GUI freeze on login screen, after startup
Issue
I recently started encountering the following issue:
on startup, the login screen usually freezes after I start typing my password (all the gui buttons are unresponsive, though the mouse cursor is still working); if I press enter and I wait, after a bit the loading screen appears and then everything is fine.
System
inxi output:
$ inxi --filter --verbosity=8
  Kernel: 6.13.5-2-MANJARO arch: x86_64 bits: 64
    compiler: gcc v: 14.2.1 clocksource: tsc
    avail: hpet,acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.13-x86_64
    root=UUID=98d46ec3-de60-4a2f-b4db-25705917988c ro
    quiet apparmor=1 security=apparmor udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A
    info: frameworks v: 6.11.0 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: CM6870 v: Rev X.0x
    serial: <superuser required> part-nu: SKU
    uuid: <superuser required> UEFI: American Megatrends
    v: 0708 date: 12/25/2012
  System RAM: total: 24 GiB available: 23.42 GiB
    used: 3.12 GiB (13.3%)
  Message: For most reliable report, use superuser +
    dmidecode.
  Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous
    size: 8 GiB speed: 1600 MT/s volts: N/A width (bits):
    data: 64 total: 64 manufacturer: TeamGroup
    part-no: TIMETEC-U8G-1600 serial: <filter>
  Device-2: ChannelA-DIMM1 type: DDR3 detail: synchronous
    size: 4 GiB speed: 1600 MT/s volts: N/A width (bits):
    data: 64 total: 64 manufacturer: 06c1
    part-no: SLA302G08-GGNHC serial: <filter>
  Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous
  Device-4: ChannelB-DIMM1 type: DDR3 detail: synchronous
  Permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: Intel Core i7-3770 bits: 64 type: MT MCP
    arch: Ivy Bridge gen: core 3 level: v2 built: 2012-15
    process: Intel 22nm family: 6 model-id: 0x3A (58)
    stepping: 9 microcode: 0x21
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4
    threads: 8 tpc: 2 smt: enabled cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1596 min/max: 1600/3900 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1596
    2: 1596 3: 1596 4: 1596 5: 1596 6: 1596 7: 1596 8: 1596
    bogomips: 54273
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept erms est f16c
    flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pebs pge pln pni popcnt pse pse36 pti pts rdrand
    rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1
    sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
    xsaveopt xtopology xtpr
  Type: l1tf mitigation: PTE Inversion; VMX: conditional
    cache flushes, SMT vulnerable
  Type: spec_store_bypass mitigation: Speculative Store
    Bypass disabled via prctl
  Type: spectre_v1 mitigation: usercopy/swapgs barriers
    and __user pointer sanitization
  Type: spectre_v2 mitigation: Retpolines; IBPB:
    conditional; IBRS_FW; STIBP: conditional; RSB filling;
  Type: srbds status: Vulnerable: No microcode
  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB]
    vendor: Gigabyte driver: nvidia v: 550.144.03
    alternate: nouveau,nvidia_drm non-free: 550/565.xx+
    status: current (as of 2025-01; EOL~2026-12-xx)
    arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none off: DVI-D-1 empty: DP-1, DP-2,
    DP-3, HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1c03
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland
    v: 24.1.6 compositor: kwin_x11 driver: X: loaded: N/A
    failed: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1080x1920 s-dpi: 91
    s-size: 301x535mm (11.85x21.06") s-diag: 614mm (24.17")
  Monitor-1: DVI-D-0 res: N/A
    size: 531x298mm (20.91x11.73") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0
    drv: nvidia gbm: drv: nvidia surfaceless: drv: nvidia
    x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 vendor: nvidia v: 550.144.03
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce
    GTX 1060 6GB/PCIe/SSE2 memory: 5.86 GiB
  API: Vulkan v: 1.4.304 layers: 5 device: 0
    type: discrete-gpu name: NVIDIA GeForce GTX 1060 6GB
    driver: N/A device-ID: 10de:1c03 surfaces: xcb,xlib
    de: kscreen-console,kscreen-doctor
    gpu: nvidia-settings,nvidia-smi wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 7 Series/C216 Family High Definition
    Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
  Device-2: NVIDIA GP106 High Definition Audio
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:10f1 class-ID: 0403
  API: ALSA v: k6.13.5-2-MANJARO status: kernel-api
    with: aoss type: oss-emulator
  Server-2: PipeWire v: 1.2.7 status: off
    with: pipewire-media-session status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    with: 1: pulseaudio-alsa type: plugin 2: pulseaudio-jack
    type: module tools: pacat,pactl
  Device-1: Realtek RTL8111/8168/8211/8411 PCI Express
    Gigabit Ethernet vendor: ASUSTeK P8 series
    driver: r8168 v: 8.055.00-NAPI modules: r8169 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full
    mac: <filter>
  IP v4: <filter> type: dynamic noprefixroute
    scope: global broadcast: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Info: services: NetworkManager, systemd-timesyncd,
    wpa_supplicant
  Local Storage: total: 1.81 TiB used: 51.2 GiB (2.8%)
  SMART Message: Unable to run smartctl. Root privileges
    required.
