I notice that with last iso (minimal plasma) there is a utility to restore Grub
well done manjaro team!
Where did I miss something? ![]()
is in Menu /System/Restore installed system settings
I have nowhere, have installed from 24.2 ISO. Otherwise I wouldn’t ask.
check the live iso
ok, thx
Package manjaro-rescue was added to live ISO profile over a year ago (2023-03-12)
Add manjaro-rescue in live-system (5abaa8d5) · Commits · Profiles & Settings / iso-profiles · GitLab
But System Recovery button in manjaro-hello was added 3 months ago (2024-03-04)
add recovery option (bd9e1f93) · Commits · Packages / Extra / manjaro-hello · GitLab
Sorry, my mistake. I do occasionally install from the ISO, but I never look at the menus there.
deed not notice before that, since I close manjaro-hello before installing…
last install I deed was with 24.0 and that button was not there as the menu option, same in 24.01
just checked now
one more question since I’ve not Manjaro-Hello installed, Will it work even on a running system?
Manjaro-rescue: helper for rescue your manjaro installation
need to be used only in live mode and enhanced the ability of manjaro-chroot
manjaro-rescue is not included in the *iso.pkgs files showing installed packages
need to be run in live mode, as I do for chroot, it make no sense to have it on a running system
since I’ve not installed a ISO with that Button in the last period i was thinking is not going to be installed, only available on the live
install-grub would be a better option for installed OS
