4000049c, task <GTask:0x5569364cf090>
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'node-params-changed', prio 50, subject <WpNode:0x5569367ed5d0> (node)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569366f6220> added <WpSimpleEventHook:0x5569365b66b0>(node/store-stream-props)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x5569366f6220>node-params-changed@node@Props)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x40000499, task <GTask:0x5569367e1760>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x4000049d, task <GTask:0x5569367e1980>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x556936745750> added <WpSimpleEventHook:0x5569365b66b0>(node/store-stream-props)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x556936745750>node-params-changed@node@Props)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x4000049b, task <GTask:0x556936808800>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpNode:72:0x5569367ed5d0> got 1 params, ok, task <GTask:0x5569367a6710>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:262:expose_tmp_globals]: <WpCore:0x5569364a28a0> exposing 2 new globals
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:262:expose_tmp_globals]: <WpCore:0x5569365b1690> exposing 2 new globals
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x4000049c, task <GTask:0x5569364cf090>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x4000049d, task <GTask:0x5569367e1980>
Aug 31 15:03:22 machine wireplumber[1041]: D pw.proxy [proxy.c:92:pw_proxy_new]: 0x55693674abc0: new 53 type PipeWire:Interface:Port/3 core-proxy:0x5569364c1b20, marshal:0x7f46bbc25dc0
Aug 31 15:03:22 machine wireplumber[1041]: D pw.proxy [proxy.c:92:pw_proxy_new]: 0x5569367dc070: new 55 type PipeWire:Interface:Port/3 core-proxy:0x5569364c1b20, marshal:0x7f46bbc25dc0
Aug 31 15:03:22 machine wireplumber[1041]: D pw.core [core.c:86:core_event_bound_id]: 0x5569364c1b20: proxy id 53 bound 79
Aug 31 15:03:22 machine wireplumber[1041]: D pw.proxy [proxy.c:143:pw_proxy_set_bound_id]: 0x55693674abc0: id:53 bound:79
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpPort:79:0x5569367c3b40> features changed 0x0 -> 0x1
Aug 31 15:03:22 machine wireplumber[1041]: D pw.core [core.c:115:core_event_bound_props]: 0x5569364c1b20: proxy id 53 bound 79
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:79:0x5569367c3b40> info, change_mask:0x3 [props,params,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpPort:79:0x5569367c3b40> features changed 0x1 -> 0x11
Aug 31 15:03:22 machine wireplumber[1041]: D pw.core [core.c:86:core_event_bound_id]: 0x5569364c1b20: proxy id 55 bound 81
Aug 31 15:03:22 machine wireplumber[1041]: D pw.proxy [proxy.c:143:pw_proxy_set_bound_id]: 0x5569367dc070: id:55 bound:81
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpPort:81:0x5569367c3e10> features changed 0x0 -> 0x1
Aug 31 15:03:22 machine wireplumber[1041]: D pw.core [core.c:115:core_event_bound_props]: 0x5569364c1b20: proxy id 55 bound 81
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:81:0x5569367c3e10> info, change_mask:0x3 [props,params,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpPort:81:0x5569367c3e10> features changed 0x1 -> 0x11
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpPort:79:0x5569367c3b40> enum id 3 (EnumFormat), seq 0x400004a0 (1073743008), task <GTask:0x5569367a6710>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x400004a1, task <GTask:0x5569367e1760>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x400004a2, task <GTask:0x5569367e1890>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpPort:81:0x5569367c3e10> enum id 3 (EnumFormat), seq 0x400004a3 (1073743011), task <GTask:0x5569367a9d10>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x400004a4, task <GTask:0x556936746060>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x400004a5, task <GTask:0x5569367e8b30>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x400004a1, task <GTask:0x5569367e1760>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpPort:79:0x5569367c3b40> got 1 params, ok, task <GTask:0x5569367a6710>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:595:enum_params_for_cache_done]: <WpPort:79:0x5569367c3b40> cached params id:3 (EnumFormat), n_params:1
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x400004a2, task <GTask:0x5569367e1890>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpPort:79:0x5569367c3b40> features changed 0x11 -> 0x51
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x400004a4, task <GTask:0x556936746060>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpPort:81:0x5569367c3e10> got 1 params, ok, task <GTask:0x5569367a9d10>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:595:enum_params_for_cache_done]: <WpPort:81:0x5569367c3e10> cached params id:3 (EnumFormat), n_params:1
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x400004a5, task <GTask:0x5569367e8b30>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpPort:81:0x5569367c3e10> features changed 0x11 -> 0x51
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'port-added', prio 150, subject <WpPort:0x5569367c3b40> (port)
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'port-added', prio 150, subject <WpPort:0x5569367c3e10> (port)
Aug 31 15:03:22 machine wireplumber[1041]: D m-si-standard-link [module-si-standard-link.c:353:create_links]: <WpSiStandardLink:0x5569367d9800> create pw link: 72:79 (Spa:Enum:AudioChannel:FL) -> 74:76 (Spa:Enum:AudioChannel:FL)
