Having issue with no display on login greeter or tty
I have been having an incredibly frustrating issue where my computer will boot normally, but when it gets to the login window there is simply no display. I can blindly type in my password and hit enter and it will load my desktop and everything will be fine, however it’s a bit more challenging if another user wants to log in.
Once logged in the display drivers work fine.
The issue began after I changed my setup from dual monitors to single. Even though the single monitor I’m using now was always the primary, for a while it was sending the login dialogue to the other monitor and eventually stopped showing anything on the primary until I was logged in.
I was on linux 6.6, then did a timeshift to three weeks ago which corrected the problem, but it reverted a number of critical updates which after bringing the system back up to date the problem returned.
Attempting to ignore updates that could’ve potentially been causing the problem resulted in more severe issues that prevented the desktop from loading at all.
At a certain point timeshift was no longer helping and TTY started having this problem too. I’ve spent almost 24 continuous hours trying to correct this problem with some assistance from chat gpt but to no avail.
The current status of my computer is the desktop is working and can be loaded by blindly entering the password, but TTY will not load at all, it just gives no output until I switch back to the GUI.
I asked ChatGPT to generate a summary of everything that I have tried so far including log outputs and system specs so I can share as much info as possible here. See below for that:
EDIT: I just discovered that when waking the computer from a suspended state it is able to display the lock screen without issue.
ChatGPT - Display Issue Summary
System Summary
Distro: Manjaro Linux (Cinnamon Edition)
Display Manager: LightDM (lightdm-slick-greeter) → briefly switched to SDDM for testing
Kernel History:
  • Working: 6.1 LTS
  • Problematic: 6.6 series
  • Currently installed: 6.12 LTS
    GPU: NVIDIA proprietary driver (video-nvidia 2024.05.03)
    Boot Mode: UEFI
    Root partition: /dev/nvme0n1p2 (ext4)
    Timeshift: BTRFS snapshots used; last confirmed working snapshot restored successfully.
Problem Description
After a system update (sudo pacman -Syu) the LightDM greeter no longer displays video output.
Symptoms:
  • Monitor reports no signal when LightDM or any TTY (Ctrl + Alt + Fx) should appear.
  • Entering password blindly logs into the desktop successfully.
  • Once in the desktop, display functions normally.
  • The issue reproduces across kernels 6.6 and 6.12.
  • TTYs are also affected — blank screen/no signal, although keyboard input is accepted.
  • The GPU otherwise works fine inside the desktop session (3D acceleration, games, etc.).
Key Logs
/var/log/lightdm/xrandr-before.log and xrandr-after.log
Show single monitor connected via HDMI-0 at 3840×2160 @ 59.94 Hz — no DP outputs active.
No configuration differences before/after greeter start.
pacman -Q | grep nvidia
lib32-nvidia-utils 580.82.09-1
linux61-nvidia 580.82.09-3
linux66-nvidia 580.82.09-3
linux515-nvidia 580.82.09-2
nvidia-settings 580.82.09-1
opencl-nvidia 580.82.09-1
(Driver 580 series.)
Actions Attempted
Kernel & Driver
  • Reverted via Timeshift → issue resolved temporarily.
  • Updating system again reintroduced the issue.
  • Downgraded NVIDIA stack initially (blocked ALA access on stable).
  • Tried kernel 6.1, 6.6, and 6.12 LTS; issue persists across all once updated.
Display Manager
  • Verified /etc/lightdm/lightdm.confgreeter-session=lightdm-slick-greeter.
  • Confirmed session-wrapper=/etc/lightdm/Xsession.
  • Tested adding:
    • logind-check-graphical=true → no effect.
    • Custom greeter-setup-script forcing xrandr --output HDMI-0 --mode 3840x2160 --rate 59.94 → no effect.
  • Switched temporarily to SDDM → system hung at greeter (no signal + input freeze).
    • Reverted symlink /etc/systemd/system/display-manager.service back to LightDM.
TTY / Recovery
  • TTYs (Ctrl + Alt + Fx) yield black screen/no signal even though the system remains responsive.
  • Only accessible via blind login or chroot from live USB.
  • Timeshift restores functional system, confirming display stack breakage is software-level.