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston
    model: SA400S37480G size: 447.13 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: B1H5 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung
    model: SSD 850 PRO 512GB size: 476.94 GiB block-size:
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate
    model: ST1000DM003-9YN162 size: 931.51 GiB block-size:
    physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC4B
    scheme: GPT
  ID-1: / raw-size: 145.35 GiB size: 142.51 GiB (98.05%)
    used: 51.17 GiB (35.9%) fs: ext4 dev: /dev/sdb6
    maj-min: 8:22 label: N/A
    uuid: 98d46ec3-de60-4a2f-b4db-25705917988c
    used: 31 MiB (32.3%) fs: vfat dev: /dev/sdb3
    maj-min: 8:19 label: N/A uuid: FEBB-B855
  Kernel: swappiness: 60 (default)
    cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: file size: 4 GiB
    used: 11.7 MiB (0.3%) priority: -2 file: /swapfile
  ID-2: swap-2 type: partition size: 8 GiB
    used: 0 KiB (0.0%) priority: -3 dev: /dev/sda3
    maj-min: 8:3 label: N/A
    uuid: e0ac06ce-c509-4738-a296-b71df305e93a
  ID-1: /dev/sda1 maj-min: 8:1 size: 347.13 GiB fs: ntfs
    label: N/A uuid: 7B107D73041F8DFA
  ID-2: /dev/sda2 maj-min: 8:2 size: 92 GiB fs: ext4
    label: N/A uuid: a06b8b4a-d75b-43b6-8af6-60c210403330
  ID-3: /dev/sdb1 maj-min: 8:17 size: 128 MiB
    fs: <superuser required> label: N/A uuid: N/A
  ID-4: /dev/sdb2 maj-min: 8:18 size: 300 MiB fs: ntfs
    label: Ripristino uuid: 7418BB4518BB04E0
  ID-5: /dev/sdb4 maj-min: 8:20 size: 330.56 GiB fs: ntfs
    label: N/A uuid: 3CBCCC76BCCC2BE8
  ID-6: /dev/sdb5 maj-min: 8:21 size: 525 MiB fs: ntfs
    label: N/A uuid: 7A745A66745A2563
  ID-7: /dev/sdc1 maj-min: 8:33 size: 100 MiB fs: vfat
    label: N/A uuid: 86BF-191E
  ID-8: /dev/sdc2 maj-min: 8:34 size: 128 MiB
  ID-9: /dev/sdc3 maj-min: 8:35 size: 901.1 GiB fs: ntfs
    label: N/A uuid: 24C8FA4DC8FA1CAC
  ID-10: /dev/sdc4 maj-min: 8:36 size: 457 MiB fs: ntfs
    label: N/A uuid: EE107550107520AF
  ID-11: /dev/sdc5 maj-min: 8:37 size: 454 MiB fs: ntfs
    label: N/A uuid: 18A4414EA4412F94
  ID-12: /dev/sdc6 maj-min: 8:38 size: 28.91 GiB fs: ext4
    label: N/A uuid: 9036c0a2-cad9-49e7-a9ba-259a3b3f5225
  ID-13: /dev/sdc7 maj-min: 8:39 size: 400 MiB fs: vfat
    label: N/A uuid: 7A22-B8EB
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 4
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
  Device-1: 1-1:2 info: Primax USB Optical Mouse
    type: mouse driver: hid-generic,usbhid interfaces: 1
    rev: 2.0 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
    power: 100mA chip-ID: 0461:4e35 class-ID: 0301
  Hub-2: 2-0:1 info: full speed or root hub ports: 2
  Hub-3: 2-1:2 info: Intel Integrated Rate Matching Hub
    ports: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 chip-ID: 8087:0024 class-ID: 0900
  Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
  Hub-5: 4-0:1 info: full speed or root hub ports: 2
  Hub-6: 4-1:2 info: Intel Integrated Rate Matching Hub
    ports: 8 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
  Device-1: 4-1.6:3 info: Primax USB Wired Keyboard
    type: keyboard,HID driver: hid-generic,usbhid
    interfaces: 2 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 0461:4dbf
    class-ID: 0300
  System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia
    temp: 38 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Packages: 2464 pm: pacman pkgs: 2452 libs: 496
    tools: pamac,yay pm: flatpak pkgs: 0 pm: snap pkgs: 12
  Active pacman repo servers in: /etc/pacman.conf
    1: https://download.sublimetext.com/arch/stable/x86_64
    1: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    2: http://manjaro.grena.ge/stable/$repo/$arch
    3: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    5: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    7: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    8: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 271
  1: cpu: 27.2% command: firefox pid: 2092
    mem: 557.7 MiB (2.3%)
  2: cpu: 10.6% command: baloo_file pid: 1626
    mem: 109.8 MiB (0.4%)
  3: cpu: 8.3% command: firefox pid: 2267
    mem: 279.6 MiB (1.1%)
  4: cpu: 7.5% command: firefox pid: 2355
    mem: 257.5 MiB (1.0%)
  5: cpu: 5.0% command: kwin_x11 pid: 1685
    mem: 170.6 MiB (0.7%)
  Memory top: 5 of 271
  1: mem: 557.7 MiB (2.3%) command: firefox pid: 2092
