Yes. I uninstalled and re-installed.
This is from before running nvidia-xconfig. Lots of errors with the monitor off:
Aug 01 09:34:24 havoc-manjaro kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
Aug 01 09:34:24 havoc-manjaro kernel: #17 #18 #19
Aug 01 09:34:24 havoc-manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Aug 01 09:34:24 havoc-manjaro kernel: pnp 00:03: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Aug 01 09:34:24 havoc-manjaro kernel: hpet_acpi_add: no address or irqs in _CRS
Aug 01 09:34:24 havoc-manjaro kernel: nvidia: loading out-of-tree module taints kernel.
Aug 01 09:34:24 havoc-manjaro kernel: nvidia: module license 'NVIDIA' taints kernel.
Aug 01 09:34:24 havoc-manjaro kernel: Disabling lock debugging due to kernel taint
Aug 01 09:34:24 havoc-manjaro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.57 Wed Jun 22 22:44:07 UTC 2022
Aug 01 09:34:24 havoc-manjaro kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Aug 01 09:34:24 havoc-manjaro systemd-modules-load[430]: Failed to find module 'i2c-nct6775'
Aug 01 09:34:24 havoc-manjaro systemd-journald[448]: File /var/log/journal/14c91aef4f544bc9a101b144c7995d9f/system.journal corrupted or uncleanly shut down, renaming and replacing.
Aug 01 09:34:25 havoc-manjaro kernel: process '/usr/bin/zerotier-one' started with executable stack
Aug 01 09:34:26 havoc-manjaro kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 01 09:34:26 havoc-manjaro kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 01 09:34:26 havoc-manjaro kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 01 09:34:26 havoc-manjaro kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 01 09:34:26 havoc-manjaro kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 01 09:34:26 havoc-manjaro kernel: acpi PNP0C14:06: duplicate WMI GUID 97845ED0-4E6D-11DE-8A39-0800200C9A66 (first instance was on PNP0C14:02)
Aug 01 09:34:26 havoc-manjaro kernel: acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 01 09:34:26 havoc-manjaro kernel: usb 1-4: config 1 has an invalid interface number: 2 but max is 1
Aug 01 09:34:26 havoc-manjaro kernel: usb 1-4: config 1 has no interface number 1
Aug 01 09:34:26 havoc-manjaro kernel: ACPI Warning: \_SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Aug 01 09:34:26 havoc-manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
Aug 01 09:34:26 havoc-manjaro kernel: ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
Aug 01 09:34:26 havoc-manjaro kernel: ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
Aug 01 09:34:26 havoc-manjaro kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-66.ucode failed with error -2
Aug 01 09:34:26 havoc-manjaro kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-65.ucode failed with error -2
Aug 01 09:34:26 havoc-manjaro kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Aug 01 09:34:27 havoc-manjaro libvirtd[704]: Unable to open /dev/kvm: No such file or directory
Aug 01 09:34:27 havoc-manjaro libvirtd[704]: internal error: Missing udev property 'ID_VENDOR_ID' on 'usb1'
Aug 01 09:34:27 havoc-manjaro libvirtd[704]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-2'
Aug 01 09:34:27 havoc-manjaro libvirtd[704]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-4'
Aug 01 09:34:27 havoc-manjaro libvirtd[704]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-8'
Aug 01 09:34:27 havoc-manjaro libvirtd[704]: internal error: Missing udev property 'ID_VENDOR_ID' on '2-8'
Aug 01 09:34:27 havoc-manjaro kernel: thermal thermal_zone1: failed to read out thermal zone (-61)
Aug 01 09:34:27 havoc-manjaro kernel: snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to polling mode: last cmd=0x000f0000
Aug 01 09:34:28 havoc-manjaro kernel: snd_hda_intel 0000:00:1f.3: No response from codec, disabling MSI: last cmd=0x000f0000
Aug 01 09:34:29 havoc-manjaro kernel: snd_hda_intel 0000:00:1f.3: Codec #0 probe error; disabling it...
Aug 01 09:34:33 havoc-manjaro kernel: NVRM: GPU at PCI:0000:01:00: GPU-b11671af-fbd5-ca45-7b3c-e397c0d5b38a
Aug 01 09:34:33 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 122, pid='<unknown>', name=<unknown>, SPI read failure at address 1040! (0x00000065)
Aug 01 09:34:33 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 62, pid='<unknown>', name=<unknown>, 0000(0000) 00000000 00000000
Aug 01 09:34:35 havoc-manjaro kernel: perf uncore: Cannot find matched IMC device.
Aug 01 09:34:35 havoc-manjaro kernel: kauditd_printk_skb: 247 callbacks suppressed
Aug 01 09:34:37 havoc-manjaro kernel: asus_wmi: Failed to get WMI notify code: AE_NOT_FOUND
Aug 01 09:34:37 havoc-manjaro kernel: asus_wmi: Failed to get event during flush: -5
Aug 01 09:34:37 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 122, pid='<unknown>', name=<unknown>, SPI read failure at address 272! (0x00000065)
Aug 01 09:34:37 havoc-manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
Aug 01 09:34:37 havoc-manjaro kernel: ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
Aug 01 09:34:37 havoc-manjaro kernel: ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
Aug 01 09:34:37 havoc-manjaro kernel: usb 1-13.3: Failed to query (GET_INFO) UVC control 5 on unit 1: 0 (exp. 1).
Aug 01 09:34:37 havoc-manjaro kernel: usb 1-13.3: Failed to query (GET_INFO) UVC control 12 on unit 1: 0 (exp. 1).
Aug 01 09:34:37 havoc-manjaro systemd-udevd[534]: event26: Failed to call EVIOCSKEYCODE with scan code 0x7c, and key code 190: Invalid argument
Aug 01 09:34:38 havoc-manjaro systemd-coredump[1146]: [š”] Process 830 (Xorg) of user 0 dumped core.
