After a reboot I noticed 6 multiples of Manjaro all showing on the same drive in addition to the Actual Manjaro (1st option).
They appear to be snapshots but are no longer showing in the snapshot submenu. In addition they also don’t have dates next to them.
I have tried rolling back several times which appeared to fix the problem temporarily but the issue reappears pretty quickly.
I have now rolled back to the 20th Dec but after an update the multiple grub entries are back again.
Is there any way to fix this? Or do I have to wipe my system?
So from hunting around the bug seems to be with a setting from grub-btrfs. That’s as far as I’ve got.
Is this in the GRUB boot menu??
Please show your terminal after
sudo update-grub
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found Windows Boot Manager on /dev/nvme0n1p3@/efi/Microsoft/boot/bootmgfw.efi
Found Manjaro Linux on /dev/nvme1n1p2
Detecting snapshots ...
No snapshots found.
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
Unmount /tmp/grub-btrfs.yfwOsyOZAp .. Success
/usr/bin/grub-probe: warning: unknown device type nvme1n1.
done
Its odd that it doesnt find any snapshots as I have 8. I searched grub-btrfs site for any clues. It says that timeshift saves its snapshots to /run/timeshift. On my system this folder is empty.
Tip:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Also, if your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Show
sudo timeshift --list
After try ro crate new snapshot
sudo timeshift --create
Show list again
And i your have snap. Try to
sudo update-grub
and chek your snapshot in grub.
but…
What happen in your nvme1n1p2 ?
Why so much manjaro boot record
Timeshift list
#Mounted '/dev/nvme1n1p2' at '/run/timeshift/87987/backup'
E: ERROR: can't list qgroups: quotas not enabled
E: btrfs returned an error: 256
E: Failed to query subvolume quota
Device : /dev/nvme1n1p2
UUID : b08c96c4-a567-41f6-a4d9-30637f36df0f
Path : /run/timeshift/87987/backup
Mode : BTRFS
Status : OK
9 snapshots, 1.6 TB free
Num Name Tags Description
0 > 2022-09-20_15-18-32 O
1 > 2022-12-20_17-00-01 W
2 > 2022-12-26_09-21-34 O Before restoring '2022-12-25 09:24:52'
3 > 2022-12-27_17-00-01 W
4 > 2022-12-27_18-55-51 O Before restoring '2022-12-27 09:12:43'
5 > 2022-12-27_23-45-34 O Before restoring '2022-12-20 17:00:01'
6 > 2022-12-27_23-54-50 O {timeshift-autosnap} {created before upgrade}
7 > 2022-12-28_00-19-49 O D M {timeshift-autosnap} {created before upgrade}
8 > 2022-12-28_09-22-46 O {timeshift-autosnap} {created before upgrade}
Creating new Timeshift
Using system disk as snapshot device for creating snapshots in BTRFS mode
Mounted '/dev/nvme1n1p2' at '/run/timeshift/88175/backup'
Creating new backup...(BTRFS)
Saving to device: /dev/nvme1n1p2, mounted at path: /run/timeshift/88175/backup
Created directory: /run/timeshift/88175/backup/timeshift-btrfs/snapshots/2022-12-28_10-04-34
Created subvolume snapshot: /run/timeshift/88175/backup/timeshift-btrfs/snapshots/2022-12-28_10-04-34/@
Created subvolume snapshot: /run/timeshift/88175/backup/timeshift-btrfs/snapshots/2022-12-28_10-04-34/@home
Created control file: /run/timeshift/88175/backup/timeshift-btrfs/snapshots/2022-12-28_10-04-34/info.json
BTRFS Snapshot saved successfully (0s)
Tagged snapshot '2022-12-28_10-04-34': ondemand
2nd Timeshift list
Mounted '/dev/nvme1n1p2' at '/run/timeshift/88387/backup'
Path : /run/timeshift/88387/backup
Mode : BTRFS
Status : OK
10 snapshots, 1.6 TB free
9 > 2022-12-28_10-04-34 O
I don’t know. That’s what I’m hoping to find out by posting here :).
I guess something went wrong.
Oh and I forgot here is output for update-grub
No snapshots found.
Unmount /tmp/grub-btrfs.rQ9lIvCL4f .. Success
done
Maby your try restore old snapshot?
sudo timeshift --restore
And choose 20 December snap or 09-20 ( and reinstall all software )
Im actually on the 20th December snapshot. When I saw this issue I rolled back severall times. Each time to an earlier snapshot. Initially the grub menu is fixed after an initial reboot. But quickly breaks again.
After what action GRUB to be a broken ?
The last major thing I did was move /home to a new drive. Everything was good. When I tried to update I got a complaint from timeshift saying something about subvolumes @ and @home etc.Becuase autosnap would let me update I decided to roll back the system to before I moved /home. Again everything seemed fine until I rebooted and noticed the multiple entries in grub.
This is normal.
The grub Boot menu always shows the installed kernels, until the older kernels are removed, and grub menu is updated.
Rolling back to a previous backup of your system won’t change that behaviour.
It wasn’t that behaviour I needed to fix. It was multiple instances of Manjaro on the boot menu, that where actually timeshift snapshots, but weren’t in the snapshot menu that was the issue.
Anyway I have fixed it. Apparently rolling back btrfs-progs to version 6.0.2-1 fixed it.
Timeshift snapshots are back in their snapshots menu and no multiple version of Manjaro anymore.
