Laptop hard drive (HDD) endlessly cycling stopping/starting disk when laptop is on battery.
On each cycle a distinctive sound is emitted (like waking disk up).
When connecting to AC power - it stops that behavior.
Details from dmesg -w:
[153386.025516] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153386.026972] sd 0:0:0:0: [sda] Stopping disk
[153391.565158] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153391.579697] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153391.579706] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153391.579710] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153391.579843] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153393.486969] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153393.486975] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153393.486978] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153393.487275] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153393.524548] ata1.00: configured for UDMA/133
[153393.533757] sd 0:0:0:0: [sda] Starting disk
[153418.108644] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153418.110108] sd 0:0:0:0: [sda] Stopping disk
[153424.418899] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153424.433527] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153424.433535] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153424.433538] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153424.436619] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153426.353031] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153426.353037] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153426.353040] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153426.353331] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153426.390508] ata1.00: configured for UDMA/133
[153426.399717] sd 0:0:0:0: [sda] Starting disk
[153450.955067] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153450.956593] sd 0:0:0:0: [sda] Stopping disk
[153456.418806] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153456.433459] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153456.433487] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153456.433512] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153456.436519] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153458.341741] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153458.341754] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153458.341762] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153458.342101] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153458.379229] ata1.00: configured for UDMA/133
[153458.389591] sd 0:0:0:0: [sda] Starting disk
[153482.927150] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153482.928660] sd 0:0:0:0: [sda] Stopping disk
[153488.418295] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153488.432887] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153488.432900] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153488.432905] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153488.436012] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153490.338605] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153490.338611] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153490.338614] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153490.338897] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153490.376007] ata1.00: configured for UDMA/133
[153490.386267] sd 0:0:0:0: [sda] Starting disk
[153531.764636] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153531.766150] sd 0:0:0:0: [sda] Stopping disk
[153532.453883] sd 0:0:0:0: [sda] Starting disk
[153559.121124] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153559.122599] sd 0:0:0:0: [sda] Stopping disk
[153565.431336] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153565.445905] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153565.445912] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153565.445915] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153565.449000] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153567.369235] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153567.369245] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153567.369251] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153567.369464] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153567.406579] ata1.00: configured for UDMA/133
[153567.416975] sd 0:0:0:0: [sda] Starting disk
[153591.886944] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153591.888427] sd 0:0:0:0: [sda] Stopping disk
[153597.431176] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153597.445785] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153597.445808] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153597.445811] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153597.448895] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153599.379966] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153599.379972] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153599.379975] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153599.380252] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153599.417371] ata1.00: configured for UDMA/133
[153599.426560] sd 0:0:0:0: [sda] Starting disk
[153645.947245] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153645.948676] sd 0:0:0:0: [sda] Stopping disk
[153651.403545] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153651.418118] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153651.418128] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153651.418132] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153651.421254] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153653.349387] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153653.349397] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153653.349402] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153653.349621] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153653.386722] ata1.00: configured for UDMA/133
[153653.395846] sd 0:0:0:0: [sda] Starting disk
[153678.160408] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153678.161848] sd 0:0:0:0: [sda] Stopping disk
[153684.470560] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153684.485211] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153684.485220] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153684.485224] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153684.488260] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153686.384394] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153686.384402] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153686.384405] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153686.384697] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153686.422127] ata1.00: configured for UDMA/133
[153686.432439] sd 0:0:0:0: [sda] Starting disk
[153711.013741] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153711.015231] sd 0:0:0:0: [sda] Stopping disk