Miscellaneous
  • Flatpak and AUR updates completed afterward — no change.
  • mhwd -li reports video-nvidia 2024.05.03 installed, no conflicting drivers.
  • lightdm --show-config confirms correct greeter/session wrapper paths.
  • Display works flawlessly once inside Cinnamon session.
Hypothesis
Something in the LightDM greeter or NVIDIA driver initialization fails during VT switch from Plymouth (or kernel console) to the X11 greeter.
TTYs also black out, suggesting a KMS / VT / framebuffer handoff bug introduced in newer NVIDIA 580 series or Xorg 21.1.15 + firmware 20250917.
Kernel 6.1 + old NVIDIA worked; any newer driver breaks both greeter and TTY video.
Information Needed / Help Requested
  1. Has anyone encountered no-signal on greeter + TTY with NVIDIA 580 drivers on Manjaro 6.1/6.12?
  2. Is there a known regression involving LightDM + nvidia-drm.modeset=1 or console handoff?
  3. What’s the recommended way to force LightDM to reinitialize display after VT handoff?
  4. Should nvidia-drm.modeset=0 or a specific kernel parameter be applied?
  5. Any confirmed workarounds beyond downgrading NVIDIA drivers (since ALA is disabled)?
Mod Edit: Formatted for better readability. :wink:
Mod edit:- General tidy of AI generated information.
Can you please explain how ChatGPT was able to collect the required information for such a report? Also, please provide output of
inxi -zv8
I explained the situation I was in to Chatgpt, it offered suggestions, I tried different ones and told it what worked and what didn’t, I gave it the log files and error reports for interpretations, so by the end of the conversation it had a pretty good idea of the process I went through, what I tried, what I had discovered and of course the drivers and other specs I was working with.
As for your request here is the output:
$ inxi -zv8
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=54863de4-0ca3-4508-b634-f7d5eb9fe747 rw quiet apparmor=1
    security=apparmor resume=UUID=29eb334c-60e3-439c-a12b-7e0667d31429
    udev.log_priority=3
  Desktop: Cinnamon v: 6.4.12 tk: GTK v: 3.24.50 wm: Muffin v: 6.4.1 tools:
    avail: cinnamon-screensaver vt: 7 dm: 1: LightDM v: 1.32.0 2: SDDM
    note: stopped Distro: Manjaro base: Arch Linux
  Type: Desktop System: Gigabyte product: Z370 AORUS Gaming 5 v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: Z370 AORUS Gaming 5-CF v: x.x
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: F5 date: 03/02/2018
  System RAM: total: 32 GiB available: 31.29 GiB used: 3.41 GiB (10.9%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3000C16-8GTZR serial: N/A
  Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous unbuffered
    part-no: F4-3200C16-8GTZR serial: N/A
  Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
  Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous unbuffered
  Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 88824
    dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: NVIDIA AD104 [GeForce RTX 4070] vendor: Micro-Star MSI
    driver: nvidia v: 580.82.09 alternate: nouveau,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-08) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
    chip-ID: 10de:2786 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8 driver: X:
    loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 68 s-size: 1434x807mm (56.46x31.77")
    s-diag: 1645mm (64.78")
  Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Samsung
    serial: <filter> built: 2020 res: N/A dpi: 69 gamma: 1.2 chroma: red:
    x: 0.671 y: 0.314 green: x: 0.271 y: 0.647 blue: x: 0.153 y: 0.051 white:
    x: 0.282 y: 0.282 size: 1420x800mm (55.91x31.5") diag: 1630mm (64.2")
    ratio: 16:9 modes: 3840x2160, 4096x2160, 2560x1440, 1920x1080, 1680x1050,
    1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
    800x600, 720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 95 2: parse_edid:
    unhandled CEA mode 93 3: parse_edid: unhandled CEA mode 94 4: parse_edid:
    unhandled CEA mode 98 5: parse_edid: unhandled CEA mode 100
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.82.09
