I do not understand the error log and the current condition of my HDD:
- Is there any way to solve these error
- Can I continue using this HDD or should I change it immediately ?
Error Logs :
Complete error log:
SMART Extended Comprehensive Error Log Version: 1 (2 sectors)
Device Error Count: 206 (device log contains only the most recent 8 errors)
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 206 [5] occurred at disk power-on lifetime: 12014 hours (500 days + 14 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 41 00 08 00 00 00 22 f2 f8 40 00 Error: UNC at LBA = 0x0022f2f8 = 2290424
Commands leading to the command that caused the error were:
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
60 00 00 00 08 00 00 00 22 f2 f8 40 08 00:00:00.123 READ FPDMA QUEUED
60 00 00 00 08 00 00 00 22 f2 f8 40 08 00:00:00.161 READ FPDMA QUEUED
27 00 00 00 00 00 00 00 00 00 00 e0 08 00:00:00.161 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
ec 00 00 00 00 00 00 00 00 00 00 a0 08 00:00:00.161 IDENTIFY DEVICE
ef 00 03 00 46 00 00 00 00 00 00 a0 08 00:00:00.161 SET FEATURES [Set transfer mode]
Error 205 [4] occurred at disk power-on lifetime: 12014 hours (500 days + 14 hours)
60 00 da 00 08 00 00 00 22 f2 f8 40 08 00:00:00.121 READ FPDMA QUEUED
60 00 00 00 08 00 00 00 22 f2 f8 40 08 00:00:00.159 READ FPDMA QUEUED
27 00 00 00 00 00 00 00 00 00 00 e0 08 00:00:00.159 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
ec 00 00 00 00 00 00 00 00 00 00 a0 08 00:00:00.159 IDENTIFY DEVICE
ef 00 03 00 46 00 00 00 00 00 00 a0 08 00:00:00.159 SET FEATURES [Set transfer mode]
Error 204 [3] occurred at disk power-on lifetime: 12014 hours (500 days + 14 hours)
60 00 00 00 08 00 00 00 22 f2 f8 40 08 00:00:00.157 READ FPDMA QUEUED
60 00 00 00 20 00 00 00 22 f1 28 40 08 00:00:00.157 READ FPDMA QUEUED
60 00 da 00 08 00 00 00 22 f1 20 40 08 00:00:00.157 READ FPDMA QUEUED
60 00 00 00 08 00 00 00 22 f0 d0 40 08 00:00:00.157 READ FPDMA QUEUED
Error 203 [2] occurred at disk power-on lifetime: 12014 hours (500 days + 14 hours)
60 00 da 00 08 00 00 00 22 f2 f8 40 08 00:00:00.082 READ FPDMA QUEUED
60 00 00 00 08 00 00 00 22 f2 f8 40 08 00:00:00.126 READ FPDMA QUEUED
27 00 00 00 00 00 00 00 00 00 00 e0 08 00:00:00.126 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
ec 00 00 00 00 00 00 00 00 00 00 a0 08 00:00:00.126 IDENTIFY DEVICE
ef 00 03 00 46 00 00 00 00 00 00 a0 08 00:00:00.126 SET FEATURES [Set transfer mode]
Error 202 [1] occurred at disk power-on lifetime: 12014 hours (500 days + 14 hours)
60 00 da 00 08 00 00 00 22 f2 f8 40 08 00:00:00.043 READ FPDMA QUEUED
27 00 00 00 00 00 00 00 00 00 00 e0 08 00:00:00.123 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
ec 00 00 00 00 00 00 00 00 00 00 a0 08 00:00:00.123 IDENTIFY DEVICE
ef 00 03 00 46 00 00 00 00 00 00 a0 08 00:00:00.123 SET FEATURES [Set transfer mode]
Error 201 [0] occurred at disk power-on lifetime: 12014 hours (500 days + 14 hours)
60 00 da 00 20 00 00 00 22 f1 28 40 08 00:00:00.121 READ FPDMA QUEUED
60 00 da 00 08 00 00 00 22 f1 20 40 08 00:00:00.121 READ FPDMA QUEUED
60 00 da 00 08 00 00 00 22 f0 d0 40 08 00:00:00.121 READ FPDMA QUEUED
Error 200 [7] occurred at disk power-on lifetime: 12014 hours (500 days + 14 hours)
60 00 00 00 08 00 00 00 22 f2 f8 40 08 00:00:00.029 READ FPDMA QUEUED
60 00 00 00 08 00 00 00 22 f3 e8 40 08 00:00:00.029 READ FPDMA QUEUED
60 00 00 00 08 00 00 00 22 f3 e0 40 08 00:00:00.029 READ FPDMA QUEUED
60 00 00 00 08 00 00 00 22 f3 d8 40 08 00:00:00.029 READ FPDMA QUEUED
60 00 00 00 08 00 00 00 22 f3 d0 40 08 00:00:00.029 READ FPDMA QUEUED
Error 199 [6] occurred at disk power-on lifetime: 12014 hours (500 days + 14 hours)
60 00 00 00 08 00 00 00 22 f2 f8 40 08 00:00:00.057 READ FPDMA QUEUED
60 00 00 00 08 00 00 00 22 f3 08 40 08 00:00:00.088 READ FPDMA QUEUED
60 00 00 00 08 00 00 00 22 f4 48 40 08 00:00:00.088 READ FPDMA QUEUED
60 00 00 00 08 00 00 00 22 f3 18 40 08 00:00:00.088 READ FPDMA QUEUED
60 00 00 00 08 00 00 00 22 f3 10 40 08 00:00:00.088 READ FPDMA QUEUED
Welcome to Manjaro!