Aug 31 15:03:22 machine wireplumber[1041]: D m-si-standard-link [module-si-standard-link.c:353:create_links]: <WpSiStandardLink:0x5569367d9800> create pw link: 72:81 (Spa:Enum:AudioChannel:FR) -> 74:75 (Spa:Enum:AudioChannel:FR)
Aug 31 15:03:22 machine wireplumber[1041]: D pw.proxy [proxy.c:92:pw_proxy_new]: 0x5569367a8e30: new 52 type PipeWire:Interface:Link/3 core-proxy:0x5569364c1b20, marshal:0x7f46bbc25d00
Aug 31 15:03:22 machine wireplumber[1041]: D pw.proxy [proxy.c:92:pw_proxy_new]: 0x5569367a41b0: new 54 type PipeWire:Interface:Link/3 core-proxy:0x5569364c1b20, marshal:0x7f46bbc25d00
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569364eb9d0> info, change_mask:0x10 [params,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:73:0x5569367e9dc0> info, change_mask:0x2 [params,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:77:0x556936749370> info, change_mask:0x2 [params,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:76:0x556936748e00> info, change_mask:0x2 [params,]
Aug 31 15:03:22 machine wireplumber[1041]: D pw.core [core.c:86:core_event_bound_id]: 0x5569364c1b20: proxy id 52 bound 78
Aug 31 15:03:22 machine wireplumber[1041]: D pw.proxy [proxy.c:143:pw_proxy_set_bound_id]: 0x5569367a8e30: id:52 bound:78
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpLink:78:0x5569364f3da0> features changed 0x0 -> 0x1
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:342:wp_registry_prepare_new_global]: <WpCore:0x5569364a28a0> new WpGlobal:78 type:WpLink proxy:0x5569364f3da0
Aug 31 15:03:22 machine wireplumber[1041]: D pw.core [core.c:115:core_event_bound_props]: 0x5569364c1b20: proxy id 52 bound 78
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpLink:78:0x5569364f3da0> info, change_mask:0x7 [props,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpLink:78:0x5569364f3da0> features changed 0x1 -> 0x11
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:105:registry_global]: <WpCore:0x5569364a28a0> global:78 perm:0x140 type:PipeWire:Interface:Link/3 -> WpLink
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:342:wp_registry_prepare_new_global]: <WpCore:0x5569364a28a0> reuse WpGlobal:78 type:WpLink proxy:0x5569364f3da0
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:75:0x55693674a480> info, change_mask:0x2 [params,]
Aug 31 15:03:22 machine wireplumber[1041]: D pw.core [core.c:86:core_event_bound_id]: 0x5569364c1b20: proxy id 54 bound 80
Aug 31 15:03:22 machine wireplumber[1041]: D pw.proxy [proxy.c:143:pw_proxy_set_bound_id]: 0x5569367a41b0: id:54 bound:80
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpLink:80:0x5569367a9820> features changed 0x0 -> 0x1
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:342:wp_registry_prepare_new_global]: <WpCore:0x5569364a28a0> new WpGlobal:80 type:WpLink proxy:0x5569367a9820
Aug 31 15:03:22 machine wireplumber[1041]: D pw.core [core.c:115:core_event_bound_props]: 0x5569364c1b20: proxy id 54 bound 80
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpLink:80:0x5569367a9820> info, change_mask:0x7 [props,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpLink:80:0x5569367a9820> features changed 0x1 -> 0x11
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:105:registry_global]: <WpCore:0x5569364a28a0> global:80 perm:0x140 type:PipeWire:Interface:Link/3 -> WpLink
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:342:wp_registry_prepare_new_global]: <WpCore:0x5569364a28a0> reuse WpGlobal:80 type:WpLink proxy:0x5569367a9820
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpPort:76:0x556936748e00> enum id 4 (Format), seq 0x400004a8 (1073743016), task <GTask:0x556936701330>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x400004a9, task <GTask:0x5569367e8b30>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpPort:75:0x55693674a480> enum id 4 (Format), seq 0x400004aa (1073743018), task <GTask:0x556936746060>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x400004ab, task <GTask:0x5569367a9d10>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569366ff2e0> info, change_mask:0x10 [params,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:105:registry_global]: <WpCore:0x5569365b1690> global:78 perm:0x140 type:PipeWire:Interface:Link/3 -> WpLink
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:342:wp_registry_prepare_new_global]: <WpCore:0x5569365b1690> new WpGlobal:78 type:WpLink proxy:(nil)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:105:registry_global]: <WpCore:0x5569365b1690> global:80 perm:0x140 type:PipeWire:Interface:Link/3 -> WpLink
Aug 31 15:03:22 machine wireplumber[1041]: D wp-registry [registry.c:342:wp_registry_prepare_new_global]: <WpCore:0x5569365b1690> new WpGlobal:80 type:WpLink proxy:(nil)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x400004a9, task <GTask:0x5569367e8b30>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpPort:76:0x556936748e00> got 1 params, ok, task <GTask:0x556936701330>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:595:enum_params_for_cache_done]: <WpPort:76:0x556936748e00> cached params id:4 (Format), n_params:1