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070/PCIe/SSE2
    memory: 11.71 GiB
  API: Vulkan v: 1.4.321 layers: 6 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 4070 driver: nvidia v: 580.82.09
    device-ID: 10de:2786 surfaces: N/A
  Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a2f0 class-ID: 0403
  Device-2: NVIDIA AD104 High Definition Audio vendor: Micro-Star MSI
    link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:22bc
    class-ID: 0403
  Device-3: Realtek USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:6
    chip-ID: 0bda:4809 class-ID: 0300
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:3165 class-ID: 0280
  IF: wlp9s0 state: down mac: <filter>
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 8087:0a2a
    class-ID: e001
  Local Storage: total: 4.89 TiB used: 1.3 TiB (26.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS2000GB
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: S8442101 temp: 44.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3250410AS
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
    tech: N/A serial: <filter> fw-rev: C scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HUA723020ALA641
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: A840 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: SV300S37A120G
    size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: BBF0 scheme: MBR
  ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: BarraCuda 120 SSD
    ZA1000CM10003 size: 931.51 GiB block-size: physical: 512 B logical: 512 B
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: D013 scheme: GPT
  ID-6: /dev/sde maj-min: 8:64 vendor: Verbatim model: Store n Go Drive
    size: 7.5 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 2.00
    scheme: MBR
  ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 1.3 TiB (73.9%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 54863de4-0ca3-4508-b634-f7d5eb9fe747
    used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: A82C-ADFC
  ID-1: swap-1 type: partition size: 34.43 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 29eb334c-60e3-439c-a12b-7e0667d31429
  ID-1: /dev/sda1 maj-min: 8:1 size: 232.88 GiB fs: ntfs label: N/A
    uuid: 1A82367982365A09
  ID-2: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sdb2 maj-min: 8:18 size: 932.89 GiB fs: ntfs label: N/A
    uuid: DED6FAE4D6FABBB9
  ID-4: /dev/sdb3 maj-min: 8:19 size: 930.11 GiB fs: ntfs label: Archive
    uuid: 264078ED4078C559
  ID-5: /dev/sdc1 maj-min: 8:33 size: 350 MiB fs: ntfs
    label: System Reserved uuid: E05E30195E2FE74E
  ID-6: /dev/sdc2 maj-min: 8:34 size: 110.61 GiB fs: ntfs label: N/A
    uuid: 9E3C41983C416BF9
  ID-7: /dev/sdc3 maj-min: 8:35 size: 856 MiB fs: ntfs label: N/A
    uuid: 408E8F248E8F1198
  ID-8: /dev/sdd1 maj-min: 8:49 size: 16 MiB fs: <superuser required>
  ID-9: /dev/sdd2 maj-min: 8:50 size: 931.5 GiB fs: ntfs label: New Volume
    uuid: 16AAE6D3AAE6AE85
  ID-10: /dev/sde1 maj-min: 8:65 size: 3.59 GiB fs: iso9660
  ID-11: /dev/sde2 maj-min: 8:66 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 1517-A94A
  Device-1: 1-2:2 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
  Device-2: 1-3:3 info: Logitech Gaming Mouse G300 type: mouse,keyboard
    lanes: 1 mode: 1.1 power: 200mA chip-ID: 046d:c246 class-ID: 0300
  Device-3: 1-4:4 info: Logitech G213 Prodigy Gaming Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c336 class-ID: 0300 serial: <filter>
  Hub-2: 1-5:5 info: Terminus Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-5.1:7 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-5.2:9 info: DaKai 2.4G RX type: keyboard,mouse
    chip-ID: 08c5:00cb class-ID: 0301
  Device-3: 1-6:6 info: Realtek USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  Device-4: 1-7:8 info: Verbatim Store n Go Clip-it Drive type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 100mA chip-ID: 18a5:0238 class-ID: 0806
    serial: <filter>
  Device-5: 1-13:10 info: Canon GX1000 series type: printer driver: usblp
    interfaces: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 2mA chip-ID: 04a9:110b class-ID: 0701 serial: <filter>
