Its done but manjaro grub is still freezing in asus screen
mhwd-kernel -li outputs now
Currently running: 5.15.16-1-MANJARO (linux515)
- linux510
- linux54
maybe youll need to reinstall grub also…
first try installing the 5.17 kernel:
mhwd-kernel -i linux517
update-grub
mkinitcpio -P
if there were no errors run:
exit
systemctl reboot
mhwd-kernel -i linux517 outputs the following
core 166.9 KiB 265 KiB/s 00:01 [#####################################################] 100%
extra 1895.7 KiB 2.72 MiB/s 00:01 [#####################################################] 100%
community 7.0 MiB 3.10 MiB/s 00:02 [#####################################################] 100%
multilib 177.5 KiB 1334 KiB/s 00:00 [#####################################################] 100%
error: no targets specified (use -h for help)
and if you try this:
pacman -Syyu linux517
Work but I cant still boot
what remains is reinstalling grub:
output from:
lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME
I get this
PATH PTTYPE PARTTYPE FSTYPE PARTTYPENAME
/dev/loop0
/dev/loop1
/dev/loop2
/dev/loop3
/dev/sda
/dev/sda1
/dev/sda2
/dev/sda3
/dev/sda4
/dev/sda5
/dev/sda6
/dev/sdb
/dev/sdb1
/dev/sdb2
/dev/nvme0n1
/dev/nvme0n1p1
/dev/nvme0n1p2
/dev/nvme0n1p3
/dev/nvme0n1p4
/dev/nvme0n1p5
/dev/nvme0n1p6
thats all?
and output from:
lsblk -f
parted -l
cat /etc/fstab
[manjaro /]# lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
loop1
loop2
loop3
sda
|-sda1 229M 11% /boot/efi
|-sda2
|-sda3
|-sda4
|-sda5 59.5G 64% /
`-sda6
sdb
|-sdb1
`-sdb2
nvme0n1
|-nvme0n1p1
|-nvme0n1p2
|-nvme0n1p3
|-nvme0n1p4
|-nvme0n1p5
`-nvme0n1p6
[manjaro /]# parted -l
Model: ATA ST1000LX015-1U71 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 274MB 273MB fat32 EFI system partition boot, esp
2 274MB 290MB 16.8MB Microsoft reserved partition msftres
3 290MB 785GB 785GB ntfs Basic data partition msftdata
4 785GB 790GB 4294MB ntfs Basic data partition msftdata
5 790GB 999GB 210GB ext4
6 999GB 1000GB 839MB ntfs Basic data partition hidden, diag
Model: SanDisk Cruzer Blade (scsi)
Disk /dev/sdb: 15.8GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 2839MB 2843MB 4194kB primary esp
Model: KINGSTON SNVS1000GB (nvme)
Disk /dev/nvme0n1: 1000GB
Disk Flags:
2 274MB 290MB 16.8MB MSR partition msftres
5 790GB 999GB 210GB ntfs Basic data partition msftdata
6 999GB 1000GB 839MB ntfs Basic data partition msftdata
[manjaro /]# cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=801E-E876 /boot/efi vfat umask=0077 0 2
UUID=173c4f10-a14c-4dd0-837e-09a7e22b786a / ext4 defaults,noatime 0 1
edit your post, click on this icon in the editor: </> and put the outputs inside of them…
run again this command:
lsblk -f
and then copy the formated output here…
loop0
loop1
loop2
loop3
sda
|-sda2
|-sda3
|-sda4
|-sda5 59.5G 64% /
`-sda6
sdb
|-sdb1
`-sdb2
nvme0n1
|-nvme0n1p1
|-nvme0n1p2
|-nvme0n1p3
|-nvme0n1p4
|-nvme0n1p5
`-nvme0n1p6
thats it?
yes it is all I get, what are you trying to do?