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'port-params-changed', prio 50, subject <WpPort:0x556936748e00> (port)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x400004ab, task <GTask:0x5569367a9d10>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpPort:75:0x55693674a480> got 1 params, ok, task <GTask:0x556936746060>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:595:enum_params_for_cache_done]: <WpPort:75:0x55693674a480> cached params id:4 (Format), n_params:1
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'port-params-changed', prio 50, subject <WpPort:0x55693674a480> (port)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpSiStandardLink:0x5569367d9800> features changed 0x0 -> 0x1
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'link-added', prio 20, subject <WpLink:0x5569367a9820> (link)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569365c9600> added <WpSimpleEventHook:0x556936546c90>(link-added@autoswitch-bluetooth-profile)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x5569365c9600>link-added@link)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:79:0x5569367c3b40> info, change_mask:0x2 [params,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:81:0x5569367c3e10> info, change_mask:0x2 [params,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpPort:79:0x5569367c3b40> enum id 4 (Format), seq 0x400004ac (1073743020), task <GTask:0x5569367a9d10>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x400004ad, task <GTask:0x556936746060>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpPort:81:0x5569367c3e10> enum id 4 (Format), seq 0x400004ae (1073743022), task <GTask:0x5569367e8b30>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x400004af, task <GTask:0x556936701330>
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'link-added', prio 20, subject <WpLink:0x5569364f3da0> (link)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569367ed900> added <WpSimpleEventHook:0x556936546c90>(link-added@autoswitch-bluetooth-profile)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x5569367ed900>link-added@link)
Aug 31 15:03:22 machine wireplumber[1041]: D s-linking [link-target.lua:144:chunk]: <WpSiStandardLink:0x5569367d9800> activated link between <WpSiAudioAdapter:0x5569367528d0> and <WpSiAudioAdapter:0x5569366f7ec0>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x400004ad, task <GTask:0x556936746060>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpPort:79:0x5569367c3b40> got 1 params, ok, task <GTask:0x5569367a9d10>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:595:enum_params_for_cache_done]: <WpPort:79:0x5569367c3b40> cached params id:4 (Format), n_params:1
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'port-params-changed', prio 50, subject <WpPort:0x5569367c3b40> (port)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x400004af, task <GTask:0x556936701330>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpPort:81:0x5569367c3e10> got 1 params, ok, task <GTask:0x5569367e8b30>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:595:enum_params_for_cache_done]: <WpPort:81:0x5569367c3e10> cached params id:4 (Format), n_params:1
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'port-params-changed', prio 50, subject <WpPort:0x5569367c3e10> (port)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpLink:78:0x5569364f3da0> info, change_mask:0x1 []
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpLink:80:0x5569367a9820> info, change_mask:0x1 []
Aug 31 15:03:22 machine wireplumber[1041]: I s-node [state-stream.lua:164:chunk]: <WpNode:72:0x5569367ed5d0> saving stream props for
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:72:0x5569367ed5d0> info, change_mask:0x8 [props,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpNode:72:0x5569367ed5d0> enum id 4 (Format), seq 0x400004b0 (1073743024), task <GTask:0x556936701330>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x400004b1, task <GTask:0x5569367e8b30>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpNode:72:0x5569367ed5d0> enum id 2 (Props), seq 0x400004b2 (1073743026), task <GTask:0x556936746060>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x400004b3, task <GTask:0x5569367a9d10>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:72:0x5569367ed5d0> info, change_mask:0x4 []
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'node-state-changed', prio 50, subject <WpNode:0x5569367ed5d0> (node)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569364eb9d0> info, change_mask:0x8 [props,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpNode:74:0x5569364eb9d0> enum id 4 (Format), seq 0x400004b4 (1073743028), task <GTask:0x5569367e1890>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x400004b5, task <GTask:0x5569367e1760>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:198:wp_pw_object_mixin_enum_params_unchecked]: <WpNode:74:0x5569364eb9d0> enum id 2 (Props), seq 0x400004b6 (1073743030), task <GTask:0x5569367a6710>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x400004b7, task <GTask:0x5569367b6ba0>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569364eb9d0> info, change_mask:0x4 []
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'node-state-changed', prio 50, subject <WpNode:0x5569364eb9d0> (node)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569367b0d20> added <WpSimpleEventHook:0x5569365adfa0>(node/suspend-node)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x5569367b0d20>node-state-changed@node)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x400004b1, task <GTask:0x5569367e8b30>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpNode:72:0x5569367ed5d0> got 1 params, ok, task <GTask:0x556936701330>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:595:enum_params_for_cache_done]: <WpNode:72:0x5569367ed5d0> cached params id:4 (Format), n_params:1