  Device-6: 1-14:11 info: YK 2.4G Wireless Device type: mouse,keyboard
    chip-ID: 3938:1080 class-ID: 0301
  Hub-3: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 42 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Packages: 1989 pm: pacman pkgs: 1941 libs: 545 tools: pamac,trizen,yay
    pm: flatpak pkgs: 48
    1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    2: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    3: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirrors2.manjaro.org/stable/$repo/$arch
    5: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    6: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    7: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    8: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
Processes:
  CPU top: 5 of 317
  1: cpu: 8.3% command: firefox pid: 3038 mem: 859.2 MiB (2.6%)
  2: cpu: 5.0% command: xfce4-terminal pid: 19034 mem: 98.0 MiB (0.3%)
  3: cpu: 3.1% command: cinnamon pid: 1747 mem: 501.3 MiB (1.5%)
  4: cpu: 2.3% command: firefox pid: 3318 mem: 398.0 MiB (1.2%)
  5: cpu: 1.1% command: firefox pid: 3140 mem: 73.4 MiB (0.2%)
  Memory top: 5 of 317
  1: mem: 859.2 MiB (2.6%) command: firefox pid: 3038 cpu: 8.3%
  2: mem: 501.3 MiB (1.5%) command: cinnamon pid: 1747 cpu: 3.1%
  3: mem: 476.3 MiB (1.4%) command: firefox pid: 3208 cpu: 0.5%
  4: mem: 398.0 MiB (1.2%) command: firefox pid: 3318 cpu: 2.3%
  5: mem: 259.6 MiB (0.8%) command: dropbox pid: 2031 cpu: 0.1%
  Processes: 317 Power: uptime: 3h 20m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.49 GiB services: csd-power,upowerd
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3
    running-in: xfce4-terminal inxi: 3.3.39
Why not install 570xx drivers instead of the latest 580xx?
Have you tried in a TTY
sudo systemctl enable sddm.service
Please provide output of
sudo journalctl -u sddm
Also provide your SDDM’s configuration file’s settings.
Switching to a standard theme also could be helpful.
It could be also worth trying to create a new user and see if the issue persists with the new user as well.
In my case, I have deleted everything in /etc/X11/xorg.conf.d/* Reboot and it works.
but 00-keyboard.conf You are gonna still need.
So if you want to try that, you could backup all does files, and reboot.
If everything works now, you could bring back every single file one by one after each reboot, and let us know which files break the login process.
sudo mkdir /etc/X11/xorg.conf.d_backup
sudo mv /etc/X11/xorg.conf.d/* /etc/X11/xorg.conf.d_backup
I did try enabling the sddm service, and when I got to the login screen the system completely froze (still with no display), even the power button did not respond and I had to do a forced shutdown
$ sudo journalctl -u sddm
Oct 06 12:05:55 Polaris systemd[1]: Started Simple Desktop Display Manager.
Oct 06 12:05:55 Polaris sddm[1344]: Initializing...
Oct 06 12:05:55 Polaris sddm[1344]: Starting...
Oct 06 12:05:55 Polaris sddm[1344]: Logind interface found
Oct 06 12:05:55 Polaris sddm[1344]: Adding new display...
Oct 06 12:05:55 Polaris sddm[1344]: Loaded empty theme configuration
Oct 06 12:05:55 Polaris sddm[1344]: Xauthority path: "/run/sddm/xauth_HOPsFP"
Oct 06 12:05:55 Polaris sddm[1344]: Using VT 2
Oct 06 12:05:55 Polaris sddm[1344]: Display server starting...
Oct 06 12:05:55 Polaris sddm[1344]: Writing cookie to "/run/sddm/xauth_HOPsFP"
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -aut>
Oct 06 12:05:58 Polaris sddm[1344]: Setting default cursor
Oct 06 12:05:58 Polaris sddm[1344]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Oct 06 12:05:58 Polaris sddm[1344]: Display server started.
Oct 06 12:05:58 Polaris sddm[1344]: Socket server starting...
Oct 06 12:05:58 Polaris sddm[1344]: Socket server started.
Oct 06 12:05:58 Polaris sddm[1344]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.c>
Oct 06 12:05:58 Polaris sddm[1344]: Greeter starting...
Oct 06 12:05:58 Polaris sddm-helper[1428]: [PAM] Starting...
Oct 06 12:05:58 Polaris sddm-helper[1428]: [PAM] Authenticating...
Oct 06 12:05:58 Polaris sddm-helper[1428]: [PAM] returning.
