GTK-NoCSD - Restore system titlebar on all GTK applications
Thought I’d announce the library I have written, which allows the removal of the GTK client side decoration (headerbar) in all GTK versions (GTK3/4, LibHandy, and LibAdwaita).
It is similar to the older gtk3-nocsd, except works for all applications, even flatpak, and there aren’t that many bugs (if any, reports are welcome)
The source/documentation is here:
https://codeberg.org/MorsMortium/GTK-NoCSD
And it is available from the AUR:
https://aur.archlinux.org/packages/gtk-nocsd-git
(sorry for link formatting)
Mod edit:- Converted malformed URLs to pre-formatted text – the complete URLs may now be easily selected and copied to clipboard by anyone who so wishes. No charge.
What is a Quark?
Thank you so much for writing this. I’ll test it out soon.
The invasion of mobile-first features on Linux desktops is very irritating to me.
Links:
GTK-NoCSD on codeberg.org
AUR: gtk-nocsd-git
Thank you! I just hate this gnome interface.
This but also an increased uptick (or maybe just my feeling) of folks initiating projects to do what has already been done in a ‘slicker’ GTK4 skin and with many missing features.
Latest example (after enjoying Shortwave since around 2019) is ‘Receiver’… which offers ‘a curated list of 30,000 stations’ but when I tested it, the curated list was well outdated…
Once again the mobile generation strikes in another attempt to dumb down the simple yet functional interface of https://www.radio-browser.info/ and present a mobile-friendly dumb interface with no useful options.
OK I have this in the path for videoDownloader, a flatpak.
/usr/bin/flatpak run --branch=stable --arch=x86_64 --command=video-downloader --env=LD_PRELOAD=/opt/gtk-nocsd/libgtk-nocsd.so com.github.unrud.VideoDownloader
Instructions are here:
https://codeberg.org/MorsMortium/GTK-NoCSD#usage
Yeah working through them , see post above yours. No joy yet.
Running in CLI
[tracy@daphne]$ /usr/bin/flatpak run --branch=stable --arch=x86_64 --command=video-downloader --env=LD_PRELOAD=/opt/gtk-nocsd/libgtk-nocsd.so com.github.unrud.VideoDownloader
ERROR: ld.so: object '/opt/gtk-nocsd/libgtk-nocsd.so' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
Ooops - sorry 'bout dat. :flushed_face:
I opened the reply box before you made your edits, and then got a little distracted for a few minutes before completing the reply. So I didn’t spot the extra info you had added to your post.
I hope you get it working on your system.
So do I.
I have managed to get it to work with Manjaro Hello
manjaro-hello
But I’m not sure if it’s a GTK3 or a GTK4 application.
it won’t work with pamac-manager (a GTK4 application), and it doesn’t seem to work with flatpaks.
For flatpak you also have to pass through the folder in which the library is. The command I use for that is
flatpak override --user --filesystem=/opt/gtk-nocsd/ --env=LD_PRELOAD=/opt/gtk-nocsd/libgtk-nocsd.so
(this globally sets it up for the user)
pamac-manager does work on my end. How exactly do you set it up? Also have you tested it manually from terminal? There are certain launchers that might need the ~/.config/environment.d part from the readme
https://0.vern.cc/A_.png
python app using GTK3 for GUI
Yeah I set that up.
I set the Environment Variable in the Menu.
I do the same for pamac-manager
I thought it might be GTK3
[tracy@daphne Downloads]$ flatpak override --user --filesystem=/opt/gtk-nocsd/ --env=LD_PRELOAD=/opt/gtk-nocsd/libgtk-nocsd.so
[tracy@daphne Downloads]$ flatpak run --branch=stable --arch=x86_64 --command=video-downloader com.github.unrud.VideoDownloader
Failed to register: Timeout was reached
That is interesting. Can you show the output of flatpak override --show and flatpak override --user --show?
[tracy@daphne Downloads]$ flatpak override --show
[tracy@daphne Downloads]$ flatpak override --user --show
[Context]
filesystems=/opt/gtk-nocsd;
[Environment]
Easyflatpak and gitfiend seem to work, but not Video Downloader.
For pamac-manager, I tried this setup method as well, It also did not work, from editing the menu and also from ~/.config/environment.d.
Per app loading is a bit fragile, since different startup methods inherit from different environments. The way I load it on my own system is having export LD_PRELOAD=/usr/lib/libgtk-nocsd.so in my ~/.bash_profile, it might not be bash_profile for you as you might have a different system shell, the profile of that is needed. Another, which might be a more unified solution and I have seen used is having LD_PRELOAD=/opt/gtk-nocsd/libgtk-nocsd.so in /etc/environment or in /etc/environment.d/gtk-nocsd.conf But these of course need super user rights to edit, and everything except the menu editing is global loading.
I use bash
That did it. Added the environment variable to my bash profile, and loged out then in.
Sweet.
That fixed VideoDownloader as well. Even Sweeter.
As a bit of offtopic, if you use KDE, I recommend Media Downloader instead (flathub: io.github.mhogomchungu.media-downloader)
Which one, there are 3 of them?