Module linux-vdso.so.1 with build-id 125b0285aa529b1b1396ff79a856cc580f53371b
Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
Module libxcb-present.so.0 with build-id 8ed389d9cd6ad7110fbb00c93b32e0efaa71a6b1
Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
Module libxcb-dri2.so.0 with build-id 7bde0abc84135ae6258a8d1d130864071c2cc327
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libEGL_mesa.so.0 with build-id 704e8022bd0cba83c053cfb72e77256933872870
Module libnvidia-egl-gbm.so.1 with build-id 6ca12a03323ba36ee09427dab2cd23c88830fcfd
Module libnvidia-eglcore.so.515.57 with build-id 9df5f29019d87cd226406e8c101173c471632fef
Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
Module libnvidia-egl-wayland.so.1 with build-id 3fc8bba212c4144db272929453f0c16d06fc23e0
Module libnvidia-glsi.so.515.57 with build-id 4e1ef540b9a4b999ba9f4434a06949d62ec74b13
Module libEGL_nvidia.so.0 with build-id fb396a05fd85f3d02af0bac0de13e00cc82703bf
Module libEGL.so.1 with build-id 30b30de54f2f848a7b8bed469349c9a7ab1b7c22
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libxml2.so.2 with build-id 8cdf00fa954d9a27f2f184c4d354cb14677446ac
Module libncursesw.so.6 with build-id b9917757481e6fa6097e2a1f31f5bb5eaf138c4e
Module libedit.so.0 with build-id 4b0babfcad161c2ad0af6e59e2493258db23a331
Module libstdc++.so.6 with build-id a24b312bb5881ceae0ffbed599201690f2a1747b
Module libxcb-dri3.so.0 with build-id 088c750254cc139e7d62b8a3fc7795a138447ccf
Module libvulkan.so.1 with build-id dd97393da4f886994c9dfc153b35ea6d906f57ff
Module libdrm_nouveau.so.2 with build-id 78e99e753be2b598acf02a6f30bc6615a6a3067f
Module libdrm_amdgpu.so.1 with build-id e03ead624f04700b1fd00df43863fecfb1ff8b72
Module libelf.so.1 with build-id c09e357a1a3b061bf219bcfb243ca31b175e77fa
Module libdrm_radeon.so.1 with build-id 5c9c31961c5f0dd9b40cb3e134b8d9189ee59fbb
Module libsensors.so.5 with build-id dc8b2c1c0d8525411aca188ea3cc3fb86d381d30
Module libLLVM-14.so with build-id 1a2033d5ab1c892c325fe839c4f45d2d4724fd1f
Module iris_dri.so with build-id f58adac87bbda2e5f4ea270dcbff1d077a7acaf7
Module libglapi.so.0 with build-id c9cb2897599baa12a671ac84a813ef3d63c665a8
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libglamoregl.so with build-id d1fbcfb0727a53cc05c81a288ca38e9e224d6f99
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libwayland-server.so.0 with build-id 4c54fc8a7c0d4eb8adf2a69e44ebf12d16969c74
Module libgbm.so.1 with build-id 589489ebc39c7c4de46d25028fd54896e0da464d
Module modesetting_drv.so with build-id 75d16c62ac83c0a7fdb8c7fd1b65537baad78597
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libgobject-2.0.so.0 with build-id a7515bd8cd51064d187953c0f506a43958de31a6
Module libgudev-1.0.so.0 with build-id 460465b63a086d945124662363191903c0002793
Module libwacom.so.9 with build-id 1fc3438938e7017596beb2e3483ce3af72c4f492
Module libevdev.so.2 with build-id 09eb82a0dfca98325f54b3918875cff09a5c1428
Module libmtdev.so.1 with build-id 862cf8d5b0a0dd4d4d225e17f54be93ab9c3b34e
Module libinput.so.10 with build-id 9de57b91e0d1d09e53606692e2c51c8b31d3dfe1
Module libinput_drv.so with build-id cf829f2000cbe7c7b226d0bc4c8188ab0fa99b62
Module libnvidia-glcore.so.515.57 with build-id 92b04a9299c745a4cc402999f180506619b14e37
Module libnvidia-tls.so.515.57 with build-id 782bcaa66034d82c6605fd02a57ebd7577d33f9c
Module libglxserver_nvidia.so with build-id b381cacdd8919da0c459313f138af4d5ed1b4e93
Module libwfb.so with build-id d2133897168704b54c415745ca88d9b145cd4942
Module libdl.so.2 with build-id 94198b268228074fa9f405bbedbbae94112593ed
Module librt.so.1 with build-id f696f0167950c759f9ea43d46167fae35d43dded
Module nvidia_drv.so with build-id 81ece02a46d9658f72a59e56bf14bcadec6d3b27
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libGLX.so.0 with build-id 02bd4ac6acc4da9288c543ea1a0cdaa70c5e151a
Module libGLdispatch.so.0 with build-id de981c020bd9dbdc159b11f4a2a541310cc3b8d5
Module libGL.so.1 with build-id b915a2e48be6c9fd3cc6f9f4c7aab1f7aeed8a4c
Module libglx.so with build-id cdac1c71de6833198b0863c5623454872e21d2b6
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libglib-2.0.so.0 with build-id 1340f3a762b2293ebf6d725edf0eb14839f85317
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libresolv.so.2 with build-id 89a368a6ad1b392d126a2a5beb9c2f61ade00279
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id 15f223925ef59dee4379ebbc0fcd14eda9ba81a2
Module libcom_err.so.2 with build-id 3360a28740ffbbd5a5c0c21d09072445908707e5
Module libk5crypto.so.3 with build-id cc77a742cb62447a53d98285b41558b8acd92866
Module libkrb5.so.3 with build-id 371cc767dacb17cb42c9c44b88eebbed5ee9a756
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libharfbuzz.so.0 with build-id b7daeb45a60c6cc012417c5cfaa09c91235d06bd
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libpthread.so.0 with build-id 95ae4f30a6f12ccbff645d30f8e1a3ee23ec7d36
Module libgssapi_krb5.so.2 with build-id 292f1ce32161c0ecc4a287bc8494d5d7c420a03f
Module libgcc_s.so.1 with build-id 0e3de903950e35ae59a5de8c00b1817a4a71ca01
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module liblzma.so.5 with build-id 28b40c7af8098a66af6ee093b6986b91cad7694d
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 1f87347b85b55db2f75a2ecea5cb45d846dc7093
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libfontenc.so.1 with build-id 5a11f1fb8c3f2714be9eb6697318f20e301e1d2f
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module ld-linux-x86-64.so.2 with build-id 0effd0e43efa4468d3c31871c93af0b7f3005673
Module libc.so.6 with build-id 60df1df31f02a7b23da83e8ef923359885b81492
Module libxcvt.so.0 with build-id 30bad674c8227152bb709556a3657d0258554309