Oct 06 12:05:58 Polaris sddm-helper[1428]: pam_unix(sddm-greeter:session): session opened for user sddm(uid>
Oct 06 12:05:58 Polaris sddm-helper[1428]: Writing cookie to "/tmp/xauth_uIAGnk"
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth >
Oct 06 12:05:58 Polaris sddm[1344]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.con>
Oct 06 12:05:58 Polaris sddm-helper[1428]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=9>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /ru>
Oct 06 12:05:58 Polaris sddm[1344]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
Oct 06 12:05:58 Polaris sddm-helper[1428]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=963)>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/s>
Oct 06 12:05:58 Polaris sddm-helper[1428]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=963) by>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/>
Oct 06 12:05:58 Polaris sddm-helper[1428]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=963) by (ui>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xau>
Oct 06 12:05:58 Polaris sddm-helper[1428]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=963) by (uid=0)
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_HO>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_HOP>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_HOPs>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_HOPsF>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_HOPsFP>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_HOPsFP ->
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_HOPsFP -n>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_HOPsFP -no>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_HOPsFP -nor>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_HOPsFP -nores>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_HOPsFP -noreset>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_HOPsFP -noreset -d>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_HOPsFP -noreset -dis>
lines 1-23
Oct 06 12:05:55 Polaris sddm[1344]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_HOPsFP -noreset -disp>
Edit: Forgot to include sddm setting info…
$ sudo cat /usr/lib/sddm/sddm.conf.d/*.conf /etc/sddm.conf /etc/sddm.conf.d/*.conf
[Autologin]
# Whether sddm should automatically log back into sessions when they exit
Relogin=false
# Name of session file for autologin session (if empty try last logged in)
Session=
# Username for autologin session
User=
[General]
# Which display server should be used.
# Valid values are: x11, x11-user, wayland. Wayland support is experimental
DisplayServer=x11
# Comma-separated list of environment variables to be set
GreeterEnvironment=
# Halt command
HaltCommand=/usr/bin/systemctl poweroff
# Input method module
InputMethod=
# Comma-separated list of Linux namespaces for user session to enter
Namespaces=
# Initial NumLock state. Can be on, off or none.
# If property is set to none, numlock won't be changed
# NOTE: Currently ignored if autologin is enabled.
Numlock=none
# Reboot command
RebootCommand=/usr/bin/systemctl reboot
[Theme]
# Current theme name
Current=
# Cursor size used in the greeter
CursorSize=
# Cursor theme used in the greeter
CursorTheme=
# Number of users to use as threshold
# above which avatars are disabled
# unless explicitly enabled with EnableAvatars
DisableAvatarsThreshold=7
# Enable display of custom user avatars
EnableAvatars=true
# Global directory for user avatars
# The files should be named <username>.face.icon
FacesDir=/usr/share/sddm/faces
# Font used in the greeter
Font=
# Theme directory path
ThemeDir=/usr/share/sddm/themes
[Users]
