GUI extraordinarily slow after installing Nvidia 3070 TI
Hello,
Some background: I just installed a new graphics card (ASUS ROG STRIX 3070 TI OC) in my desktop (ASUS ROG STRIX Z690-A with Intel 12700K) . I had previously used the integrated graphics on my GPU until I found a good deal on a GPU. I am running the proprietary Nvidia drivers.
When I boot, the login screen seems to load and perform pretty quickly, but once I login, KDE slows to a crawl. I have tried the auto install of both the proprietary and open-source drivers, and I get the same result. To make matters stranger, it occasionally works fine on some boots. Also, XRDP desktop almost always works fine. It’s mainly just the direct boot.
I have also tried booting into the live CD. The open-source drivers work great there, but the proprietary drivers are still slow as heck there as well.
I tried looking into the forums to find this, but all I found that sounded similar was someone using an EGPU on a laptop. Anyone have any suggestions on how best to debug this?
To add here… I’m using the hybrid prime driver. Neither direct login nor XRDP work without the hybrid driver.
I also need to note that I have set my PCIE as the default graphic device in BIOS. I’m still looking to see if there is any way to completely disable the integrated graphics.
provide formatted output from:
inxi -Fazy
mhwd -l & mhwd -li
find /etc/X11/ -name "*.conf"
Thank you for the response! Here is what you asked for.
inxi -Fazy:
  Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=d7f61351-5519-4c4a-9544-dd0a1860de04 rw quiet apparmor=1
    security=apparmor udev.log_priority=3 acpi_enforce_resources=lax ibt=off
  Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 dm: SDDM
  Mobo: ASUSTeK model: ROG STRIX Z690-A GAMING WIFI D4 v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 0807
    date: 12/03/2021
  Info: model: 12th Gen Intel Core i7-12700K bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 built: 2021 process: Intel 7 (10nm ESF)
    family: 6 model-id: 0x97 (151) stepping: 2 microcode: 0x1F
  Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
    cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
    L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
  Speed (MHz): avg: 4529 high: 4915 min/max: 800/6300:6400:3800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 4196 2: 4810 3: 4889
    4: 4283 5: 4826 6: 4854 7: 4900 8: 4915 9: 4900 10: 4200 11: 4899 12: 4800
    13: 4880 14: 4815 15: 4692 16: 4653 17: 3642 18: 3822 19: 3791 20: 3819
    bogomips: 144440
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: ASUSTeK driver: nvidia
    v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2482 class-ID: 0300
  Device-2: EMEET HD Webcam C960 type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 1-13.3:8 chip-ID: 328f:003f class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :10.0
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95")
  Monitor-1: rdp0 res: 1920x1080 hz: 50 size: N/A modes: N/A
  OpenGL: renderer: llvmpipe (LLVM 14.0.6 256 bits) v: 4.5 Mesa 22.1.3
    direct render: Yes
  Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 1-13.3:8 chip-ID: 328f:003f
    alternate: snd_sof_pci_intel_tgl class-ID: 0102 bus-ID: 00:1f.3
    chip-ID: 8086:7ad0 serial: <filter> class-ID: 0403
  Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b
    class-ID: 0403
  Device-3: EMEET HD Webcam C960 type: USB driver: snd-usb-audio,uvcvideo
  Device-4: ASUSTek USB Audio type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:2 chip-ID: 0b05:1a16
    class-ID: 0300
  Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.21 running: no
  Sound Server-4: PulseAudio v: 16.1 running: yes
  Sound Server-5: PipeWire v: 0.3.56 running: yes
  Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  IF-ID-2: zt7nnnbzba state: unknown speed: 10 Mbps duplex: full
    mac: <filter>
    bus-ID: 1-14:7 chip-ID: 8087:0026 class-ID: e001
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
  Local Storage: total: 1.82 TiB used: 923.15 GiB (49.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 35.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 type: SSD serial: <filter> rev: 4B2QGXA7 temp: 39.9 C scheme: MBR
  ID-3: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk
    model: U3 Cruzer Micro size: 3.83 GiB block-size: physical: 512 B
    logical: 512 B type: N/A serial: <filter> rev: 3.21 scheme: MBR
  ID-1: / raw-size: 128.8 GiB size: 126.22 GiB (98.00%)
    used: 47.45 GiB (37.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:7
    used: 27.5 MiB (28.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
  System Temperatures: cpu: 33.0 C mobo: N/A
  Processes: 460 Uptime: 19h 58m wakeups: 0 Memory: 62.55 GiB
  used: 3.18 GiB (5.1%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1639
  pacman: 1618 lib: 405 flatpak: 5 snap: 16 Shell: Zsh v: 5.9 default: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.19
mhwd -l & mhwd -li:
> Installed PCI configs:
> 0000:01:00.0 (0300:10de:2482) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime            2021.12.18               false            PCI
          video-nvidia            2021.12.18               false            PCI
           video-linux            2018.05.04                true            PCI
    video-nvidia-470xx            2021.12.18               false            PCI
find /etc/X11/ -name “*.conf”:
/etc/X11/xorg.conf.d/00-keyboard.conf
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf
/etc/X11/xrdp/xorg.conf
/etc/X11/mhwd.d/nvidia.conf
provide output again from:
mhwd -li
and also what is this xrdp in this line:
did you installed some stuff related to xorg/graphics?
mhwd -li
/etc/X11/xrdp/xorg.conf:
Section "ServerLayout"
    Identifier "X11 Server"
    Screen "Screen (xrdpdev)"
    InputDevice "xrdpMouse" "CorePointer"
    InputDevice "xrdpKeyboard" "CoreKeyboard"
EndSection
Section "ServerFlags"
    # This line prevents "ServerLayout" sections in xorg.conf.d files
    # overriding the "X11 Server" layout (xrdp #1784)
    Option "DefaultServerLayout" "X11 Server"
    Option "DontVTSwitch" "on"
    Option "AutoAddDevices" "off"
EndSection
Section "Module"
    Load "dbe"
    Load "ddc"
    Load "extmod"
    Load "glx"
    Load "int10"
    Load "record"
    Load "vbe"
    Load "xorgxrdp"
    Load "fb"
EndSection
Section "InputDevice"
    Identifier "xrdpKeyboard"
    Driver "xrdpkeyb"
EndSection
    Identifier "xrdpMouse"
    Driver "xrdpmouse"
EndSection
Section "Monitor"
    Identifier "Monitor"
    Option "DPMS"
    HorizSync 30-80
    VertRefresh 60-75
    ModeLine "1920x1080" 138.500 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync
    ModeLine "1280x720" 74.25 1280 1720 1760 1980 720 725 730 750 +HSync +VSync
    Modeline "1368x768" 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync
    Modeline "1600x900" 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync
EndSection
Section "Device"
    Identifier "Video Card (xrdpdev)"
    Driver "xrdpdev"
    Option "DRMDevice" "/dev/dri/renderD128"
    Option "DRI3" "1"
EndSection
Section "Screen"
    Identifier "Screen (xrdpdev)"
    Device "Video Card (xrdpdev)"
    Monitor "Monitor"
    DefaultDepth 24
    SubSection "Display"
        Depth 24
        Modes "640x480" "800x600" "1024x768" "1280x720" "1280x1024" "1600x900" "1920x1080"
    EndSubSection
EndSection
If you are talking about XRDP stuff, I installed xorgxrdp-glamor, but that was months ago and worked well before the Nvidia card.
and do you need it? if not uninstall it and remove these configs:
sudo rm /etc/X11/xorg.conf
sudo rm /etc/X11/xrdp/xorg.conf
reboot and test
Valid point. I had that so I could run some GPU intensive apps over XRDP. That said, I had forgot that it was specific to Intel and AMD, and there is a separate one for Nvidia
That said, after uninstall, I still have the same issue with direct login, and now XRDP is jacked.
did you remove also this config?
if you reenable again the intel in bios, do you have still issues?
I removed the configs. I actually think this might be a clash between the HDMI audio driver on the Nvidia and the onboard Intel audio for the mobo.
That said, I think I got hit with a version update while re-installing the drivers (to test something), and I cannot remember how I resolved this last time. The following output from dmesg shows both the version magic error I’m currently facing that is stopping the kernel modules from loading, as well as the HD audio error that I am seeing.
[    4.936403] nvidia: version magic '5.15.57-2-MANJARO SMP preempt mod_unload ' should be '5.15.55-1-MANJARO SMP preempt mod_unload '
[    5.720710] snd_hda_intel 0000:00:1f.3: No response from codec, disabling MSI: last cmd=0x000f0000
[    6.724028] snd_hda_intel 0000:00:1f.3: Codec #0 probe error; disabling it...