Module libtirpc.so.3 with build-id 5bef2adfdee3df283f593b3e2d37b6dac405256a
Module libdrm.so.2 with build-id 39847bc84bc769f632f8f599a62fdcc98c9270cd
Module libudev.so.1 with build-id bd33a52ea53820d57e8ab7cf4ffd283274cf8ab4
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libunwind.so.8 with build-id e7f3b22127b00d8b14b2560df707cbbeb0134861
Module libsystemd.so.0 with build-id 761a39da56f185d6f1ef6f7bb95a3299789eb3e2
Module libxshmfence.so.1 with build-id d9b3ce4edb0b6a0818bcc57dda020d2da5e3c895
Module libXfont2.so.2 with build-id 154202dd7ddb86f6ae4d3bc762dfd8570b86882a
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id 60db1eac70f819bea9d4c366603c1583067510b4
Module libnettle.so.8 with build-id a2cc6a257b0729585e870b345b83497c478ee28b
Module libpciaccess.so.0 with build-id eacbec3cbdaae4e27f40804adbd53fe406ebd804
Module libm.so.6 with build-id 1b7296ef9fd806e47060788389293c824b09ad72
Module libpixman-1.so.0 with build-id d2170a3ac106c2a68597bf7910ab04b1cdd69c14
Module Xorg with build-id 7eb3c71a79d1a4df8409b669e6a13b49335c1078
Stack trace of thread 830:
#0 0x00007f8d93a2936c n/a (libc.so.6 + 0x8e36c)
#1 0x00007f8d939d9838 raise (libc.so.6 + 0x3e838)
#2 0x00007f8d939c3535 abort (libc.so.6 + 0x28535)
#3 0x0000564d335f6910 OsAbort (Xorg + 0x157910)
#4 0x0000564d335f82b3 FatalError (Xorg + 0x1592b3)
#5 0x0000564d335fdc4c n/a (Xorg + 0x15ec4c)
#6 0x00007f8d939d98e0 n/a (libc.so.6 + 0x3e8e0)
#7 0x00007f8d93a2936c n/a (libc.so.6 + 0x8e36c)
#8 0x00007f8d939d9838 raise (libc.so.6 + 0x3e838)
#9 0x00007f8d939c3535 abort (libc.so.6 + 0x28535)
#10 0x00007f8d939c345c n/a (libc.so.6 + 0x2845c)
#11 0x00007f8d939d2366 __assert_fail (libc.so.6 + 0x37366)
#12 0x0000564d3353db66 dixRegisterPrivateKey (Xorg + 0x9eb66)
#13 0x00007f878e02f9ca glamor_init (libglamoregl.so + 0xd9ca)
#14 0x00007f8d922ec1a1 n/a (modesetting_drv.so + 0xf1a1)
#15 0x0000564d3351ec54 AddGPUScreen (Xorg + 0x7fc54)
#16 0x0000564d33632ca1 n/a (Xorg + 0x193ca1)
#17 0x0000564d3365202a n/a (Xorg + 0x1b302a)
#18 0x0000564d336788e1 n/a (Xorg + 0x1d98e1)
#19 0x0000564d33678ad3 config_init (Xorg + 0x1d9ad3)
#20 0x0000564d334dd381 n/a (Xorg + 0x3e381)
#21 0x00007f8d939c4290 n/a (libc.so.6 + 0x29290)
#22 0x00007f8d939c434a __libc_start_main (libc.so.6 + 0x2934a)
#23 0x0000564d334de4b5 _start (Xorg + 0x3f4b5)
Stack trace of thread 1131:
#0 0x00007f8d93a24119 n/a (libc.so.6 + 0x89119)
#1 0x00007f8d93a26920 pthread_cond_wait (libc.so.6 + 0x8b920)
#2 0x00007f878c56e7cc n/a (iris_dri.so + 0xb27cc)
#3 0x00007f878c567ecc n/a (iris_dri.so + 0xabecc)
#4 0x00007f8d93a2754d n/a (libc.so.6 + 0x8c54d)
#5 0x00007f8d93aac874 __clone (libc.so.6 + 0x111874)
Stack trace of thread 1142:
Stack trace of thread 1128:
Stack trace of thread 1130:
Stack trace of thread 1144:
Stack trace of thread 1133:
Stack trace of thread 1129:
Stack trace of thread 1132:
Stack trace of thread 1134:
Stack trace of thread 1135:
Stack trace of thread 1136:
Stack trace of thread 1139:
Stack trace of thread 1141:
Stack trace of thread 1143:
Stack trace of thread 1140:
Stack trace of thread 1137:
Stack trace of thread 1138:
Aug 01 09:34:38 havoc-manjaro sddm[714]: Failed to read display number from pipe
Aug 01 09:34:41 havoc-manjaro kernel: usb 1-13.3: 3:1: cannot get freq at ep 0x84
Aug 01 09:34:42 havoc-manjaro sddm[714]: Attempt 1 starting the Display server on vt 1 failed
Aug 01 09:34:43 havoc-manjaro kernel: kauditd_printk_skb: 7 callbacks suppressed
Aug 01 09:34:45 havoc-manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
Aug 01 09:34:45 havoc-manjaro kernel: ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
Aug 01 09:34:45 havoc-manjaro kernel: ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
Aug 01 09:34:45 havoc-manjaro kernel: NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x23:0xffff:1382)
Aug 01 09:34:45 havoc-manjaro kernel: NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
Aug 01 09:34:45 havoc-manjaro sddm[714]: Failed to read display number from pipe
Aug 01 09:34:45 havoc-manjaro sddm[714]: Attempt 2 starting the Display server on vt 1 failed
Aug 01 09:34:47 havoc-manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
Aug 01 09:34:47 havoc-manjaro kernel: ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
Aug 01 09:34:47 havoc-manjaro kernel: ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
Aug 01 09:34:47 havoc-manjaro kernel: NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x23:0xffff:1382)
Aug 01 09:34:47 havoc-manjaro kernel: NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
Aug 01 09:34:47 havoc-manjaro sddm[714]: Failed to read display number from pipe
Aug 01 09:34:47 havoc-manjaro sddm[714]: Attempt 3 starting the Display server on vt 1 failed
Aug 01 09:34:47 havoc-manjaro sddm[714]: Could not start Display server on vt 1
Aug 01 09:35:20 havoc-manjaro systemd-journald[448]: File /var/log/journal/14c91aef4f544bc9a101b144c7995d9f/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Aug 01 09:36:26 havoc-manjaro kernel: kauditd_printk_skb: 10 callbacks suppressed
This is after running the nvidia-xconfig, reboot, and login. The monitor is back, but the slowness still exists:
Aug 01 09:57:29 havoc-manjaro kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
Aug 01 09:57:29 havoc-manjaro kernel: #17 #18 #19
Aug 01 09:57:29 havoc-manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Aug 01 09:57:29 havoc-manjaro kernel: pnp 00:03: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Aug 01 09:57:29 havoc-manjaro kernel: hpet_acpi_add: no address or irqs in _CRS
Aug 01 09:57:29 havoc-manjaro kernel: nvidia: loading out-of-tree module taints kernel.