# Default $PATH for logged in users
DefaultPath=/usr/local/sbin:/usr/local/bin:/usr/bin
# Comma-separated list of shells.
# Users with these shells as their default won't be listed
HideShells=
# Comma-separated list of users that should not be listed
HideUsers=
# Maximum user id for displayed users
MaximumUid=60513
# Minimum user id for displayed users
MinimumUid=1000
# Remember the session of the last successfully logged in user
RememberLastSession=true
# Remember the last successfully logged in user
RememberLastUser=true
# When logging in as the same user twice, restore the original session, rather than create a new one
ReuseSession=true
[Wayland]
# Path of the Wayland compositor to execute when starting the greeter
CompositorCommand=weston --shell=kiosk
# Enable Qt's automatic high-DPI scaling
EnableHiDPI=true
# Path to a script to execute when starting the desktop session
SessionCommand=/usr/share/sddm/scripts/wayland-session
# Comma-separated list of directories containing available Wayland sessions
SessionDir=/usr/local/share/wayland-sessions,/usr/share/wayland-sessions
# Path to the user session log file
SessionLogFile=.local/share/sddm/wayland-session.log
[X11]
# Path to a script to execute when starting the display server
DisplayCommand=/usr/share/sddm/scripts/Xsetup
# Path to a script to execute when stopping the display server
DisplayStopCommand=/usr/share/sddm/scripts/Xstop
EnableHiDPI=true
# Arguments passed to the X server invocation
ServerArguments=-nolisten tcp
# Path to X server binary
ServerPath=/usr/bin/X
SessionCommand=/usr/share/sddm/scripts/Xsession
# Comma-separated list of directories containing available X sessions
SessionDir=/usr/local/share/xsessions,/usr/share/xsessions
SessionLogFile=.local/share/sddm/xorg-session.log
# Path to Xephyr binary
XephyrPath=/usr/bin/Xephyr
[Autologin]
Relogin=false
Session=plasma
[General]
InputMethod=
Numlock=on
[Theme]
Current=breath
CursorTheme=breeze_cursors
EnableAvatars=true
[Users]
HideShells=
HideUsers=
MaximumUid=60000
MinimumUid=1000
ReuseSession=false
[Wayland]
EnableHiDPI=false
SessionDir=/usr/share/wayland-sessions
[X11]
EnableHiDPI=false
MinimumVT=1
SessionDir=/usr/share/xsessions
UserAuthFile=.Xauthority
XauthPath=/usr/bin/xauth
[Theme]
Current=breath
InputMethod=qtvirtualkeyboard
Is this situation a known issue with 580xx? I did do a timeshift that brought me back to 550xx at one point and it resolved the issue, but that left me with a number of packages that wouldn’t run unless I updated them and trying to update my packages without updating the drivers caused a number of dependency conflicts that prevented Manjaro from booting past GRUB. Admittedly that was probably user error though
I gave that a try, I deleted everything in the X11 folder except the xinit folder and nothing changed
Not specifically, as far as I’m aware.
However, to quote my late Father;
“Just because the thing is new doesn’t mean it’s good”.
570xx has at least had some time to prove itself – in your position I’d give the suggestion from @philm some serious consideration:
Frankly I’m a little bit nervous to try downgrading the driver as I already tried that once and ended up somehow breaking everything (including timeshift) to the point where I had to manually repair the system from a live usb. Part of the problem is that a symptom of this driver issue is that TTY is also not working, which means if Manjaro fails to load I basically have to repair it from a live usb. I’ll try it again if that’s the best chance I have of fixing this issue, but I want to make sure I’m doing it right. I read through this thread and it looked like the recommendation was to run sudo manjaro-downgrade nvidia, select the package I want (which in my case would be 575.64.05) and after running that I should sudo mkinitcpio -P then sudo update-grub and reboot.
My understanding however was that this utility did not include dependencies in the downgrade process, so wouldn’t there be other packages I would also need to downgrade?
I think before installing it will ask for the old versions. But this is exactly the problem with downgrading and why it leads to an unsupported state. The old nvidia can need old dependency X., but something else can need the newer version ox X. It can very quickly become very messy.
Did you disable LightDM before enabling SDDM? If not, that was likely the reason for your crash.
Looking through your notes (above) it seems you brought most of that grief upon yourself – blindly following ChatGPT “suggestions” and random posts, with no clear idea of what you were doing – but, rest assured, you’re not the only one. :wink:
Booting with a Manjaro Installer USB and entering a chroot environment is an established method of performing maintenance outside of the running system. This should never be considered a last resort, but a necessary tool; users are encouraged to always have a very recent (if not the latest) USB on hand.
I’m not convinced that it is a driver issue, but then, I made a conscious decision over a decade ago to use AMD graphics exclusively, which means I’m rather out of touch with Nvidia of late. That their drivers are still giving grief to a major portion of Linux users is no surprise, however.
I seems like you have taken the wrong message away from that topic. If you had read much past the first few posts, you might have noticed several wanings about the procedures suggested;
More importantly, you missed the warnings from a Manjaro Team member:
And regarding official drivers downloaded directly from Nvidia;
If I recall, when installing another driver there were prompt(s) to replace/uninstall the previous – again, I haven’t used Nvidia in some time, so treat this with caution, and seek clarification.