[    7.705094] input: PC Speaker as /devices/platform/pcspkr/input/input10
[    7.730730] snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to single_cmd mode: last cmd=0x000f0000
[    7.730880] azx_single_wait_for_response: 248 callbacks suppressed
[    7.731190] hdaudio hdaudioC0D0: no AFG or MFG node found
[    7.731191] snd_hda_intel 0000:00:1f.3: no codecs initialized
provide output from:
ls /etc/modprobe.d
also there was a recent stable update, did you run it? if not run it, reboot and test
i found that this magic should be is possibly fixed with purging the 5.15 kernel and isntalling it again …
Yeah, I there was a kernel update. I just installed it, and it fixed the module issue. The direct login slowness still exists. Here is a partial dmesg after this last boot. There are a lot of errors in there around when it’s trying to enable audio.
[    3.834979] usb 1-10: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[    3.834980] usb 1-10: Product: ASM107x
[    3.834981] usb 1-10: Manufacturer: ASUS TEK.
[    3.835538] hub 1-10:1.0: USB hub found
[    3.835705] hub 1-10:1.0: 4 ports detected
[    3.855806] ACPI Warning: \_SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
[    3.959942] usb 1-13: new high-speed USB device number 5 using xhci_hcd
[    3.976755] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.013277] snd_hda_intel 0000:00:1f.3: No response from codec, disabling MSI: last cmd=0x000f0000
[    4.079546] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.079550] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.079553] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.079694] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.079696] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.079697] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.079837] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.079839] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.079840] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.079984] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.079985] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.079987] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.080126] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.080128] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.080129] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.080269] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.080270] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.080271] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.080410] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.080411] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.080413] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.080552] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.080553] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.080555] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.080694] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.080695] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.080697] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.080836] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.080837] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.080838] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.080977] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.080979] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.080980] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.081119] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.081120] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.081122] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.081261] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.081262] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.081264] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.081403] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.081404] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.081405] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.081544] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[    4.081546] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[    4.081547] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[    4.100152] usb 1-13: New USB device found, idVendor=058f, idProduct=6254, bcdDevice= 1.00
[    4.100154] usb 1-13: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.100803] hub 1-13:1.0: USB hub found
[    4.100845] hub 1-13:1.0: 4 ports detected
[    4.189944] usb 1-10.1: new high-speed USB device number 6 using xhci_hcd
[    4.299153] usb 1-10.1: New USB device found, idVendor=0781, idProduct=5406, bcdDevice= 0.10
[    4.299156] usb 1-10.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.299156] usb 1-10.1: Product: U3 Cruzer Micro
[    4.299157] usb 1-10.1: Manufacturer: SanDisk Corporation
[    4.299157] usb 1-10.1: SerialNumber: 00001868FA60E8FD
[    4.423278] usb 1-14: new full-speed USB device number 7 using xhci_hcd
[    4.564705] usb 1-14: New USB device found, idVendor=8087, idProduct=0026, bcdDevice= 0.02
[    4.564708] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.636666] usb 1-13.3: new high-speed USB device number 8 using xhci_hcd
[    4.751220] usb 1-13.3: New USB device found, idVendor=328f, idProduct=003f, bcdDevice= 1.01
[    4.751222] usb 1-13.3: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[    4.751223] usb 1-13.3: Product: HD Webcam eMeet C960
[    4.751223] usb 1-13.3: Manufacturer: EMEET
[    4.751224] usb 1-13.3: SerialNumber: SN0001
[    5.032553] snd_hda_intel 0000:00:1f.3: Codec #0 probe error; disabling it...
[    6.043318] snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to single_cmd mode: last cmd=0x000f0000
[    6.043466] azx_single_wait_for_response: 246 callbacks suppressed
[    6.043773] hdaudio hdaudioC0D0: no AFG or MFG node found
[    6.043775] snd_hda_intel 0000:00:1f.3: no codecs initialized
[   10.813297] NVRM: GPU at PCI:0000:01:00: GPU-b11671af-fbd5-ca45-7b3c-e397c0d5b38a
[   10.813299] NVRM: Xid (PCI:0000:01:00): 122, pid='<unknown>', name=<unknown>, SPI read failure at address 1296! (0x00000065)
[   11.063794] NVRM: Xid (PCI:0000:01:00): 62, pid='<unknown>', name=<unknown>, 0000(0000) 00000000 00000000
[   12.297414] input: PC Speaker as /devices/platform/pcspkr/input/input10
[   12.390715] perf uncore: Cannot find matched IMC device.
[   12.390721] perf uncore: Cannot find matched IMC device.
[   12.395069] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 655360 ms ovfl timer
[   12.395070] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   12.395071] RAPL PMU: hw unit of domain package 2^-14 Joules
[   12.397344] cryptd: max_cpu_qlen set to 1000
[   12.404570] AVX2 version of gcm_enc/dec engaged.
[   12.404602] AES CTR mode by8 optimization enabled
[   12.718943] intel_tcc_cooling: Programmable TCC Offset detected
[   13.829634] audit: type=1131 audit(1659126657.843:124): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.126771] iTCO_vendor_support: vendor-support=0
[   14.130829] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[   14.130897] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   14.132450] i8042: PNP: No PS/2 controller found.
[   14.139247] asus_wmi: ASUS WMI generic driver loaded
[   14.141153] asus_wmi: SFUN value: 0x1
[   14.141155] eeepc-wmi eeepc-wmi: Detected ATK, not ASUSWMI, use DSTS
[   14.141366] asus_wmi: SFUN value: 0x1
[   14.141368] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[   14.141369] asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
[   14.141385] asus_wmi: Failed to get WMI notify code: AE_NOT_FOUND
[   14.141386] asus_wmi: Failed to get event during flush: -5
[   14.141560] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input11
[   14.141856] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input12
[   14.256614] ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[   14.256626] ee1004 0-0051: 512 byte EE1004-compliant SPD EEPROM, read-only
[   14.256631] ee1004 0-0052: 512 byte EE1004-compliant SPD EEPROM, read-only
[   14.256635] ee1004 0-0053: 512 byte EE1004-compliant SPD EEPROM, read-only
[   14.395001] audit: type=1130 audit(1659126658.409:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.395411] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[   14.408992] mc: Linux media interface: v0.10
[   14.411235] audit: type=1130 audit(1659126658.426:126): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.416489] hid-generic 0003:0B05:1A16.0001: hiddev96,hidraw0: USB HID v1.11 Device [Generic USB Audio] on usb-0000:00:14.0-2/input7
[   14.417142] hid-generic 0003:0B05:19AF.0002: hiddev97,hidraw1: USB HID v1.11 Device [AsusTek Computer Inc. AURA LED Controller] on usb-0000:00:14.0-4/input2
[   14.417154] usbcore: registered new interface driver usbhid
[   14.417155] usbhid: USB HID core driver
[   14.450935] usb-storage 1-10.1:1.0: USB Mass Storage device detected
[   14.450986] scsi host10: usb-storage 1-10.1:1.0
[   14.451049] usbcore: registered new interface driver usb-storage
[   14.454962] usbcore: registered new interface driver uas
[   14.462245] videodev: Linux video capture interface: v2.00
[   14.524552] Bluetooth: Core ver 2.22
[   14.524566] NET: Registered PF_BLUETOOTH protocol family
[   14.524566] Bluetooth: HCI device and connection manager initialized
[   14.524568] Bluetooth: HCI socket layer initialized
[   14.524571] Bluetooth: L2CAP socket layer initialized
[   14.524572] Bluetooth: SCO socket layer initialized
[   14.532989] usb 1-13.3: Found UVC 1.00 device HD Webcam eMeet C960 (328f:003f)
[   14.533552] usb 1-13.3: Failed to query (GET_INFO) UVC control 5 on unit 1: 0 (exp. 1).
[   14.533701] usb 1-13.3: Failed to query (GET_INFO) UVC control 12 on unit 1: 0 (exp. 1).
[   14.543363] input: HD Webcam eMeet C960: HD Webcam as /devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13.3/1-13.3:1.0/input/input13
[   14.543393] usbcore: registered new interface driver uvcvideo
[   14.610938] igc 0000:07:00.0 enp7s0: renamed from eth0
[   14.643562] usbcore: registered new interface driver btusb
[   14.643873] intel_rapl_msr: PL4 support detected.