Aug 01 09:57:29 havoc-manjaro kernel: nvidia: module license 'NVIDIA' taints kernel.
Aug 01 09:57:29 havoc-manjaro kernel: Disabling lock debugging due to kernel taint
Aug 01 09:57:29 havoc-manjaro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.57 Wed Jun 22 22:44:07 UTC 2022
Aug 01 09:57:29 havoc-manjaro kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Aug 01 09:57:29 havoc-manjaro systemd-modules-load[440]: Failed to find module 'i2c-nct6775'
Aug 01 09:57:31 havoc-manjaro kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 01 09:57:31 havoc-manjaro kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 01 09:57:31 havoc-manjaro kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 01 09:57:31 havoc-manjaro kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 01 09:57:31 havoc-manjaro kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 01 09:57:31 havoc-manjaro kernel: acpi PNP0C14:06: duplicate WMI GUID 97845ED0-4E6D-11DE-8A39-0800200C9A66 (first instance was on PNP0C14:02)
Aug 01 09:57:31 havoc-manjaro kernel: acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 01 09:57:31 havoc-manjaro kernel: usb 1-4: config 1 has an invalid interface number: 2 but max is 1
Aug 01 09:57:31 havoc-manjaro kernel: usb 1-4: config 1 has no interface number 1
Aug 01 09:57:31 havoc-manjaro kernel: process '/usr/bin/zerotier-one' started with executable stack
Aug 01 09:57:31 havoc-manjaro kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-66.ucode failed with error -2
Aug 01 09:57:31 havoc-manjaro kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-65.ucode failed with error -2
Aug 01 09:57:31 havoc-manjaro kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Aug 01 09:57:31 havoc-manjaro kernel: ACPI Warning: \_SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Aug 01 09:57:32 havoc-manjaro kernel: thermal thermal_zone1: failed to read out thermal zone (-61)
Aug 01 09:57:32 havoc-manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
Aug 01 09:57:32 havoc-manjaro kernel: ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
Aug 01 09:57:32 havoc-manjaro kernel: ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
Aug 01 09:57:32 havoc-manjaro libvirtd[727]: Unable to open /dev/kvm: No such file or directory
Aug 01 09:57:32 havoc-manjaro libvirtd[727]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-10'
Aug 01 09:57:32 havoc-manjaro libvirtd[727]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-13'
Aug 01 09:57:32 havoc-manjaro libvirtd[727]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-14'
Aug 01 09:57:32 havoc-manjaro libvirtd[727]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-2'
Aug 01 09:57:32 havoc-manjaro libvirtd[727]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-4'
Aug 01 09:57:32 havoc-manjaro libvirtd[727]: internal error: Missing udev property 'ID_VENDOR_ID' on '2-8'
Aug 01 09:57:32 havoc-manjaro kernel: snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to polling mode: last cmd=0x000f0000
Aug 01 09:57:33 havoc-manjaro kernel: snd_hda_intel 0000:00:1f.3: No response from codec, disabling MSI: last cmd=0x000f0000
Aug 01 09:57:34 havoc-manjaro kernel: snd_hda_intel 0000:01:00.1: azx_get_response timeout, switching to polling mode: last cmd=0x001f0500
Aug 01 09:57:35 havoc-manjaro kernel: snd_hda_intel 0000:00:1f.3: Codec #0 probe error; disabling it...
Aug 01 09:57:35 havoc-manjaro kernel: snd_hda_intel 0000:01:00.1: azx_get_response timeout, switching to single_cmd mode: last cmd=0x001f0500
Aug 01 09:57:37 havoc-manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20210730/dsfield-184)
Aug 01 09:57:37 havoc-manjaro kernel: ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20210730/dswload2-477)
Aug 01 09:57:37 havoc-manjaro kernel: ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20210730/psparse-529)
Aug 01 09:57:38 havoc-manjaro kernel: kauditd_printk_skb: 247 callbacks suppressed
Aug 01 09:57:38 havoc-manjaro systemd[939]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Aug 01 09:57:38 havoc-manjaro systemd[939]: Failed to start Update XDG user dir configuration.
Aug 01 09:57:38 havoc-manjaro sddm-greeter[948]: QFont::fromString: Invalid description '(empty)'
Aug 01 09:57:39 havoc-manjaro kernel: NVRM: GPU at PCI:0000:01:00: GPU-b11671af-fbd5-ca45-7b3c-e397c0d5b38a
Aug 01 09:57:39 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 62, pid='<unknown>', name=<unknown>, 0000(0000) 00000000 00000000
Aug 01 09:57:39 havoc-manjaro kernel: perf uncore: Cannot find matched IMC device.
Aug 01 09:57:41 havoc-manjaro kernel: asus_wmi: Failed to get WMI notify code: AE_NOT_FOUND
Aug 01 09:57:41 havoc-manjaro kernel: asus_wmi: Failed to get event during flush: -5
Aug 01 09:57:41 havoc-manjaro kernel: usb 1-13.3: Failed to query (GET_INFO) UVC control 5 on unit 1: 0 (exp. 1).
Aug 01 09:57:41 havoc-manjaro kernel: usb 1-13.3: Failed to query (GET_INFO) UVC control 12 on unit 1: 0 (exp. 1).