and also post output from this:
blkid
/dev/loop1: TYPE="squashfs"
/dev/nvme0n1p5: LABEL="Nuevo vol" BLOCK_SIZE="512" UUID="FC0613750613305E" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="5ff45ee7-18f1-4f00-a8d7-00fa7bca8013"
/dev/nvme0n1p3: LABEL="OS" BLOCK_SIZE="512" UUID="446820E56820D806" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="885e8720-e6dd-11eb-9477-efd28e652680"
/dev/nvme0n1p1: UUID="801E-E876" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="885e871b-e6dd-11eb-9477-efd28e652680"
/dev/nvme0n1p6: LABEL="RECOVERY" BLOCK_SIZE="512" UUID="66B2CF5FB2CF31FB" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="885e8730-e6dd-11eb-9477-efd28e652680"
/dev/nvme0n1p4: LABEL="SharedDisk" BLOCK_SIZE="512" UUID="3E0EA98C0EA93E31" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="885e8729-e6dd-11eb-9477-efd28e652680"
/dev/nvme0n1p2: PARTLABEL="MSR partition" PARTUUID="885e871c-e6dd-11eb-9477-efd28e652680"
/dev/sdb2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="EC32-C57A" BLOCK_SIZE="512" TYPE="vfat"
/dev/sdb1: BLOCK_SIZE="2048" UUID="2022-01-23-13-09-40-00" LABEL="MANJARO_XFCEM_2122" TYPE="iso9660"
/dev/loop2: TYPE="squashfs"
/dev/loop0: TYPE="squashfs"
/dev/sda4: LABEL="SharedDisk" BLOCK_SIZE="512" UUID="3E0EA98C0EA93E31" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="a65818ae-abbf-40b4-afc8-e1637efdb1b8"
/dev/sda2: PARTLABEL="Microsoft reserved partition" PARTUUID="72845421-4b9b-42a7-8d8c-8606e93fe7ed"
/dev/sda5: UUID="173c4f10-a14c-4dd0-837e-09a7e22b786a" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="26cfc501-a66e-1243-9fb8-ae105d31d173"
/dev/sda3: LABEL="OS" BLOCK_SIZE="512" UUID="3E70A3B870A37575" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="517ec845-cc0c-4f86-aefe-6e982bf75de9"
/dev/sda1: LABEL_FATBOOT="SYSTEM" LABEL="SYSTEM" UUID="801E-E876" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="f42ff209-4ebb-498e-84f8-64adb137ecff"
/dev/sda6: LABEL="RECOVERY" BLOCK_SIZE="512" UUID="66B2CF5FB2CF31FB" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="b57b65f0-b7c6-474b-86a2-f1c77db09d19"
/dev/loop3: TYPE="squashfs"
i dont know, you could try reinstall grub… so are you running efi, just to be sure?
I tried following this tutorial https://wiki.manjaro.org/index.php?title=GRUB/Restore_the_GRUB_Bootloader but I get this messages for the following commands.
[manjaro /]# pacman -Syu grub
core is up to date
extra is up to date
community 7.0 MiB 3.91 MiB/s 00:02 [#####################################################] 100%
multilib is up to date
warning: grub-2.06-6 is up to date -- reinstalling
resolving dependencies...
Packages (1) grub-2.06-6
Total Installed Size: 47.93 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [#####################################################] 100%
(1/1) checking package integrity [#####################################################] 100%
(1/1) loading package files [#####################################################] 100%
(1/1) checking for file conflicts [#####################################################] 100%
error: failed to commit transaction (conflicting files)
grub: /etc/grub.d/00_header exists in filesystem
... several lines of a file existing in filesystem ...
So tried doing
pacman -Syu --overwrite '*' grub
core is up to date
extra is up to date
community is up to date
warning: /boot/grub/grub.cfg installed as /boot/grub/grub.cfg.pacnew
warning: /etc/default/grub installed as /etc/default/grub.pacnew
:: Grub does no longer support side-loading modules when secure boot is
enabled. Thus booting will fail, unless you have an efi executable
'grubx64.efi' with bundled modules.
ldconfig: File /usr/lib/libhpipp.so.0 is empty, not checked.
... several lines saying x is empty or truncated, not checked ...
(1/2) Arming ConditionNeedsUpdate...
(2/2) Updating the info directory file...
and the some steps later I tried to chroot as told in the tutorial but i cant
[manjaro manjaro]# manjaro-chroot /mnt /bin/bash
mount: /mnt/proc: mount point does not exist.
I kept on creating the directories by sudo mkdir /mnt/proc for example but now i get
mount: /mnt/etc/resolv.conf: mount point does not exist.
chroot: failed to run command '/bin/bash': No such file or directory
[manjaro manjaro]# sudo mkdir /mnt/etc/resolv.conf
mkdir: cannot create directory ‘/mnt/etc/resolv.conf’: No such file or directory
look at this:
do you have enabled secure boot in bios? check that first
It is already disabled, normally I have a dual boot I dont know if that changes anything?