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x400004b3, task <GTask:0x5569367a9d10>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpNode:72:0x5569367ed5d0> got 1 params, ok, task <GTask:0x556936746060>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x400004b8, task <GTask:0x5569367e8b30>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569367ab7b0> added <WpSimpleEventHook:0x5569365b66b0>(node/store-stream-props)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x5569367ab7b0>node-params-changed@node@Props)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569366ff2e0> info, change_mask:0x8 [props,]
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569366ff2e0> info, change_mask:0x4 []
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x400004b5, task <GTask:0x5569367e1760>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpNode:74:0x5569364eb9d0> got 1 params, ok, task <GTask:0x5569367e1890>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:595:enum_params_for_cache_done]: <WpNode:74:0x5569364eb9d0> cached params id:4 (Format), n_params:1
Aug 31 15:03:22 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'node-params-changed', prio 50, subject <WpNode:0x5569364eb9d0> (node)
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x400004b7, task <GTask:0x5569367b6ba0>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:128:enum_params_done]: <WpNode:74:0x5569364eb9d0> got 2 params, ok, task <GTask:0x5569367a6710>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:595:enum_params_for_cache_done]: <WpNode:74:0x5569364eb9d0> cached params id:2 (Props), n_params:2
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:1350:wp_core_sync_closure]: <WpCore:0x5569364a28a0> sync, seq 0x400004b9, task <GTask:0x5569367e1890>
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x400004b8, task <GTask:0x5569367e8b30>
Aug 31 15:03:22 machine wireplumber[1041]: D s-node [suspend-node.lua:28:chunk]: <WpNode:74:0x5569364eb9d0> changed state to running
Aug 31 15:03:22 machine wireplumber[1041]: D wp-core [core.c:252:core_done]: <WpCore:0x5569364a28a0> done, seq 0x400004b9, task <GTask:0x5569367e1890>
Aug 31 15:03:23 machine wireplumber[1041]: I wp-state [state.c:338:wp_state_save]: <WpState:0x5569365b7110> saving state into /home/user/.local/state/wireplumber/stream-properties
Aug 31 15:03:24 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpLink:78:0x5569364f3da0> info, change_mask:0x1 []
Aug 31 15:03:24 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpLink:80:0x5569367a9820> info, change_mask:0x1 []
Aug 31 15:03:24 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:72:0x5569367ed5d0> info, change_mask:0xc [props,]
Aug 31 15:03:24 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'node-state-changed', prio 50, subject <WpNode:0x5569367ed5d0> (node)
Aug 31 15:03:24 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569364eb9d0> info, change_mask:0x10 [params,]
Aug 31 15:03:24 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:73:0x5569367e9dc0> info, change_mask:0x2 [params,]
Aug 31 15:03:24 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:77:0x556936749370> info, change_mask:0x2 [params,]
Aug 31 15:03:24 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:76:0x556936748e00> info, change_mask:0x2 [params,]
Aug 31 15:03:24 machine wireplumber[1041]: D pw.core [core.c:76:core_event_remove_id]: 0x5569364c1b20: object remove 52
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:245:pw_proxy_remove]: 0x5569367a8e30: remove id:52 removed:0 destroyed:0 zombie:0 ref:1
Aug 31 15:03:24 machine wireplumber[1041]: D wp-registry [registry.c:137:registry_global_remove]: <WpCore:0x5569364a28a0> global removed:78 type:WpLink
Aug 31 15:03:24 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'link-removed', prio 20, subject <WpLink:0x5569364f3da0> (link)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:210:pw_proxy_destroy]: 0x5569367a8e30: destroy id:52 removed:1 zombie:0 ref:1
Aug 31 15:03:24 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpLink:0x5569364f3da0> features changed 0x11 -> 0x10
Aug 31 15:03:24 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpLink:0x5569364f3da0> features changed 0x10 -> 0x0
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:272:pw_proxy_unref]: 0x5569367a8e30: free 4294967295
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569364f1bc0: id:78 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569364ff020: id:78 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936500110: id:78 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936528a40: id:78 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936581d70: id:78 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x55693655a1f0: id:78 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569365ba0d0: id:78 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.core [core.c:76:core_event_remove_id]: 0x5569364c1b20: object remove 53
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:245:pw_proxy_remove]: 0x55693674abc0: remove id:53 removed:0 destroyed:0 zombie:0 ref:1
