Ok so I tried using mhwd to install 570xx like you described, it went smoothly, 570 is installed, however it did not fix my issue unfortunately. Is it possible to go back to 550xx, or would that be likely to break things?
It looks like only 570xx, 575xx (and greater) drivers will support the GeForce RTX 4070, so 550xx is out of the proverbial ball park.
I note that your BIOS has updates available.
While an update may not magically fix the current issue, it’s nonetheless a consideration that might improve something related. The choice is yours.
The latest (non-Beta) BIOS for the Z370 AORUS Gaming 5 (rev. 1.0) appears to be F15. Search the Gigabyte site for instructions on how to apply it.
How can that be? I bought my 4070 about a week after it was released and the most current driver series was 515xx at the time. I was running 550xx until a few months ago when I started noticing this problem
Remember, these are the proprietary drivers from Nvidia, the only difference is that they are repackaged for Linux.
These are what I found on the Nvidia site that support the GeForce RTX 4070; there are no versions below 570.124.04 listed.
If what you say is accurate (and I have no reason to doubt it) then perhaps I’m wrong about that; Nvidia might have removed 550.xxx from their search results.
You haven’t responded regarding possibly updating the BIOS.
You claim the same issue arises with 580xx and now 570xx:
Here I see the 550xx mentioned and that a timeshift restore apparently “resolved the issue”. I suspect this may only be coincidence, however, you could arguably test that theory by following the same procedure used to install 570xx.
However…
Based on your comments I mentioned earlier that I suspect graphics might not be the issue;
If you manage to login and “everything is fine” then graphics are by definition fine too. That being the case, the issue must then be elsewhere – perhaps related to the LightDM or Greeter configurations – and these are things I’ve not toyed with in a long time.
Basically, you might be barking up the wrong tree, but of course, this is only conjecture until evidence either way can be found.
My guess then is they removed 550xx from the list because maybe they no longer officially provide support for it, but I most definitely did have the 4070 running on 550 and previous versions back to at least 515.
I am willing to give it a shot, but I have to apologize as I have been very busy lately, I just got married and I’m in the middle of a move so my life has been chaos. I’m trying to make as much time as I can to chip away at this problem but it’s been a challenge. I just need to find some time to update the bios and I’ll let you know how that goes. I do appreciate you taking the time to help me with this.
I suppose it may not technically be the graphics itself that is causing the issue but rather how the computer handles the output signals. During my diagnostics with Chat GPT it originally thought the issue was that lightDM was still trying to output the display to the second monitor which no longer exists. It believed the config file was corrupted and I tried deleting it and letting it rebuild but that did not fix the problem.
At one point during the troubleshooting I ran timeshift and the display was back to working order, the catch was all my applications were out of date. After doing sudo pacman -Syu the display problem returned. I do believe I was on 550xx before the update and 580xx after (and kernel 5.15, then 6.1 I believe), but I can’t say for a certainty. This led me to believe it was a driver update that was causing the problem.
I asked Chat GPT to write a brief summary of what it believes the problem is based on the troubleshooting that I did, I’m hoping this will be helpful information for you:
ChatGPT generated content
The Most Probable Root Cause
The login-screen display issue (no signal until you log in blindly) is almost certainly caused by a GPU mode-setting conflict between the NVIDIA driver and the display manager (LightDM/SDDM) during early X server initialization.
In plain terms:
When LightDM or SDDM starts, it asks the NVIDIA driver to set up a display output.
Your GPU does initialize, but the screen goes dark because the signal timing or mode chosen by the greeter doesn’t match what your monitor expects.
Once you log in and your desktop environment (Cinnamon) starts, a new X session is created that re-initializes the display correctly — which is why the desktop works fine after login.
Why This Happens Specifically on Your System
Several interacting factors make this problem persist:
- NVIDIA 580.xx driver series regression
These drivers (and several prior ones) have known bugs on certain HDMI 4K displays — they mis-detect refresh rate or color depth when LightDM initializes before full GPU power management is ready.
That’s why your xrandr logs show correct modes later, but nothing displays during greeter startup.
- LightDM/SDDM start timing
The greeter launches before the GPU and display kernel modules are fully ready.