[   14.643897] intel_rapl_common: Found RAPL domain package
[   14.643899] intel_rapl_common: Found RAPL domain core
[   14.645416] Bluetooth: hci0: Device revision is 2
[   14.645417] Bluetooth: hci0: Secure boot is enabled
[   14.645417] Bluetooth: hci0: OTP lock is enabled
[   14.645418] Bluetooth: hci0: API lock is enabled
[   14.645418] Bluetooth: hci0: Debug lock is disabled
[   14.645418] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[   14.645419] Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
[   14.646019] Bluetooth: hci0: Found device firmware: intel/ibt-1040-4150.sfi
[   14.672375] audit: type=1130 audit(1659126658.686:127): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.696970] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   14.696972] Bluetooth: BNEP filters: protocol multicast
[   14.696976] Bluetooth: BNEP socket layer initialized
[   14.831654] audit: type=1130 audit(1659126658.846:128): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.833772] audit: type=1130 audit(1659126658.849:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.876631] NVRM: Xid (PCI:0000:01:00): 122, pid='<unknown>', name=<unknown>, SPI read failure at address 272! (0x00000065)
[   14.933401] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[   14.933405] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[   14.933407] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[   14.933548] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
[   14.933550] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
[   14.933551] ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
[   15.457292] scsi 10:0:0:0: Direct-Access     SanDisk  U3 Cruzer Micro  3.21 PQ: 0 ANSI: 2
[   15.457363] sd 10:0:0:0: Attached scsi generic sg0 type 0
[   15.459093] sd 10:0:0:0: [sda] 8027793 512-byte logical blocks: (4.11 GB/3.83 GiB)
[   15.459311] sd 10:0:0:0: [sda] Write Protect is off
[   15.459313] sd 10:0:0:0: [sda] Mode Sense: 03 00 00 00
[   15.459516] sd 10:0:0:0: [sda] No Caching mode page found
[   15.459517] sd 10:0:0:0: [sda] Assuming drive cache: write through
[   15.464602]  sda: sda1 sda2
[   15.467194] sd 10:0:0:0: [sda] Attached SCSI removable disk
[   15.964446] Bluetooth: hci0: Waiting for firmware download to complete
[   15.964454] Bluetooth: hci0: Firmware loaded in 1287532 usecs
[   15.964514] Bluetooth: hci0: Waiting for device to boot
[   15.982413] Bluetooth: hci0: Device booted in 17505 usecs
[   15.990695] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-1040-4150.ddc
[   15.992502] Bluetooth: hci0: Applying Intel DDC parameters completed
[   15.996514] Bluetooth: hci0: Firmware timestamp 2022.22 buildtype 1 build 44918
[   16.113431] NET: Registered PF_ALG protocol family
[   16.249676] audit: type=1100 audit(1659126660.263:130): pid=1042 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[   16.249697] audit: type=1101 audit(1659126660.263:131): pid=1042 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[   16.250535] audit: type=1103 audit(1659126660.266:132): pid=1042 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[   16.274159] audit: type=1130 audit(1659126660.289:133): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   18.647237] igc 0000:07:00.0 enp7s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[   18.647477] IPv6: ADDRCONF(NETDEV_CHANGE): enp7s0: link becomes ready
[   18.712660] process '/usr/bin/zerotier-one' started with executable stack
[   18.828322] tun: Universal TUN/TAP device driver, 1.6
[   18.845689] usb 1-13.3: 3:1: cannot get freq at ep 0x84
[   18.851614] usbcore: registered new interface driver snd-usb-audio
[   19.661795] kauditd_printk_skb: 17 callbacks suppressed
[   19.661801] audit: type=1131 audit(1659126663.676:145): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   24.842791] audit: type=1131 audit(1659126668.856:146): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   25.056830] NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000009
[   29.033416] usb 1-8: new full-speed USB device number 9 using xhci_hcd
[   29.175495] usb 1-8: New USB device found, idVendor=0951, idProduct=16b7, bcdDevice= 0.11
[   29.175513] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   29.175519] usb 1-8: Product: HyperX Alloy FPS Mechanical Gaming Keyboard
[   29.175523] usb 1-8: Manufacturer: Kingston
[   29.180148] input: Kingston HyperX Alloy FPS Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:0951:16B7.0003/input/input14
[   29.237323] hid-generic 0003:0951:16B7.0003: input,hidraw2: USB HID v1.11 Keyboard [Kingston HyperX Alloy FPS Mechanical Gaming Keyboard] on usb-0000:00:14.0-8/input0
[   29.239389] input: Kingston HyperX Alloy FPS Mechanical Gaming Keyboard Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.1/0003:0951:16B7.0004/input/input15
[   29.239598] input: Kingston HyperX Alloy FPS Mechanical Gaming Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.1/0003:0951:16B7.0004/input/input16
[   29.294000] input: Kingston HyperX Alloy FPS Mechanical Gaming Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.1/0003:0951:16B7.0004/input/input17
[   29.294384] input: Kingston HyperX Alloy FPS Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.1/0003:0951:16B7.0004/input/input19
[   29.295157] hid-generic 0003:0951:16B7.0004: input,hiddev98,hidraw3: USB HID v1.11 Mouse [Kingston HyperX Alloy FPS Mechanical Gaming Keyboard] on usb-0000:00:14.0-8/input1
[   29.296197] hid-generic 0003:0951:16B7.0005: hiddev99,hidraw4: USB HID v1.11 Device [Kingston HyperX Alloy FPS Mechanical Gaming Keyboard] on usb-0000:00:14.0-8/input2
[   29.465272] mousedev: PS/2 mouse device common for all mice
[   29.506819] usb 1-13.4: new full-speed USB device number 10 using xhci_hcd
[   29.609850] usb 1-13.4: New USB device found, idVendor=04d9, idProduct=fa58, bcdDevice= 1.10
[   29.609864] usb 1-13.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[   29.609870] usb 1-13.4: Product: USB Laser Game Mouse
[   29.623616] input: USB Laser Game Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13.4/1-13.4:1.0/0003:04D9:FA58.0006/input/input20
[   29.623983] hid-generic 0003:04D9:FA58.0006: input,hidraw5: USB HID v1.10 Mouse [USB Laser Game Mouse] on usb-0000:00:14.0-13.4/input0
[   29.628228] input: USB Laser Game Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13.4/1-13.4:1.1/0003:04D9:FA58.0007/input/input21
[   29.684041] hid-generic 0003:04D9:FA58.0007: input,hidraw6: USB HID v1.10 Keyboard [USB Laser Game Mouse] on usb-0000:00:14.0-13.4/input1
[   29.694420] input: USB Laser Game Mouse Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13.4/1-13.4:1.2/0003:04D9:FA58.0008/input/input22
[   29.750555] input: USB Laser Game Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13.4/1-13.4:1.2/0003:04D9:FA58.0008/input/input23
[   29.751384] hid-generic 0003:04D9:FA58.0008: input,hiddev100,hidraw7: USB HID v1.10 Device [USB Laser Game Mouse] on usb-0000:00:14.0-13.4/input2
[   33.161883] audit: type=1100 audit(1659126677.176:147): pid=1128 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="havoc" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=failed'
[   33.941171] audit: type=1131 audit(1659126677.956:148): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   33.963592] audit: type=1334 audit(1659126677.979:149): prog-id=0 op=UNLOAD
[   33.963608] audit: type=1334 audit(1659126677.979:150): prog-id=0 op=UNLOAD
[   33.963614] audit: type=1334 audit(1659126677.979:151): prog-id=0 op=UNLOAD
[   37.257183] audit: type=1334 audit(1659126681.186:152): prog-id=23 op=LOAD
[   37.257435] audit: type=1334 audit(1659126681.189:153): prog-id=24 op=LOAD
[   37.257594] audit: type=1334 audit(1659126681.189:154): prog-id=25 op=LOAD
[   37.280399] audit: type=1130 audit(1659126681.208:155): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   39.152515] audit: type=1100 audit(1659126683.047:156): pid=1133 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="havoc" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[   39.152517] audit: type=1101 audit(1659126683.047:157): pid=1133 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="havoc" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[   39.152768] audit: type=1103 audit(1659126683.047:158): pid=1133 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="havoc" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[   39.152771] audit: type=1006 audit(1659126683.047:159): pid=1133 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[   39.152772] audit: type=1300 audit(1659126683.047:159): arch=c000003e syscall=1 success=yes exit=4 a0=7 a1=7ffc41ad9410 a2=4 a3=7ffc41ad9124 items=0 ppid=757 pid=1133 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj==unconfined key=(null)
[   39.152773] audit: type=1327 audit(1659126683.047:159): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746833303361626334352D343763352D346235652D383464612D316532396362646638646330002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
[   39.168524] audit: type=1130 audit(1659126683.060:160): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   39.171289] audit: type=1101 audit(1659126683.064:161): pid=1135 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="havoc" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   39.171309] audit: type=1103 audit(1659126683.064:162): pid=1135 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="havoc" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[   39.171332] audit: type=1006 audit(1659126683.064:163): pid=1135 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[   41.866662] usb 1-8: USB disconnect, device number 9
[   42.085652] usb 1-13.4: USB disconnect, device number 10
[   44.913227] kauditd_printk_skb: 11 callbacks suppressed
[   44.913233] audit: type=1131 audit(1659126688.742:171): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   45.081928] audit: type=1334 audit(1659126688.911:172): prog-id=0 op=UNLOAD
[   45.081938] audit: type=1334 audit(1659126688.911:173): prog-id=0 op=UNLOAD
[   45.081941] audit: type=1334 audit(1659126688.911:174): prog-id=0 op=UNLOAD
[   45.299684] audit: type=1130 audit(1659126689.126:175): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   45.301907] audit: type=1334 audit(1659126689.129:176): prog-id=27 op=LOAD
[   45.301959] audit: type=1334 audit(1659126689.129:177): prog-id=28 op=LOAD
[   45.328633] audit: type=1130 audit(1659126689.156:178): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   45.432279] audit: type=1130 audit(1659126689.258:179): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   45.462545] audit: type=1400 audit(1659126689.288:180): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=1344 comm="snap-confine" capability=12  capname="net_admin"
[   45.470797] ISO 9660 Extensions: Microsoft Joliet Level 3
[   45.472821] ISO 9660 Extensions: Microsoft Joliet Level 3
[   45.474691] ISO 9660 Extensions: RRIP_1991A
[   45.875801] usb 1-13.3: 3:1: cannot get freq at ep 0x84
[   45.879173] usb 1-13.3: 3:1: cannot get freq at ep 0x84
[   47.550673] NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000a
[   47.879305] Bluetooth: RFCOMM TTY layer initialized
[   47.879311] Bluetooth: RFCOMM socket layer initialized
[   47.879313] Bluetooth: RFCOMM ver 1.11
[   52.831263] usb 1-13.3: Failed to query (GET_DEF) UVC control 12 on unit 1: 0 (exp. 3).