[153717.540546] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153717.555095] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153717.555109] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153717.555117] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153717.558234] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153719.481794] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153719.481800] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153719.481803] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153719.482028] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153719.519103] ata1.00: configured for UDMA/133
[153719.529348] sd 0:0:0:0: [sda] Starting disk
[153770.053800] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153770.055287] sd 0:0:0:0: [sda] Stopping disk
[153775.563439] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153775.578010] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153775.578017] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153775.578021] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153775.581103] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153777.501766] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153777.501772] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153777.501775] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153777.502013] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153777.539146] ata1.00: configured for UDMA/133
[153777.548310] sd 0:0:0:0: [sda] Starting disk
[153802.106363] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153802.107812] sd 0:0:0:0: [sda] Stopping disk
[153804.103097] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153804.115279] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153804.115292] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153804.115299] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153804.115451] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153805.238929] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153805.238938] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153805.238941] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153805.239194] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153805.276410] ata1.00: configured for UDMA/133
[153805.286681] sd 0:0:0:0: [sda] Starting disk
[153872.388203] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153872.389661] sd 0:0:0:0: [sda] Stopping disk
[153878.389565] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153878.404157] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153878.404167] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153878.404173] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153878.407280] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153880.320223] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153880.320233] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153880.320237] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153880.320552] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153880.357733] ata1.00: configured for UDMA/133
[153880.367982] sd 0:0:0:0: [sda] Starting disk
[153903.687112] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153903.688585] sd 0:0:0:0: [sda] Stopping disk
[153909.542588] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153909.557820] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153909.557835] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153909.557843] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153909.560910] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153911.498777] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153911.498794] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153911.498802] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153911.499069] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153911.536139] ata1.00: configured for UDMA/133
[153911.546403] sd 0:0:0:0: [sda] Starting disk
[153945.682157] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153945.683564] sd 0:0:0:0: [sda] Stopping disk
[153951.355665] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153951.371321] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153951.371332] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153951.371339] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153951.374501] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153953.303126] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153953.303140] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153953.303148] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153953.303347] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153953.340500] ata1.00: configured for UDMA/133
[153953.349617] sd 0:0:0:0: [sda] Starting disk
[153977.947710] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[153977.949199] sd 0:0:0:0: [sda] Stopping disk
[153983.565607] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[153983.580262] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153983.580273] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153983.580279] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153983.583327] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153985.520602] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[153985.520613] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[153985.520618] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[153985.520881] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[153985.558056] ata1.00: configured for UDMA/133
[153985.568347] sd 0:0:0:0: [sda] Starting disk
[154009.745954] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154009.747377] sd 0:0:0:0: [sda] Stopping disk
[154015.348721] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154015.363300] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154015.363313] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154015.363335] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154015.366467] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154017.293070] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154017.293076] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154017.293079] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154017.293330] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154017.330472] ata1.00: configured for UDMA/133
[154017.340689] sd 0:0:0:0: [sda] Starting disk
[154042.318211] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154042.319696] sd 0:0:0:0: [sda] Stopping disk
[154048.415211] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154048.429816] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154048.429823] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154048.429841] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154048.432919] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154050.350796] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154050.350804] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154050.350808] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154050.351062] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154050.388269] ata1.00: configured for UDMA/133
[154050.398489] sd 0:0:0:0: [sda] Starting disk
[154110.181154] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154110.182610] sd 0:0:0:0: [sda] Stopping disk