Aug 31 15:03:24 machine wireplumber[1041]: D wp-registry [registry.c:137:registry_global_remove]: <WpCore:0x5569364a28a0> global removed:79 type:WpPort
Aug 31 15:03:24 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'port-removed', prio 150, subject <WpPort:0x5569367c3b40> (port)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:210:pw_proxy_destroy]: 0x55693674abc0: destroy id:53 removed:1 zombie:0 ref:1
Aug 31 15:03:24 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpPort:0x5569367c3b40> features changed 0x51 -> 0x50
Aug 31 15:03:24 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpPort:0x5569367c3b40> features changed 0x50 -> 0x0
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:272:pw_proxy_unref]: 0x55693674abc0: free 4294967295
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569364f1bc0: id:79 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569364ff020: id:79 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936500110: id:79 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936528a40: id:79 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936581d70: id:79 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x55693655a1f0: id:79 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569365ba0d0: id:79 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpPort:75:0x55693674a480> info, change_mask:0x2 [params,]
Aug 31 15:03:24 machine wireplumber[1041]: D pw.core [core.c:76:core_event_remove_id]: 0x5569364c1b20: object remove 54
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:245:pw_proxy_remove]: 0x5569367a41b0: remove id:54 removed:0 destroyed:0 zombie:0 ref:1
Aug 31 15:03:24 machine wireplumber[1041]: D wp-registry [registry.c:137:registry_global_remove]: <WpCore:0x5569364a28a0> global removed:80 type:WpLink
Aug 31 15:03:24 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'link-removed', prio 20, subject <WpLink:0x5569367a9820> (link)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:210:pw_proxy_destroy]: 0x5569367a41b0: destroy id:54 removed:1 zombie:0 ref:1
Aug 31 15:03:24 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpLink:0x5569367a9820> features changed 0x11 -> 0x10
Aug 31 15:03:24 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpLink:0x5569367a9820> features changed 0x10 -> 0x0
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:272:pw_proxy_unref]: 0x5569367a41b0: free 4294967295
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569364f1bc0: id:80 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569364ff020: id:80 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936500110: id:80 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936528a40: id:80 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936581d70: id:80 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x55693655a1f0: id:80 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569365ba0d0: id:80 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.core [core.c:76:core_event_remove_id]: 0x5569364c1b20: object remove 55
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:245:pw_proxy_remove]: 0x5569367dc070: remove id:55 removed:0 destroyed:0 zombie:0 ref:1
Aug 31 15:03:24 machine wireplumber[1041]: D wp-registry [registry.c:137:registry_global_remove]: <WpCore:0x5569364a28a0> global removed:81 type:WpPort
Aug 31 15:03:24 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'port-removed', prio 150, subject <WpPort:0x5569367c3e10> (port)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:210:pw_proxy_destroy]: 0x5569367dc070: destroy id:55 removed:1 zombie:0 ref:1
Aug 31 15:03:24 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpPort:0x5569367c3e10> features changed 0x51 -> 0x50
Aug 31 15:03:24 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpPort:0x5569367c3e10> features changed 0x50 -> 0x0
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:272:pw_proxy_unref]: 0x5569367dc070: free 4294967295
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569364f1bc0: id:81 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569364ff020: id:81 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936500110: id:81 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936528a40: id:81 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936581d70: id:81 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x55693655a1f0: id:81 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569365ba0d0: id:81 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.core [core.c:76:core_event_remove_id]: 0x5569364c1b20: object remove 46
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:245:pw_proxy_remove]: 0x5569367c4980: remove id:46 removed:0 destroyed:0 zombie:0 ref:1
Aug 31 15:03:24 machine wireplumber[1041]: D wp-registry [registry.c:137:registry_global_remove]: <WpCore:0x5569364a28a0> global removed:72 type:WpNode
Aug 31 15:03:24 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'node-removed', prio 130, subject <WpNode:0x5569367ed5d0> (node)
Aug 31 15:03:24 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569367de3f0> added <WpSimpleEventHook:0x5569365a49d0>(lib/audio-group-utils/destroy-audio-group-loopback)
Aug 31 15:03:24 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569367de3f0> added <WpSimpleEventHook:0x5569365aa6a0>(node/destroy-item)