[   52.831428] usb 1-13.3: Failed to query (GET_MIN) UVC control 12 on unit 1: 0 (exp. 3).
[   52.831534] usb 1-13.3: Failed to query (GET_MAX) UVC control 12 on unit 1: 0 (exp. 3).
[   52.831703] usb 1-13.3: Failed to query (GET_RES) UVC control 12 on unit 1: 0 (exp. 3).
[   52.865367] kauditd_printk_skb: 9 callbacks suppressed
[   52.865369] audit: type=1111 audit(1659126696.659:184): pid=709 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="enp7s0" ifindex=3 args=500 pid=1622 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[   52.869018] audit: type=1111 audit(1659126696.662:185): pid=709 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlo1" ifindex=2 args=500 pid=1622 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[   52.870815] audit: type=1334 audit(1659126696.662:186): prog-id=30 op=LOAD
[   52.870993] audit: type=1334 audit(1659126696.665:187): prog-id=31 op=LOAD
[   52.871164] audit: type=1334 audit(1659126696.665:188): prog-id=32 op=LOAD
[   52.896315] audit: type=1130 audit(1659126696.688:189): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   52.984245] audit: type=1111 audit(1659126696.775:190): pid=709 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlo1" ifindex=2 args=500 pid=1622 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[   53.095560] audit: type=1334 audit(1659126696.888:191): prog-id=33 op=LOAD
[   53.095845] audit: type=1334 audit(1659126696.888:192): prog-id=34 op=LOAD
[   53.095914] audit: type=1334 audit(1659126696.888:193): prog-id=35 op=LOAD
[   55.683854] NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000b
[   63.799363] NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000c
[   67.464467] kauditd_printk_skb: 3 callbacks suppressed
[   67.464470] audit: type=1131 audit(1659126711.242:197): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   67.521191] audit: type=1334 audit(1659126711.298:198): prog-id=0 op=UNLOAD
[   67.521195] audit: type=1334 audit(1659126711.298:199): prog-id=0 op=UNLOAD
[   67.521196] audit: type=1334 audit(1659126711.298:200): prog-id=0 op=UNLOAD
[   68.401131] audit: type=1334 audit(1659126712.179:201): prog-id=0 op=UNLOAD
[   69.500766] audit: type=1100 audit(1659126713.275:202): pid=1749 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="havoc" exe="/usr/bin/sshd" hostname=192.168.2.47 addr=192.168.2.47 terminal=ssh res=success'
[   69.501317] audit: type=1101 audit(1659126713.279:203): pid=1749 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="havoc" exe="/usr/bin/sshd" hostname=192.168.2.47 addr=192.168.2.47 terminal=ssh res=success'
[   69.501821] audit: type=1103 audit(1659126713.279:204): pid=1749 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="havoc" exe="/usr/bin/sshd" hostname=192.168.2.47 addr=192.168.2.47 terminal=ssh res=success'
[   69.501843] audit: type=1006 audit(1659126713.279:205): pid=1749 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=4 res=1
[   69.501851] audit: type=1300 audit(1659126713.279:205): arch=c000003e syscall=1 success=yes exit=4 a0=3 a1=7ffe22b6bd00 a2=4 a3=7ffe22b6ba14 items=0 ppid=747 pid=1749 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4 comm="sshd" exe="/usr/bin/sshd" subj==unconfined key=(null)
[   71.907391] NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000d
[   80.013729] NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000e
[   80.137488] kauditd_printk_skb: 3 callbacks suppressed
[   80.137490] audit: type=1100 audit(1659126723.916:208): pid=1873 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="havoc" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[   80.137562] audit: type=1101 audit(1659126723.916:209): pid=1873 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="havoc" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[   80.137862] audit: type=1110 audit(1659126723.916:210): pid=1873 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[   80.138883] audit: type=1105 audit(1659126723.916:211): pid=1873 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
check with lspci what you have under the PCI:0000:01:00
also the otput from:
ls /etc/modprobe.d
also provide logs:
journalctl -b0 -p4 --no-pager
and if you really think its because of the nvdia audio we can blacklist it and test if it helps
I mean, I could be wrong. That was the main thing I was seeing, but you seem to have found something there.
lspci:
00:00.0 Host bridge: Intel Corporation 12th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:01.0 PCI bridge: Intel Corporation 12th Gen Core Processor PCI Express x16 Controller #1 (rev 02)
00:06.0 PCI bridge: Intel Corporation 12th Gen Core Processor PCI Express x4 Controller #0 (rev 02)
00:0a.0 Signal processing controller: Intel Corporation Platform Monitoring Technology (rev 01)
00:0e.0 RAID bus controller: Intel Corporation Volume Management Device NVMe RAID Controller
00:14.0 USB controller: Intel Corporation Alder Lake-S PCH USB 3.2 Gen 2x2 XHCI Controller (rev 11)
00:14.2 RAM memory: Intel Corporation Alder Lake-S PCH Shared SRAM (rev 11)
00:14.3 Network controller: Intel Corporation Alder Lake-S PCH CNVi WiFi (rev 11)
00:15.0 Serial bus controller: Intel Corporation Alder Lake-S PCH Serial IO I2C Controller #0 (rev 11)
00:15.1 Serial bus controller: Intel Corporation Alder Lake-S PCH Serial IO I2C Controller #1 (rev 11)
00:15.2 Serial bus controller: Intel Corporation Alder Lake-S PCH Serial IO I2C Controller #2 (rev 11)
00:16.0 Communication controller: Intel Corporation Alder Lake-S PCH HECI Controller #1 (rev 11)
00:17.0 SATA controller: Intel Corporation Alder Lake-S PCH SATA Controller [AHCI Mode] (rev 11)
00:1a.0 PCI bridge: Intel Corporation Device 7ac8 (rev 11)
00:1b.0 PCI bridge: Intel Corporation Device 7ac4 (rev 11)
00:1c.0 PCI bridge: Intel Corporation Alder Lake-S PCH PCI Express Root Port #1 (rev 11)
00:1c.1 PCI bridge: Intel Corporation Alder Lake-S PCH PCI Express Root Port #2 (rev 11)
00:1c.3 PCI bridge: Intel Corporation Device 7abb (rev 11)
00:1f.0 ISA bridge: Intel Corporation Z690 Chipset LPC/eSPI Controller (rev 11)
00:1f.3 Audio device: Intel Corporation Alder Lake-S HD Audio Controller (rev 11)
00:1f.4 SMBus: Intel Corporation Alder Lake-S PCH SMBus Controller (rev 11)
00:1f.5 Serial bus controller: Intel Corporation Alder Lake-S PCH SPI Controller (rev 11)
01:00.0 VGA compatible controller: NVIDIA Corporation GA104 [GeForce RTX 3070 Ti] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO
04:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO
06:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
07:00.0 Ethernet controller: Intel Corporation Ethernet Controller I225-V (rev 03)
ls /etc/modprobe.d:
mhwd-gpu.conf
contents of that file:
## Generated by mhwd - Manjaro Hardware Detection
blacklist nouveau
blacklist ttm
blacklist drm_kms_helper
blacklist drm
Jul 29 15:30:45 havoc-manjaro kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
Jul 29 15:30:45 havoc-manjaro kernel:  #17 #18 #19
Jul 29 15:30:45 havoc-manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jul 29 15:30:45 havoc-manjaro kernel: hpet_acpi_add: no address or irqs in _CRS
Jul 29 15:30:45 havoc-manjaro kernel: nvidia: loading out-of-tree module taints kernel.
