whats output from:
test -d /sys/firmware/efi && echo efi || echo bios
whats output from:
from the live usb I get “efi” as output
were you chrooted when you run the command?
Yes and tried outside chroot and got the same thing
so using your link above this is how to reinstall grub:
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
then this:
grub-mkconfig -o /boot/grub/grub.cfg
post errors/warnings
[manjaro /]# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
Installation finished. No error reported.
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-5.17-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.17-x86_64.img
Found initrd fallback image: /boot/initramfs-5.17-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
done
ok so now reboot and see if that helped:
exit
systemctl reboot
and if you try different kernel from the advanced options
I already did and none works
and in the black screen try entering into tty: ctrl+alt+f2
if f2 dont work try f1-f6 can you enter it?
I can do it, then what do I do?
I log in and then?
And what is tty useful for?
so are you using kde? or gnome?
I use xfce
so type in the tty this:
startx
so chroot again from live usb and we try reinstall graphics drivers, xorg and hopefully that will be enough…
I get an error while trying to reinstall the drivers
[manjaro /]# sudo mhwd -l
mhwd: error while loading shared libraries: /usr/lib/libhd.so.21: file too short
[manjaro /]# sudo mhwd -a
[manjaro /]# pacman -Syu xorg-server
core.db failed to download
error: failed retrieving file 'core.db' from mirror.moson.org : Could not resolve host: mirror.moson.org
warning: too many errors from mirror.moson.org, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.cyberhost.uk : Could not resolve host: mirror.cyberhost.uk
warning: too many errors from mirror.cyberhost.uk, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.ibakerserver.pt : Could not resolve host: mirror.ibakerserver.pt
warning: too many errors from mirror.ibakerserver.pt, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.mirrors.lavatech.top : Could not resolve host: manjaro.mirrors.lavatech.top
warning: too many errors from manjaro.mirrors.lavatech.top, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from www.mirrorservice.org : Could not resolve host: www.mirrorservice.org
warning: too many errors from www.mirrorservice.org, skipping for the remainder of this transaction
error: failed to synchronize all databases (invalid url for server)
post output from:
mhwd -l && mhwd -li
and did you connect to internet before you chrooted?
Yes I am connected
[manjaro /]# mhwd -l && mhwd -li