Aug 31 15:03:24 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x5569367de3f0>node-removed@node)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:210:pw_proxy_destroy]: 0x5569367c4980: destroy id:46 removed:1 zombie:0 ref:1
Aug 31 15:03:24 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpNode:0x5569367ed5d0> features changed 0x10171 -> 0x10170
Aug 31 15:03:24 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpNode:0x5569367ed5d0> features changed 0x10170 -> 0x10000
Aug 31 15:03:24 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpNode:0x5569367ed5d0> features changed 0x10000 -> 0x0
Aug 31 15:03:24 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpSiAudioAdapter:0x5569367528d0> features changed 0x1 -> 0x0
Aug 31 15:03:24 machine wireplumber[1041]: D pw.proxy [proxy.c:272:pw_proxy_unref]: 0x5569367c4980: free 4294967295
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569364f1bc0: id:72 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569364ff020: id:72 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936500110: id:72 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936528a40: id:72 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x556936581d70: id:72 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x55693655a1f0: id:72 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:165:impl_set_property]: 0x5569365ba0d0: id:72 key:(null) type:(null) value:(null)
Aug 31 15:03:24 machine wireplumber[1041]: D mod.protocol-native [connection.c:278:clear_buffer]: 0x5569364c2940 clear fds:0 n_fds:0
Aug 31 15:03:24 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569364eb9d0> info, change_mask:0x4 []
Aug 31 15:03:24 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'node-state-changed', prio 50, subject <WpNode:0x5569364eb9d0> (node)
Aug 31 15:03:24 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569365cea30> added <WpSimpleEventHook:0x5569365adfa0>(node/suspend-node)
Aug 31 15:03:24 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x5569365cea30>node-state-changed@node)
Aug 31 15:03:24 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569366ff2e0> info, change_mask:0x10 [params,]
Aug 31 15:03:24 machine wireplumber[1041]: D wp-registry [registry.c:137:registry_global_remove]: <WpCore:0x5569365b1690> global removed:78 type:WpLink
Aug 31 15:03:24 machine wireplumber[1041]: D wp-registry [registry.c:137:registry_global_remove]: <WpCore:0x5569365b1690> global removed:79 type:WpPort
Aug 31 15:03:24 machine wireplumber[1041]: D wp-registry [registry.c:137:registry_global_remove]: <WpCore:0x5569365b1690> global removed:80 type:WpLink
Aug 31 15:03:24 machine wireplumber[1041]: D wp-registry [registry.c:137:registry_global_remove]: <WpCore:0x5569365b1690> global removed:81 type:WpPort
Aug 31 15:03:24 machine wireplumber[1041]: D wp-registry [registry.c:137:registry_global_remove]: <WpCore:0x5569365b1690> global removed:72 type:WpNode
Aug 31 15:03:24 machine wireplumber[1041]: D mod.protocol-native [connection.c:278:clear_buffer]: 0x5569365c5220 clear fds:0 n_fds:0
Aug 31 15:03:24 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpNode:74:0x5569366ff2e0> info, change_mask:0x4 []
Aug 31 15:03:24 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'session-item-removed', prio 110, subject <WpSiAudioAdapter:0x5569367528d0> (session-item)
Aug 31 15:03:24 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x556936750e20> added <WpSimpleEventHook:0x5569365837b0>(linking/linkable-removed)
Aug 31 15:03:24 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x556936750e20> added <WpSimpleEventHook:0x556936585f80>(linking/rescan-trigger)
Aug 31 15:03:24 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x556936750e20>session-item-removed@session-item)
Aug 31 15:03:24 machine wireplumber[1041]: I s-linking [rescan.lua:69:unhandleLinkable]: <WpSiAudioAdapter:0x5569367528d0> unhandling item 181
Aug 31 15:03:24 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'session-item-removed', prio 110, subject <WpSiStandardLink:0x5569367d9800> (session-item)
Aug 31 15:03:24 machine wireplumber[1041]: I s-linking [rescan.lua:92:unhandleLinkable]: <WpSiStandardLink:0x5569367d9800> ... link removed
Aug 31 15:03:24 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpSiStandardLink:0x5569367d9800> features changed 0x1 -> 0x0
Aug 31 15:03:24 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'rescan-for-linking', prio -500, subject <invalid:(nil)> ((null))
Aug 31 15:03:24 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569366f9490> added <WpSimpleEventHook:0x556936582ab0>(lib/filter-utils/rescan)
Aug 31 15:03:24 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569366f9490> added <WpSimpleEventHook:0x556936583d80>(linking/rescan)
Aug 31 15:03:24 machine wireplumber[1041]: D wp-event [event.c:391:wp_event_collect_hooks]: <WpEvent:0x5569366f9490> added <WpSimpleEventHook:0x55693655a2c0>(m-standard-event-source/rescan-done)
Aug 31 15:03:24 machine wireplumber[1041]: D wp-event-dispatcher [event-dispatcher.c:267:wp_event_dispatcher_push_event]: <WpEventDispatcher:0x556936504af0> pushed event (<0x5569366f9490>rescan-for-linking)
Aug 31 15:03:24 machine wireplumber[1041]: D s-node [suspend-node.lua:28:chunk]: <WpNode:74:0x5569364eb9d0> changed state to idle
Aug 31 15:03:24 machine wireplumber[1041]: I m-lua-scripting [filter-utils.lua:292:rescanFilters]: rescanning filters...
Aug 31 15:03:24 machine wireplumber[1041]: I s-linking [rescan.lua:150:chunk]: rescanning...