Jul 29 15:30:45 havoc-manjaro kernel: nvidia: module license 'NVIDIA' taints kernel.
Jul 29 15:30:45 havoc-manjaro kernel: Disabling lock debugging due to kernel taint
Jul 29 15:30:45 havoc-manjaro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  515.57  Wed Jun 22 22:44:07 UTC 2022
Jul 29 15:30:45 havoc-manjaro kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Jul 29 15:30:45 havoc-manjaro systemd-modules-load[436]: Failed to find module 'i2c-nct6775'
Jul 29 15:30:45 havoc-manjaro kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jul 29 15:30:45 havoc-manjaro kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jul 29 15:30:45 havoc-manjaro kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jul 29 15:30:45 havoc-manjaro kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jul 29 15:30:45 havoc-manjaro kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jul 29 15:30:45 havoc-manjaro kernel: acpi PNP0C14:06: duplicate WMI GUID 97845ED0-4E6D-11DE-8A39-0800200C9A66 (first instance was on PNP0C14:02)
Jul 29 15:30:45 havoc-manjaro kernel: acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jul 29 15:30:46 havoc-manjaro kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-66.ucode failed with error -2
Jul 29 15:30:46 havoc-manjaro kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-65.ucode failed with error -2
Jul 29 15:30:46 havoc-manjaro kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Jul 29 15:30:46 havoc-manjaro kernel: thermal thermal_zone1: failed to read out thermal zone (-61)
Jul 29 15:30:46 havoc-manjaro systemd-udevd[552]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Jul 29 15:30:47 havoc-manjaro kernel: snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to polling mode: last cmd=0x000f0000
Jul 29 15:30:47 havoc-manjaro kernel: usb 1-4: config 1 has an invalid interface number: 2 but max is 1
Jul 29 15:30:47 havoc-manjaro kernel: usb 1-4: config 1 has no interface number 1
Jul 29 15:30:47 havoc-manjaro kernel: ACPI Warning: \_SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)Jul 29 15:30:48 havoc-manjaro kernel: snd_hda_intel 0000:00:1f.3: No response from codec, disabling MSI: last cmd=0x000f0000
Jul 29 15:30:48 havoc-manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
Jul 29 15:30:48 havoc-manjaro kernel: ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
Jul 29 15:30:48 havoc-manjaro kernel: ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
Jul 29 15:30:48 havoc-manjaro libvirtd[746]: Unable to open /dev/kvm: No such file or directory
Jul 29 15:30:48 havoc-manjaro libvirtd[746]: internal error: Missing udev property 'ID_VENDOR_ID' on 'usb1'
Jul 29 15:30:48 havoc-manjaro libvirtd[746]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-10'
Jul 29 15:30:48 havoc-manjaro libvirtd[746]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-10.1'
Jul 29 15:30:48 havoc-manjaro libvirtd[746]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-13'
Jul 29 15:30:48 havoc-manjaro libvirtd[746]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-2'
Jul 29 15:30:48 havoc-manjaro libvirtd[746]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-4'
Jul 29 15:30:48 havoc-manjaro libvirtd[746]: internal error: Missing udev property 'ID_VENDOR_ID' on '2-8'
Jul 29 15:30:49 havoc-manjaro kernel: snd_hda_intel 0000:00:1f.3: Codec #0 probe error; disabling it...
Jul 29 15:30:50 havoc-manjaro kernel: snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to single_cmd mode: last cmd=0x000f0000
Jul 29 15:30:50 havoc-manjaro kernel: azx_single_wait_for_response: 246 callbacks suppressed
Jul 29 15:30:50 havoc-manjaro kernel: hdaudio hdaudioC0D0: no AFG or MFG node found
Jul 29 15:30:50 havoc-manjaro kernel: snd_hda_intel 0000:00:1f.3: no codecs initialized
Jul 29 15:30:54 havoc-manjaro kernel: NVRM: GPU at PCI:0000:01:00: GPU-b11671af-fbd5-ca45-7b3c-e397c0d5b38a
Jul 29 15:30:54 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 122, pid='<unknown>', name=<unknown>, SPI read failure at address 1296! (0x00000065)
Jul 29 15:30:55 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 62, pid='<unknown>', name=<unknown>, 0000(0000) 00000000 00000000
Jul 29 15:30:56 havoc-manjaro kernel: perf uncore: Cannot find matched IMC device.
Jul 29 15:30:58 havoc-manjaro kernel: asus_wmi: Failed to get WMI notify code: AE_NOT_FOUND
Jul 29 15:30:58 havoc-manjaro kernel: asus_wmi: Failed to get event during flush: -5
Jul 29 15:30:58 havoc-manjaro kernel: usb 1-13.3: Failed to query (GET_INFO) UVC control 5 on unit 1: 0 (exp. 1).
Jul 29 15:30:58 havoc-manjaro kernel: usb 1-13.3: Failed to query (GET_INFO) UVC control 12 on unit 1: 0 (exp. 1).
Jul 29 15:30:58 havoc-manjaro systemd-udevd[516]: event11: Failed to call EVIOCSKEYCODE with scan code 0x7c, and key code 190: Invalid argument
Jul 29 15:30:58 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 122, pid='<unknown>', name=<unknown>, SPI read failure at address 272! (0x00000065)
Jul 29 15:30:58 havoc-manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
Jul 29 15:30:58 havoc-manjaro kernel: ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
Jul 29 15:30:58 havoc-manjaro kernel: ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
Jul 29 15:30:59 havoc-manjaro kernel: sd 10:0:0:0: [sda] No Caching mode page found
Jul 29 15:30:59 havoc-manjaro kernel: sd 10:0:0:0: [sda] Assuming drive cache: write through
Jul 29 15:31:00 havoc-manjaro systemd[1044]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Jul 29 15:31:00 havoc-manjaro systemd[1044]: Failed to start Update XDG user dir configuration.
Jul 29 15:31:00 havoc-manjaro sddm-greeter[1053]: QFont::fromString: Invalid description '(empty)'
Jul 29 15:31:00 havoc-manjaro sddm-greeter[1053]: QObject: Cannot create children for a parent that is in a different thread.