[154116.468157] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154116.482792] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154116.482815] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154116.482818] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154116.485896] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154118.421132] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154118.421155] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154118.421159] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154118.421388] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154118.458446] ata1.00: configured for UDMA/133
[154118.468635] sd 0:0:0:0: [sda] Starting disk
[154143.010944] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154143.012388] sd 0:0:0:0: [sda] Stopping disk
[154146.954632] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154146.966159] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154146.966166] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154146.966169] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154146.966336] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154148.751601] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154148.751612] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154148.751618] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154148.751819] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154148.788857] ata1.00: configured for UDMA/133
[154148.799089] sd 0:0:0:0: [sda] Starting disk
[154175.010777] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154175.012259] sd 0:0:0:0: [sda] Stopping disk
[154180.467571] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154180.482116] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154180.482125] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154180.482131] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154180.482264] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154182.408290] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154182.408298] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154182.408302] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154182.408542] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154182.445611] ata1.00: configured for UDMA/133
[154182.454783] sd 0:0:0:0: [sda] Starting disk
[154209.143913] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154209.145354] sd 0:0:0:0: [sda] Stopping disk
[154215.454236] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154215.468855] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154215.468863] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154215.468868] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154215.471960] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154217.403065] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154217.403074] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154217.403078] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154217.403320] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154217.440398] ata1.00: configured for UDMA/133
[154217.450654] sd 0:0:0:0: [sda] Starting disk
[154245.832626] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154245.834139] sd 0:0:0:0: [sda] Stopping disk
[154249.587088] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154249.598981] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154249.598988] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154249.598991] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154249.599138] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154251.515965] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154251.515972] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154251.515975] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154251.516200] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154251.553269] ata1.00: configured for UDMA/133
[154251.563521] sd 0:0:0:0: [sda] Starting disk
[154276.130170] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154276.131607] sd 0:0:0:0: [sda] Stopping disk
[154282.440403] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154282.455040] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154282.455067] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154282.455070] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154282.458148] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154284.384882] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154284.384905] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154284.384910] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154284.385221] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154284.422321] ata1.00: configured for UDMA/133
[154284.432558] sd 0:0:0:0: [sda] Starting disk
[154308.809202] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154308.810692] sd 0:0:0:0: [sda] Stopping disk
[154314.440534] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154314.455160] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154314.455185] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154314.455190] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154314.458265] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154316.381806] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154316.381817] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154316.381822] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154316.382068] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154316.419173] ata1.00: configured for UDMA/133
[154316.429443] sd 0:0:0:0: [sda] Starting disk
[154355.030858] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154355.032261] sd 0:0:0:0: [sda] Stopping disk
[154360.519851] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154360.534483] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154360.534506] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154360.534509] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154360.537566] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154362.453020] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154362.453028] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154362.453032] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154362.453317] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154362.490563] ata1.00: configured for UDMA/133
[154362.499816] sd 0:0:0:0: [sda] Starting disk
[154387.263596] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154387.265067] sd 0:0:0:0: [sda] Stopping disk
[154393.373162] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154393.387766] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154393.387776] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154393.387782] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154393.390890] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154395.322604] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154395.322610] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154395.322613] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154395.322894] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154395.360147] ata1.00: configured for UDMA/133
[154395.370441] sd 0:0:0:0: [sda] Starting disk
[154435.072580] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154435.074055] sd 0:0:0:0: [sda] Stopping disk