Aug 31 15:03:27 machine wireplumber[1041]: D mod.protocol-native [connection.c:278:clear_buffer]: 0x5569364c2940 clear fds:0 n_fds:0
Aug 31 15:03:27 machine wireplumber[1041]: D wp-registry [registry.c:105:registry_global]: <WpCore:0x5569364a28a0> global:72 perm:0x1c8 type:PipeWire:Interface:Client/3 -> WpClient
Aug 31 15:03:27 machine wireplumber[1041]: D wp-registry [registry.c:342:wp_registry_prepare_new_global]: <WpCore:0x5569364a28a0> new WpGlobal:72 type:WpClient proxy:(nil)
Aug 31 15:03:27 machine wireplumber[1041]: D mod.protocol-native [connection.c:278:clear_buffer]: 0x5569365c5220 clear fds:0 n_fds:0
Aug 31 15:03:27 machine wireplumber[1041]: D wp-registry [registry.c:105:registry_global]: <WpCore:0x5569365b1690> global:72 perm:0x1c8 type:PipeWire:Interface:Client/3 -> WpClient
Aug 31 15:03:27 machine wireplumber[1041]: D wp-registry [registry.c:342:wp_registry_prepare_new_global]: <WpCore:0x5569365b1690> new WpGlobal:72 type:WpClient proxy:(nil)
Aug 31 15:03:27 machine wireplumber[1041]: D wp-registry [registry.c:262:expose_tmp_globals]: <WpCore:0x5569364a28a0> exposing 1 new globals
Aug 31 15:03:27 machine wireplumber[1041]: D wp-registry [registry.c:262:expose_tmp_globals]: <WpCore:0x5569365b1690> exposing 1 new globals
Aug 31 15:03:27 machine wireplumber[1041]: D pw.proxy [proxy.c:92:pw_proxy_new]: 0x5569367dc6f0: new 46 type PipeWire:Interface:Client/3 core-proxy:0x5569364c1b20, marshal:0x7f46bbc25d40
Aug 31 15:03:27 machine wireplumber[1041]: D pw.core [core.c:86:core_event_bound_id]: 0x5569364c1b20: proxy id 46 bound 72
Aug 31 15:03:27 machine wireplumber[1041]: D pw.proxy [proxy.c:143:pw_proxy_set_bound_id]: 0x5569367dc6f0: id:46 bound:72
Aug 31 15:03:27 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpClient:72:0x5569366ea270> features changed 0x0 -> 0x1
Aug 31 15:03:27 machine wireplumber[1041]: D pw.core [core.c:115:core_event_bound_props]: 0x5569364c1b20: proxy id 46 bound 72
Aug 31 15:03:27 machine wireplumber[1041]: D wp-pw-obj-mixin [pipewire-object-mixin.c:734:wp_pw_object_mixin_handle_event_info]: <WpClient:72:0x5569366ea270> info, change_mask:0x1 [props,]
Aug 31 15:03:27 machine wireplumber[1041]: D wp-object [object.c:613:wp_object_update_features]: <WpClient:72:0x5569366ea270> features changed 0x1 -> 0x11
Aug 31 15:03:27 machine wireplumber[1041]: D s-client [access-default.lua:85:chunk]: <WpClient:72:0x5569366ea270> No rule for client 72 (access unrestricted)
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:95:impl_add_listener]: metadata 0x5569364f1bc0:
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 bluetooth.use-persistent-storage Spa:String:JSON {
                                                           description = "Whether to use persistent BT storage or not"
                                                           type = "bool"
                                                           default = true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 bluetooth.autoswitch-to-headset-profile Spa:String:JSON {
                                                           description = "Whether to autoswitch to BT headset profile or not"
                                                           type = "bool"
                                                           default = true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 device.restore-profile Spa:String:JSON {
                                                           description = "Whether to restore device profile or not"
                                                           type = "bool"
                                                           default = true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 device.restore-routes Spa:String:JSON {
                                                           description = "Whether to restore device routes or not"
                                                           type = "bool"
                                                           default = true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 device.routes.default-sink-volume Spa:String:JSON {
                                                           description = "The default volume for sink devices"
                                                           type = "float"
                                                           default = 0.064
                                                           min = 0.0
                                                           max = 1.0
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 device.routes.default-source-volume Spa:String:JSON {
                                                           description = "The default volume for source devices"
                                                           type = "float"
                                                           default = 1.0
                                                           min = 0.0
                                                           max = 1.0
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 linking.role-based.duck-level Spa:String:JSON {
                                                           description = "The volume level to apply when ducking (= reducing volume for a higher priority stream to be audible) in the role-based linking policy"
                                                           type = "float"
                                                           default = 0.3
                                                           min = 0.0
                                                           max = 1.0
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 linking.allow-moving-streams Spa:String:JSON {
                                                           description = "Whether to allow metadata to move streams at runtime or not"
                                                           type = "bool"
                                                           default = true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 linking.follow-default-target Spa:String:JSON {
                                                           description = "Whether to allow streams follow the default device or not"
                                                           type = "bool"
                                                           default = true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 monitor.camera-discovery-timeout Spa:String:JSON {
                                                           description = "The camera discovery timeout in milliseconds"
                                                           type = "int"
                                                           default = 1000
                                                           min = 0
                                                           max = 60000
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 node.features.audio.no-dsp Spa:String:JSON {
                                                           description = "Whether to never convert audio to F32 format or not"
                                                           type = "bool"
                                                           default = false
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 node.features.audio.monitor-ports Spa:String:JSON {
                                                           description = "Whether to enable monitor ports on audio nodes or not"