                                                  (Parent is QGuiApplication(0x7ffdde5ae830), parent's thread is QThread(0x55df7ec82650), current thread is QThread(0x55df7ed591e0)
Jul 29 15:31:00 havoc-manjaro sddm-greeter[1053]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Jul 29 15:31:00 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/Main.qml:440:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jul 29 15:31:00 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/VirtualKeyboard.qml:23:1: Type InputPanel unavailable
Jul 29 15:31:00 havoc-manjaro sddm-greeter[1053]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Jul 29 15:31:00 havoc-manjaro sddm-greeter[1053]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Jul 29 15:31:00 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/Login.qml:92:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jul 29 15:31:02 havoc-manjaro kernel: process '/usr/bin/zerotier-one' started with executable stack
Jul 29 15:31:02 havoc-manjaro kernel: usb 1-13.3: 3:1: cannot get freq at ep 0x84
Jul 29 15:31:03 havoc-manjaro kernel: kauditd_printk_skb: 17 callbacks suppressed
Jul 29 15:31:09 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000009
Jul 29 15:31:19 havoc-manjaro sddm-helper[1128]: [PAM] authenticate: Authentication failure
Jul 29 15:31:19 havoc-manjaro sddm[757]: Authentication error: "Authentication failure"
Jul 29 15:31:19 havoc-manjaro sddm[757]: Auth: sddm-helper exited with 1
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/Main.qml:415: TypeError: Cannot read property 'smallSpacing' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/ActionButton.qml:64: TypeError: Cannot read property 'smallSpacing' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/ActionButton.qml:34: TypeError: Cannot read property 'gridUnit' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/ActionButton.qml:36: TypeError: Cannot read property 'largeSpacing' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/ActionButton.qml:37: TypeError: Cannot read property 'smallSpacing' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/SessionManagementScreen.qml:83: TypeError: Cannot read property 'gridUnit' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/SessionManagementScreen.qml:112: TypeError: Cannot read property 'smallSpacing' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/SessionManagementScreen.qml:98: TypeError: Cannot read property 'gridUnit' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/SessionManagementScreen.qml:99: TypeError: Cannot read property 'gridUnit' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/SessionManagementScreen.qml:89: TypeError: Cannot read property 'gridUnit' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/UserList.qml:25: TypeError: Cannot read property 'gridUnit' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/UserList.qml:26: TypeError: Cannot read property 'gridUnit' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/UserDelegate.qml:106: TypeError: Cannot read property 'largeSpacing' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/UserDelegate.qml:44: TypeError: Cannot read property 'smallSpacing' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/UserDelegate.qml:72: TypeError: Cannot read property 'largeSpacing' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/UserDelegate.qml:98: TypeError: Cannot read property 'gridUnit' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/UserDelegate.qml:78: TypeError: Cannot read property 'longDuration' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/components/UserDelegate.qml:50: TypeError: Cannot read property 'longDuration' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/Main.qml:202: TypeError: Cannot read property 'longDuration' of null
Jul 29 15:31:23 havoc-manjaro sddm-greeter[1053]: file:///usr/share/sddm/themes/Sweet/Main.qml:420: TypeError: Cannot read property 'longDuration' of null
Jul 29 15:31:23 havoc-manjaro startplasma-x11[1149]: kf.service.services: The action "QuitTeams" in the desktop file "/var/lib/snapd/desktop/applications/teams_teams.desktop" has no Name or no Exec key
Jul 29 15:31:23 havoc-manjaro startplasma-x11[1149]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but no Exec line
Jul 29 15:31:23 havoc-manjaro startplasma-x11[1149]: kf.service.sycoca: Invalid Service :  "/usr/share/applications/qemu.desktop"
Jul 29 15:31:23 havoc-manjaro klauncher[1180]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jul 29 15:31:23 havoc-manjaro kcminit_startup[1184]: QDBusConnection: error: could not send signal to service "" path "//home/havoc/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/havoc/.kde4/share/config/kdeglobals
Jul 29 15:31:28 havoc-manjaro kernel: kauditd_printk_skb: 11 callbacks suppressed
Jul 29 15:31:28 havoc-manjaro kwin_x11[1195]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Jul 29 15:31:29 havoc-manjaro kwin_x11[1195]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Jul 29 15:31:29 havoc-manjaro kwin_x11[1195]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Jul 29 15:31:29 havoc-manjaro kded5[1192]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.8'
Jul 29 15:31:29 havoc-manjaro ksmserver[1265]: Qt: Session management error: networkIdsList argument is NULL
Jul 29 15:31:29 havoc-manjaro kernel: usb 1-13.3: 3:1: cannot get freq at ep 0x84
Jul 29 15:31:31 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000a
Jul 29 15:31:31 havoc-manjaro backlighthelper[1483]: org.kde.powerdevil: no kernel backlight interface found
Jul 29 15:31:31 havoc-manjaro org_kde_powerdevil[1280]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Jul 29 15:31:31 havoc-manjaro org_kde_powerdevil[1280]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Jul 29 15:31:31 havoc-manjaro pulseaudio[1328]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jul 29 15:31:36 havoc-manjaro kwin_x11[1195]: kwin_core: XCB error: 10 (BadAccess), sequence: 849, resource id: 474, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Jul 29 15:31:36 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 930, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
Jul 29 15:31:36 havoc-manjaro org_kde_powerdevil[1280]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jul 29 15:31:36 havoc-manjaro org_kde_powerdevil[1280]: org.kde.powerdevil: The profile  "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Jul 29 15:31:36 havoc-manjaro org_kde_powerdevil[1280]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Jul 29 15:31:36 havoc-manjaro gnome-keyring-daemon[1640]: discover_other_daemon: 1
Jul 29 15:31:36 havoc-manjaro kernel: usb 1-13.3: Failed to query (GET_DEF) UVC control 12 on unit 1: 0 (exp. 3).
Jul 29 15:31:36 havoc-manjaro kernel: usb 1-13.3: Failed to query (GET_MIN) UVC control 12 on unit 1: 0 (exp. 3).
Jul 29 15:31:36 havoc-manjaro kernel: usb 1-13.3: Failed to query (GET_MAX) UVC control 12 on unit 1: 0 (exp. 3).
Jul 29 15:31:36 havoc-manjaro kernel: usb 1-13.3: Failed to query (GET_RES) UVC control 12 on unit 1: 0 (exp. 3).
Jul 29 15:31:36 havoc-manjaro kernel: kauditd_printk_skb: 9 callbacks suppressed
Jul 29 15:31:36 havoc-manjaro plasmashell[1286]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:43:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
Jul 29 15:31:36 havoc-manjaro plasmashell[1286]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:41: TypeError: Cannot read property 'length' of undefined
Jul 29 15:31:36 havoc-manjaro plasmashell[1286]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jul 29 15:31:36 havoc-manjaro plasmashell[1286]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/FullRepresentation.qml:21:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
Jul 29 15:31:36 havoc-manjaro plasmashell[1286]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.horizontalbars/contents/ui/FullRepresentation.qml:28:9: Unable to assign [undefined] to double
Jul 29 15:31:36 havoc-manjaro baloo_file_extractor[1516]: kf.baloo: Found "/home/havoc/snap/teams/7/.config" in the ContentIndexingDB, although it should be skipped
Jul 29 15:31:37 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1277, resource id: 60817414, major code: 18 (ChangeProperty), minor code: 0
Jul 29 15:31:39 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000b
Jul 29 15:31:39 havoc-manjaro plasmashell[1286]: kf.quickcharts.deprecated: LegendDelegate::colorVisible is deprecated (since 5.82): Use an empty indicator instead
Jul 29 15:31:39 havoc-manjaro plasmashell[1286]: kf.quickcharts.deprecated: LegendDelegate::layoutWidth is deprecated (since 5.82): Unused
Jul 29 15:31:39 havoc-manjaro plasmashell[1286]: kf.quickcharts.deprecated: LegendDelegate::valueWidth is deprecated (since 5.82): Use maximumValueWidth instead
Jul 29 15:31:39 havoc-manjaro kded5[1192]: kf.service.services: The action "QuitTeams" in the desktop file "/var/lib/snapd/desktop/applications/teams_teams.desktop" has no Name or no Exec key
Jul 29 15:31:39 havoc-manjaro kded5[1192]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but no Exec line
Jul 29 15:31:39 havoc-manjaro kded5[1192]: kf.service.sycoca: Invalid Service :  "/usr/share/applications/qemu.desktop"
Jul 29 15:31:44 havoc-manjaro plasmashell[1286]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Jul 29 15:31:44 havoc-manjaro plasmashell[1286]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Jul 29 15:31:44 havoc-manjaro plasmashell[1286]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Jul 29 15:31:44 havoc-manjaro plasmashell[1286]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x564ca5790ad0)
Jul 29 15:31:44 havoc-manjaro plasmashell[1286]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x564ca5751b40)
Jul 29 15:31:44 havoc-manjaro plasmashell[1286]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x564ca573e2d0)
Jul 29 15:31:44 havoc-manjaro plasmashell[1286]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x564ca56f49f0)
Jul 29 15:31:44 havoc-manjaro plasmashell[1286]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x564ca573e2d0)
Jul 29 15:31:44 havoc-manjaro plasmashell[1286]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x564ca4e4c840)
Jul 29 15:31:47 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000c
Jul 29 15:31:51 havoc-manjaro kernel: kauditd_printk_skb: 3 callbacks suppressed
Jul 29 15:31:55 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000d
Jul 29 15:32:00 havoc-manjaro xembedsniproxy[1285]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 449, resource id: 54525955, major code: 12 (ConfigureWindow), minor code: 0
Jul 29 15:32:00 havoc-manjaro plasmashell[1286]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Jul 29 15:32:00 havoc-manjaro plasmashell[1286]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Jul 29 15:32:00 havoc-manjaro plasmashell[1286]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
Jul 29 15:32:00 havoc-manjaro plasmashell[1286]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Jul 29 15:32:00 havoc-manjaro plasmashell[1286]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Jul 29 15:32:01 havoc-manjaro kdeconnectd[1325]: kdeconnect.core: Could not query capabilities from notifications server
Jul 29 15:32:01 havoc-manjaro plasmashell[1286]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Jul 29 15:32:03 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000e
Jul 29 15:32:03 havoc-manjaro kernel: kauditd_printk_skb: 3 callbacks suppressed
Jul 29 15:32:11 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000f
Jul 29 15:32:11 havoc-manjaro plasmashell[1286]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jul 29 15:32:16 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1740, resource id: 4194328, major code: 18 (ChangeProperty), minor code: 0
Jul 29 15:32:21 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000010
