Incredibly, more than two years later this problem has still not been fixed. All gnome gtk4 apps are very slow to start. This includes the Settings app, which is also a gtk4 app. There is generally a very long startup notification (spinning cursor). Perhaps, the worst affected is gnome-clocks. I tried Ubuntu, Fedora and Garuda Linux Gnome and found that this problem does not exist for those distros. On those distros gnome-clocks opens instantly, for example. For now I have switched to gtk3 apps wherever possible.
Hello @905 ![]()
Try this:
export GSK_RENDERER=gl; pamac-manager
export GSK_RENDERER=ngl; pamac-manager
ngl uses Vulkan instead of OpenGL and is the default renderer. If your hardware is old, use gl.
Makes no difference.
For a start, please provide some system information:
inxi --admin --verbosity=8 --filter --no-host --width
This is the minimum information usually requested, and will allow others to discover other factors that might be contributing.
I do not believe this is a hardware problem particular to my machine. When trying gnome with other distros on the same machine there is no issue.
If you have a working and non-working distribution you can run diagnostic commands on both machines and compare data to find differences
@905 You could probably switch to unstable branch, since that branch is equal to ArchLinux Stable and Garuda. I use the unstable branch myself and see no real delay… maybe 1-3 seconds. Could you test that?
How does this belief prevent you from providing requested information?
Good luck.
inxi --admin --verbosity=8 --filter --no-host --width ✔
Kernel: 6.11.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=0a3ce957-5e92-408f-babe-76d6617790cb rw quiet splash apparmor=1
Desktop: GNOME v: 47.1 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: Dell product: Inspiron 5567 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 01W6F7 v: A00 serial: <superuser required> part-nu: 0767
uuid: <superuser required> UEFI: Dell v: 1.0.1 date: 08/11/2016
ID-1: BAT0 charge: 5.7 Wh (100.0%) condition: 5.7/42.0 Wh (13.5%) volts: 12.4
min: 11.4 model: LGC-LGC3.553 DELL T2JX467 type: Li-ion serial: <filter>
status: full
System RAM: total: 8 GiB available: 7.66 GiB used: 2.19 GiB (28.6%)
Array-1: capacity: 16 GiB slots: 2 modules: 1 EC: None
Device-1: ChannelA-DIMM0 type: no module installed
Device-2: DIMM B type: DDR4 detail: synchronous size: 8 GiB speed:
spec: 2400 MT/s actual: 2133 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: 163500000000
part-no: 8ATF1G64HZ-2G3B1 serial: <filter>
Info: model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF6
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 400 min/max: 400/3100 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 21607
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: Realtek Integrated Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0bda:568a
Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x0525 built: 2016 res: 1366x768
dpi: 101 gamma: 1.2 chroma: red: x: 0.569 y: 0.345 green: x: 0.333 y: 0.561
blue: x: 0.157 y: 0.118 white: x: 0.314 y: 0.329
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1366x768
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
device-ID: 8086:5916 memory: 3.74 GiB unified: yes display-ID: :0.0
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.11.6-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:3165 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF-ID-1: CloudflareWARP state: unknown speed: 10000 Mbps duplex: full
mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> scope: global
IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 8087:0a2a
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 465.76 GiB used: 119.72 GiB (25.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C1
dev-links: cdrom
ID-1: / raw-size: 461.47 GiB size: 453.15 GiB (98.20%)
used: 119.72 GiB (26.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 0a3ce957-5e92-408f-babe-76d6617790cb
used: 304 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: E1D9-1DD6
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: d28768e1-9ced-4872-a2d7-042408542022
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Realtek Integrated Webcam type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0bda:568a class-ID: 0e02 serial: <filter>