Aug 01 09:57:42 havoc-manjaro systemd-udevd[467]: event24: Failed to call EVIOCSKEYCODE with scan code 0x7c, and key code 190: Invalid argument
Aug 01 09:57:42 havoc-manjaro sddm-greeter[948]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffc850aca00), parent's thread is QThread(0x5609d1439650), current thread is QThread(0x5609d1510660)
Aug 01 09:57:42 havoc-manjaro sddm-greeter[948]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Aug 01 09:57:42 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/Main.qml:440:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Aug 01 09:57:42 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/VirtualKeyboard.qml:23:1: Type InputPanel unavailable
Aug 01 09:57:42 havoc-manjaro sddm-greeter[948]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Aug 01 09:57:42 havoc-manjaro sddm-greeter[948]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Aug 01 09:57:42 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/Login.qml:92:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Aug 01 09:57:45 havoc-manjaro kernel: kauditd_printk_skb: 13 callbacks suppressed
Aug 01 09:57:46 havoc-manjaro kernel: usb 1-13.3: 3:1: cannot get freq at ep 0x84
Aug 01 09:57:52 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000a
Aug 01 09:58:02 havoc-manjaro kernel: kauditd_printk_skb: 11 callbacks suppressed
Aug 01 09:58:17 havoc-manjaro sddm-helper[1302]: [PAM] authenticate: Authentication failure
Aug 01 09:58:17 havoc-manjaro sddm[742]: Authentication error: "Authentication failure"
Aug 01 09:58:17 havoc-manjaro sddm[742]: Auth: sddm-helper exited with 1
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/Main.qml:415: TypeError: Cannot read property 'smallSpacing' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/ActionButton.qml:64: TypeError: Cannot read property 'smallSpacing' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/ActionButton.qml:34: TypeError: Cannot read property 'gridUnit' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/ActionButton.qml:36: TypeError: Cannot read property 'largeSpacing' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/ActionButton.qml:37: TypeError: Cannot read property 'smallSpacing' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/SessionManagementScreen.qml:83: TypeError: Cannot read property 'gridUnit' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/SessionManagementScreen.qml:112: TypeError: Cannot read property 'smallSpacing' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/SessionManagementScreen.qml:98: TypeError: Cannot read property 'gridUnit' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/SessionManagementScreen.qml:99: TypeError: Cannot read property 'gridUnit' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/SessionManagementScreen.qml:89: TypeError: Cannot read property 'gridUnit' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/UserList.qml:25: TypeError: Cannot read property 'gridUnit' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/UserList.qml:26: TypeError: Cannot read property 'gridUnit' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/UserDelegate.qml:106: TypeError: Cannot read property 'largeSpacing' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/UserDelegate.qml:44: TypeError: Cannot read property 'smallSpacing' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/UserDelegate.qml:72: TypeError: Cannot read property 'largeSpacing' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/UserDelegate.qml:98: TypeError: Cannot read property 'gridUnit' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/UserDelegate.qml:78: TypeError: Cannot read property 'longDuration' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/components/UserDelegate.qml:50: TypeError: Cannot read property 'longDuration' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/Main.qml:202: TypeError: Cannot read property 'longDuration' of null
Aug 01 09:58:22 havoc-manjaro sddm-greeter[948]: file:///usr/share/sddm/themes/Sweet/Main.qml:420: TypeError: Cannot read property 'longDuration' of null
Aug 01 09:58:22 havoc-manjaro startplasma-x11[1308]: kf.service.services: The action "QuitTeams" in the desktop file "/var/lib/snapd/desktop/applications/teams_teams.desktop" has no Name or no Exec key
Aug 01 09:58:22 havoc-manjaro startplasma-x11[1308]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but no Exec line
Aug 01 09:58:22 havoc-manjaro startplasma-x11[1308]: kf.service.sycoca: Invalid Service : "/usr/share/applications/qemu.desktop"
Aug 01 09:58:22 havoc-manjaro klauncher[1339]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Aug 01 09:58:22 havoc-manjaro kcminit_startup[1343]: QDBusConnection: error: could not send signal to service "" path "//home/havoc/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/havoc/.kde4/share/config/kdeglobals
Aug 01 09:58:27 havoc-manjaro kwin_x11[1354]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Aug 01 09:58:28 havoc-manjaro kwin_x11[1354]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Aug 01 09:58:28 havoc-manjaro kwin_x11[1354]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Aug 01 09:58:28 havoc-manjaro ksmserver[1386]: Qt: Session management error: networkIdsList argument is NULL
Aug 01 09:58:28 havoc-manjaro kded5[1351]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.9'
Aug 01 09:58:28 havoc-manjaro kwin_x11[1354]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 782, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
Aug 01 09:58:28 havoc-manjaro baloo_file[1408]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.51'
Aug 01 09:58:28 havoc-manjaro kernel: usb 1-13.3: 3:1: cannot get freq at ep 0x84
Aug 01 09:58:29 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000b
Aug 01 09:58:29 havoc-manjaro kwin_x11[1354]: kwin_core: XCB error: 10 (BadAccess), sequence: 844, resource id: 474, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Aug 01 09:58:29 havoc-manjaro backlighthelper[1630]: org.kde.powerdevil: no kernel backlight interface found
Aug 01 09:58:30 havoc-manjaro pulseaudio[1473]: stat('/etc/pulse/default.pa.d'): No such file or directory
Aug 01 09:58:34 havoc-manjaro org_kde_powerdevil[1405]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Aug 01 09:58:34 havoc-manjaro org_kde_powerdevil[1405]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Aug 01 09:58:34 havoc-manjaro org_kde_powerdevil[1405]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Aug 01 09:58:34 havoc-manjaro org_kde_powerdevil[1405]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Aug 01 09:58:34 havoc-manjaro kernel: usb 1-13.3: Failed to query (GET_DEF) UVC control 12 on unit 1: 0 (exp. 3).
Aug 01 09:58:34 havoc-manjaro kernel: usb 1-13.3: Failed to query (GET_MIN) UVC control 12 on unit 1: 0 (exp. 3).
Aug 01 09:58:34 havoc-manjaro kernel: usb 1-13.3: Failed to query (GET_MAX) UVC control 12 on unit 1: 0 (exp. 3).
Aug 01 09:58:34 havoc-manjaro kernel: usb 1-13.3: Failed to query (GET_RES) UVC control 12 on unit 1: 0 (exp. 3).
Aug 01 09:58:34 havoc-manjaro gnome-keyring-daemon[1795]: discover_other_daemon: 1
Aug 01 09:58:34 havoc-manjaro kernel: kauditd_printk_skb: 8 callbacks suppressed
Aug 01 09:58:34 havoc-manjaro plasmashell[1410]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:43:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
Aug 01 09:58:34 havoc-manjaro plasmashell[1410]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:41: TypeError: Cannot read property 'length' of undefined
Aug 01 09:58:34 havoc-manjaro plasmashell[1410]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Aug 01 09:58:35 havoc-manjaro plasmashell[1410]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/FullRepresentation.qml:21:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
Aug 01 09:58:35 havoc-manjaro plasmashell[1410]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.horizontalbars/contents/ui/FullRepresentation.qml:28:9: Unable to assign [undefined] to double
Aug 01 09:58:35 havoc-manjaro baloo_file_extractor[1669]: kf.baloo: Found "/home/havoc/snap/teams/7/.config" in the ContentIndexingDB, although it should be skipped
Aug 01 09:58:38 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000c
Aug 01 09:58:38 havoc-manjaro kwin_x11[1354]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1290, resource id: 62914566, major code: 18 (ChangeProperty), minor code: 0
Aug 01 09:58:38 havoc-manjaro plasmashell[1410]: kf.quickcharts.deprecated: LegendDelegate::colorVisible is deprecated (since 5.82): Use an empty indicator instead
Aug 01 09:58:38 havoc-manjaro plasmashell[1410]: kf.quickcharts.deprecated: LegendDelegate::layoutWidth is deprecated (since 5.82): Unused
Aug 01 09:58:38 havoc-manjaro plasmashell[1410]: kf.quickcharts.deprecated: LegendDelegate::valueWidth is deprecated (since 5.82): Use maximumValueWidth instead
Aug 01 09:58:46 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000d
Aug 01 09:58:50 havoc-manjaro kernel: kauditd_printk_skb: 3 callbacks suppressed
Aug 01 09:58:50 havoc-manjaro systemd-coredump[1887]: [š”] Process 1852 (teams) of user 1000 dumped core.