                                                           type = "bool"
                                                           default = true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 node.features.audio.control-port Spa:String:JSON {
                                                           description = "Whether to enable control ports on audio nodes or not"
                                                           type = "bool"
                                                           default = false
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 node.stream.restore-props Spa:String:JSON {
                                                           description = "Whether to restore properties on stream nodes or not"
                                                           type = "bool"
                                                           default = true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 node.stream.restore-target Spa:String:JSON {
                                                           description = "Whether to restore target on stream nodes or not"
                                                           type = "bool"
                                                           default = true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 node.stream.default-playback-volume Spa:String:JSON {
                                                           description = "The default volume for playback nodes"
                                                           type = "float"
                                                           default = 1.0
                                                           min = 0.0
                                                           max = 1.0
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 node.stream.default-capture-volume Spa:String:JSON {
                                                           description = "The default volume for capture nodes"
                                                           type = "float"
                                                           default = 1.0
                                                           min = 0.0
                                                           max = 1.0
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 node.stream.default-media-role Spa:String:JSON {
                                                           description = "A media.role to assign on streams that have none specified"
                                                           type = "string"
                                                           default = null
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 node.filter.forward-format Spa:String:JSON {
                                                           description = "Whether to forward format on filter nodes or not"
                                                           type = "bool"
                                                           default = false
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x5569364f1bc0: 0 node.restore-default-targets Spa:String:JSON {
                                                           description = "Whether to restore default targets or not"
                                                           type = "bool"
                                                           default = true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.core [core.c:41:core_event_ping]: 0x5569364c1b20: object 3 ping 1073743822
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:95:impl_add_listener]: metadata 0x5569364ff020:
Aug 31 15:03:27 machine wireplumber[1041]: D pw.core [core.c:41:core_event_ping]: 0x5569364c1b20: object 4 ping 1073743824
Aug 31 15:03:27 machine wireplumber[1041]: D m-standard-event-source [module-standard-event-source.c:239:wp_standard_event_source_create_event]: <WpStandardEventSource:0x556936596d30> pushing event 'client-added', prio 200, subject <WpClient:0x5569366ea270> (client)
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:95:impl_add_listener]: metadata 0x556936500110:
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 bluetooth.use-persistent-storage Spa:String:JSON true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 bluetooth.autoswitch-to-headset-profile Spa:String:JSON true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 device.restore-profile Spa:String:JSON true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 device.restore-routes Spa:String:JSON true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 device.routes.default-sink-volume Spa:String:JSON 0.064
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 device.routes.default-source-volume Spa:String:JSON 1.0
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 linking.role-based.duck-level Spa:String:JSON 0.3
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 linking.allow-moving-streams Spa:String:JSON true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 linking.follow-default-target Spa:String:JSON true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 monitor.camera-discovery-timeout Spa:String:JSON 1000
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 node.features.audio.no-dsp Spa:String:JSON false
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 node.features.audio.monitor-ports Spa:String:JSON true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 node.features.audio.control-port Spa:String:JSON false
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 node.stream.restore-props Spa:String:JSON true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 node.stream.restore-target Spa:String:JSON true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 node.stream.default-playback-volume Spa:String:JSON 1.0
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 node.stream.default-capture-volume Spa:String:JSON 1.0
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 node.stream.default-media-role Spa:String:JSON null
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 node.filter.forward-format Spa:String:JSON false
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936500110: 0 node.restore-default-targets Spa:String:JSON true
Aug 31 15:03:27 machine wireplumber[1041]: D pw.core [core.c:41:core_event_ping]: 0x5569364c1b20: object 5 ping 1073743826
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:95:impl_add_listener]: metadata 0x556936581d70:
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936581d70: 0 default.configured.audio.sink Spa:String:JSON {"name":"alsa_output.pci-0000_01_00.1.hdmi-stereo"}
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936581d70: 0 default.audio.sink Spa:String:JSON {"name":"alsa_output.pci-0000_01_00.1.hdmi-stereo"}
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936581d70: 0 default.audio.source Spa:String:JSON {"name":"alsa_input.pci-0000_00_1f.3.analog-stereo"}
Aug 31 15:03:27 machine wireplumber[1041]: D pw.metadata [impl-metadata.c:74:emit_properties]: metadata 0x556936581d70: 0 default.video.source Spa:String:JSON {"name":"v4l2_input.pci-0000_00_14.0-usb-0_5_1.0"}
Aug 31 15:03:27 machine wireplumber[1041]: D pw.core [core.c:41:core_event_ping]: 0x5569364c1b20: object 10 ping 1073743828
Aug 31 15:03:27 machine wireplumber[1041]: D wp-metadata [metadata.c:244:metadata_event_property]: <WpMetadata:31:0x5569364f3ca0> remove id:33 key:log.level
