Gtk2 apps not following system dark theme
The info on the possible issue mentions that there can be an issue with GTK4 apps not following the system dark theme anymore. I personally didn’t have this issue and didn’t have to use the measures advised, probably because I use Adwaita-dark.
However, what is not mentioned is that GTK2 apps may stop following the dark theme. In my case I noticed it on Rainlendar. Granted, not the most widely-used app, but other GTK2 apps are affected as well. Again, there may not be a lot of them still around, but it affects, for example, HexChat, which, if I’m not mistaken, is shipped with every Manjaro fresh install.
Mod edit: Your posts have been moved to a dedicated topic. :eyes:
Hexchat has not been included in ISOs since Wynsdey 24.0.6 (2024-08-12)
Manjaro 24.0 Wynsdey released
Hexchat was dropped to aur as is now everything gtk2.
Hexchat has been discontinued, over a year.
2.16.2, The Final Release
Posted - 09 Feb 2024
This week 2.16.2 has been released. It contains some small fixes and features that have accumulated over the past two years since the last release.
This will be the last release I make of HexChat. The project has largely been unmaintained for years now and nobody else stepped up to do that work.
I want to say thank you to all of the contributors, users, and chatters I’ve interacted with over the years. HexChat was a very important and formative project for me; I started contributing to it as a teenager, learned so much, met many great people, and it led to greater things in my life. It is hard to let go but the time has come for me to move on.
I am going to move all data that I can to be hosted on Github, so all documentation, installers, and dependencies will be there until the end of Microsoft.
Forks of the project are welcomed. Nobody can stop the code from living on.
https://forum.manjaro.org/t/stable-update-2025-12-08-25-1-anh-linh-preview/183479/215?u=kzer-za
https://forum.manjaro.org/t/stable-update-2025-12-08-25-1-anh-linh-preview/183479/217?u=kzer-za
Well, for me it is still recently, sorry that I missed it :slight_smile:
Regardless, there are still some GTK2 apps around. Take Rainlendar, for example. So, any advice on how to make them follow the dark theme now?
Rainlendar is available from AUR
AUR (en) - rainlendar-lite
AUR (en) - rainlendar-pro
I suggest open a new topic for this
I doubt they ever did…
It will be more and more difficult as time passes…
Until the last update they did.
As it has been a long time since a spent time in a GTK2 environment - I stand corrected :slight_smile:
AUR package rainlandar-lite has 3 skins in folder /opt/rainlendar2/skins/
Chromophore.r2skin Savannah.r2skin Shadow4.r2skin
Rainlender FAQ - How can I create new skins?
You can find skin format documentation from the Rainlendar’s help file. It also contains a step by step tutorial for making a simple xml-format skin.
One possibility is to look at one of the existing Rainlendar skins and see how it’s made. Rainlendar2 skin (.r2skin) is just a normal zip archive with different file extension so you can uncompress it after renaming the extension back to .zip. The archive contains few xml files and the resources (images, scripts, …). The skin.xml file must be in the root of the archive so make sure that when you are zipping the archive after modifications that it doesn’t contain any extra folders.
The same three default skins available for the last 20 years (naturally, updated from time to time).
@Kzer-Za
I’d almost forgotten about Rainlendar…
(I’ve had a Pro licence for more years than I care to remember)
“Shadow4” always seemed the easiest (most practical) to manage, but there are other 3rd party skins available that you might like to investigate;
Some nice skins to be found here:
And some older collections:
As a last resort, if you’re feeling creative:
@soundofthunder
Rainlendar skins do not affect its standard GUI elements, like the color of the window “background” (against which the text is displayed), text color, and so on. They affect only the specific Rainlendar widgets (they are displayed in a kind of an “additional layer” of your desktop surface; think Conky to visualize what I mean). The themes affect only visual effects of these widgets. But when you need to open an event or task (to add a new one or edit an existing one) — this is done through standard GUI windows and those are rendered with the standard window background, which after the last update became light. Also the context menu (the one that is displayed when you right-click the Rainlendar tray item) is also rendered in standard GUI theme colors, so it also used to be dark, but became light, and is equally unaffected by Rainlendar skins.
Yes, I understand how it works.
I also understand that one can be lucky and find a skin that disguises things to a degree.
With respect the underlying controls, I’m afraid there’s little to be done about that with GTK2 being removed. Perhaps it’s time to start petitioning the developer to update – though, he’s a one-man-operation, so I wouldn’t hold my breath.
Okay, thanks for the advice. I doubt that he will fix it, since he did not yet move from GTK2, so I was hoping there was a way to adjust something on the user side.
Adwaita themes from extra repository do not support Gtk2
but there is an AUR package
AUR (en) - adwaita-dark
Package Base: adwaita-dark
Description: A dark GTK2 theme for use alongside the dark variant of GTK3 Adwaita
Upstream URL: AdwaitaDark - Gnome-look.org
Last Updated: 2018-11-07 02:51 (UTC)
Dependencies: gtk2 AUR (gtk2-patched-filechooser-icon-view AUR)
There is however;
which might potentially restore GTK2 support to an extent (“might” being the operative word).
Being sourced via the AUR this would be entirely at your own risk and no support will be offered.
Yes, it is among requirements for Rainlendar.
Thanks! Unfortunately, it did not seem to help, but I suppose that is to be expected since it was not updated for 6 years :person_shrugging:
That’s due to the Gtk 2 themes being removed from gnome-themes-extra. They’re in the AUR as gnome-themes-extra-gtk2.