Module /snap/teams/7/usr/share/teams/teams with build-id c3b7f83e8a64a8f83449435bcddfbafa5a185d35
Module /snap/teams/7/gnome-platform/usr/lib/x86_64-linux-gnu/libxcb-glx.so.0.0.0 with build-id cbc885c7ff2328753017dce83ce7013a3c735cc7
Module /var/lib/snapd/hostfs/usr/lib/libnvidia-glcore.so.515.57 with build-id 92b04a9299c745a4cc402999f180506619b14e37
Module /var/lib/snapd/hostfs/usr/lib/libnvidia-glsi.so.515.57 with build-id 4e1ef540b9a4b999ba9f4434a06949d62ec74b13
Module /var/lib/snapd/hostfs/usr/lib/libGLX_nvidia.so.515.57 with build-id 53712e4e9771e5f7e201be3987f4a31d0a97db09
Module /var/lib/snapd/hostfs/usr/lib/libnvidia-tls.so.515.57 with build-id 782bcaa66034d82c6605fd02a57ebd7577d33f9c
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libGLdispatch.so.0.0.0 with build-id 8b48d0a875b130c9a6f2d0f558f53246ac22c0cf
Module /snap/teams/7/gnome-platform/usr/lib/x86_64-linux-gnu/libGLX.so.0.0.0 with build-id 6195bcee98ae963430016f23c66900b4501e6dcd
Module /snap/teams/7/gnome-platform/usr/lib/x86_64-linux-gnu/libGL.so.1.0.0 with build-id 8601ec40b43cc466f98317e208e52d1b8f7b863d
Module /snap/teams/7/usr/share/teams/libEGL.so with build-id 332acb64ab3904a778a304cb761d5797728a135a
Module /snap/teams/7/usr/share/teams/libGLESv2.so with build-id c96bb20e6a8544755e465a6e2b4499e3be4b56cf
Module /snap/teams/7/lib/x86_64-linux-gnu/libkeyutils.so.1.5 with build-id ccf39e49333249e43f465986b782d687686d9bbb
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libgraphite2.so.3.0.1 with build-id 8dc36725dbcad45e40a76ab12d83685aa39abe4c
Module /lib/x86_64-linux-gnu/libgpg-error.so.0.22.0 with build-id f958b7b9ce43ccad1ea543b42cadfe8663f63705
Module /lib/x86_64-linux-gnu/libuuid.so.1.3.0 with build-id 4938b15a667a41cc98755418556ea492500a927a
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libgmp.so.10.3.2 with build-id d40ea9b5ec5bc46799e4a412319617bd38be9341
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libhogweed.so.4.5 with build-id 372ee4a2e4bb08f1a2b01ae486f88e7466add389
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libnettle.so.6.5 with build-id 433053b348a412f5cf22d07f699d412ad753fbe5
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libtasn1.so.6.5.5 with build-id 6036b89a3bb671b32e01464c0c82bfa016186352
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0 with build-id 0e2784298e7d3f4d894fe130acefa77c3e624f72
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libidn2.so.0.3.3 with build-id ee6e9462ba2491f4ee8c4e52c3323274a9366614
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0 with build-id 8cff559d91e3376842a1ba41ccf74eb9decd159b
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1 with build-id eae217d2281e12bcd43675c73c59df29d7167c66
Module /snap/teams/7/lib/x86_64-linux-gnu/libcom_err.so.2.1 with build-id 17107881df65c66b4c6d38cab37c285fa44663bd
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1 with build-id 729f89dd92e3441fa99f8682533f7b92ee48880d
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libkrb5.so.3.3 with build-id 320112ee17c7f1886dbeb108429063b22d996e9e
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libdatrie.so.1.3.3 with build-id 0c29e7bb71b459097f0a02f3ce94b03a141d54e3
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libharfbuzz.so.0.10702.0 with build-id 204d6da78ed0feeae539ca71d40181ec64543ed2
Module /lib/x86_64-linux-gnu/libgcrypt.so.20.2.1 with build-id 86d0fa901cabb998d93af72c615edf7f849cb112
Module /usr/lib/x86_64-linux-gnu/liblz4.so.1.7.1 with build-id 056d303335a61401eb4d9db74942f4db20444ece
Module /lib/x86_64-linux-gnu/liblzma.so.5.2.2 with build-id 7aa2aad2dac1b21ad4677b8a2a43495afbaa65a9
Module /snap/teams/7/lib/x86_64-linux-gnu/libbsd.so.0.8.7 with build-id 5778a8a28ec1c4b154ce0d9c35686f082c41284a
Module /lib/x86_64-linux-gnu/libblkid.so.1.1.0 with build-id bbe20d3ad910e39003554ef3317a14ce834b57e7
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libavahi-client.so.3.2.9 with build-id d14e46109c55fb34ea77e6b798b52d9cff39f4ec
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libavahi-common.so.3.5.3 with build-id 1d1a3d8c4ca35ceb84ea507aa87635bc9bc8c31d
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libgnutls.so.30.14.10 with build-id da3c78836d1c97b4158870fb2a84817c0653d8e9
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2 with build-id 9fd187fe6579db3b458e021ccac0eccafc66b1b7
Module /snap/teams/7/gnome-platform/usr/lib/x86_64-linux-gnu/libwayland-server.so.0.1.0 with build-id f9bce5a06e453bfa120a0a5b4670d61218ff3aa0
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libxcb-render.so.0.0.0 with build-id 56e0864750f281a2eb23f6253aad75ee7af960fa
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libxcb-shm.so.0.0.0 with build-id dcabce620d5bea0411caee0e57bbd626091abcce
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libpng16.so.16.34.0 with build-id d532f2230c3c84289a0833fc0c1352aaac5892c6
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libpixman-1.so.0.34.0 with build-id 3c3da6e5e912f2f7fc95155dff00f0cd454511bf
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libthai.so.0.3.0 with build-id 91b8d676941b633961c0fa6ed55a35d953ce6768
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libfreetype.so.6.15.0 with build-id da11d808a420654284fc36fff91e32a742379144
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libwayland-client.so.0.3.0 with build-id 56c50b3f44c8a85a7533fc74d8b5323ba97926f3
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libwayland-egl.so.1.0.0 with build-id 6087d2e0157b21c0da46960d7275eef6dfa8c7bf
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libwayland-cursor.so.0.0.0 with build-id 87c5b08b83df18f5c62405708ab5820443392ab6
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libxkbcommon.so.0.0.0 with build-id 0aa31e16edd934ecf6b53988c7f15eceb82dad9c
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libXinerama.so.1.0.0 with build-id 02ab62947fe2d1fc26246ae50e04c17f91cbec5c
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libfontconfig.so.1.10.1 with build-id 387ddda1c9beecb8d69f15792c8d27e087533c40