Adding logind-check-graphical=true helped some users because it delays greeter startup until the kernel reports a connected display, but in your case the driver still mis-modesets.
- TTY/console black-screen linkage
The same framebuffer handoff issue that blanks the greeter also kills text TTYs, because both rely on kernel console output on the NVIDIA DRM device.
This explains why TTYs give “no signal” but wake-from-sleep (where the driver re-programs the mode) displays correctly.
- Persistence across kernels (6.6, 6.12, etc.)
The kernel updates didn’t fix it because the real culprit is in the user-space driver (nvidia-utils / lib32-nvidia-utils / nvidia-settings) not aligning with the X server’s startup order.
Supporting Clues
xrandr logs confirm that HDMI-0 is recognized with correct resolutions and refresh rates after X starts — meaning the physical link is fine.
TTYs and LightDM both fail to display, but waking from sleep restores signal → points to a mode-setting reinitialization fix.
Switching to SDDM produced the same blank-screen result, meaning the issue is not greeter-specific but happens before any theme loads.
Flatpak / kernel / package updates didn’t change behavior → confirms driver timing, not configuration corruption.
In Summary
Component Role in the problem
NVIDIA 580.xx driver Likely introducing display-initialization bug on HDMI 4K displays
LightDM/SDDM timing Starting X too early, before GPU modeset stabilizes
Kernel console/TTY Shares same framebuffer, so when the mode fails, all consoles go black
Workaround effect Logging in triggers a fresh X init → video returns
The most realistic fixes (based on other users’ success)
- Force early modeset:
Add kernel parameter
nvidia-drm.modeset=1
in /etc/default/grub, then run
sudo update-grub
(This enables atomic mode setting for the NVIDIA DRM kernel module.)
Downgrade to driver 550.xx
Many users reported that reverting from 580.xx to 550.144.03 restores proper LightDM display initialization. -
Switch greeter compositor
Using lightdm-gtk-greeter instead of slick-greeter sometimes avoids the blank screen because it doesn’t use the same GPU compositing path.
Mod edit:- General tidy of ChatGPT generated content.
Please avoid posting AI generated content. If you believe any of it has merit, include it in your own words rather than pasting AI’s board room presentation. ![]()
However, as it was mentioned, please post the output of;
cat /etc/default/grub
Also, output of;
cat /etc/lightdm/lightdm.conf
Look for the greeter being used (indicated in lightdm.conf), and substitute the *-greeter.conf of the next command for that; then paste that command output also.
cat /etc/lightdm/lightdm-gtk-greeter.conf
Perhaps these may be of interest to someone who actually uses Cinnamon.
Wow, this is still going.
Try this Package:
❯ pacman -Q |g nvidia
hip-runtime-nvidia 6.4.3-2
libnvidia-container 1.17.8-2
libva-nvidia-driver 0.0.14-1
linux-firmware-nvidia 20250917-1
nvidia-550xx-dkms 550.163.01-3
nvidia-550xx-utils 550.163.01-3
nvidia-container-toolkit 1.17.8-1
nvidia-prime 1.0-5
opencl-nvidia 580.82.09-1
If I understood what you were asking for, here was the output:
$ pacman -Q | grep -E "nvidia|opencl|libva"
lib32-libva 2.22.0-1
lib32-libva-intel-driver 2.4.1-2
lib32-libva-vdpau-driver 0.7.4-8
lib32-nvidia-570xx-utils 570.190-1
libva 2.22.0-1
libva-intel-driver 2.4.1-5
libva-vdpau-driver 0.7.4-7
linux515-nvidia-570xx-open 570.190-1
linux61-nvidia-570xx-open 570.190-2
linux612-nvidia-570xx-open 570.190-2
mhwd-nvidia 580.82.09-1
mhwd-nvidia-390xx 390.157-21
mhwd-nvidia-470xx 470.256.02-15
mhwd-nvidia-570xx 570.190-3
mhwd-nvidia-575xx 575.64.05-2
nvidia-570xx-settings 570.190-2
nvidia-570xx-utils 570.190-2
nvidia-driver-assistant 0.22.82.07-1
$ cat /etc/default/grub:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=29eb334c-60e3-439c-a12b-7e0667d31429 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
$ cat /etc/lightdm/lightdm.conf:
