Actually I have changed my method based on the post by @ bogdancovaciu
Disclaimer untested on UEFI/GPT /secure boot motherboard as I still use MBR etc
First I have 2 hard drives (ssd lucky me) one has linux and the other W10. I removed linux and W10 borked because grub was in the MBR of W10 drive. I refuse to use UEFI or GPT etc…anyhow I use W10 to repair mbr, let me know if you have the same issue.
Use root powers to edit /etc/grub.d/40_custom to create a chainloader entry for W10
Use root powers to edit /etc/default/grub so although my entries may differ from mine the intent is to ensure…grub menu is not hidden, grub does not remember last used entry, grub menu is highlighted on your main choice, and personal choice…grub font is huge enough for my eyesight
Then update-grub as below.
Try at own risk but you can always boot a linux usb/cd …change the files and use chroot to update-grub.
Example of a 2 drive system where W10 is on second drive for 40_custom
I am omitting the top of the file and showing the last line and new content with a prefix of / to avoid the hash symbol thinking I wanted large text
The effect of this menu is allow grub to swap to the MBR of the other drive, and as W10 has control of that drive, its bootloader stuff is there and will do its job
/# the ‘exec tail’ line above.
menuentry “W10” {
insmod ntfs
set root=(hd1)
chainloader +1
Example of 1 drive system where W10 is on a partition
Untested, is to chainload to a Partition Boot Record (PBR) where W10 is on a partition maybe same drive as your laptop?
Only line below changes from above (for /dev/sda4 as an example for target PBR)
set root=(hd0,4)
Extra Notes
grub header loads mbr,gpt, font, graphics, video modules
Some people think that as their current grub.cfg shows for /dev/sda1
set root=‘hd0,msdos1’ that forces them from above example to use
set root=‘hd0,mddos4’
but I disagree…keep it simple.
Example of lines to change for /etc/default/grub
GRUB_DEFAULT=0
(there is a hash here)/# GRUB_TIMEOUT_STYLE=hidden
GRUB_SAVEDEFAULT=false
GRUB_GFXMODE=800x600
GRUB_DISABLE_OS_PROBER=true
Notes
- grub counts from zero menu entries and hard drive
- grub counts from 1 …partitions (don’t blame me for this )
- If you rarely go into that other OS you ignore my advice on savedefault
- The smaller the resolution the easier to read the menu
- We need os-prober disabled as we have a better method (IMHO)
Execute
sudo update-grub
to change your grub.cfg
good luck