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0.4000.14 with build-id 4338eae486fd382ccc533012d62968ed9959b1c9
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libepoxy.so.0.0.0 with build-id 4213e6a38bc70c7a77192b4b186c4fbb38a4f3e3
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libcairo-gobject.so.2.11510.0 with build-id be8e7175ce7853d91a64c8621a7a75a022e555dd
Module /lib/x86_64-linux-gnu/libsystemd.so.0.21.0 with build-id c0f3e29f89333fb183ceebe8859ac700ffa48c90
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libplds4.so with build-id 64e1ba5c0c1afed0f5770c1b91e8113792ba7fd6
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libplc4.so with build-id 12a25d77902bfa086d0143f1406268107b4fa68f
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0 with build-id f35e3e5ff3fede9b4a4715aebd4677f356fc3ce9
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libXau.so.6.0.0 with build-id 571d2c0a08a78e9afbb7fc8e927e7fe9e6e60663
Module /lib/x86_64-linux-gnu/libmount.so.1.1.0 with build-id c3e565680f4f33fdfabce12db4b079ccab4700f1
Module /lib/x86_64-linux-gnu/libresolv-2.27.so with build-id 0f375714358902a9cc97b6255860e804e2027f0c
Module /lib/x86_64-linux-gnu/libselinux.so.1 with build-id bc6660abcafb3cef8f7c775c6f848366b69f17fa
Module /lib/x86_64-linux-gnu/libz.so.1.2.11 with build-id 6517f816c946c49ad246642f79493cd0ca2629db
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.5600.4 with build-id 4221d791000c2555976147966bc14b3e752cf245
Module /lib/x86_64-linux-gnu/libpcre.so.3.13.3 with build-id 08328a29c1364d46576dd95f25062b2cca3b0c73
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libffi.so.6.0.4 with build-id 3555b5f599c9787dfddbf9e8df6f706b9044d985
Module /lib/x86_64-linux-gnu/libc-2.27.so with build-id f7307432a8b162377e77a182b6cc2e53d771ec4b
Module /lib/x86_64-linux-gnu/libgcc_s.so.1 with build-id 679f3ae11120ec7c483bc9295345d836f5c104f7
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libcups.so.2 with build-id a1be018edb4934bbd28adcbb6ea14aa914a058cb
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libatspi.so.0.0.1 with build-id 44d760d79cd1f927cb1bd8cfd81728f53cee40c2
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libasound.so.2.0.0 with build-id 07c6ffd29c43c5b1b0809f79be87090416320838
Module /snap/teams/7/gnome-platform/usr/lib/x86_64-linux-gnu/libgbm.so.1.0.0 with build-id bd014af296ff020a48ad1234453310d6069e16e3
Module /snap/teams/7/gnome-platform/usr/lib/x86_64-linux-gnu/libdrm.so.2.4.0 with build-id a2181b9804670894e9db0a5c1228c42be4aad0b6
Module /snap/teams/7/lib/x86_64-linux-gnu/libexpat.so.1.6.7 with build-id 41c3d975f41bc97d465e4260d2034430a0f6a496
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libXrandr.so.2.2.0 with build-id f93914194e8d750b58629f3cb1ba0383fbe8c27b
Module /lib/x86_64-linux-gnu/libm-2.27.so with build-id 365483d22aefb38cd989ebc15bf6b135138f6c64
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libcairo.so.2.11510.0 with build-id 48aee3d2318aefb167e3715bad1866bf25a29563
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libpango-1.0.so.0.4000.14 with build-id d16fc9243474919f532d141fcc58a9468d72c20d
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libpangocairo-1.0.so.0.4000.14 with build-id 16372b79278309083f80f21580450b59a3ae8e3d
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libgdk-3.so.0.2200.30 with build-id 5298ec4d065b4f7ca436d4b2a92263520dcf3e2d
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libgtk-3.so.0.2200.30 with build-id 46ee1cde97670ecf98c9ce419ca8ccaaf03fb454
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.3611.0 with build-id 1e04f486328afe0eb1437debfd3d89f19d6417dd
Module /snap/teams/7/lib/x86_64-linux-gnu/libdbus-1.so.3.19.4 with build-id 91f08630041e94c95749a2733c0ce91a0b2b79a0
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libatk-bridge-2.0.so.0.0.0 with build-id b393686855226716cfa062f92b3b021742649bb8
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libatk-1.0.so.0.22810.1 with build-id 3f39cbe6431bd19ca399e0a6f09fa5a55be9bc11
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libnspr4.so with build-id 19f69293ad4719543fb9f17f98684e62deb3308f
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libsmime3.so with build-id 1eae4f5267f6f9c49551b023826decec0bf40e99
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libnssutil3.so with build-id a2f362b33d480966a555c481caf82320006019a8
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libnss3.so with build-id 781e13c43651b7dda4ee11bc928012597f74e44c
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libXtst.so.6.1.0 with build-id f5b91f39bffeba7770712f5876e162593784d92c
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libXrender.so.1.3.0 with build-id a7acaf84adf6b580236c7cf005412a5949febb49
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libXi.so.6.1.0 with build-id 2ca3d7c388bf3a1bf2e35038533d20141a2a2c6c
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libXfixes.so.3.1.0 with build-id 7444d1981c956223bccea31b0ca0c23dfa5af09d
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libXext.so.6.4.0 with build-id ec7ddbe21ea0de71ba48ad4d2402042654de5a88
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libXdamage.so.1.1.0 with build-id 0e0e25f6bc914aaeb8143a436cf6aa3385454268
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libXcursor.so.1.0.2 with build-id d5fa0c558ae79081c022e74729b596a7dd8ef13d
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libXcomposite.so.1.0.0 with build-id effdb06e0243f21f2a1fe384fb3c67a04c9ce8d7
Module /snap/teams/7/gnome-platform/usr/lib/x86_64-linux-gnu/libxcb-dri3.so.0.0.0 with build-id fdfef4ae8f8765165a7fbcad03200d7d22d6e1e4
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0 with build-id 3d49ac024ca8f7e36f5296a7d0d7f083ab1c8a62
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libX11-xcb.so.1.0.0 with build-id 059afb70fcacfe4e78461d10cd18c886b1a1e61a
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libX11.so.6.3.0 with build-id 4124168452d079d48767ebadd480872381d71faa