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x564ca5c40c10) QQmlContext(0x564ca5c9bd90) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1889, resource id: 41943109, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1890, resource id: 41943111, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1891, resource id: 41943113, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1892, resource id: 41943115, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1893, resource id: 41943117, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1894, resource id: 41943119, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1895, resource id: 41943105, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1896, resource id: 41943107, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x564ca615e060) QQmlContext(0x564ca5c9bd90) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2142, resource id: 41943109, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2143, resource id: 41943111, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2144, resource id: 41943113, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2145, resource id: 41943115, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2146, resource id: 41943117, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2147, resource id: 41943119, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2148, resource id: 41943105, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2149, resource id: 41943107, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1261, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1262, resource id: 41943105, major code: 55 (CreateGC), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1263, resource id: 41943105, major code: 72 (PutImage), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1264, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1265, resource id: 41943107, major code: 55 (CreateGC), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1266, resource id: 41943107, major code: 72 (PutImage), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1267, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1268, resource id: 41943109, major code: 55 (CreateGC), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1269, resource id: 41943109, major code: 72 (PutImage), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1270, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1271, resource id: 41943111, major code: 55 (CreateGC), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1272, resource id: 41943111, major code: 72 (PutImage), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1273, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1274, resource id: 41943113, major code: 55 (CreateGC), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1275, resource id: 41943113, major code: 72 (PutImage), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1276, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1277, resource id: 41943115, major code: 55 (CreateGC), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1278, resource id: 41943115, major code: 72 (PutImage), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1279, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1280, resource id: 41943117, major code: 55 (CreateGC), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1281, resource id: 41943117, major code: 72 (PutImage), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1282, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1283, resource id: 41943119, major code: 55 (CreateGC), minor code: 0
Jul 29 15:32:26 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1284, resource id: 41943119, major code: 72 (PutImage), minor code: 0
Jul 29 15:32:29 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000011
Jul 29 15:32:37 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000012
Jul 29 15:32:45 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000013
Jul 29 15:32:47 havoc-manjaro kernel: kauditd_printk_skb: 4 callbacks suppressed
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2340, resource id: 41943109, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2341, resource id: 41943111, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2342, resource id: 41943113, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2343, resource id: 41943115, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2344, resource id: 41943117, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2345, resource id: 41943119, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2346, resource id: 41943105, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2347, resource id: 41943107, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2349, resource id: 41943109, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2350, resource id: 41943111, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2351, resource id: 41943113, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2352, resource id: 41943115, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2353, resource id: 41943117, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2354, resource id: 41943119, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2355, resource id: 41943105, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2356, resource id: 41943107, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2373, resource id: 41943109, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2374, resource id: 41943111, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2375, resource id: 41943113, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2376, resource id: 41943115, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2378, resource id: 41943119, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2379, resource id: 41943105, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2380, resource id: 41943107, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2384, resource id: 41943109, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2385, resource id: 41943111, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2386, resource id: 41943113, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2387, resource id: 41943115, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2388, resource id: 41943117, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2389, resource id: 41943119, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2390, resource id: 41943105, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2391, resource id: 41943107, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2408, resource id: 41943109, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2409, resource id: 41943111, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2410, resource id: 41943113, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2411, resource id: 41943115, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2412, resource id: 41943117, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2413, resource id: 41943119, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2414, resource id: 41943105, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:50 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2415, resource id: 41943107, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:32:53 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000014
Jul 29 15:33:01 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000015
Jul 29 15:33:01 havoc-manjaro plasmashell[1286]: org.kde.plasma.pulseaudio: context kaput
Jul 29 15:33:06 havoc-manjaro plasmashell[1286]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:71:17: Unable to assign [undefined] to int
Jul 29 15:33:09 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000016
Jul 29 15:33:17 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000017
Jul 29 15:33:17 havoc-manjaro plasmashell[1286]: Trying to take space not available BasicAppletContainer_QMLTYPE_54_QML_74(0x564ca4ef8f70, parent=0x564ca4b3b900, geometry=1632,330 176x240)
Jul 29 15:33:25 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000018
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2226, resource id: 41943109, major code: 54 (FreePixmap), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2227, resource id: 41943110, major code: 60 (FreeGC), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2228, resource id: 41943111, major code: 54 (FreePixmap), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2229, resource id: 41943112, major code: 60 (FreeGC), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2230, resource id: 41943113, major code: 54 (FreePixmap), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2231, resource id: 41943114, major code: 60 (FreeGC), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2232, resource id: 41943115, major code: 54 (FreePixmap), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2233, resource id: 41943116, major code: 60 (FreeGC), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2234, resource id: 41943117, major code: 54 (FreePixmap), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2235, resource id: 41943118, major code: 60 (FreeGC), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2236, resource id: 41943119, major code: 54 (FreePixmap), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2237, resource id: 41943120, major code: 60 (FreeGC), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2238, resource id: 41943105, major code: 54 (FreePixmap), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2239, resource id: 41943106, major code: 60 (FreeGC), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2240, resource id: 41943107, major code: 54 (FreePixmap), minor code: 0
Jul 29 15:33:25 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2241, resource id: 41943108, major code: 60 (FreeGC), minor code: 0
Jul 29 15:33:30 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2588, resource id: 41943121, major code: 19 (DeleteProperty), minor code: 0
Jul 29 15:33:30 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2591, resource id: 41943121, major code: 19 (DeleteProperty), minor code: 0
Jul 29 15:33:30 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2592, resource id: 41943121, major code: 18 (ChangeProperty), minor code: 0
Jul 29 15:33:30 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2593, resource id: 41943121, major code: 19 (DeleteProperty), minor code: 0
Jul 29 15:33:30 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2594, resource id: 41943121, major code: 19 (DeleteProperty), minor code: 0
Jul 29 15:33:30 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2595, resource id: 41943121, major code: 19 (DeleteProperty), minor code: 0
Jul 29 15:33:30 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2596, resource id: 41943121, major code: 7 (ReparentWindow), minor code: 0
Jul 29 15:33:30 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2597, resource id: 41943121, major code: 6 (ChangeSaveSet), minor code: 0
Jul 29 15:33:30 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2598, resource id: 41943121, major code: 2 (ChangeWindowAttributes), minor code: 0
Jul 29 15:33:30 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2599, resource id: 41943121, major code: 10 (UnmapWindow), minor code: 0
Jul 29 15:34:04 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2911, resource id: 4194309, major code: 18 (ChangeProperty), minor code: 0
Jul 29 15:34:19 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4484, resource id: 41943139, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:34:19 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4485, resource id: 41943141, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:34:19 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4486, resource id: 41943143, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:34:19 havoc-manjaro kwin_x11[1195]: kwin_core: Failed to focus 0x2800024 (error 8)
Jul 29 15:34:19 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4828, resource id: 41943139, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:34:19 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4829, resource id: 41943141, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:34:19 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4830, resource id: 41943143, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:34:19 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5155, resource id: 41943139, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:34:19 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5156, resource id: 41943141, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:34:19 havoc-manjaro kwin_x11[1195]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5157, resource id: 41943143, major code: 14 (GetGeometry), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2551, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2552, resource id: 41943135, major code: 55 (CreateGC), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2553, resource id: 41943135, major code: 72 (PutImage), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2554, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2555, resource id: 41943137, major code: 55 (CreateGC), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2556, resource id: 41943137, major code: 72 (PutImage), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2557, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2558, resource id: 41943139, major code: 55 (CreateGC), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2559, resource id: 41943139, major code: 72 (PutImage), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2560, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2561, resource id: 41943141, major code: 55 (CreateGC), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2562, resource id: 41943141, major code: 72 (PutImage), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2563, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2564, resource id: 41943143, major code: 55 (CreateGC), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2565, resource id: 41943143, major code: 72 (PutImage), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2566, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2567, resource id: 41943145, major code: 55 (CreateGC), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2568, resource id: 41943145, major code: 72 (PutImage), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2569, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2570, resource id: 41943147, major code: 55 (CreateGC), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2571, resource id: 41943147, major code: 72 (PutImage), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2572, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2573, resource id: 41943149, major code: 55 (CreateGC), minor code: 0
Jul 29 15:34:19 havoc-manjaro plasmashell[1286]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2574, resource id: 41943149, major code: 72 (PutImage), minor code: 0
I greatly appreciate the help!