    cpu: 27.2%
  2: mem: 487.7 MiB (2.0%) command: plasmashell pid: 1720
    cpu: 3.0%
  3: mem: 279.6 MiB (1.1%) command: firefox pid: 2267
    cpu: 8.3%
  4: mem: 257.5 MiB (1.0%) command: firefox pid: 2355
    cpu: 7.5%
  5: mem: 241.6 MiB (1.0%) command: firefox pid: 2438
    cpu: 1.9%
  Processes: 271 Power: uptime: 6m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend,
    test_resume image: 9.34 GiB
    services: org_kde_powerdevil,upowerd Init: systemd
    v: 257 default: graphical tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 12 Shell: Zsh
    v: 5.9 default: Bash v: 5.2.37 running-in: konsole
    inxi: 3.3.37
Additional Information
What I’ve Tried
  • Resetting and changing the login screen configuration
  • Changing Kernel (to 6.12.17-1 LTS)
  • Installing all updates
Notable Things I Did Recently Before and After the Issue Presented Itself
Restored GRUB from a bootable device following the manjaro guide using chroot.
Hi @foffy
The details you have given might be fine for someone wishing to buy a computer, but for Support purposes more useful information is generally needed.
When providing system information it’s usually best to ask your system directly using the inxi command described (below).
Update Announcements
System Information
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Required reading
Resources
Update
I have encountered other issues that I’m not sure are related: after waking up from sleep the screen only displays the cursor and is otherwise black, requiring reboot. I have found a similar thread on the manjaro forum, that suggests to reinstall the NVIDIA drivers. Although this doesn’t solve the problem for me, it prompted me to try to change the drivers to the open source ones. This doesn’t fix the problem but introduces other artifacts, which suggests that this is a graphics issue. I do have some overclocking on my gpu, I will try to revert to default and update the post.
Here is the log of the last boot, when I tried to wake up from sleep.
Log
$ journalctl --boot=-1 --priority=3 --catalog --no-pager
apr 30 17:32:33 foffy-cm6870 kernel:
apr 30 17:33:08 foffy-cm6870 pulseaudio[1780]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.bluez': unit failed
apr 30 17:33:08 foffy-cm6870 org_kde_powerdevil[1794]: No traced function stack for current thread
apr 30 17:33:08 foffy-cm6870 org_kde_powerdevil[1794]: [  1794] Error detecting VCP version using VCP feature xDF: Error_Info[EIO in ddc_write_read_with_retry, causes: DDCRC_DDC_DATA, EIO]
apr 30 17:40:18 foffy-cm6870 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN0.DRV0._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
apr 30 17:40:18 foffy-cm6870 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN0.DRV0._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
apr 30 17:40:18 foffy-cm6870 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN1.DRV0._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
apr 30 17:40:18 foffy-cm6870 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN1.DRV0._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
apr 30 17:40:18 foffy-cm6870 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN1.DRV1._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
apr 30 17:40:18 foffy-cm6870 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN1.DRV1._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
apr 30 17:40:19 foffy-cm6870 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN0.DRV0._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
apr 30 17:40:19 foffy-cm6870 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN0.DRV0._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
apr 30 17:40:23 foffy-cm6870 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN1.DRV1._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
apr 30 17:40:23 foffy-cm6870 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN1.DRV1._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
apr 30 17:40:23 foffy-cm6870 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN1.DRV0._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
apr 30 17:40:23 foffy-cm6870 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN1.DRV0._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
apr 30 17:41:52 foffy-cm6870 kernel: watchdog: watchdog0: watchdog did not stop!