# General configuration
# start-default-seat = True to always start one seat if none are defined in the configuration
# greeter-user = User to run greeter as
# minimum-display-number = Minimum display number to use for X servers
# minimum-vt = First VT to run displays on
# lock-memory = True to prevent memory from being paged to disk
# user-authority-in-system-dir = True if session authority should be in the system location
# guest-account-script = Script to be run to setup guest account
# logind-check-graphical = True to on start seats that are marked as graphical by logind
# log-directory = Directory to log information to
# run-directory = Directory to put running state in
# cache-directory = Directory to cache to
# sessions-directory = Directory to find sessions
# remote-sessions-directory = Directory to find remote sessions
# greeters-directory = Directory to find greeters
# backup-logs = True to move add a .old suffix to old log files when opening new ones
# dbus-service = True if LightDM provides a D-Bus service to control it
[LightDM]
#start-default-seat=true
#greeter-user=lightdm
#minimum-display-number=0
#minimum-vt=7 # Setting this to a value < 7 implies security issues, see FS#46799
#lock-memory=true
#user-authority-in-system-dir=false
#guest-account-script=guest-account
#log-directory=/var/log/lightdm
run-directory=/run/lightdm
#cache-directory=/var/cache/lightdm
#sessions-directory=/usr/share/lightdm/sessions:/usr/share/xsessions:/usr/share/wayland-sessions
#remote-sessions-directory=/usr/share/lightdm/remote-sessions
#greeters-directory=$XDG_DATA_DIRS/lightdm/greeters:$XDG_DATA_DIRS/xgreeters
#backup-logs=true
#dbus-service=true
# Seat configuration
# Seat configuration is matched against the seat name glob in the section, for example:
# [Seat:*] matches all seats and is applied first.
# [Seat:seat0] matches the seat named "seat0".
# [Seat:seat-thin-client*] matches all seats that have names that start with "seat-thin-client".
# type = Seat type (local, xremote)
# pam-service = PAM service to use for login
# pam-autologin-service = PAM service to use for autologin
# pam-greeter-service = PAM service to use for greeters
# xserver-command = X server command to run (can also contain arguments e.g. X -special-option)
# xmir-command = Xmir server command to run (can also contain arguments e.g. Xmir -special-option)
# xserver-config = Config file to pass to X server
# xserver-layout = Layout to pass to X server
# xserver-allow-tcp = True if TCP/IP connections are allowed to this X server
# xserver-share = True if the X server is shared for both greeter and session
# xserver-hostname = Hostname of X server (only for type=xremote)
# xserver-display-number = Display number of X server (only for type=xremote)
# xdmcp-manager = XDMCP manager to connect to (implies xserver-allow-tcp=true)
# xdmcp-port = XDMCP UDP/IP port to communicate on
# xdmcp-key = Authentication key to use for XDM-AUTHENTICATION-1 (stored in keys.conf)
# greeter-session = Session to load for greeter
# greeter-hide-users = True to hide the user list
# greeter-allow-guest = True if the greeter should show a guest login option
# greeter-show-manual-login = True if the greeter should offer a manual login option
# greeter-show-remote-login = True if the greeter should offer a remote login option
# user-session = Session to load for users
# allow-user-switching = True if allowed to switch users
# allow-guest = True if guest login is allowed
# guest-session = Session to load for guests (overrides user-session)
# session-wrapper = Wrapper script to run session with
# greeter-wrapper = Wrapper script to run greeter with
# guest-wrapper = Wrapper script to run guest sessions with
# display-setup-script = Script to run when starting a greeter session (runs as root)
# display-stopped-script = Script to run after stopping the display server (runs as root)
# greeter-setup-script = Script to run when starting a greeter (runs as root)
# session-setup-script = Script to run when starting a user session (runs as root)
# session-cleanup-script = Script to run when quitting a user session (runs as root)
# autologin-guest = True to log in as guest by default
# autologin-user = User to log in with by default (overrides autologin-guest)
# autologin-user-timeout = Number of seconds to wait before loading default user
# autologin-session = Session to load for automatic login (overrides user-session)
# autologin-in-background = True if autologin session should not be immediately activated
# exit-on-failure = True if the daemon should exit if this seat fails
[Seat:*]
#type=local
#pam-service=lightdm
#pam-autologin-service=lightdm-autologin
#pam-greeter-service=lightdm-greeter
#xserver-command=X