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.5600.4 with build-id cbe9bd6b0a4135558dc1fae93ad94d53b2427464
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.5600.4 with build-id 1548dc39c875598d592047b1504f94c40a66684f
Module /snap/teams/7/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.5600.4 with build-id a6f6a14a5b22465dff9ccfbbadc9530fc9ea5e52
Module /lib/x86_64-linux-gnu/librt-2.27.so with build-id 536945c2f46fc84dbd99d38c377cdae9d1d4fdab
Module /lib/x86_64-linux-gnu/libpthread-2.27.so with build-id 1f06001733b9be9478b105faf0dac6bdf36c85de
Module /lib/x86_64-linux-gnu/libdl-2.27.so with build-id 4c0610fa7b0706d9abc26de5e7940d2e2578eec5
Module /snap/teams/7/usr/share/teams/libffmpeg.so with build-id f4cbd7c85466098f8f63de880e565d5001e8322d
Module /snap/teams/7/lib/x86_64-linux-gnu/bindtextdomain.so with build-id fedf4f3fe3e518798c75cd25498950a8d874bd8d
Module /snap/teams/7/gnome-platform/libpreload-chromium-content-api.so with build-id 88cb434de27666c3cb7e65cae03000da98960e7a
Module ld-linux-x86-64.so.2 with build-id 9ea8014cf02021a29e57aa3e0512e9bb6e30541d
Stack trace of thread 1854:
#0 0x00005648725ab376 n/a (/snap/teams/7/usr/share/teams/teams + 0x5367376)
#1 0x00005648725aac03 n/a (/snap/teams/7/usr/share/teams/teams + 0x5366c03)
#2 0x000056487112edf6 n/a (/snap/teams/7/usr/share/teams/teams + 0x3eeadf6)
#3 0x000056487114012f n/a (/snap/teams/7/usr/share/teams/teams + 0x3efc12f)
#4 0x00005648710ffefa n/a (/snap/teams/7/usr/share/teams/teams + 0x3ebbefa)
#5 0x00005648711407f4 n/a (/snap/teams/7/usr/share/teams/teams + 0x3efc7f4)
#6 0x000056487111976e n/a (/snap/teams/7/usr/share/teams/teams + 0x3ed576e)
#7 0x0000564871158a97 n/a (/snap/teams/7/usr/share/teams/teams + 0x3f14a97)
#8 0x0000564871178c65 n/a (/snap/teams/7/usr/share/teams/teams + 0x3f34c65)
#9 0x00007ff5e0f9f6db n/a (/lib/x86_64-linux-gnu/libpthread-2.27.so + 0x76db)
Aug 01 09:58:51 havoc-manjaro xembedsniproxy[1406]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 460, resource id: 50331651, major code: 12 (ConfigureWindow), minor code: 0
Aug 01 09:58:51 havoc-manjaro plasmashell[1410]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Aug 01 09:58:51 havoc-manjaro plasmashell[1410]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Aug 01 09:58:51 havoc-manjaro plasmashell[1410]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Aug 01 09:58:52 havoc-manjaro plasmashell[1410]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5621f6cd2270)
Aug 01 09:58:52 havoc-manjaro plasmashell[1410]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5621f6c907e0)
Aug 01 09:58:52 havoc-manjaro plasmashell[1410]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x5621f6c035a0)
Aug 01 09:58:52 havoc-manjaro plasmashell[1410]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5621f6c67eb0)
Aug 01 09:58:52 havoc-manjaro plasmashell[1410]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5621f6c035a0)
Aug 01 09:58:52 havoc-manjaro plasmashell[1410]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x5621f6c35b50)
Aug 01 09:58:52 havoc-manjaro plasmashell[1410]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Aug 01 09:58:52 havoc-manjaro plasmashell[1410]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Aug 01 09:58:52 havoc-manjaro plasmashell[1410]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
Aug 01 09:58:52 havoc-manjaro plasmashell[1410]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Aug 01 09:58:53 havoc-manjaro kwin_x11[1354]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1857, resource id: 60817416, major code: 15 (QueryTree), minor code: 0
Aug 01 09:58:55 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000e
Aug 01 09:58:56 havoc-manjaro kernel: kauditd_printk_skb: 6 callbacks suppressed
Aug 01 09:59:00 havoc-manjaro kdeconnectd[1466]: kdeconnect.core: Could not query capabilities from notifications server
Aug 01 09:59:04 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 0000000f
Aug 01 09:59:05 havoc-manjaro kernel: kauditd_printk_skb: 11 callbacks suppressed
Aug 01 09:59:09 havoc-manjaro kwin_x11[1354]: kwin_core: XCB error: 152 (BadDamage), sequence: 2285, resource id: 18874428, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Aug 01 09:59:09 havoc-manjaro kwin_x11[1354]: kwin_core: XCB error: 3 (BadWindow), sequence: 2303, resource id: 18874425, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Aug 01 09:59:12 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000010
Aug 01 09:59:12 havoc-manjaro kwin_x11[1354]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2361, resource id: 4194328, major code: 18 (ChangeProperty), minor code: 0
Aug 01 09:59:12 havoc-manjaro plasmashell[1410]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Aug 01 09:59:12 havoc-manjaro plasmashell[1410]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Aug 01 09:59:17 havoc-manjaro plasmashell[1410]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Aug 01 09:59:20 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000011
Aug 01 09:59:28 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000012
Aug 01 09:59:31 havoc-manjaro kernel: kauditd_printk_skb: 5 callbacks suppressed
Aug 01 09:59:36 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000013
Aug 01 09:59:44 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000014
Aug 01 09:59:44 havoc-manjaro plasmashell[1410]: org.kde.plasma.pulseaudio: context kaput
Aug 01 09:59:44 havoc-manjaro plasmashell[1410]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:71:17: Unable to assign [undefined] to int
Aug 01 09:59:52 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000015
Aug 01 10:00:00 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000016
Aug 01 10:00:00 havoc-manjaro plasmashell[1410]: Trying to take space not available BasicAppletContainer_QMLTYPE_54_QML_74(0x5621f643faa0, parent=0x5621f60a9240, geometry=1632,330 176x240)
Aug 01 10:00:08 havoc-manjaro kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000000 Count 00000017