[154441.376224] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154441.390809] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154441.390832] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154441.390836] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154441.393926] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154443.316089] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154443.316097] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154443.316100] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154443.316328] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154443.353541] ata1.00: configured for UDMA/133
[154443.363810] sd 0:0:0:0: [sda] Starting disk
[154467.967904] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154467.969342] sd 0:0:0:0: [sda] Stopping disk
[154468.655252] sd 0:0:0:0: [sda] Starting disk
[154496.075521] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154496.076975] sd 0:0:0:0: [sda] Stopping disk
[154501.532341] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154501.546917] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154501.546925] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154501.546928] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154501.550062] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154503.505610] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154503.505618] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154503.505621] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154503.505857] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154503.542949] ata1.00: configured for UDMA/133
[154503.553220] sd 0:0:0:0: [sda] Starting disk
[154561.141801] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154561.143292] sd 0:0:0:0: [sda] Stopping disk
[154567.451980] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154567.466553] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154567.466562] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154567.466566] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154567.469650] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154569.405042] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154569.405049] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154569.405053] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154569.405336] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154569.442558] ata1.00: configured for UDMA/133
[154569.452889] sd 0:0:0:0: [sda] Starting disk
[154594.591640] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154594.593145] sd 0:0:0:0: [sda] Stopping disk
[154600.518149] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154600.532732] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154600.532743] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154600.532748] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154600.535799] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154602.458770] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154602.458779] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154602.458784] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154602.459062] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154602.496198] ata1.00: configured for UDMA/133
[154602.506483] sd 0:0:0:0: [sda] Starting disk
[154626.672563] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[154626.674042] sd 0:0:0:0: [sda] Stopping disk
[154632.518316] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[154632.532878] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154632.532885] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154632.532889] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154632.535953] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154634.464713] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[154634.464720] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[154634.464724] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[154634.464957] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[154634.502064] ata1.00: configured for UDMA/133
[154634.512330] sd 0:0:0:0: [sda] Starting disk
Disk info:
$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 4K 1 loop /var/lib/snapd/snap/bare/5
loop1 7:1 0 55,4M 1 loop /var/lib/snapd/snap/core18/2074
loop2 7:2 0 55,4M 1 loop /var/lib/snapd/snap/core18/2128
loop3 7:3 0 162,9M 1 loop /var/lib/snapd/snap/gnome-3-28-1804/145
loop4 7:4 0 164,8M 1 loop /var/lib/snapd/snap/gnome-3-28-1804/161
loop5 7:5 0 65,1M 1 loop /var/lib/snapd/snap/gtk-common-themes/1515
loop6 7:6 0 65,2M 1 loop /var/lib/snapd/snap/gtk-common-themes/1519
loop7 7:7 0 139,4M 1 loop /var/lib/snapd/snap/skype/187
loop8 7:8 0 139,4M 1 loop /var/lib/snapd/snap/skype/186
loop9 7:9 0 32,3M 1 loop /var/lib/snapd/snap/snapd/13170
loop10 7:10 0 32,4M 1 loop /var/lib/snapd/snap/snapd/13270
sda 8:0 0 1,8T 0 disk
├─sda1 8:1 0 745,1G 0 part /music
├─sda2 8:2 0 465,7G 0 part /video
├─sda3 8:3 0 559,2G 0 part /data
└─sda4 8:4 0 93,1G 0 part /var
sdb 8:16 0 238,5G 0 disk
├─sdb1 8:17 0 300M 0 part /boot/efi
├─sdb2 8:18 0 27,9G 0 part /
├─sdb3 8:19 0 193,2G 0 part /home
└─sdb4 8:20 0 17,1G 0 part [SWAP]
$ lsblk -d -o name,type,rota
NAME TYPE ROTA
loop0 loop 1
loop1 loop 1
loop2 loop 1
loop3 loop 1
loop4 loop 1
loop5 loop 1
loop6 loop 1
loop7 loop 1
loop8 loop 1
loop9 loop 1
loop10 loop 1
sda disk 1
sdb disk 0
$ hwinfo --disk --only /dev/sda
25: IDE 00.0: 10600 Disk
[Created at block.245]
Unique ID: 3OOL.X8wfWU50PqC
Parent ID: abAj.sCgsdZGgaI3
SysFS ID: /class/block/sda
SysFS BusID: 0:0:0:0
SysFS Device Link: /devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0
Hardware Class: disk
Model: "ST2000LM007-1R81"
Device: "ST2000LM007-1R81"
Revision: "SDM2"
Driver: "ahci", "sd"
Driver Modules: "ahci"
Device File: /dev/sda
Device Files: /dev/sda, /dev/disk/by-id/ata-ST2000LM007-1R8174_ZDZ3MS2X, /dev/disk/by-id/wwn-0x5000c500b2256b74, /dev/disk/by-path/pci-0000:00:17.0-ata-1, /dev/disk/by-path/pci-0000:00:17.0-ata-1.0
Device Number: block 8:0-8:15
BIOS id: 0x81
Drive status: no medium
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #2 (SATA controller)
$ inxi -bD
System: Host: roman-pc Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.22.5
Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: G3 3779 v: N/A serial: <superuser required>
Mobo: Dell model: 04R93M v: A00 serial: <superuser required> UEFI: Dell v: 1.2.1 date: 07/18/2018
Battery: ID-1: BAT0 charge: 2.2 Wh (14.3%) condition: 15.4/56.0 Wh (27.5%)
CPU: Info: 6-Core Intel Core i7-8750H [MT MCP] speed: 4000 MHz min/max: 800/4100 MHz
Graphics: Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] driver: nvidia v: 470.63.01
Device-3: Realtek Integrated Webcam type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting,nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 1060 with Max-Q Design/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
Network: Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
Drives: Local Storage: total: 2.05 TiB used: 321.83 GiB (15.3%)
ID-1: /dev/sda vendor: Seagate model: ST2000LM007-1R8174 size: 1.82 TiB
ID-2: /dev/sdb vendor: SK Hynix model: SC311 SATA 256GB size: 238.47 GiB
Info: Processes: 362 Uptime: 3d 21h 28m Memory: 15.49 GiB used: 8.05 GiB (52.0%) Shell: Bash inxi: 3.3.07