I might just have to re-install. At this point after a reboot, the display manager won’t load on the local, it shows a blank screen on RDP, and SSH hangs after I enter my password. I can manjaro-chroot from the live USB, but that’s about it.
Replace driver configs.
sudo mhwd -r pci video-hybrid-intel-nvidia-prime
sudo mhwd -i pci video-nvidia
you have several of these logs, so there is something wrong with the nvidia…
it points out to me that it could be:
  1. some setting in bios
  2. kernel thing - since you are runnning 5.15 and also with the live usb you had issue
  3. wrong drivers installed, but since it also happens with the live usb…
you dont have to chroot, enter into tty in the black screen: ctrl+alt+f2 or f1-f6 keys, and remove the nvidia drivers:
systemctl reboot
then when you are back in the system without the nvidia post output from:
mhwd -l
First off, thanks again for the help.
OK. Weird thing. I boot this today to take a look at it, and now I can SSH in. That said, Plasma hard froze on me. Really weird. I completely disabled xrdp in case that was doing something.
I am also of the opinion that there is some strange driver or hardware conflict, but the mobo and video card are from the same manufacturer, and I believe I have the integrated graphics turned off in BIOS.
I gave it a shot and ran everything above. I get this now, but I think that video-nvidia is not installed even though it says it is:
> 0000:01:00.0 (0300:10de:2482) Display controller nVidia Corporation:
          video-nvidia            2021.12.18               false            PCI
    video-nvidia-470xx            2021.12.18               false            PCI
           video-linux            2018.05.04                true            PCI
X isn’t booting without the Nvidia drivers. Should I install the free drivers?
[   227.592]
X.Org X Server 1.21.1.4
[   227.592] Current Operating System: Linux havoc-manjaro 5.15.57-2-MANJARO #1 SMP PREEMPT Mon Jul 25 01:32:51 UTC 2022 x86_64
[   227.592] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=d7f61351-5519-4c4a-9544-dd0a1860de04 rw quiet apparmor=1 security=apparmor udev.log_priority=3 acpi_enforce_resources=lax ibt=off
[   227.592]
[   227.592] Current version of pixman: 0.40.0
[   227.592]    Before reporting problems, check http://wiki.x.org
[   227.592] Markers: (--) probed, (**) from config file, (==) default setting,
[   227.592] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jul 31 16:27:16 2022
[   227.592] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   227.593] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   227.593] (==) No Layout section.  Using the first Screen section.
[   227.593] (==) No screen section available. Using defaults.
[   227.593] (**) |-->Screen "Default Screen Section" (0)
[   227.593] (**) |   |-->Monitor "<default monitor>"
[   227.593] (==) No monitor specified for screen "Default Screen Section".
[   227.593] (==) Automatically adding devices
[   227.593] (==) Automatically enabling devices
[   227.593] (==) Automatically adding GPU devices
[   227.593] (==) Automatically binding GPU devices
[   227.593] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   227.593] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[   227.593]    Entry deleted from font path.
[   227.593] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[   227.593] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[   227.593] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[   227.593] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF
[   227.593] (==) ModulePath set to "/usr/lib/xorg/modules"
[   227.593] (II) The server relies on udev to provide the list of input devices.
[   227.593] (II) Module ABI versions:
[   227.593]    X.Org ANSI C Emulation: 0.4
[   227.593]    X.Org Video Driver: 25.2
[   227.593]    X.Org XInput driver : 24.4
[   227.593]    X.Org Server Extension : 10.0
[   227.593] (++) using VT number 2
[   227.594] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[   227.594] (II) xfree86: Adding drm device (/dev/dri/card0)
[   227.594] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[   227.595] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[   227.596] (--) PCI:*(1@0:0:0) 10de:2482:1043:880e rev 161, Mem @ 0x84000000/16777216, 0x4000000000/268435456, 0x4010000000/33554432, I/O @ 0x00006000/128, BIOS @ 0x????????/131072
[   227.596] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[   227.596] (II) LoadModule: "glx"
[   227.596] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   227.597] (II) Module glx: vendor="X.Org Foundation"
[   227.597]    compiled for 1.21.1.4, module version = 1.0.0
[   227.597]    ABI class: X.Org Server Extension, version 10.0
[   227.598] (==) Matched nouveau as autoconfigured driver 0
[   227.598] (==) Matched nv as autoconfigured driver 1
[   227.598] (==) Matched modesetting as autoconfigured driver 2
[   227.598] (==) Matched fbdev as autoconfigured driver 3
[   227.598] (==) Matched vesa as autoconfigured driver 4
[   227.598] (==) Assigned the driver to the xf86ConfigLayout
[   227.598] (II) LoadModule: "nouveau"
[   227.598] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[   227.598] (II) Module nouveau: vendor="X.Org Foundation"
[   227.598]    compiled for 1.21.1.1, module version = 1.0.17
[   227.598]    Module class: X.Org Video Driver
[   227.598]    ABI class: X.Org Video Driver, version 25.2
[   227.598] (II) LoadModule: "nv"
[   227.598] (WW) Warning, couldn't open module nv
[   227.598] (EE) Failed to load module "nv" (module does not exist, 0)
[   227.598] (II) LoadModule: "modesetting"
[   227.598] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[   227.599] (II) Module modesetting: vendor="X.Org Foundation"
[   227.599]    compiled for 1.21.1.4, module version = 1.21.1
[   227.599]    Module class: X.Org Video Driver
[   227.599]    ABI class: X.Org Video Driver, version 25.2
[   227.599] (II) LoadModule: "fbdev"
[   227.599] (WW) Warning, couldn't open module fbdev
[   227.599] (EE) Failed to load module "fbdev" (module does not exist, 0)
[   227.599] (II) LoadModule: "vesa"
[   227.599] (WW) Warning, couldn't open module vesa
[   227.599] (EE) Failed to load module "vesa" (module does not exist, 0)
[   227.599] (II) NOUVEAU driver
[   227.599] (II) NOUVEAU driver for NVIDIA chipset families :
[   227.599]    RIVA TNT            (NV04)
[   227.599]    RIVA TNT2           (NV05)
[   227.599]    GeForce 256         (NV10)
[   227.599]    GeForce 2           (NV11, NV15)
[   227.599]    GeForce 4MX         (NV17, NV18)
[   227.599]    GeForce 3           (NV20)
[   227.599]    GeForce 4Ti         (NV25, NV28)
[   227.599]    GeForce FX          (NV3x)
[   227.599]    GeForce 6           (NV4x)
[   227.599]    GeForce 7           (G7x)
[   227.599]    GeForce 8           (G8x)
[   227.599]    GeForce 9           (G9x)
[   227.599]    GeForce GTX 2xx/3xx (GT2xx)
[   227.599]    GeForce GTX 4xx/5xx (GFxxx)
[   227.599]    GeForce GTX 6xx/7xx (GKxxx)
[   227.599]    GeForce GTX 9xx     (GMxxx)
[   227.599]    GeForce GTX 10xx    (GPxxx)
[   227.599] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[   227.599] (EE) [drm] Failed to open DRM device for (null): -2
[   227.600] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
[   227.600] (WW) Falling back to old probe method for modesetting
[   227.600] (EE) [drm] Failed to open DRM device for (null): -2
[   227.600] (EE) Screen 0 deleted because of no matching config section.
[   227.600] (II) UnloadModule: "modesetting"
[   227.600] (EE) Device(s) detected, but none match those in the config file.
[   227.600] (EE)
Fatal server error:
[   227.600] (EE) no screens found(EE)
[   227.600] (EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
[   227.600] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   227.600] (EE)
[   227.604] (EE) Server terminated with error (1). Closing log file.
1 did you enable again the integrated in bios?
2 you have installed the wrong drivers:
so remove them:
reboot, you should be able to boot normally now on the intel drivers
3 install the nvidia drivers:
reboot and see if you can boot