#xmir-command=Xmir
#xserver-config=
#xserver-layout=
#xserver-allow-tcp=false
#xserver-share=true
#xserver-hostname=
#xserver-display-number=
#xdmcp-manager=
#xdmcp-port=177
#xdmcp-key=
greeter-session=lightdm-slick-greeter
#greeter-hide-users=false
#greeter-allow-guest=true
#greeter-show-manual-login=false
#greeter-show-remote-login=true
#user-session=default
#allow-user-switching=true
#allow-guest=true
#guest-session=
session-wrapper=/etc/lightdm/Xsession
#greeter-wrapper=
#guest-wrapper=
#display-setup-script=
#display-stopped-script=
#greeter-setup-script=
#session-setup-script=
#session-cleanup-script=
#autologin-guest=false
#autologin-user=
#autologin-user-timeout=0
#autologin-in-background=false
#autologin-session=
#exit-on-failure=false
# XDMCP Server configuration
# enabled = True if XDMCP connections should be allowed
# port = UDP/IP port to listen for connections on
# listen-address = Host/address to listen for XDMCP connections (use all addresses if not present)
# key = Authentication key to use for XDM-AUTHENTICATION-1 or blank to not use authentication (stored in keys.conf)
# hostname = Hostname to report to XDMCP clients (defaults to system hostname if unset)
# The authentication key is a 56 bit DES key specified in hex as 0xnnnnnnnnnnnnnn. Alternatively
# it can be a word and the first 7 characters are used as the key.
[XDMCPServer]
#enabled=false
#port=177
#listen-address=
#key=
#hostname=
# VNC Server configuration
# enabled = True if VNC connections should be allowed
# command = Command to run Xvnc server with
# port = TCP/IP port to listen for connections on
# listen-address = Host/address to listen for VNC connections (use all addresses if not present)
# width = Width of display to use
# height = Height of display to use
# depth = Color depth of display to use
[VNCServer]
#enabled=false
#command=Xvnc
#port=5900
#listen-address=
#width=1024
#height=768
#depth=8
$ cat /etc/lightdm/slick-greeter.conf:
[Greeter]
background=/usr/share/backgrounds/cinnamon/forest.jpg
theme-name=Matcha-azul
icon-theme-name=Papirus-Light-Maia
activate-numlock=true
show-power=false
only-on-monitor=HDMI-0
Mod edit:- General tidy. No charge.
Your inxi from a month ago shows this for your Monitor:
… disabled?
But your greeter configuration says:
only show the greeter on that disabled monitor?
… which, to me, would mean: you don’t get to see it
Do I interpret this correctly?
I would suggest you comment out that line in the greeter configuration (put a # in front of it)
and see what happens.
That was put there originally because when I was using two monitors it was displaying the login window on the secondary monitor and even after disconnecting the secondary monitor it was seemingly still trying to output to the secondary monitor. Originally when the problem occurred that parameter was set to auto. But just for a sanity check I tried commenting out as you said and rebooting. It made no difference.
That is an interesting line in the inxi however, I did not notice that before. Would this mean that the nvidia driver is reporting that the monitor is present but turned off? Why would it think the monitor is turned off?
To test a remote theory, could you remove quiet from the GRUB_CMDLINE_LINUX_DEFAULT= line in /etc/default/grub; close and save the file and run update-grub; then reboot.
Here is the bootlog
You may find this section informative:
$ journalctl -b -1 | grep -Ei "nvidia|drm|fb|frame|edid|hdmi"
Nov 12 21:12:43 Polaris kernel: signal: max sigframe size: 2032
Nov 12 21:12:43 Polaris kernel: ACPI: bus type drm_connector registered
Nov 12 21:12:43 Polaris kernel: simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
Nov 12 21:12:43 Polaris kernel: [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
Nov 12 21:12:43 Polaris kernel: fbcon: Deferring console take-over
Nov 12 21:12:43 Polaris kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
Nov 12 21:12:43 Polaris kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 14382fbf9b4d278b5c022f1081ca4b0bdb05767e'
Nov 12 21:12:43 Polaris kernel: fbcon: Taking over console
Nov 12 21:12:43 Polaris kernel: Console: switching to colour frame buffer device 128x48
Nov 12 21:12:43 Polaris systemd[1]: systemd 257.9-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
Nov 12 21:12:43 Polaris systemd[1]: Starting Load Kernel Module drm...
