My mobo will go up to 5.0, it looks like. I’ll have to play around with that setting to see if it fixes it. I will also likely remove the riser. It came with the case, and it’s probably not the best quality, if I had to guess.
This fixed it! I’ve rebooted several times without issue. I still have to use X11 instead of Wayland, but I have read that’s more of an issue with Nvidia driver support with Wayland than anything.
So, my future steps will probably be to get a faster cable or just go with the direct install on the board. Thank you, everyone!
Setting the PCIE version seems to have fixed the GPU fan reporting:
Mon Aug 1 12:20:48 2022
| NVIDIA-SMI 515.57 Driver Version: 515.57 CUDA Version: 11.7 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A |
| 0% 41C P8 10W / 310W | 247MiB / 8192MiB | 7% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 769 G /usr/lib/Xorg 109MiB |
| 0 N/A N/A 1234 G /usr/bin/kwin_x11 78MiB |
| 0 N/A N/A 1310 G /usr/bin/plasmashell 53MiB |
| 0 N/A N/A 13118 G /usr/bin/nvidia-settings 0MiB |