Device-2: 1-6:3 info: Realtek RTS5129 Card Reader Controller
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
Device-3: 1-8:4 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 39.0 C pch: 29.0 C mobo: 25.0 C sodimm: SODIMM C
Fan Speeds (rpm): cpu: 0
Packages: 1285 pm: pacman pkgs: 1279 libs: 374
tools: gnome-software,pamac,yay pm: flatpak pkgs: 6
1: https://mirrors.cicku.me/manjaro/unstable/$repo/$arch
2: https://mirrors2.manjaro.org/unstable/$repo/$arch
3: https://mirrors.manjaro.org/repo/unstable/$repo/$arch
Processes:
CPU top: 5 of 225
1: cpu: 44.8% command: firefox pid: 9685 mem: 511.5 MiB (6.5%)
2: cpu: 19.3% command: firefox pid: 9889 mem: 261.3 MiB (3.3%)
3: cpu: 7.1% command: gnome-terminal-server pid: 10070 mem: 62.6 MiB (0.7%)
4: cpu: 6.7% command: firefox pid: 9822 mem: 241.2 MiB (3.0%)
5: cpu: 5.1% command: zsh pid: 10078 mem: 11.7 MiB (0.1%)
Memory top: 5 of 225
1: mem: 511.5 MiB (6.5%) command: firefox pid: 9685 cpu: 44.8%
2: mem: 374.6 MiB (4.7%) command: gnome-shell pid: 1466 cpu: 3.0%
3: mem: 261.3 MiB (3.3%) command: firefox pid: 9889 cpu: 19.3%
4: mem: 241.2 MiB (3.0%) command: firefox pid: 9822 cpu: 6.7%
5: mem: 202.3 MiB (2.5%) command: firefox pid: 9765 cpu: 4.0%
Processes: 225 Power: uptime: 2h 53m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.05 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.36
I AM on the Unstable branch. A month ago I was on the Stable branch. Which branch you use makes no difference.
Anything in the logs?
Maybe try starting the applications from the terminal and observing the output?
I may also note that your profile lists your desktop as XFCE and wonder if this was converted to Gnome, or was Gnome installed fresh?
You had not previously specified which branch you are using.
Without any clear indication of the branch being used it’s a fair assumption that you might have been using the Stable branch.
In this case it is also a fair suggestion to switch to Unstable (or Testing) for the purpose of comparison and testing against newer packages; a different environment.
If you are suggesting the issue you are experiencing is somehow Manjaro specific, thus far there doesn’t seem much information provided that might help confirm or deny that.
All I can suggest is working with – rather than against – those wishing to help, so that a solution might be reached.
If you haven’t found a solution after keeping a well maintained Manjaro Gnome system for more than two years (I too find this incredible) is to perhaps use one of the other distributions mentioned.
BIOS
I note that your BIOS is rather old. Updating to the latest (non-Beta) BIOS is often a smart move; and can often solve issues you might not even be aware of.
In this instance, BIOS version 1.2.7 released on 2019-05-09 – marked as critical – is available from the Dell site:
I’d suggest contacting Dell for instructions on applying the BIOS update; do this if only to address the security issues listed.
KERNEL
I notice you are using kernel 6.11.
Kernel 6.12 (LTS) is expected to be generally available this month. Switching kernels might improve things to some extent, though with a laptop of this vintage kernels 6.1 (LTS) or 6.6 (LTS) might also be worth trying.
Other possibly related articles:
- Some programs taking a long time to launche
- Comment from Unstable Update 2023-05-06
- Marked solution from After last full upgrade apps loading very slow – this may be pertinent with respect @cscs’s comment above.
- General search results: Gnome apps slow
Good luck.
I updated the BIOS. I have already tried the two older kernels you mention. That did not solve the problem. Thanks a lot for your help and time all the same.
I finally discovered the source of the problem: it is the papirus-maia icon theme. When I changed to the default Adwaita theme, all gtk4 themes start normally. The long startup notifications are gone. The gnome-clocks app starts instantly as in other distros.
Updating to the adwaita-icon-theme-legacy-46.2-3 package also resolves some issues noted of late:
sudo pacman -Syu adwaita-icon-theme-legacy
well done. that does seem to make a dramatic difference. 2 years yikes!.
I use papirus-dark-maia. Adwaita icons looks horrible on Manjaro dark.
So is papirus-dark-maia icons part of the Manjaro official theme? it fits perfectly so i assume it is. Will the devs be able to fix this theme?