Nov 12 21:12:43 Polaris systemd[1]: modprobe@drm.service: Deactivated successfully.
Nov 12 21:12:43 Polaris systemd[1]: Finished Load Kernel Module drm.
Nov 12 21:12:43 Polaris kernel: nvidia: loading out-of-tree module taints kernel.
Nov 12 21:12:43 Polaris kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Nov 12 21:12:43 Polaris kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 238
Nov 12 21:12:43 Polaris kernel: nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
Nov 12 21:12:43 Polaris systemd-modules-load[366]: Inserted module 'nvidia'
Nov 12 21:12:43 Polaris kernel: NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64 570.190 Release Build (manjarolinux-builder@echo manjarolinux)
Nov 12 21:12:44 Polaris kernel: nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 570.190 Release Build (manjarolinux-builder@echo manjarolinux)
Nov 12 21:12:44 Polaris kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
Nov 12 21:12:44 Polaris kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input28
Nov 12 21:12:44 Polaris kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input29
Nov 12 21:12:44 Polaris kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input30
Nov 12 21:12:44 Polaris kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input31
Nov 12 21:12:45 Polaris kernel: [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 1
Nov 12 21:12:46 Polaris kernel: nvidia 0000:01:00.0: vgaarb: deactivate vga console
Nov 12 21:12:46 Polaris kernel: fbcon: nvidia-drmdrmfb (fb0) is primary device
Nov 12 21:12:46 Polaris kernel: Console: switching to colour frame buffer device 240x67
Nov 12 21:12:46 Polaris kernel: nvidia 0000:01:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
Nov 12 21:12:46 Polaris systemd-modules-load[366]: Inserted module 'nvidia_drm'
Nov 12 21:12:46 Polaris systemd-resolved[1056]: . IN DS 38696 8 2 683d2d0acb8c9b712a1948b27f741219298d0a450d612c483af444a4c0fb2b16
Nov 12 21:15:58 Polaris kernel: traps: appimagelaunche[2457] general protection fault ip:7fb5982cbcb4 sp:7fff1bb6fa88 error:0 in libstdc++.so.6.0.34[cbcb4,7fb598297000+155000]
#0 0x00007fb5982cbcb4 local_Rb_tree_increment (libstdc++.so.6 + 0xcbcb4)
#3 0x00007fb5989076b1 n/a (libQt5Core.so.5 + 0x3076b1)
#4 0x00007fb598909b9e _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x309b9e)
#5 0x00007fb5988f75a9 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2f75a9)
#6 0x00007fb5988d0397 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x2d0397)
#7 0x00007fb598927640 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x327640)
#8 0x00007fb598927792 n/a (libQt5Core.so.5 + 0x327792)
#9 0x00007fb598d08880 n/a (libglib-2.0.so.0 + 0x5e880)
#10 0x00007fb598d09cd7 n/a (libglib-2.0.so.0 + 0x5fcd7)
#11 0x00007fb598d09ee5 g_main_context_iteration (libglib-2.0.so.0 + 0x5fee5)
#12 0x00007fb598921d49 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x321d49)
#13 0x00007fb5988c88bb _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2c88bb)
#14 0x00007fb5988d4bdb _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2d4bdb)
#16 0x00007fb597e27675 n/a (libc.so.6 + 0x27675)
#17 0x00007fb597e27729 __libc_start_main (libc.so.6 + 0x27729)
Nov 12 21:21:58 Polaris kernel: traps: appimagelaunche[3126] general protection fault ip:7fba758cbcb4 sp:7ffdf79f7598 error:0 in libstdc++.so.6.0.34[cbcb4,7fba75897000+155000]
#0 0x00007fba758cbcb4 local_Rb_tree_increment (libstdc++.so.6 + 0xcbcb4)
#3 0x00007fba75f076b1 n/a (libQt5Core.so.5 + 0x3076b1)
#4 0x00007fba75f09b9e _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x309b9e)
#5 0x00007fba75ef75a9 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2f75a9)
#6 0x00007fba75ed0397 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x2d0397)
#7 0x00007fba75f27640 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x327640)