I restored the defaults on my graphics, it seemed to improve stability, but it doesn’t solve the problem. Now when I wake the PC from sleep the screen is still black, but manjaro manages to restart the KWin window manager, with the following message:
Desktop effects were restarted due to a graphics reset
The loading screen still freezes after login for a few seconds, so the problem is definitely not solved. I’d like to underline that in windows I don’t encounter these stability issues. I’m still not 100% sure it’s the graphics, but I will try to use the cpu integrated graphics to rule out anything else, then I will update this comment.
The following tutorial might be useful;
Does this issue manifest when using both X11 and Wayland?
https://www.asus.com/de/supportonly/cm6870/helpdesk_bios/
CM6870 BIOS 0708
Version 0708
4.11 MB
2013/02/05
Fixed Power On By RTC function failed.
PulseAudio OR pipewire
test grub cmd line nowatchdog
the Rest is normal
My Bios version is already the latest.
is an error I always got on shutdown, not sure why, but in every installation of Manjaro I’ve ever done (even on different hardware). This thread suggests it’s kind of normal. I will take your hint though and maybe update this comment. I will get back to the other hints as soon as I manage. Thanks for the feedback everybody.
I tried switching to a Wayland desktop session, it solved the wake problem. On startup the login screen freezes (not on every startup, I am always able to enter the password), then it goes black for like 15s with no video output, before going to the loading screen. (I was wondering, would it help if I submitted journalctl output with -priority=4?). Here is the latest log(s):
Log with wake from sleep
journalctl --boot=0 --priority=3 --catalog --no-pager
mag 01 10:31:31 foffy-cm6870 kernel:
mag 01 10:34:21 foffy-cm6870 pulseaudio[1789]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.bluez': activation request failed: unknown unit
mag 01 10:34:26 foffy-cm6870 pulseaudio[1789]: Failed to open connection to session manager: None of the authentication protocols specified are supported
mag 01 10:34:26 foffy-cm6870 pulseaudio[1789]: Failed to load module "module-x11-xsmp" (argument: "display=:1 xauthority=/run/user/1000/xauth_FkJVKb session_manager=local/foffy-cm6870:@/tmp/.ICE-unix/1813,unix/foffy-cm6870:/tmp/.ICE-unix/1813"): initialization failed.
mag 01 10:34:28 foffy-cm6870 org_kde_powerdevil[1859]: No traced function stack for current thread
mag 01 10:34:49 foffy-cm6870 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN0.DRV0._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
mag 01 10:34:49 foffy-cm6870 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN0.DRV0._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
mag 01 10:34:49 foffy-cm6870 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN1.DRV0._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
mag 01 10:34:49 foffy-cm6870 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN1.DRV0._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
mag 01 10:34:49 foffy-cm6870 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN1.DRV1._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
mag 01 10:34:49 foffy-cm6870 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN1.DRV1._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
mag 01 10:34:50 foffy-cm6870 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN0.DRV0._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
mag 01 10:34:50 foffy-cm6870 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN0.DRV0._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
mag 01 10:34:54 foffy-cm6870 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN1.DRV1._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
mag 01 10:34:54 foffy-cm6870 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN1.DRV1._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
mag 01 10:34:54 foffy-cm6870 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN1.DRV0._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
mag 01 10:34:54 foffy-cm6870 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN1.DRV0._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
mag 01 10:34:55 foffy-cm6870 org_kde_powerdevil[1859]: No traced function stack for current thread
Log with just login
mag 01 10:57:56 foffy-cm6870 kernel:
mag 01 10:58:47 foffy-cm6870 pulseaudio[1781]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.bluez': activation request failed: unknown unit
mag 01 10:58:49 foffy-cm6870 pulseaudio[1781]: Failed to open connection to session manager: None of the authentication protocols specified are supported
mag 01 10:58:49 foffy-cm6870 pulseaudio[1781]: Failed to load module "module-x11-xsmp" (argument: "display=:1 xauthority=/run/user/1000/xauth_yjFLvs session_manager=local/foffy-cm6870:@/tmp/.ICE-unix/1805,unix/foffy-cm6870:/tmp/.ICE-unix/1805"): initialization failed.
So it’s been a while, I believe I figured out the reason my system was getting frozen on login. It’s mainly my fault, not surprisingly.
Backstory: my desktop pc had a dead CMOS battery, so each time it lost connection to live tension, the bios reset to defaults.
The relevant setting which changed, I think, is the SATA interface which is by default set to IDE; this, from what I gather, can be a problem especially if you have a SSD and have installed the system in AHCI. So I ended up changing the battery and setting the interface to AHCI, which seems to have solved the startup issue.
AHCI is generally required for UEFI booting, as well. So, either way, the battery condition is now the obvious cause. Another typical indicator of battery failure is having to reset the date/time fairly frequently.
Good to know you’re back in the game.