The following Wiki page typically has all the information needed to install the best available drivers; rather obvious by it’s absence, you’ll notice that “downgrading” isn’t mentioned at all, for good reason:
There is also this – noticed in a recent Update announcement topic:
I presume this choice is given during install when a supported Nvidia GPU is used; and/or when updated versions of these series are made available through a normal update session.
I’m not aware of whether a new procedure exists for changing the driver series, post install. This might be something others could expand on.
Did you know that “NEW” is also an acronym for “Never Ever Worked”? :grin:
Yes - two competing display managers are never good - just one of the two should be active/enabled.
I do now. :wink:
Adding this as being possibly related (the OP describes “no display”):
I’m uncertain that this would still be relevant in Stable branch or if the OP might nonetheless still be affected by it.
Yes I did
I was aware that CHAT GPT could cause more problems, however the reason I went to it was because I had a problem that involved very specific circumstances and I couldn’t find any other threads where people had the same problem as me with the same symptoms. Despite Chat GPT sometimes giving bad advice, it did seem to be very effective as a diagnostic tool -interpereting log files, explaining what different commands do and what is actually happening behind the scenes when things aren’t working. Believe it or not I did actually learn a lot from Chat GPT about how to use different tools that previously I didn’t know how to use or didn’t know existed. This is all part of the learning curve for me.
If not a driver issue then what could it be? I have had a number of different issues with my pc over the years and the vast majority of the time it fell back to a bad nvidia driver update, so it doesn’t surprise me that this would also be a driver issue. I have used nvidia gpus because they are more familiar to me (maybe their naming schemes are just slightly easier to follow lol) but with the number of issues I have had with them it might be time to switch to amd for my next update
I do not believe this is the case, usually when going through the updates it just gives you the most recent version. I believe to install a different version you would have to explicitly install it and then blacklist the higher version to prevent it from updating to that when you install the rest of the updates. I do understand that downgrading drivers is not a recommended thing to do, however at this point it doesn’t seem like I have many other options. The only other Idea I have at this point is to try timeshift again and attempt to update everything other than the drivers. I’m not sure if that restore point I used last time is still working however, and I don’t know which updates to blacklist so that I can do this without breaking the system again. Last time I tried this it broke a lot of my applications, Firefox completely reset to default settings and somehow the backups didn’t work, I had to reinstall all my plugins and reconfigure their settings, reinstall all my bookmarks on my toolbar, reconfigure my preferences and find my themes all over again. I’d like to avoid having to do that again, but if it means fixing my computer then I would do it
Not being an Nvidia user, I can neither confirm or deny, but if it doesn’t work that way, perhaps it should. :man_shrugging:
Often, one of the problems with downgrading, blacklisting, and repeatedly restoring snapshots only to repeat the same process over and over again, is that we can be left in what’s generally referred to as an unsupported partial upgrade state where more problems might be caused than those one is attempting to fix.
This comment is why I suspect there might be other contributing factors;
You have sddm in the mix.
The following was listed in a recent Known Issues and Solutions section of an Update announcement:
SDDM may crash with Nvidia drivers
There was also the following in the Unstable or Testing branch.
It’s not mentioned whether you might have switched to another branch temporarily in an attempt to solve your issue; just as it’s uncertain whether this is still relevant in Stable, but the symptoms seem to potentially fit:
Graphical issues on older hardware (Black screen, Flickering) due to mesa 25.2.x update
Each major version, eg 570, 580, is a separate package, as such you only get updates to that version. You don’t get switched to a new major version during an update (at least not while the currently installed one is still in the repo).
For ease, from now on I’ll just call each major version a driver.
You use mhwd to install a driver, and when updates are available for that driver then it will be updated with the rest of the system.
mhwd -l   # list available drivers for your device
mhwd -li  # show installed driver
sudo mhwd -r pci video-nvidia       # remove old driver
sudo mhwd -i pci video-nvidia-570xx # install new driver
mhwd basically just automates the process of manually installing or removing a driver. If you prefer a GUI, then you can use the Manjaro Settings Manager to do it.
The commands above are in the “Configure Graphics Cards” wiki article that @soundofthunder linked to earlier in the thread.