#8 0x00007fba75f27792 n/a (libQt5Core.so.5 + 0x327792)
#9 0x00007fba76308880 n/a (libglib-2.0.so.0 + 0x5e880)
#10 0x00007fba76309cd7 n/a (libglib-2.0.so.0 + 0x5fcd7)
#11 0x00007fba76309ee5 g_main_context_iteration (libglib-2.0.so.0 + 0x5fee5)
#12 0x00007fba75f21d49 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x321d49)
#13 0x00007fba75ec88bb _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2c88bb)
#14 0x00007fba75ed4bdb _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2d4bdb)
#16 0x00007fba75427675 n/a (libc.so.6 + 0x27675)
#17 0x00007fba75427729 __libc_start_main (libc.so.6 + 0x27729)
Nov 12 21:25:18 Polaris kernel: traps: appimagelaunche[3429] general protection fault ip:7fda38acbcb4 sp:7ffcb5fb34f8 error:0 in libstdc++.so.6.0.34[cbcb4,7fda38a97000+155000]
I have been doing some experimenting this evening and I discovered that this issue is nonexistent when I use a different monitor, I tried two other displays, one was a tv and one was a monitor, in both cases the issue did not exist, both the login window and the TTYs had no issue displaying. This led me to believe it must be some configuration setting for my normal monitor that is causing the problem. I tried purging the EDID configurations by deleting these files:
$ sudo rm -rf /var/lib/lightdm/.cache
$ sudo rm -rf ~/.config/monitors.xml
$ sudo rm -rf /etc/X11/xorg.conf.d/*
$ sudo mkinitcpio -P
I then shut down the computer, reconnected my original monitor and tried again. The problem persisted. While the screen was on no display (when it should show the login window) I swapped the hdmi cable to a different input on the monitor and that did not help. This made me think that the monitor itself has a corrupted EDID cached and keeps sending it to the computer even after the config files on the computer are reset.
I tried to force the computer to see the correct EDID
$ sudo mkdir -p /lib/firmware/edid
$ base64 -d ~/tv-edid.b64 | sudo tee /usr/lib/firmware/edid/tv-edid.bin > /dev/null
$ ls -l /usr/lib/firmware/edid
-rw-r--r-- 1 root root 256 Nov 12 21:005 tv-edid.bin
I created /etc/X11/xorg.conf.d/10-forced-edid.conf with these contents:
Section "Device"
Identifier "Nvidia Card"
Driver "nvidia"
Option "ConnectedMonitor" "HDMI-0"
Option "CustomEDID" "HDMI-0:/usr/lib/firmware/edid/tv-edid.bin"
EndSection
And rebooted. Unfortunately that still didn’t fix the problem. Not sure what else to try at this point short of buying a new tv
That may well be your only remaining recourse.
Presumedly it’s out of warranty, which would be unfortunate. Clearly, no other possibilities are forthcoming, at this time.
We can leave the thread open a while longer, if you like, but sooner or later it will be closed, if there is no further activity.
If it does close, you’re wecome to request it be re-opened if you have additional information to add. Simply ask a Moderation staff member via PM, and it will be re-opened at their discretion.
Well I finally fixed the problem! -sort of. I wanted to leave a comment here in case anyone else ever has this issue.
Given that this seemed to be a problem with the hdmi protocol, specifically between this tv and this gpu, I decided to try using a different protocol. I bought a displayport to hdmi adapter with an active conversion chip and connected the tv through the displayport connection instead and boom, instantly fixed! The conversion chip interfaces with the tv on behalf of the gpu, so the tv thinks it’s connecting to a completely different device, one that is apparently more tolerant.
Technically it’s not a true fix, it’s more of a workaround, but it suits my needs just fine and it’s a whole lot cheaper than a new tv
Generally an adapter cable isn’t recommended. In this case, with active conversion chip, it seems to a welcome contradiction to the rule.
Good to know it’s finally resolved.
